[FAQ] Crysis3 Stürzt ab
Desperados9
Hallo Leute
Ich hab ein Problem mit c3.
Ich hab es mir bei Origin heruntergeladen.
Es Startet auch aber sobald ich Spielen will bleibt es hängen und reagiert nicht mehr.
Was kann ich da tun
Spiel ist aktualiesiert genauso wie meine Treiber für CPU und Grafik.
Hier noch der Log von C3
BackupNameAttachment=" Build(1000) 04 Nov 13 (15 03 55)" -- used by backup system
Log Started at 11/04/13 15:03:55
Running 32 bit version
Executable: C:\Program Files (x86)\Origin Games\Crysis 3\Bin32\crysis3.exe
FileVersion: 1.2.1.1000
ProductVersion: 1.2.1.1000
Using STLport C++ Standard Library implementation
Executable Command Line: "C:\Program Files (x86)\Origin Games\Crysis 3\Bin32\crysis3.exe"
Total number of logical processors: 2
Number of available logical processors: 2
Total number of system cores: 1
Number of cores available to process: 1
Processor 0:
CPU: AMD AMD A4-5300 APU with Radeon(tm) HD Graphics
Family: 15, Model: 0, Stepping: 1
FPU: On-Chip
CPU Speed (estimated): 3393.9 MHz
MMX: not present
SSE: present
3DNow!: not present
Serial number not present or disabled
Windows 7 64 bit SP 1 (build 6.1.7601)
System language: German
Windows Directory: "C:\Windows"
Prerequisites...
* Installation of KB940105 hotfix required: no! (either not needed or already installed)
Local time is 15:03:56 11/04/13, system running for 1 minutes
4049MB physical memory installed, 2642MB available, 4095MB virtual memory installed, 34 percent of memory in use
PageFile usage: 168MB, Working Set: 142MB, Peak PageFile usage: 193MB,
Current display mode is 1920x1080x32, (Unknown graphics card)
IBM enhanced (101/102-key) keyboard and 5+ button mouse installed
Stream Engine Initialization
GameName: Crysis 3
BuildTime: Jul 23 2013 08:23:20
Font initialization
Physics initialization
Sound initialization
<Sound> Initializing AudioDevice now!
<Sound> Initialize FMOD with dynamic memory callbacks
<Sound> Starting to initialize Windows Audio Session API output!
<Sound> Playback drivers found: 1
<Sound> Available playback drivers:
1. Lautsprecher (Realtek High Definition Audio)
<Sound> FmodEx-AudioDevice: Now running on driver: Lautsprecher (Realtek High Definition Audio)
<Sound> Record drivers found: 1
<Sound> Available record drivers:
1. FrontMic (Realtek High Definition Audio)
<Sound> Record config is set to autodetect using record driver 0
<Sound> Using speaker mode: FMOD_SPEAKERMODE_STEREO
<Sound> Initializing FMOD-EX now!
<Sound> Initialized FMOD-EX
<Sound> Using FMOD version: 00044211 and internal 00044211!
<Sound> Initializing SoundSystem now!
Renderer initialization
Logging video adapters:
- AMD Radeon HD 6900 Series (vendor = 0x1002, device = 0x6719)
- Adapter index: 0
- Dedicated video memory: 1015 MB
- Feature level: DX11 (SM 5.0)
- Displays connected: yes
- - - Updated - - -
Oh je Mene Signatur stimmt natürlich nicht mehr!!!!!!
CPU: AMD AMD A4-5300 APU with Radeon(tm) HD Graphics -> o wtf is dat?
ein notebook mit so komischen AMD apu?! :) das game selber sagt dazu wohl zurecht UNKNOWN! :-P vieleich gänzlich unnsuportet GPU, weil zu abgespeckt oder zu neu...
Die APU Läuft nur als CPU jetzt mit 2x4,1GhZ
Die Grafikkarte ist eine AMD 6950
Das Log wurde nicht richtig kopiert
Hier jetzt das ganze LOG:
Processor 0:
FPU: On-Chip
MMX: not present
SSE: present
3DNow!: not present
Prerequisites...
GameName: Crysis 3
Font initialization
- Adapter index: 0
- Suitable rendering device: yes
Network initialization
[net] Socket IO management: External [LobbyIDAddr], Internal [Select]
network hostname: besitzerpc
ip:192.168.178.34
[Network Version]: RELEASE PURE CLIENT
Lobby initialization
MovieSystem initialization
Console initialization
Time initialization
Input initialization
AI initialization
Initializing Animation System
Initializing 3D Engine
Script System Initialization
Entity system initialization
LiveCreate initialization
Initializing AI System
Initializing additional systems
[GameProfiles]: Successfully activated profile 'default' for user 'Besitzer'
username Besitzer signedIn 1 userIndex -1
ActivateProfile profileName default
[Game Version]: RELEASE PURE CLIENT
[Warning] Unknown command: buyammo
