Chaintech ** VNF4 / VNF4 Ultra ZENITH VE ** Sammelthread
F
forumer
Guest
Chaintech VNF4 / VNF4 Ultra ZENITH VE
Links:
Daten @ Chaintech
vMod @ vr-zone.com
Review @ overclockercafe.com
Review @ au-ja.org
Review @ ninjalane.com
Review @ xbitlabs.com
Review @ legitreviews.com
Bios:
Memclock index value (MHz): 100/133/166/200
CAS latency (TCL): 2,0 / 2,5 / 3,0
Min RAS active time (Tras): Auto / 5 / 6 / 7 / 8 / 9 / 10 / 11 / 12 / 13 / 14 / 15
RAS to CAS (Trcd): Auto / 2 / 3 / 4 / 5 / 6 / 7
Row prechrage time (Trp): Auto / 2 / 3 / 4 / 5 / 6 / 7
1T/2T Memory Timing: 1T / 2T
Read Preample value (ns): 2 / 2,5 / 3 / 3,5 / 4 / 4,5 / 5 / 5,5 / 6 / 6,5 / 7 / 7,5 / 8 / 8,5 / 9 / 9,5
Async Latency value (ns): 2 / 3 / 4 / 5 / 6 / 7 / 8 / 9 / 10 / 11
S/W memory hole Remapping: Disabled / Enabled
MTBR mapping mode: Continous / Discrete
CPU Frequency: 200 bis 400 MHz
PCIE Clock: 100 bis 145 MHz
Hammer VID Control: x4 / x4,5 / x5 / x5,5 / x6 / x6,5 / x7 / x7,5 / x8 / x8,5 / x9 / x9,5 / x10 / x10,5 / x11
CPU Voltage Regulator: 0,900 bis 1,70 Volt
DIMM Voltage Regulator: 2,70 / 2,80 / 2,90 Volt
Chipset Voltage Regulator: 1,60 / 1,65 / 1,70 Volt
HT Frequency: Auto / 1 / 2 / 3 / 4 / 5
HT Width: 8/8, 16/8, 8/16, 16/16
Allgemein:
Form Factor ATX (305mm x 220mm)
CPU Supports AMD Socket-939 Athlon 64 FX / Athlon 64 processor
Processor interface via 2000MT/s HyperTransport bus
Chipset NVIDIA nForce4 (VNF4) / nForce4 Ultra (VNF4 Ultra)
Main Memory Four 184-pin DDR DIMMs up to 4GB
Supports Dual Channel DDR266/333/400 memory
Expansion Slots PCI Express x16 port for PCI Express graphics card
Two PCI Express x1 ports
Three 32bit PCI slots (v2.3 compliant)
Audio Subsystem Supports enhanced NVIDIA 7.1-channel audio
Complies with AC'97 Rev 2.3 specifications
Six audio jacks with automatic jack sensing
Supports 48KHz coaxial S/PDIF output
EAX/Direct Sound 3D/I3DL2/A3D compatible
SATA Supports four native SATA 1.5Gb/s devices (VNF4)
Supports four native SATA2 3.0Gb/s devices (VNF4 Ultra)
Hot-swap capability, allowing disks to be changed without powering down the system.
Optimized for the high-performance NVIDIA RAID technology
Supports SATA ATAPI devices
UltraDMA IDE Ports Supports 2 UltraDMA-66/100/133 IDE ports
FDD One FDD connector supports up to 2.88MB
USB2.0 Supports total 10 USB2.0 ports with High-Speed Device @480 Mb/s Transfer Rates
Embedded system monitoring Temperature sensing for CPU and system
Fan speed monitoring and control for CPU and system
NVIDIA Gigabit Ethernet Supports 10/100/1000Base-T Gigabit Ethernet with external PHY
NVIDIA ActiveArmor (VNF4 Ultra) A dedicated secure networking engine enhances networking security while reducing CPU overhead
Specialized features defend against spyware intrusions and hacker attacks
An intelligent application manager alerts you when unknown applications attempt to access the network
Supports the new Microsoft networking architecture for fast and secure networking
Boot-Block Flash ROM Award system BIOS supports PnP, APM, DMI, ACPI, & Multi-device booting features
Software Driver CD
Value Pack
Other Feature Rear panel I/O ports
PS/2 Mouse and Keyboard port
25-pin D-Sub female Parallel port
Two 9-pin D-Sub male Serial ports
Four USB ports and one RJ45 connector
6-port Audio Jack for 7.1-Channel and S/PDIF output
Internal I/O connectors
Four 3x1 pin fan connectors
Three 5x2 pin USB connectors for additional 6 USB ports
3x1 pin wake on LAN connector with housing
3x1 pin wake on Modem connector with housing
Two 4x1 pin CD-in connectors with 2.54mm pitch housing
5x2 pin Front Audio connector
9x2 pin Front Panel connector
24 pin ATX Power connector
4 pin ATX 12V Power connector
Mir gefällt das Board echt und einen Shop konnte ich dazu bisher nicht ausfindig machen.
Das Board ist denke ich für viele hier interesant weil es doch recht günstig ist!
MFG
MFG
hm, chaintech und guenstig in ger :stupid: . dann guck dir mal epox an, die sind hier guenstig.
forumer schrieb:
Kennst Du die Preise in Deutschland?
Auf der ersten Seite von dem test bei au-ja steht irgendwas von 105€
da
Das einzige was mir auffällt ist das es grottenschlecht beim ocing ist.
Ab einem 230 Mhz bleibt Windows bei dem test von au-ja hängen. :shake:
da
Kann am ersten Bios liegen und an den Testern selbst. Abwarten :coolblue:
Habe schon alles durch gegooglet nichts gefunden keinen Shop
der das Board anbietet :( hört sich nämlich echt nicht schlecht
an.
Sushi
Joa liegt daran das CT atm noch keine neuen bzw wieder aufgenommen Vertriebswege in Deutschland hat...............
