[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
Danke, versuche ich MOrgen gleich mal aus !!!
So, hatte nach meinem fehlgeschlagenen Biosupdate das Mainboard beim Händler eingeschickt, nachdem alle Versuche das alte Bios wiederherzustellen bzw. ein neues Bios zu flashen, fehlgeschlagen sind. Hab jetzt letzte Woche ein neues Mars als Vorabtausch auf Kulanz bekommen :bigok:. Bin jetzt nur am überlegen, ob ich das Mars oder mein neuen P45 behalte.
würde mir jetzt spontan nichts einfallen, nur das die p45 boards jetzt auch undervolten können so wie das mars schon immer konnte
ok und den vdroop bug hat das asus wie immer :)
Habe CR 1T mit nur einem Riegel bei 2,16V versucht. Nichts zu machen, obwohl meine DG9MH`s das eigentlich schaffen sollten. Ich vermute jetzt, dass es sich um ein Bug handelt. Es könnte aber auch ganz allgemein am P35 Chipsatz liegen.
Und, hat sich irgendwas verändert zu Vorgängerversionen?
Die einzige mir bekannte OC-funktionsfähige Aegis Panel-Version auf dem Mars war die 1.0.2.14. Jetzt sind wir bei 1.0.2.34 angelangt. Da sind schon einige Versionen dazwischen. Könnte mir vorstellen, dass OC + Windows damit jetzt stabiler geht. Ich werde es mal testen. :)
Das kann man wohl sagen. Die OC- Funktion funktioniert viel besser! :banana:
BIOS- Einstellung: 266x10 @1066Mhz Cl5
Version 1.0.2.34:
FSB 290x10 @1163Mhz. Höher wollte ich nicht, weil der RAM dort sein Limit hat. Runter ging es auch bis FSB 225x10. Ab 224x10 friert der Bildschirm ein.
Offenbar kann man sich innerhalb eines 66Mhz FSB- Straps bewegen.
Version 1.0.2.14
Schon nach Erhöhung von FSB 266x10 auf FSB 267x10 fror der Bildschirm ein!
macht hier jemand GTL Optimierung auf dem MARS ??
Bei DFI geht das, beim BlackOps auch. Aber wie soll das beim Mars gehen?
hi
hat hier jemand einen q9550 auf seinem mars laufen ??
Habe noch keinen in einer Signatur gesehen. Q9550 + E0 ist vielleicht noch zu neu. Läuft aber bestimmt prima.:)
Habe da mal eine Bitte: :hail:
Könnte mal jemand seine CPU runtertakten und die VCore (mit Werten kleiner als 0,9375V) untervolten? Bei mir liegt dann die maximale Spannung an. Wäre wichig für mich zu wissen, ob vielleicht nur mein Board fehlerhaft ist.
Weitere Infos auch auf folgenden Links:
http://www.forumdeluxx.de/forum/showthread.php?t=535834
http://www.xtremesystems.org/forums/showthread.php?t=202022
jein
bei höherem multi 450
bei kleinerem 470
werd aber nochmal genau testen, mir waren anfangs meine 24/7 settings wichtiger zu finden
...ich habe ein Riesen-Problem mit meinem Mars:
Gerade eingebaut, gestartet, ab ins BIOS, alles auf "optimized" sowie SATA-LW eingestellt und neugestartet. Unter Windows dann Updates + Treiber installiert und heruntergefahren.
Beim Neustart ins BIOS, einige Optimierungen gemacht, gespeichert und BIOS verlassen.
Jetzt kommt er nur noc bis zum "MARS"-Startbildschirm, und schlatet dann aus, dann wieder ein und wieder nur bis zum Bildschirm.
Der übliche "An-Aus-Bug" kannst ja eigentlich nicht sein, ich habe den rechner weder vom Strom getrennt noch sonstwas. Kein OC, nix. :(
Bin am verzweifeln, nach CMOS Reset (nur über den Jumper+ Batterie raus, alles andere hilft nicht) und nur den nötigsten Änderungen im BIOS ist es genau das gleiche, ich hab schon alles abgebaut um irgendwas auszuschließen, hilft nix... :(
Board tot oder woran liegt das...??? Help! :fresse:
lass mal länger die batterie raus, dazu nur ein ram rein stecken
atx stecker vom mb trennen
kaltgerätekabel vom nt trennen, sollte aber eh klar sein
...danke.
Läuft momentan, habs etwas ausführlicher gemacht. Im XS-Foxconn Forum leider nix direkt zum fehler gefunden, aber dann nochmal versucht, "ohne alles" zu starten. Also nachdem ich nochmal CMOS clear mit Batterie raus gemacht hab, alle HD's + Laufwerke ab, Soundkarte raus, alle USB-Geräte ab, etc.
Dann ins BIOS, "optimized defaults" geladen, juhuu, kommt ins BIOS, nächster Schritt, erstes Profil geladen, neustart, klappt wieder... :)
Den ATX-Stecker hatte ich ebenso kurz ab wie den P8 (ohne welchen der Screen schwarz bleibt...), was genau jetzt Heilung gebracht hat, keine Ahnung, aber ich hoffe ich bleibe davon verschont für die nächste Zeit... :)
Andere Frage: Wo liegt der Unterschied zwischen den einzelnen BIOS-Versionen, also G, P usw. Sind G immer die Betas, oder worin unterscheiden die sich...?#
...würde jetzt das G30 flashen, st das Windows-Tool zuverlässig...?
Mangels gesockeltem BIOS-Chip will ich da sicher sein... :fresse:
Also ich hab bisher 2x unter windows geflasht ging immer ohne Probs gibt hier iwoe 1-3seiten vorher eine kurze anleitung wie man flashen sollte, das man im notfall wenns einen das bios zerschossen hat noch flashen kann
...hehe, grad das komplette Programm durrch...
- Tools von der CD installiert, Updates heruntergeladen und installiert...
- als letztes G30 BIOS, das bleib bei 52% hängen... FUUUUUUUUUCKCKCKCKCK!!! :wall: :grrr: :hwluxx:
- gesucht, was das Netz hergibt, gleich mal Mail an Foxconn, etc. usw. pp.
- > auf Seite 23 hier im Thread die Info zum Blindflashen gelesen...oft genug gemacht, daher dachte ich, Versuch macht kluch... :d :fresse:
- Disk vorbereitet, angeschlossen, Rechner gestartet. Geht erstmal an, aus, wieder an, läuft weiter, LED am Floppy blinkt....fängt an zu rattern *supi, irgendwas scheint er zu machen...* ...rattert *sollte ich nicht irgendwann mal awdflash tippen* ...egal, lass ihn machen.... Plötzlich piept er in gleichmäßigen Abständen... *hmm, könnte bedeuten, Flash beendet*
- Rechner wieder zurück an seinen Platz, alles angeschlossen, gestartet... TADAAA! Er läuft wieder! Astrein, und das trotz gesockeltem BIOS...! :fresse: :banana:
...ich konnte noch nicht mal im Foxconn-XS-Forum in Erfahrung bringen, wo der Unterschied zwischen den P und G-Versionen ist (G sind scheinbar meist betas, aber das wird ja kaum der einzige unterschied sein, denn das letzte beta,G30, welches ich auch drauf hab, ist schon wieder einige Monate alt... :(
...welchen FSB erreicht ihr denn ohne Spannungserhöhung? Ich bin bis knapp unter 500 gekommen, Feintuning und Stabilitätstest stehen noch aus. bei 500 und 1,28V (also einen Klick hoch) lief es bei mir im alltagsbetrieb absolut stabil. also surfen, daddeln, Videos encoden und brennen.
Foxconn Support Service hatte mir zugesagt wegen des Undervolting Bugs an einem BIOS- Update zu arbeiten. Mit dem P16 ist dieses Problem jedoch noch nicht gefixt.
Leider gibt auch die Beschreibung "Update CPU Micro Code" beim P16" keine genaue Informationen über die Veränderungen / Neuerung.
Ähnliche Themen
