Fillrate Benchmark 2004
so hier mein erstes erbegnis =)
FillrateBenchmark(tm) 2004 - "easy benchmark series"
Benchmark Main Program Version: FRB_V092
Benchmark Date/Time : 13.06.2004 22:22:04
System Information
CPU : AMD Athlon(tm)
GFX : RADEON 9700 PRO
OS : Microsoft Windows XP
Settings : 1024x768 32 bits D16 No AA
Benchmark Result
FrameBuffer Clear : 3801,6 FPS
Color Fill : 1829,555 M-Pixel/s
Z Fill : 1482,267 M-Pixel/s
Color + Z Fill : 1358,954 M-Pixel/s
Single Texture : 150,9949 M-Pixel/s
Single Texture Alpha Blend : 150,9949 M-Pixel/s
Dual Textures : 148,4784 M-Pixel/s
Triple Textures : 150,9949 M-Pixel/s
Quad Textures : 150,9949 M-Pixel/s
1 Floating Poing Texture : 150,9949 M-Pixel/s
Render to Self : 357,7741 M-Pixel/s
PS 1.1 Simple : 1469,684 M-Pixel/s
PS 1.4 Simple : 1482,267 M-Pixel/s
PS 2.0 Simple : 1469,684 M-Pixel/s
PS 2.0 PP Simple : 1497,367 M-Pixel/s
Customized Pixel Shader : 1301,073 M-Pixel/s
PS 2.0 Complex : (Unsupported)
PS 2.0 PP Complex : (Unsupported)
PS 2.0 Massive Register : (Unsupported)
PS 2.0 PP Massive Register : (Unsupported)
PS 2.0 Sincos Procedure Tex : (Unsupported)
PS 2.0 Per-Pixel Lighting : (Unsupported)
* End of FillrateBenchmark Result
spz:d
ich kann ihn nicht runterladen
So...jetzt da es geht...hier mein erster Bench:
(ohne OC und mit viel Qualität und 2xAA im Treiber..ich bench nochmal..)
CPU : Intel(R) Pentium(R) 4 CPU 2.80GHz
GFX : ASUS V9980 Ultra V56.55
Benchmark Result
FrameBuffer Clear : 5888 FPS
Color Fill : 1827,039 M-Pixel/s
Z Fill : 3188,51 M-Pixel/s
Color + Z Fill : 1633,262 M-Pixel/s
Single Texture : 1399,22 M-Pixel/s
Single Texture Alpha Blend : 1376,571 M-Pixel/s
Dual Textures : 1316,172 M-Pixel/s
Triple Textures : 737,3586 M-Pixel/s
Quad Textures : 530,9989 M-Pixel/s
1 Floating Poing Texture : (Unsupported)
Render to Self : 974,1271 M-Pixel/s
PS 1.1 Simple : 1233,125 M-Pixel/s
PS 1.4 Simple : 1233,125 M-Pixel/s
PS 2.0 Simple : 530,9989 M-Pixel/s
PS 2.0 PP Simple : 1233,125 M-Pixel/s
Customized Pixel Shader : 606,4964 M-Pixel/s
so...hier die entgültigen benches ohne TreiberAA+AF :)
Benchmark Date/Time : 14.06.2004 00:10:36
System Information
Benchmark Result
FrameBuffer Clear : 7334,4 FPS
Color Fill : 2028,365 M-Pixel/s
Z Fill : 3822,688 M-Pixel/s
Color + Z Fill : 2023,332 M-Pixel/s
Single Texture : 2000,683 M-Pixel/s
Single Texture Alpha Blend : 1721,342 M-Pixel/s
Dual Textures : 1962,934 M-Pixel/s
Triple Textures : 956,3013 M-Pixel/s
Quad Textures : 646,7617 M-Pixel/s
Render to Self : 1285,554 M-Pixel/s
PS 1.1 Simple : 1950,351 M-Pixel/s
PS 1.4 Simple : 1952,868 M-Pixel/s
PS 2.0 Simple : 649,2782 M-Pixel/s
PS 2.0 PP Simple : 1955,384 M-Pixel/s
Customized Pixel Shader : 654,3114 M-Pixel/s
System Information
CPU : AMD Athlon(tm) 64 Processor 3200+
GFX : RADEON 9800 PRO
Benchmark Result
FrameBuffer Clear : 5350,4 FPS
Color Fill : 1514,983 M-Pixel/s
Z Fill : 1444,518 M-Pixel/s
Color + Z Fill : 963,851 M-Pixel/s
Single Texture : 1592,997 M-Pixel/s
Single Texture Alpha Blend : 1592,997 M-Pixel/s
Dual Textures : 1331,272 M-Pixel/s
Triple Textures : 961,3345 M-Pixel/s
Quad Textures : 737,3586 M-Pixel/s
1 Floating Poing Texture : 1343,855 M-Pixel/s
Render to Self : 2488,69 M-Pixel/s
PS 1.1 Simple : 1411,803 M-Pixel/s
PS 1.4 Simple : 1414,319 M-Pixel/s
PS 2.0 Simple : 1414,319 M-Pixel/s
PS 2.0 PP Simple : 1414,319 M-Pixel/s
Customized Pixel Shader : 1429,419 M-Pixel/s
Alles ohne Overclocking. Also 2Ghz und 380/340 :)
Benchmark Date/Time : 14.06.2004 00:53:53
System Information
Benchmark Result
FrameBuffer Clear : 4774,4 FPS
Color Fill : 2443,601 M-Pixel/s
Z Fill : 2161,744 M-Pixel/s
Color + Z Fill : 1774,191 M-Pixel/s
Single Texture : 2428,502 M-Pixel/s
Single Texture Alpha Blend : 1600,546 M-Pixel/s
Dual Textures : 1280,941 M-Pixel/s
Triple Textures : 843,0551 M-Pixel/s
Quad Textures : 634,1788 M-Pixel/s
1 Floating Poing Texture : 1253,258 M-Pixel/s
Render to Self : 2293,026 M-Pixel/s
PS 1.1 Simple : 2415,919 M-Pixel/s
PS 1.4 Simple : 2418,436 M-Pixel/s
PS 2.0 Simple : 2438,568 M-Pixel/s
PS 2.0 PP Simple : 2441,085 M-Pixel/s
Customized Pixel Shader : 1298,556 M-Pixel/s
spz:d
Alles Original, also ohne OC
Benchmark Date/Time : 14.06.2004 01:09:54
System Information
CPU : Intel(R) Pentium(R) 4 CPU 3.00GHz
GFX : NVIDIA GeForce FX 5950 Ultra
OS : Microsoft Windows 2000
Benchmark Result
FrameBuffer Clear : 7308,8 FPS
Color Fill : 2023,332 M-Pixel/s
Z Fill : 3890,636 M-Pixel/s
Color + Z Fill : 2018,299 M-Pixel/s
Single Texture : 1995,65 M-Pixel/s
Single Texture Alpha Blend : 1469,684 M-Pixel/s
Dual Textures : 1522,532 M-Pixel/s
Triple Textures : 893,3868 M-Pixel/s
Quad Textures : 651,7948 M-Pixel/s
Render to Self : 1328,336 M-Pixel/s
PS 1.1 Simple : 1988,1 M-Pixel/s
PS 1.4 Simple : 1988,1 M-Pixel/s
PS 2.0 Simple : 654,3114 M-Pixel/s
PS 2.0 PP Simple : 1575,38 M-Pixel/s
Customized Pixel Shader : 639,2119 M-Pixel/s
MFG
Chris
hier jetzt Graka @ 530/1010mhz
Benchmark Date/Time : 14.06.2004 01:15:18
System Information
Benchmark Result
FrameBuffer Clear : 7372,8 FPS
Color Fill : 2141,612 M-Pixel/s
Z Fill : 4084,413 M-Pixel/s
Color + Z Fill : 2141,612 M-Pixel/s
Single Texture : 2088,763 M-Pixel/s
Triple Textures : 938,6852 M-Pixel/s
Quad Textures : 687,0269 M-Pixel/s
Render to Self : 1391,46 M-Pixel/s
PS 1.1 Simple : 2098,83 M-Pixel/s
PS 1.4 Simple : 2101,346 M-Pixel/s
PS 2.0 Simple : 692,0602 M-Pixel/s
PS 2.0 PP Simple : 1811,939 M-Pixel/s
Benchmark Date/Time : 14.06.2004 01:40:24
System Information
CPU : Unknown CPU Typ
GFX : NVIDIA GeForce2 GTS/GeForce2 Pro
Benchmark Result
FrameBuffer Clear : 806,4 FPS
Color Fill : 636,6953 M-Pixel/s
Z Fill : 322,1226 M-Pixel/s
Color + Z Fill : 322,1226 M-Pixel/s
Single Texture : 639,2119 M-Pixel/s
Single Texture Alpha Blend : 322,1226 M-Pixel/s
Dual Textures : 324,6391 M-Pixel/s
Triple Textures : 324,6391 M-Pixel/s
Quad Textures : 324,6391 M-Pixel/s
Render to Self : 105,6965 M-Pixel/s
PS 1.1 Simple : (Unsupported)
PS 1.4 Simple : (Unsupported)
PS 2.0 Simple : (Unsupported)
PS 2.0 PP Simple : (Unsupported)
Customized Pixel Shader : (Unsupported)
FrameBuffer Clear : 4556,8 FPS
Color Fill : 1426,902 M-Pixel/s
Z Fill : 2053,531 M-Pixel/s
Color + Z Fill : 1082,13 M-Pixel/s
Single Texture : 1469,684 M-Pixel/s
Single Texture Alpha Blend : 1482,267 M-Pixel/s
Dual Textures : 1167,694 M-Pixel/s
Triple Textures : 817,8893 M-Pixel/s
Quad Textures : 629,1456 M-Pixel/s
1 Floating Poing Texture : 1162,661 M-Pixel/s
Render to Self : 2135,74 M-Pixel/s
PS 1.1 Simple : 1235,642 M-Pixel/s
PS 1.4 Simple : 1235,642 M-Pixel/s
PS 2.0 Simple : 1235,642 M-Pixel/s
Customized Pixel Shader : 1238,159 M-Pixel/s
mit 2x AA und 4AF im Treiber, config siehe sig
Benchmark Date/Time : 16.06.2004 17:51:49
System Information
Benchmark Result
FrameBuffer Clear : 4748,8 FPS
Color Fill : 2431,019 M-Pixel/s
Z Fill : 2146,645 M-Pixel/s
Color + Z Fill : 1771,674 M-Pixel/s
Single Texture : 2413,403 M-Pixel/s
Dual Textures : 1273,391 M-Pixel/s
Triple Textures : 840,5386 M-Pixel/s
1 Floating Poing Texture : 1245,708 M-Pixel/s
Render to Self : 2282,54 M-Pixel/s
PS 1.1 Simple : 2403,336 M-Pixel/s
PS 1.4 Simple : 2425,986 M-Pixel/s
PS 2.0 Simple : 2425,986 M-Pixel/s
PS 2.0 PP Simple : 2431,019 M-Pixel/s
Customized Pixel Shader : 1285,974 M-Pixel/s
spz:d
Mein Ergebnis:
Benchmark Date/Time : 16.06.2004 19:02:35
System Information
CPU : Intel(R) Pentium(R) 4 CPU 3.20GHz
Benchmark Result
FrameBuffer Clear : 6835,2 FPS
Color Fill : 1907,57 M-Pixel/s
Z Fill : 3666,66 M-Pixel/s
Color + Z Fill : 1907,57 M-Pixel/s
Single Texture : 1837,105 M-Pixel/s
Single Texture Alpha Blend : 1447,035 M-Pixel/s
Dual Textures : 1517,499 M-Pixel/s
Triple Textures : 873,2542 M-Pixel/s
Quad Textures : 611,5295 M-Pixel/s
Render to Self : 1254,936 M-Pixel/s
PS 1.1 Simple : 1874,854 M-Pixel/s
PS 1.4 Simple : 1874,854 M-Pixel/s
PS 2.0 Simple : 614,0461 M-Pixel/s
PS 2.0 PP Simple : 1507,433 M-Pixel/s
Customized Pixel Shader : 593,9135 M-Pixel/s
System Information
CPU : AMD Athlon(tm) (2600+@2,4GHZ)
GFX : MSI MS-StarForce GeForce FX 5600 (NVIDIA GeForce FX 5600)
Benchmark Result
FrameBuffer Clear : 2124,8 FPS
Color Fill : 1434,452 M-Pixel/s
Z Fill : 1436,969 M-Pixel/s
Color + Z Fill : 1225,576 M-Pixel/s
Single Texture : 1353,921 M-Pixel/s
Single Texture Alpha Blend : 747,425 M-Pixel/s
Dual Textures : 689,5436 M-Pixel/s
Triple Textures : 337,222 M-Pixel/s
Quad Textures : 231,5256 M-Pixel/s
Render to Self : 576,7168 M-Pixel/s
PS 1.1 Simple : 717,226 M-Pixel/s
PS 1.4 Simple : 717,226 M-Pixel/s
PS 2.0 Simple : 206,3597 M-Pixel/s
PS 2.0 PP Simple : 234,0422 M-Pixel/s
Customized Pixel Shader : 239,0753 M-Pixel/s
