please,product authenticity check.
BoomBoop
Hello everyone ,
I bought Micron Ballistix 32GBx2 3200,
Thaiphoon recognizes it as D9XPF. When I disassemble the memory stick, it shows C9BLG. Is it fake? See the picture.
thank you all.
Thank you.
照片
Welcome to Hardwareluxx :wink:
That kit looks authentic to me. C9BLG are just a different speed bin of Micron 16Gbit B-Die (CT40A2G8VA-55M:B). Thaiphoon has no way to recognize the actual speed bin of the ICs used, if that is not programmed in the SPD. Instead it probably uses either the default SPD speed to generate that or some kind of predetermined default value. You would have to ask Vitaliy about that.
thank you very much
