Infos zum AMD 890GX.
The AMD 890GX chipset is not something very different from the current AMD 790GX North bridge. In fact, both shares the HT3 integrated graphics and 2 PCIe Gen 2 x8 slots supporting CrossFire X. The major difference in the north bridge is it’s support of the graphics capability.
The 790GX supports DX10, UVD and clocks at 700MHz. The 890GX supports DX10.1, UVD2 and clocks at 700MHz.
With a new north bridge, it also comes with a new south bridge pair. THe new SB850 chipset is similar to the SB750. The major difference is that instead of supporting 12 USB 2.0 ports on SB750, the SB850 supports 14 USB 2.0 ports. The SB750 supports 6 SATAII (3Gbps) ports while the SB850 improved on the spec and will support 6 x SATAIII (6Gbps) ports. Both South bridges support the AMD overdrive. Thus if you have a hacked bios, chances that you can run your dual core or tri core as a quad core is still possible unless they lock it in bios.
Quelle: OCW http://forums.ocworkbench.com/showthread.php?p=455804#post455804
Laut heise-online (nach ECS-Angaben) soll die GPU des 890GX (RS890) ein HD4290 sein.
http://www.heise.de/newsticker/meld...psaetzen-AMD-880G-890GX-und-890FX-901924.html
Es soll auch noch der 880G (RS880P) erscheinen. Ebenso der 890FX (RD890).
Erscheinungstermin wahrscheinlich erst zur Cebit 2010 (Anfang März).
Die ersten Boards lassen sich auch schon blicken (CES 2010 in Las Vegas).
ECS A890GXM-A
ECS A890GXM-AU (mit PCIe-USB3-Adaptercard)
Quelle: OCW http://en.ocworkbench.com/tech/ecs-...cs-a890gxm-a-and-usb-3-card-u3n2-at-ces-2010/
ECS IC890GXM-A
Asus M4A89GTD Pro
ECS A890GXM-A
ECS IC890GXM-A
Asus M4A89GTD Pro
