emissary42
Kapitän zur See
- Ort
- Nehr'esham
- Desktop System
- Endlos-Baustelle
- AMD & Intel
- alle Hersteller
- Luft
- G.SKILL, Corsair & Co
- 8K, 5K, 4K
- 80plus Platinum
NEC Electronics uPD720200 Firmware Updater
Flashen auf eigene Gefahr. Bitte die Hinweise im Beitrag beachten.
Download: http://www.klurk.com/files/HLMT1K5E/F302108FWUP5.zip
Betrifft im Moment folgende Mainboards:
Release Notes
Vorgehen
Gigabyte:
X58A-UD7/UD5/UD3R
P55A-UD7/UD6/UD5/UD4P/UD4/UD3P/UD3R/UD3, P55-USB3/USB3L
H57M-USb3
H55M-USB3
EP45T-USB3P
EP43T-USB3
EP41T-USB3, EP41T-USB3L
790XT-USB3
790XTA-UD4
890GPA-UD3H
790FXTA-UD5
770TA-UD3
770T-USB3
785GMT-USB3
und vermutlich auch alle anderen Modelle mit einem NEC Electronics uPD720200, ohne Gewähr
Release Notes
"F302108FWUP5.EXE" updates uPD720200 FW from verion 3.0.1.6 or older to 3.0.2.1. If the FW version is 3.0.2.1 or later, it does not update.
Note1 : F302108FWUP5.EXE is for uPD720200 whose revision ID of PCI Configuration Register is 3h or for later version.
Note2 : If uPD720200 is not detected on the target PC, F302108FWUP5.EXE does not start to update.
Note3 : If multiple uPD720200s are detected on the PC, F302108FWUP5.EXE does not start to update.
Note4 : F302108FWUP5.EXE updates FW regardless of SSID and SVID in the serial ROM.
(If you want to limit the update target to the device with specific SSID
and SVID, you can generate the update file with "Updater Generator".)
Note5 : Users must restart or shoutdown after updating the FW.
Vorgehen
Flashen auf eigene Gefahr1. Disconnect all USB devices connected with the USB3.0 ports.
2. Execute "F302108FWUP5.EXE".
3. Show the License Agreement. If you accept all the terms of the preceding License Agreement, please select "I accept".
4. Show the precaustions. Please check all items.
5. Press "Update" button.
6. After updating, let you restart the computer.
7. Confirm FW Version.On the Start menu, click All Programs, NEC Electronics, USB3.0 Host Controller Driver, and then USB3.0 Hsot Controller Utility.
8. Show USB3.0 Host Controller Information. If "Firmware Version" is 3021, you succeed in updating FW.
