<Fehlersuche-STOPCode 0x124> BSOD i7 6950X ohne OC
camber
Hallo zusammen,
vielleicht hat jemand eine Idee oder kennt das Problem.
Ich habe sporadisch einen BSOD mit folgender Kennung:
On Sat 25.07.2020 11:24:22 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\072520-30718-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x3DDB60)
Bugcheck code: 0x124 (0x0, 0xFFFFA70BFEF2A028, 0xBA000000, 0x58000402)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Mon 20.07.2020 17:17:13 your computer crashed or a problem was reported
crash dump file: C:\Windows\MEMORY.DMP
This was probably caused by the following module: pshed.dll (PSHED!PshedBugCheckSystem+0x10)
Bugcheck code: 0x124 (0x0, 0xFFFF8784CDB3D028, 0xBA000000, 0x58000402)
file path: C:\Windows\system32\pshed.dll
product: Betriebssystem Microsoft® Windows®
description: Plattformspezifischer Hardwarefehlertreiber
The crash took place in a Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Sun 19.07.2020 18:23:58 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\071920-25500-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFCB8ADC12A028, 0xBA000000, 0x58000402)
das System ist:
- Lian Li PC-X2000FNB TYR Series Big-Tower USB 3.0, schwarz - gedämmt
- Intel® Core™ i7 6950X
- MSI X99S XPower AC
- 32Gb=2x16Gb G.SKILL F4-3200C14D-32GTZ Kit
- MSI GeForce RTX 2080 Ti GAMING X TRIO
- Windows 10 Professional 64 Bit
- Creative Soundblaster AE-9
- Enermax Platimax 850W ATX 2.4
Das passiert wenn der Rechner übertaktet ist genauso wie wenn ich ihn auf Standard lasse. Bei einer Übertaktung auf 4.2GHz und Stresstest mit Prime,AIDA oder Intel Extreme Tuning Utility läuft er. Ich habe keine Idee.
Was hat es damit aufsich?:
Rufen Sie das BIOS auf (F2) und wählen Sie Advanced Chipset Features (Erweiterte Chipsatz-Funktionen) aus. Deaktivieren Sie die Option "C1E Enhanced Halt State"
Läuft seit 2 Tagen wie eh und jeh. Alles noch auf Standard mit EIST, TurboBoost und Enhanced Turbo. XMP ist auch noch aus. Aber auch in dem Zustand gab es die sporadischen BSOD 0x124.
Ich habe die CPU getauscht, RAM auf Quadchannel erweitert und Grafikarte mit dem Stromanschluss von der Soundkarte (einen 6-poligen) getauscht.
Was war jetzt die Ursache?
