Laptop-RAM erweiterbar oder nicht?
glupto
Hallo, weiß jemand, ob ich den RAM des Laptops einer Bekannten erweitern kann, hier die dxdiag-Daten:
Danke
glupto
System Information
Time of this report: 11/21/2013, 12:14:44
Machine name: VAIO-R600
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_qfe.130704-0421)
Language: German (Regional Setting: German)
System Manufacturer: Sony Corporation
System Model: PCG-R600HMPD(DE)
BIOS: PhoenixBIOS 4.0 Release 6.0.
Processor: Mobile Intel(R) Pentium(R) III CPU - M 1200MHz
Memory: 510MB RAM
Page File: 531MB used, 460MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) 82830M Graphics Controller-0
Manufacturer: Intel Corporation
Chip type: Intel(R) 82830M Chip
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_3577&SUBSYS_8100104D&REV_04
Display Memory: 48.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Sony Notebook LCD
Monitor Max Res: 1024,768
Driver Name: ialmdnt5.dll
Driver Version: 6.13.0001.3024 (English)
DDI Version: 8
Driver Attributes: Final Retail
Driver Date/Size: 2/16/2002 08:06:44, 62014 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: Nicht zutreffend
Mini VDD: ialmnt5.sys
Mini VDD Date: 2/16/2002 08:06:56, 238109 bytes
Device Identifier: {D7B78E66-7637-11CF-2D78-01A1A6C2CB35}
Vendor ID: 0x8086
Device ID: 0x3577
SubSys ID: 0x8100104D
Revision ID: 0x0004
Revision ID: 0x0004
Video Accel: ModeMPEG2_B ModeMPEG2_A ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: YAMAHA AC-XG WDM Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_8086&DEV_2485&SUBSYS_8100104D&REV_02
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: yacxgc.sys
Driver Version: 6.13.0010.3152 (English)
WHQL Logo'd: Yes
Date and Size: 7/19/2002 21:25:58, 202880 bytes
Other Files:
Driver Provider: YAMAHA CORPORATION
HW Accel Level: Full
Cap Flags: 0xB5B
Min/Max Sample Rate: 48000, 48000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xCC0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
YAMAHA AC-XG WDM Audio, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI-Mapper [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Maus
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Tastatur
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB-Root-Hub
| Vendor/Product ID: 0x8086, 0x2487
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/13/2008 19:45:37, 59520 bytes
| Driver: usbd.sys, 8/9/2013 01:55:06, 5376 bytes
Gameport Devices
PS/2 Devices
+ Standardtastatur (101/102 Tasten) oder Microsoft Natural Keyboard (PS/2)
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 4/14/2008 02:55:34, 52992 bytes
| Driver: kbdclass.sys, 4/14/2008 02:58:36, 25216 bytes
+ Terminalserver-Tastaturtreiber
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/14/2008 03:23:26, 40840 bytes
+ Alps Pointing-device
| Matching Device ID: *sny9001
| Upper Filters: ApfiltrService
| Service: i8042prt
| Driver: mouclass.sys, 4/14/2008 02:49:36, 23552 bytes
| Driver: Apfiltr.sys, 7/10/2002 01:23:18, 78225 bytes
| Driver: Vxdif.dll, 6/11/2002 06:27:40, 69150 bytes
| Driver: Apoint.exe, 2/28/2002 19:27:24, 114688 bytes
| Driver: ApntEx.exe, 7/13/2001 18:44:24, 32768 bytes
| Driver: Ezcapt.exe, 10/28/2001 01:55:46, 143360 bytes
| Driver: Apvfb.exe, 9/8/2000 19:34:38, 167936 bytes
| Driver: Apoint.dll, 3/8/2002 21:08:02, 114688 bytes
| Driver: ApRes.dll, 7/4/2002 23:17:40, 1339392 bytes
| Driver: EzLaunch.dll, 10/28/2001 01:58:48, 192512 bytes
| Driver: Elprop.dll, 8/24/1998 15:37:08, 91136 bytes
| Driver: EzAuto.dll, 7/11/2002 06:04:20, 65536 bytes
| Driver: ApWheel.dll, 1/14/1999 02:41:24, 6144 bytes
| Driver: ApointJP.pop, 4/21/1999 03:12:14, 32621 bytes
| Driver: ApointUS.pop, 7/4/2002 23:45:18, 35121 bytes
| Driver: ApointGR.pop, 11/17/2000 23:57:22, 37748 bytes
| Driver: ApointFR.pop, 7/4/2002 23:12:10, 38394 bytes
| Driver: ApointIT.pop, 11/18/2000 00:03:30, 36622 bytes
| Driver: ApointSP.pop, 10/17/2000 01:16:36, 37179 bytes
| Driver: ApointKR.pop, 10/17/2000 01:14:40, 33386 bytes
| Driver: ApointCS.pop, 8/11/2001 23:45:56, 31450 bytes
| Driver: ApointCT.pop, 10/28/2001 23:49:06, 31089 bytes
| Driver: Uninstap.exe, 7/9/2002 21:53:18, 167936 bytes
+ Terminalserver-Maustreiber
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: Conexant-Ambit SoftK56 Data,Fax ICH Modem
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM3
DirectPlay8 IPX Service Provider: IPX Adapter 1 - (00000000,00D059BDC50A)
DirectPlay8 IPX Service Provider: IPX Adapter 2 - (00000000,0800466B149D)
DirectPlay8 TCP/IP Service Provider: LAN-Verbindung - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1,4 KBit/s
Voxware SC06 6,4 KBit/s
Voxware SC03 3,2 KBit/s
MS-PCM 64 KBit/s
MS-ADPCM 32,8 KBit/s
Microsoft GSM 6.10 13 KBit/s
TrueSpeech(TM) 8,6 KBit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 7.0 GB
Total Space: 19.1 GB
File System: NTFS
Model: IC25N040ATCS04-0
Drive: D:
Free Space: 18.4 GB
Total Space: 19.0 GB
File System: NTFS
Drive: F:
Model: Sony i.LINK CD-RW DVD-ROM Drive IEEE 1394 SBP2 Device
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (German), 4/13/2008 19:40:46, 62976 bytes
System Devices
Name: Intel(R) 82830M Graphics Controller-0
Device ID: PCI\VEN_8086&DEV_3577&SUBSYS_8100104D&REV_04\3&61AAA01&0&10
Driver: C:\WINDOWS\system32\DRIVERS\ialmnt5.sys, 6.13.0001.3024 (English), 2/16/2002 08:06:56, 238109 bytes
Driver: C:\WINDOWS\system32\ialmdnt5.dll, 6.13.0001.3024 (English), 2/16/2002 08:06:44, 62014 bytes
Driver: C:\WINDOWS\system32\ialmdev5.dll, 6.13.0001.3024 (English), 2/16/2002 08:06:34, 91549 bytes
Driver: C:\WINDOWS\system32\ialmdd5.dll, 6.13.0001.3024 (English), 2/16/2002 08:06:06, 278596 bytes
Driver: C:\WINDOWS\system32\hccutils.dll, 3.00.0000.1438 (English), 1/30/2002 15:23:28, 114688 bytes
Driver: C:\WINDOWS\system32\igfxsrvc.dll, 3.00.0000.1438 (English), 1/30/2002 15:24:48, 286720 bytes
Driver: C:\WINDOWS\system32\igfxpph.dll, 3.00.0000.1438 (English), 1/30/2002 15:32:32, 200704 bytes
Driver: C:\WINDOWS\system32\igfxeud.dll, 3.00.0000.1438 (English), 1/30/2002 15:31:38, 221184 bytes
Driver: C:\WINDOWS\system32\igfxcpl.cpl, 3.00.0000.1438 (English), 1/30/2002 15:29:10, 94208 bytes
Driver: C:\WINDOWS\system32\igfxcfg.exe, 3.00.0000.1438 (English), 1/30/2002 15:28:50, 454656 bytes
Driver: C:\WINDOWS\system32\igfxdiag.exe, 3.00.0000.1438 (English), 1/30/2002 15:30:10, 151552 bytes
Driver: C:\WINDOWS\system32\igfxdgps.dll, 1/30/2002 15:30:14, 28672 bytes
Driver: C:\WINDOWS\system32\igfxdev.dll, 3.00.0000.1438 (English), 1/30/2002 15:23:12, 135168 bytes
Driver: C:\WINDOWS\system32\igfxdo.dll, 3.00.0000.1438 (English), 1/30/2002 15:22:44, 86016 bytes
Driver: C:\WINDOWS\system32\igfxrenu.lrc, 3.00.0000.1438 (English), 1/30/2002 15:23:36, 147456 bytes
Driver: C:\WINDOWS\system32\igfxhenu.lhp, 1/30/2002 15:33:26, 50710 bytes
Driver: C:\WINDOWS\system32\igfxtray.exe, 3.00.0000.1438 (English), 1/30/2002 15:33:14, 151552 bytes
Driver: C:\WINDOWS\system32\igfxhk.dll, 3.00.0000.1438 (English), 1/30/2002 15:25:02, 102400 bytes
Driver: C:\WINDOWS\system32\hkcmd.exe, 3.00.0000.1438 (English), 1/30/2002 15:25:20, 106496 bytes
Driver: C:\WINDOWS\system32\igfxress.dll, 3.00.0000.1438 (English), 1/30/2002 15:23:44, 503808 bytes
Driver: C:\WINDOWS\system32\igfxhchs.lhp, 1/30/2002 15:33:30, 51065 bytes
Driver: C:\WINDOWS\system32\igfxhcht.lhp, 1/30/2002 15:33:34, 51207 bytes
Driver: C:\WINDOWS\system32\igfxhdan.lhp, 1/30/2002 15:33:40, 52269 bytes
Driver: C:\WINDOWS\system32\igfxhdeu.lhp, 1/30/2002 15:33:44, 52835 bytes
Driver: C:\WINDOWS\system32\igfxheng.lhp, 1/30/2002 15:33:48, 50710 bytes
Driver: C:\WINDOWS\system32\igfxhesp.lhp, 1/30/2002 15:33:52, 51786 bytes
Driver: C:\WINDOWS\system32\igfxhfin.lhp, 1/30/2002 15:33:54, 52612 bytes
Driver: C:\WINDOWS\system32\igfxhfra.lhp, 1/30/2002 15:33:56, 51823 bytes
Driver: C:\WINDOWS\system32\igfxhfrc.lhp, 1/30/2002 15:33:58, 51814 bytes
Driver: C:\WINDOWS\system32\igfxhita.lhp, 1/30/2002 15:34:06, 51795 bytes
Driver: C:\WINDOWS\system32\igfxhjpn.lhp, 1/30/2002 15:34:08, 54839 bytes
Driver: C:\WINDOWS\system32\igfxhkor.lhp, 1/30/2002 15:34:12, 52866 bytes
Driver: C:\WINDOWS\system32\igfxhnld.lhp, 1/30/2002 15:34:14, 52593 bytes
Driver: C:\WINDOWS\system32\igfxhnor.lhp, 1/30/2002 15:34:16, 52386 bytes
Driver: C:\WINDOWS\system32\igfxhplk.lhp, 1/30/2002 15:34:18, 52841 bytes
Driver: C:\WINDOWS\system32\igfxhptb.lhp, 1/30/2002 15:34:20, 51671 bytes
Driver: C:\WINDOWS\system32\igfxhptg.lhp, 1/30/2002 15:34:24, 52321 bytes
Driver: C:\WINDOWS\system32\igfxhrus.lhp, 1/30/2002 15:34:26, 53285 bytes
Driver: C:\WINDOWS\system32\igfxhsve.lhp, 1/30/2002 15:34:28, 52135 bytes
Driver: C:\WINDOWS\system32\igfxhtha.lhp, 1/30/2002 15:34:30, 55087 bytes
Driver: C:\WINDOWS\system32\igfxhcsy.lhp, 1/30/2002 15:33:38, 52697 bytes
Driver: C:\WINDOWS\system32\igfxhell.lhp, 1/30/2002 15:33:46, 54147 bytes
Driver: C:\WINDOWS\system32\igfxhhun.lhp, 1/30/2002 15:34:04, 53375 bytes
Driver: C:\WINDOWS\system32\igfxhtrk.lhp, 1/30/2002 15:34:32, 53135 bytes
Driver: C:\WINDOWS\system32\igfxrchs.lrc, 3.00.0000.1438 (English), 1/30/2002 15:33:30, 147456 bytes
Driver: C:\WINDOWS\system32\igfxrcht.lrc, 3.00.0000.1438 (English), 1/30/2002 15:33:32, 147456 bytes
Driver: C:\WINDOWS\system32\igfxrdan.lrc, 3.00.0000.1438 (English), 1/30/2002 15:33:40, 151552 bytes
Driver: C:\WINDOWS\system32\igfxrdeu.lrc, 3.00.0000.1438 (English), 1/30/2002 15:33:42, 151552 bytes
Driver: C:\WINDOWS\system32\igfxreng.lrc, 3.00.0000.1438 (English), 1/30/2002 15:33:48, 147456 bytes
Driver: C:\WINDOWS\system32\igfxresp.lrc, 3.00.0000.1438 (English), 1/30/2002 15:33:50, 155648 bytes
Driver: C:\WINDOWS\system32\igfxrfin.lrc, 3.00.0000.1438 (English), 1/30/2002 15:33:54, 151552 bytes
Driver: C:\WINDOWS\system32\igfxrfra.lrc, 3.00.0000.1438 (English), 1/30/2002 15:33:56, 155648 bytes
Driver: C:\WINDOWS\system32\igfxrfrc.lrc, 3.00.0000.1438 (English), 1/30/2002 15:33:58, 155648 bytes
Driver: C:\WINDOWS\system32\igfxrita.lrc, 3.00.0000.1438 (English), 1/30/2002 15:34:06, 155648 bytes
Driver: C:\WINDOWS\system32\igfxrjpn.lrc, 3.00.0000.1438 (English), 1/30/2002 15:34:08, 147456 bytes
Driver: C:\WINDOWS\system32\igfxrkor.lrc, 3.00.0000.1438 (English), 1/30/2002 15:34:10, 147456 bytes
Driver: C:\WINDOWS\system32\igfxrnld.lrc, 3.00.0000.1438 (English), 1/30/2002 15:34:12, 151552 bytes
Driver: C:\WINDOWS\system32\igfxrnor.lrc, 3.00.0000.1438 (English), 1/30/2002 15:34:16, 151552 bytes
Driver: C:\WINDOWS\system32\igfxrplk.lrc, 3.00.0000.1438 (English), 1/30/2002 15:34:18, 151552 bytes
Driver: C:\WINDOWS\system32\igfxrptb.lrc, 3.00.0000.1438 (English), 1/30/2002 15:34:20, 151552 bytes
Driver: C:\WINDOWS\system32\igfxrptg.lrc, 3.00.0000.1438 (English), 1/30/2002 15:34:22, 155648 bytes
Driver: C:\WINDOWS\system32\igfxrrus.lrc, 3.00.0000.1438 (English), 1/30/2002 15:34:24, 151552 bytes
Driver: C:\WINDOWS\system32\igfxrsve.lrc, 3.00.0000.1438 (English), 1/30/2002 15:34:28, 151552 bytes
Driver: C:\WINDOWS\system32\igfxrtha.lrc, 3.00.0000.1438 (English), 1/30/2002 15:34:30, 151552 bytes
Driver: C:\WINDOWS\system32\igfxrcsy.lrc, 3.00.0000.1438 (English), 1/30/2002 15:33:36, 151552 bytes
Driver: C:\WINDOWS\system32\igfxrell.lrc, 3.00.0000.1438 (English), 1/30/2002 15:33:46, 159744 bytes
Driver: C:\WINDOWS\system32\igfxrhun.lrc, 3.00.0000.1438 (English), 1/30/2002 15:34:02, 155648 bytes
Driver: C:\WINDOWS\system32\igfxrtrk.lrc, 3.00.0000.1438 (English), 1/30/2002 15:34:32, 151552 bytes
Driver: C:\WINDOWS\system32\drivers\wa301a.sys, 4.13.0001.3024 (English), 2/16/2002 08:07:00, 26681 bytes
Driver: C:\WINDOWS\system32\drivers\wa301b.sys, 4.13.0001.3024 (English), 2/16/2002 08:07:00, 26681 bytes
Driver: C:\WINDOWS\system32\drivers\a302.sys, 4.13.0001.3024 (English), 2/16/2002 08:07:04, 10297 bytes
Driver: C:\WINDOWS\system32\drivers\a303.sys, 4.13.0001.3024 (English), 2/16/2002 08:07:12, 26169 bytes
Driver: C:\WINDOWS\system32\drivers\a304.sys, 4.13.0001.3024 (English), 2/16/2002 08:07:18, 25657 bytes
Driver: C:\WINDOWS\system32\drivers\a305.sys, 4.13.0001.3024 (English), 2/16/2002 08:07:22, 11321 bytes
Driver: C:\WINDOWS\system32\drivers\a306.sys, 4.13.0001.3024 (English), 2/16/2002 08:07:26, 13881 bytes
Driver: C:\WINDOWS\system32\drivers\a307.sys, 4.13.0001.3024 (English), 2/16/2002 08:07:34, 20025 bytes
Driver: C:\WINDOWS\system32\drivers\a308.sys, 4.13.0001.3024 (English), 2/16/2002 08:07:42, 10297 bytes
Driver: C:\WINDOWS\system32\drivers\a309.sys, 4.13.0001.3024 (English), 2/16/2002 08:07:38, 23609 bytes
Driver: C:\WINDOWS\system32\drivers\wa310a.sys, 4.13.0001.3024 (English), 2/16/2002 08:07:46, 27705 bytes
Driver: C:\WINDOWS\system32\drivers\wa310b.sys, 4.13.0001.3024 (English), 2/16/2002 08:07:46, 27705 bytes
Driver: C:\WINDOWS\system32\drivers\vch.sys, 4.13.0001.3024 (English), 2/16/2002 08:07:08, 18487 bytes
Driver: C:\WINDOWS\system32\ialmrem.dll, 6.13.0001.3024 (English), 2/16/2002 08:07:30, 49152 bytes
Driver: C:\WINDOWS\system32\shpshftr.dll, 2/16/2002 07:37:04, 249856 bytes
Driver: C:\WINDOWS\system32\ialmgicd.dll, 6.13.0001.3024 (English), 2/16/2002 07:49:52, 1785856 bytes
Driver: C:\WINDOWS\system32\ialmgdev.dll, 6.13.0001.3024 (English), 2/16/2002 07:50:48, 147456 bytes
Driver: C:\WINDOWS\system32\iAlmCoIn_0_v2.dll, 1.00.1000.0002 (English), 2/16/2002 08:07:16, 49152 bytes
Name: Intel(R) 82830M Graphics Controller-1
Device ID: PCI\VEN_8086&DEV_3577&SUBSYS_8100104D&REV_00\3&61AAA01&0&11
Driver: C:\WINDOWS\system32\iAlmCoIn_1_v2.dll, 1.00.1000.0002 (English), 2/16/2002 08:07:16, 49152 bytes
Name: Intel(R) 82830 Prozessor-zu-E/A-Controller - 3575
Device ID: PCI\VEN_8086&DEV_3575&SUBSYS_00000000&REV_04\3&61AAA01&0&00
Driver: n/a
Name: Intel(R) 82801CAM LPC-Schnittstellencontroller - 248C
Device ID: PCI\VEN_8086&DEV_248C&SUBSYS_00000000&REV_02\3&61AAA01&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (German), 4/14/2008 02:58:03, 37632 bytes
Name: Intel(r) 82801CAM Ultra ATA Storage-Controller-248A
Device ID: PCI\VEN_8086&DEV_248A&SUBSYS_8100104D&REV_02\3&61AAA01&0&F9
Driver: n/a
Name: Standard PCI-zu-USB universeller Hostcontroller
Device ID: PCI\VEN_8086&DEV_2487&SUBSYS_8100104D&REV_02\3&61AAA01&0&EA
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.5512 (English), 4/13/2008 19:45:35, 20608 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.6437 (English), 8/9/2013 01:55:08, 144128 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (German), 4/14/2008 03:22:31, 77312 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/13/2008 19:45:37, 59520 bytes
Name: Conexant-Ambit SoftK56 Data,Fax ICH Modem
Device ID: PCI\VEN_8086&DEV_2486&SUBSYS_8100104D&REV_02\3&61AAA01&0&FE
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\HSF_CNXT.sys, 5.00.0001.0001 (English), 8/14/2002 19:02:32, 584816 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\Ich.sys, 2.00.0001.0001 (English), 8/14/2002 19:02:32, 67068 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\faxnt.sys, 2.00.0001.0001 (English), 8/14/2002 19:02:32, 217019 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\fsksnt.sys, 2.00.0001.0001 (English), 8/14/2002 19:02:32, 127373 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\fallback.sys, 2.00.0001.0001 (English), 8/14/2002 19:02:32, 310739 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\v124nt.sys, 2.00.0001.0001 (English), 8/14/2002 19:02:33, 534669 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\k56nt.sys, 2.00.0001.0001 (English), 8/14/2002 19:02:33, 427199 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\tonesnt.sys, 2.00.0001.0001 (English), 8/14/2002 19:02:33, 56639 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\mdmxsdk.sys, 1.00.0000.0000 (English), 8/14/2002 19:02:33, 17744 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\amosnt.sys, 2.00.0001.0001 (English), 8/14/2002 19:02:32, 168205 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\rksample.sys, 2.00.0001.0001 (English), 8/14/2002 19:02:33, 68486 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\soar.sys, 2.00.0001.0001 (English), 8/14/2002 19:02:33, 48750 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\CNXCsr.cty, 2/26/2002 19:06:10, 98628 bytes
Driver: C:\WINDOWS\system32\mdmxsdk.dll, 1.00.0000.0000 (English), 8/14/2002 19:02:33, 57344 bytes
Driver: C:\Program Files\CONEXANT\CNXT_MODEM_PCI_VEN_8086&DEV_2486&SUBSYS_8100104D\uninst.exe, 10.12.0000.0000 (English), 8/14/2002 19:02:33, 266240 bytes
Driver: C:\WINDOWS\system32\hsfinst.dll, 5.00.0001.0001 (English), 8/14/2002 19:02:32, 11562 bytes
Name: YAMAHA AC-XG Audio Device
Device ID: PCI\VEN_8086&DEV_2485&SUBSYS_8100104D&REV_02\3&61AAA01&0&FD
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.5512 (German), 4/14/2008 03:22:13, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.5512 (German), 4/14/2008 03:23:07, 129536 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.5512 (German), 4/13/2008 20:16:36, 141056 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.5512 (English), 4/13/2008 19:45:14, 60160 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.5512 (English), 4/13/2008 20:19:41, 146048 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.5512 (German), 4/13/2008 19:45:15, 49408 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.5512 (English), 4/14/2008 03:23:08, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\yacxgc.sys, 6.13.0010.3152 (English), 7/19/2002 21:25:58, 202880 bytes
Driver: C:\WINDOWS\system32\yacxgc.cpl, 6.13.0010.3152 (English), 7/19/2002 21:30:10, 249856 bytes
Driver: C:\WINDOWS\system32\yacxgeng.hlp, 7/18/2000 19:11:12, 19065 bytes
Driver: C:\WINDOWS\system32\yacxgfre.hlp, 7/21/2000 01:41:30, 21405 bytes
Driver: C:\WINDOWS\system32\yacxgger.hlp, 7/21/2000 01:41:36, 20422 bytes
Driver: C:\WINDOWS\system32\yacxgita.hlp, 7/21/2000 01:41:42, 20736 bytes
Driver: C:\WINDOWS\system32\yacxgjpn.hlp, 7/20/2000 02:28:36, 18642 bytes
Driver: C:\WINDOWS\system32\yacxgkor.hlp, 7/21/2000 01:46:26, 29529 bytes
Driver: C:\WINDOWS\system32\yacxgpor.hlp, 7/21/2000 01:46:34, 20722 bytes
Driver: C:\WINDOWS\system32\yacxgsch.hlp, 7/21/2000 00:27:22, 16517 bytes
Driver: C:\WINDOWS\system32\yacxgspa.hlp, 7/21/2000 02:14:48, 20714 bytes
Driver: C:\WINDOWS\system32\yacxgswe.hlp, 7/21/2000 01:46:44, 20310 bytes
Driver: C:\WINDOWS\system32\yacxgtch.hlp, 7/20/2000 23:32:52, 16403 bytes
Driver: C:\WINDOWS\system32\yacxgdut.hlp, 10/24/2000 05:27:54, 16265 bytes
Driver: C:\WINDOWS\system32\yacxgnor.hlp, 10/24/2000 05:31:26, 15768 bytes
Driver: C:\WINDOWS\system32\yac3ren.ax, 5.12.0001.2012 (English), 11/22/2000 21:24:42, 65536 bytes
Device ID: PCI\VEN_8086&DEV_2484&SUBSYS_8100104D&REV_02\3&61AAA01&0&E9
Name: Intel(R) 82801CA/CAM SMBus-Controller - 2483
Device ID: PCI\VEN_8086&DEV_2483&SUBSYS_8100104D&REV_02\3&61AAA01&0&FB
Driver: n/a
Device ID: PCI\VEN_8086&DEV_2482&SUBSYS_8100104D&REV_02\3&61AAA01&0&E8
Name: Intel(R) 82801BAM/CAM PCI-Brücke - 2448
Device ID: PCI\VEN_8086&DEV_2448&SUBSYS_00000000&REV_42\3&61AAA01&0&F0
Driver: n/a
Name: Intel(R) PRO/100 VE Network Connection
Device ID: PCI\VEN_8086&DEV_1031&SUBSYS_8100104D&REV_42\4&139E449D&0&40F0
Driver: n/a
Name: LAN-Express IEEE 802.11 PCI Adapter
Device ID: PCI\VEN_1260&DEV_3873&SUBSYS_02011468&REV_01\4&139E449D&0&58F0
Driver: n/a
Name: Ricoh R/RL/RT/RC/5C475(II), R5C520 oder kompatibler CardBus-Controller
Device ID: PCI\VEN_1180&DEV_0475&SUBSYS_8100104D&REV_80\4&139E449D&0&28F0
Driver: C:\WINDOWS\system32\DRIVERS\pcmcia.sys, 5.01.2600.5512 (German), 4/14/2008 03:02:16, 120576 bytes
Name: Texas Instruments OHCI-konformer IEEE 1394-Hostcontroller
Device ID: PCI\VEN_104C&DEV_8023&SUBSYS_8100104D&REV_00\4&139E449D&0&10F0
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.5512 (English), 4/13/2008 19:46:18, 61696 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.5512 (English), 4/13/2008 19:46:18, 53376 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.5512 (English), 4/13/2008 19:51:25, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.5512 (English), 4/13/2008 19:51:25, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 13:46:40, 6400 bytes
DirectX Components
ddraw.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:08 279552 bytes
ddrawex.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:08 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/18/2001 11:00:00 10496 bytes
d3d8.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:08 1179648 bytes
d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:08 8192 bytes
d3d9.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:08 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/18/2001 11:00:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:08 824320 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/18/2001 11:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/18/2001 11:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/18/2001 11:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/18/2001 11:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 German Final Retail 8/18/2001 11:00:00 33040 bytes
dplayx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 229888 bytes
dpmodemx.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 24064 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/18/2001 11:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 57856 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:43 29696 bytes
dpnsvr.exe: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:43 17920 bytes
dpnet.dll: 5.03.2600.6311 English Final Retail 11/2/2012 03:02:36 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:20:27 3072 bytes
dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:20:27 3072 bytes
dpvoice.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 214016 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:43 83456 bytes
dpvvox.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 116736 bytes
dpvacm.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 60928 bytes
dpserial.dll: 5.00.2134.0001 German Final Retail 8/18/2001 11:00:00 54032 bytes
dinput.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 163328 bytes
dinput8.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 186368 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/18/2001 11:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 German Final Retail 8/18/2001 11:00:00 395264 bytes
joy.cpl: 5.03.2600.5512 German Final Retail 4/14/2008 03:23:07 69632 bytes
gcdef.dll: 5.01.2600.0000 German Final Retail 8/18/2001 11:00:00 78336 bytes
pid.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:23 35328 bytes
dsound.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 1293824 bytes
dswave.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 19456 bytes
dsdmo.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 74240 bytes
dmusic.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 104448 bytes
dmband.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 61440 bytes
dmime.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 35840 bytes
dmstyle.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 105984 bytes
dmsynth.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:09 82432 bytes
dx7vb.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 619008 bytes
dx8vb.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 1227264 bytes
dxdiagn.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:09 2113536 bytes
mfc40.dll: 4.01.0000.6151 English Beta Retail 9/18/2010 07:52:56 954368 bytes
mfc42.dll: 6.02.8081.0000 English Final Retail 2/8/2011 14:33:28 978944 bytes
wsock32.dll: 5.01.2600.5512 German Final Retail 4/14/2008 03:22:32 24576 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 4/14/2008 03:22:07 70656 bytes
devenum.dll: 6.05.2600.5512 German Final Retail 4/14/2008 03:22:08 59904 bytes
dxmasf.dll: 6.04.0009.1133 German Final Retail 4/14/2008 03:22:09 500278 bytes
mciqtz32.dll: 6.05.2600.5512 German Final Retail 4/14/2008 03:22:14 35328 bytes
mpg2splt.ax: 6.05.2600.6333 English Final Retail 1/2/2013 07:49:00 148992 bytes
msdmo.dll: 6.05.2600.5512 English Final Retail 4/14/2008 03:22:16 14336 bytes
encapi.dll: 5.03.2600.5512 English Final Retail 4/14/2008 03:22:10 20480 bytes
qasf.dll: 9.00.0000.4503 German Final Retail 4/14/2008 03:22:23 237568 bytes
qcap.dll: 6.05.2600.5512 German Final Retail 4/14/2008 03:22:23 192512 bytes
qdv.dll: 6.05.2600.5512 German Final Retail 4/14/2008 03:22:23 279040 bytes
qdvd.dll: 6.05.2600.6169 German Final Retail 11/3/2011 16:28:30 387072 bytes
qedit.dll: 6.05.2600.6404 German Final Retail 6/4/2013 08:22:49 563712 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 4/13/2008 18:21:32 733696 bytes
quartz.dll: 6.05.2600.6333 German Final Retail 1/2/2013 07:49:00 1297920 bytes
strmdll.dll: 4.01.0000.3938 German Final Retail 8/26/2009 09:00:21 247326 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 4/14/2008 03:23:07 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 4/14/2008 03:23:07 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/14/2008 03:22:12 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/14/2008 03:22:12 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/14/2008 03:22:12 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/14/2008 03:22:12 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/14/2008 03:22:12 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/14/2008 03:23:07 154624 bytes
mswebdvd.dll: 6.05.2600.5857 German Final Retail 8/5/2009 09:59:36 206336 bytes
ks.sys: 5.03.2600.5512 German Final Retail 4/13/2008 20:16:36 141056 bytes
ksproxy.ax: 5.03.2600.5512 German Final Retail 4/14/2008 03:23:07 129536 bytes
ksuser.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:13 4096 bytes
stream.sys: 5.03.2600.5512 German Final Retail 4/13/2008 19:45:15 49408 bytes
mspclock.sys: 5.03.2600.5512 German Final Retail 4/13/2008 19:39:50 5376 bytes
mspqm.sys: 5.01.2600.5512 German Final Retail 4/13/2008 19:39:51 4992 bytes
mskssrv.sys: 5.03.2600.5512 German Final Retail 4/13/2008 19:39:52 7552 bytes
swenum.sys: 5.03.2600.5512 German Final Retail 4/13/2008 19:39:53 4352 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/14/2008 03:23:07 118272 bytes
msvidctl.dll: 6.05.2600.5512 German Final Retail 4/14/2008 03:22:18 1433088 bytes
vbisurf.ax: 5.03.2600.5512 English Final Retail 4/14/2008 03:23:07 30208 bytes
msyuv.dll: 5.03.2600.5908 English Final Retail 11/27/2009 18:11:57 17920 bytes
wstdecod.dll: 5.03.2600.5512 German Final Retail 4/14/2008 03:22:32 51200 bytes
DirectShow Filters
DirectShow Filters:
InterVideo G726Dec DMO,0x00600800,1,1,,
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
SONY DV Video Decoder,0x00400000,1,1,sdvvd.ax,1.82.5170.0000
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
InterVideo Audio Processor Fx,0x00400000,1,1,Auprocfx.ax,
InterVideo Video Decoder,0x00700000,2,4,IVIVIDEO.ax,6.00.0006.0042
Effect Filter - Sphere,0x00200000,1,1,Sphere.ax,2.00.0000.11170
Flip,0x00200000,1,1,LeftRight.ax,2.03.0000.10180
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.6333
Sony MPEG Audio Decoder TN,0x00000000,1,1,SMADTN.ax,3.00.0528.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,1.00.0004.0042
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.6333
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.4503
Effect Filter - Spotlight,0x00200000,1,1,Spotlight.ax,2.01.0000.2100
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.6333
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.6333
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
RealVideo Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0001.0001
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.6333
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,
Movie Effector Emboss,0x00200000,1,1,Emboss.ax,2.01.0000.2120
Movie Effector Mosaic,0x00200000,1,1,Mosaic.ax,2.01.0000.2120
Movie Effector Soft Focus,0x00200000,1,1,SoftFocus.ax,2.01.0000.2120
Movie Effector Mirror,0x00200000,1,1,Mirror.ax,2.03.0000.10180
Movie Effector Wave,0x00200000,1,1,Wave.ax,2.01.0000.2120
Movie Effector Painting,0x00200000,1,1,Illust.ax,2.01.0000.2120
Movie Effector Outline,0x00200000,1,1,Edge.ax,4.01.0000.9060
Movie Effector Black & White,0x00200000,1,1,Mono.ax,1.00.0000.7070
Movie Effector Sepia,0x00200000,1,1,Sepia.ax,1.00.0000.7070
Movie Effector Negative,0x00200000,1,1,Nega.ax,1.00.0000.7070
Movie Effector Basic Color,0x00200000,1,1,Primary.ax,1.00.0000.7090
Movie Effector Frame,0x00200000,1,1,BmpOverlay.ax,2.04.0000.11260
Movie Effector Panorama,0x00200000,1,1,Panorama.ax,2.04.0000.11170
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6333
Sony MPEG Video Decoder,0x00100000,1,1,SMVD.ax,2.26.0000.0000
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.6333
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.06.0000.0052
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.6333
WAV Dest,0x00200000,0,0,wavdest.ax,
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Smart DV Audio Decoder,0x00200000,1,1,SmartDVAD.ax,3.00.0003.4130
Effect Filter - Old Films,0x00200000,1,1,OldFilm.ax,2.03.0000.10180
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,1.00.0000.0004
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.6333
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.6333
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.4503
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Effect Filter - After Image,0x00200000,1,1,AfterImage.ax,2.01.0000.2100
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Still Capture Filter,0x00200000,1,1,StillCap.ax,2.04.0000.11171
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,2.00.0002.0036
InterVideo MPEG4 Video Decoder,0x00800000,1,1,MP4VDEC.ax,0.08.0007.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.4503
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
Effect Filter - Date,0x00200000,1,1,Date.ax,2.01.0000.2100
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.6333
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.4503
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.6333
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.6169
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.6333
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.6333
RealMedia Source,0x00600000,0,0,RealMediaSplitter.ax,1.00.0001.0001
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.4503
InterVideo Audio Decoder,0x00700000,1,1,iviaudio.ax,6.00.0006.0042
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Sony MPEG Video Decoder TN,0x00000000,1,1,SMVDTN.ax,3.00.0615.0000
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4504
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
SONY YUV to RGB24,0x00200000,1,1,yuvtorgb24.ax,2.03.0000.11080
Effect Filter - Zigzag,0x00200000,1,1,Zigzag.ax,2.01.0000.2100
SONY YUV to RGB,0x00200000,1,1,yuvtorgb.ax,4.00.0000.6200
Resizing Filter,0x00200000,1,1,DVResize.ax,1.00.0000.6210
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
Effect Filter - Auto Shutter,0x00200000,1,1,Shutter.ax,4.01.0000.9260
RealAudio Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0001.0001
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.6169
Sony MultiFile TS/rawDV Source,0x00200000,0,1,multasync.ax,1.00.0000.6120
Sony MPEG2-TS SPH,0x00000000,1,1,sph.ax,1.00.0000.6260
Sony MPEG2-TS Transform and File Writer,0x00200000,1,1,m2tsTnW.ax,1.00.0000.7190
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.6169
Visualizer Source Filter,0x00200000,0,1,VisSrc.ax,1.02.0000.11050
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.6333
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.4503
Effect Filter - Spiral,0x00200000,1,1,Spiral.ax,2.01.0000.2100
InterVideo Navigator,0x00190000,0,3,IVInav.ax,6.00.0006.0042
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.6333
Still Capture TransformFilter,0x00200000,1,1,StillCap2.ax,4.02.0000.7170
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
Intervideo QT source,0x00200000,0,1,iviQTsource.ax,1.00.0000.0001
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.4503
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Sony DV MediaSample Time Stamper,0x00200000,1,1,DVSTAMP.ax,1.00.0000.13210
Nero Video Decoder,0x00600000,2,2,NeVideo.ax,2.00.0002.0030
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.6404
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.6404
Sony MPEG Encode Filter,0x00200000,2,0,SMpegEnc.ax,1.00.0016.0000
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.6169
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6333
Smart DV Video Decoder,0x00200000,1,1,SmartDVVD.ax,4.00.0000.7050
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Sony raw DV puller,0x00200000,1,1,rawdvtee.ax,1.00.0000.13210
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.6333
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.6333
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.6333
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.4503
Nero File Source,0x00200000,0,1,NeFileSrc.ax,1.00.0000.0006
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,1.00.0000.0004
Effect Filter - Gold,0x00200000,1,1,Gold.ax,2.00.0000.11120
Sony raw DV tee,0x00200000,1,1,dvtee.ax,1.00.0001.7100
YAMAHA AC3 SPDIF Renderer,0x00000000,0,0,,
Sony Null Renderer,0x00200000,1,0,nullrnd.ax,1.00.0000.13250
Effect Filter - Change Faces,0x00200000,1,1,Swap.ax,2.01.0000.4070
Nero DVD Decoder,0x00600000,2,2,NeVideo.ax,2.00.0002.0030
Sony rawDV File Writer,0x00200000,1,0,rawdvwtr.ax,1.00.0001.14270
Sony MPEG Audio Decoder,0x00100000,1,1,SMAD.ax,2.13.0000.0000
Nero Digital Parser,0x00600000,0,3,NDParser.ax,2.00.0002.0036
RealMedia Splitter,0x00600000,1,1,RealMediaSplitter.ax,1.00.0001.0001
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
CyberLink QuickTime Source Filter,0x00200000,0,2,QuickTime.ax,1.00.0000.1016
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.6333
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.6333
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.6333
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
Effect Filter - Digital Zoom,0x00200000,1,1,Zoom.ax,3.00.0000.3050
Sony Tsm Filter,0x00200000,1,1,Tsm.ax,1.01.0000.7130
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6333
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0000
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.6333
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
Sony MPEG2 TS Splitter,0x00600002,1,2,tssplt.ax,1.00.0000.4200
WDM Streaming-Daten-Transforms:
Microsoft Kernel-Echounterdrückung,0x00200000,2,2,,5.03.2600.5512
Microsoft Kernel GS Wavetablesynthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel-DLS-Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel-DRM-Audioentschlüsselung,0x00200000,1,1,,5.03.2600.5512
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.6333
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
SONY DV Software-Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Sony MJPG software CODEC,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft MPEG-4 Video Codec V2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft MPEG-4 Video Codec V1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.6333
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.6333
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.6333
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.6333
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.6333
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.6333
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.6333
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.6333
ATRAC3,0x00200000,1,1,quartz.dll,6.05.2600.6333
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.6333
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.6333
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.6333
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.6333
Audio Capture Sources:
YAMAHA AC-XG WDM Audio,0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.6333
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.6333
WDM Streaming-Capturegeräte:
YAMAHA AC-XG WDM Audio,0x00200000,2,2,,5.03.2600.5512
WDM Streaming-Wiedergabegeräte:
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming-Mixer:
Microsoft Kernel-Waveaudiomixer,0x00200000,2,2,,5.03.2600.5512
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,
Encrypt/Tag,0x00200000,0,0,encdec.dll,
XDS Codec,0x00200000,0,0,encdec.dll,
Audio Renderers:
YAMAHA AC-XG WDM Audio,0x00200000,1,0,quartz.dll,6.05.2600.6333
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.6333
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.6333
DirectSound: YAMAHA AC-XG WDM Audio,0x00200000,1,0,quartz.dll,6.05.2600.6333
WDM Streaming-Systemgeräte:
YAMAHA AC-XG WDM Audio,0x00200000,12,2,,5.03.2600.5512
Poste mal am besten was für Ram verbaut ist und ob noch freie Rambänke sind.
510MB RAM Klingen schon bissel komisch normal sind 512MB (also immer Potenz mit Basis 2).
lol du verlangst nicht ernsthaft das man sich aus dem unnütz langen datenwust was raussuchen soll??
am besten geht man immer so vor, man lässt sich die genaue bezeichnugn das läppis geben und sucht anhand dieser das ding im netz, da bekommt man infos über verauten ram, anzahl der ram bänke und wieviel ram überhaupt unterstützt wird
noch besser wenn du das teil bei dir hast dann kannst selber nachgucken was drin ist, solltest aber trotzdem nachprüfen welche riegel grösse das gerät verträgt
Jo nachm wiki max 512MB Ram, was auch verbaut ist. Höchstens durch ausprobieren (evtl unter linux), sonst wie schon angedeutet: reine Geldverschwendung.
