denke das wird einige von Euch interessieren...
Motherboard ASRock Z68 Extreme4
CPU
- Supports 2nd Generation Intel Core i7 / i5 / i3 in LGA1155 Package
- Advanced V8 Power Phase Design
- Supports Intel Turbo Boost 2.0 Technology
- Supports Intel K-Series unlocked CPU
- Supports Hyper-Threading Technology
Chipset
- Intel Z68
Memory
- Dual Channel DDR3 memory technology
- 4 x DDR3 DIMM slots
- Supports DDR3 2133 (OC) / 1866 (OC) / 1600/1333/1066 non-ECC, un-buffered memory
- Max. capacity of system memory: 32GB *
- Supports Intel Extreme Memory Profile (XMP)
BIOS
- 64Mb AMI UEFI Legal BIOS with GUI support
- Supports "Plug and Play"
- ACPI 1.1 Compliance Wake Up Events
- Supports jumperfree
- SMBIOS 2.3.1 Support
- CPU Core, IGPU, DRAM, PCH, CPU PLL, VTT, VCCSA Voltage Multi-adjustment
Graphics
- Supports Intel HD Graphics Built-in Visuals: Intel Quick Sync Video, Intel InTru 3D, Intel Clear Video HD Technology, Intel HD Graphics 2000/3000, Intel Advanced Vector Extensions (AVX)
- Pixel Shader 4.1, DirectX 10.1
- Max. shared memory 1759MB
- Multi VGA Output options: D-Sub, DVI-D, HDMI and DisplayPort
- Supports HDMI 1.4a Technology with max. resolution up to 1920x1200 @ 60Hz
- Supports DVI with max. resolution up to 1920x1200 @ 60Hz
- Supports D-Sub with max. resolution up to 2048x1536 @ 75Hz
- Supports DisplayPort with max. resolution up to 2560x1600 @ 60Hz
- Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI (Compliant HDMI monitor is required)
- Supports HDCP function with DVI, HDMI and DisplayPort ports
- Supports Full HD 1080p Blu-ray (BD) / HD-DVD playback with DVI, HDMI and DisplayPort ports
Audio
- 7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec)
- Premium Blu-ray audio support
- Supports THX TruStudio PRO
LAN
- PCIE x1 Gigabit LAN 10/100/1000 Mb / s
- Broadcom BCM57781
- Supports Wake-On-LAN
- Supports Energy Efficient Ethernet 802.3az
Slots
- 3 x PCI Express 2.0 x16 slots (PCIE2/PCIE4: single at x16 or dual at x8/x8 mode; PCIE5: x4 mode)
- 2 x PCI Express 2.0 x1 slots
- 2 x PCI slots
- Supports ATI Quad CrossFireX, 3-Way CrossFireX and CrossFireX
- Supports NVIDIA Quad SLI and SLI
SATA3
- 2 x SATA3 6.0 Gb / s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5, Intel Rapid Storage and Intel Smart Response Technology), NCQ, AHCI and "Hot Plug" functions
- 2 x SATA3 6.0 Gb / s connectors by Marvell SE9120, support NCQ, AHCI and "Hot Plug" functions (SATA3_M2 connector is shared with eSATA3 port)
USB 3.0 - 2 x Rear USB 3.0 ports by Etron EJ168A, support USB 1.0/2.0/3.0 up to 5Gb / s
- 1 x Front USB 3.0 header (supports 2 USB 3.0 ports) by Etron EJ168A, supports USB 1.0/2.0/3.0 up to 5Gb / s
Connector
- 4 x SATA2 3.0 Gb / s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5, Intel Rapid Storage and Intel Smart Response Technology), NCQ, AHCI and Hot Plug functions
- 4 x SATA3 6.0 Gb / s connectors
- 1 x Floppy connector
- 1 x IR header
- 1 x CIR header
- 1 x COM port header
- 1 x HDMI_SPDIF header
- 1 x IEEE 1394 header
- 1 x Power LED header
- CPU / Chassis / Power FAN connector
- 24 pin ATX power connector
- 8 pin 12V power connector
- SLI / XFire power connector
- Front panel audio connector
- 3 x USB 2.0 headers (support 6 USB 2.0 ports)
- 1 x USB 3.0 header (supports 2 USB 3.0 ports)
- 1 x Dr. Debug with LED
Rear Panel I / O
- 1 x PS / 2 Keyboard Port
- 1 x VGA / D-Sub Port
- 1 x VGA / DVI-D Port
- 1 x HDMI Port
- 1 x DisplayPort
- 1 x Optical SPDIF Out Port
- 4 x Ready-to-Use USB 2.0 Ports
- 1 x eSATA3 Connector
- 2 x Ready-to-Use USB 3.0 Ports
- 1 x RJ-45 LAN Port with LED (ACT / LINK LED and SPEED LED)
- 1 x IEEE 1394 Port
- 1 x Clear CMOS Switch with LED
- HD Audio Jack: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone
Unique Feature
- ASRock Extreme Tuning Utility (AXTU)
- Instant Boot
- ASRock Instant Flash
- ASRock APP Charger
- SmartView
- ASRock XFast USB
- Lucid Virtu
- ASRock On / Off Play Technology
- Hybrid Booster:
- CPU Frequency Stepless Control
- ASRock U-COP
- Boot Failure Guard (BFG)
- Combo Cooler Option (CCO)
- Good Night LED
Smart Switch
- 1 x Power Switch with LED
- 1 x Reset Switch with LED
Support CD
- Drivers, Utilities, AntiVirus Software (Trial Version), ASRock Software Suite (CyberLink DVD Suite - OEM and Trial)
Accessories
- 1 x ASRock SLI_Bridge_2S Card
- Quick Installation Guide, Support CD, I / O Shield
- Floppy Cable
- 4 x SATA Data Cables (optional)
- 2 x SATA 1 to 1 Power Cables (optional)
- 1 x 3.5mm Audio Cable (optional)
- 1 x Front USB 3.0 Panel
- 4 x HDD Screws
- 6 x Chassis Screws
- 1 x Rear USB 3.0 Bracket
Hardware Monitor
- CPU Temperature Sensing
- Chassis Temperature Sensing
- CPU / Chassis / Power Fan Tachometer
- CPU / Chassis Quiet Fan (Allow Chassis Fan Speed \u200b\u200bAuto-Adjust by CPU Temperature)
- CPU / Chassis Fan Multi-Speed \u200b\u200bControl
- Voltage Monitoring: +12 V, +5 V, +3.3 V, CPU Vcore
Form Factor
- ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
- All Solid Capacitor design (100% Japan-made high-quality Conductive Polymer Capacitors)
CPU
Chipset
- Intel Z68
Memory
BIOS
Graphics
Audio
LAN
- Broadcom BCM57781
Slots
- 2 x PCI slots
SATA3
Connector
- 1 x IR header
- 1 x CIR header
Rear Panel I / O
- 1 x HDMI Port
- 1 x DisplayPort
Unique Feature
- Instant Boot
- SmartView
- ASRock XFast USB
- Lucid Virtu
- Hybrid Booster:
- ASRock U-COP
- Good Night LED
Smart Switch
Support CD
Accessories
- Floppy Cable
- 4 x HDD Screws
Hardware Monitor
Form Factor
