Anyone with windows 2003 server enterprise & ati card able to install the 3.10 cat drivers?
I cant get this latest set to install. I uninstalled 3.9 as per ati instructions then attempted to install the new ones. When i do i get this message
"inf error video driver not found"
Then i close box and another message pops up.
"setup was unable to complete the installation, try to setup your display adapter with a standard vga driver before running setup"
I installed winsdows 2003 on another partition & tried it on a clean install and its same again. But my previous prob of not being able to install windvd 5 is not there on the new installation
pointreyes
Mystery Man, after the problems I had with the 3.10 drivers on my Windows XP Pro installation-I'm not willing to even test the drivers on my precious, highly stable, uber important w2k3 ES installation.
Even uninstalling the 3.10 drivers caused havoc on my XP Pro installation that I finally just recovered an image of the OS to get it back to the 3.9s. As of late I cannot even image my w2k3 ES OS. Apparently some new application I have on the OS has killed the ability to even image it anymore. :sad: Until I solve that problem I cannot take risks with the evil 3.10 drivers. Note: there is another that is having problems with the 3.10 drivers with w2k3 ES: Zao at rage3d
quote:
If anyone care to know, when installing the 3.9 or 3.10 cats on my Win2k3 Enterprise, it attempts and fails to install 'Windows XP 64-bit drivers'. Might it be that they are already included in the Cats?
http://www.rage3d.com/board/showthread.php?threadid=33708221&perpage=30&pagenumber=3
