Techtrancer
Urgestein
AMD FX-Series "Centurion" & "Vishera" & "Delhi" OC Thread
AMD FX-Series
OC Thread
CPU SPEC
Sammelthread`s & OC Listen
OC TIP's MAINBOARD
OC TIP´S CPU
OC TIP´S RAM
Vorgehensweise beim Übertakten
Nützliche Programme
OC Thread
CPU SPEC
Tests zu den FX-9XXX + FX-83XX ProzessorenFX-9590 ==> AMD Processors for Desktops: AMD Phenom
FX-9370 ==> AMD Processors for Desktops: AMD Phenom
FX-8370 ==> http://products.amd.com/en-us/Deskt...+&f6=&f7=32nm&f8=&f9=&f10=False&f11=&f12=True
FX-8370E ==> http://products.amd.com/en-us/Deskt...+&f6=&f7=32nm&f8=&f9=&f10=False&f11=&f12=True
FX-8350 ==> http://products.amd.com/en-us/Deskt...=True]AMD Processors for Desktops: AMD Phenom
FX-8320 ==> AMD Processors for Desktops: AMD Phenom
FX 8320E ==> http://products.amd.com/en-us/Deskt...+&f6=&f7=32nm&f8=&f9=&f10=False&f11=&f12=True
Opteron 3380 ==> http://www.cpu-world.com/CPUs/Bulldozer/AMD-Opteron 3380 - OS3380OLW8KHK.html
Opteron 3365 ==> http://www.cpu-world.com/CPUs/Bulldozer/AMD-Opteron 3365.html
Opteron 3350 EE ==> http://www.cpu-world.com/CPUs/Bulldozer/AMD-Opteron 3350 HE - OS3350HOW4KHK.html
Opteron 3320 HE ==> http://www.cpu-world.com/CPUs/Bulldozer/AMD-Opteron 3320 EE - OS3320SJW4KHK.html
FX-6350 ==> http://www.cpu-world.com/CPUs/Bulldozer/AMD-FX-Series FX-6350.html
FX-6300 ==> AMD Processors for Desktops: AMD Phenom
FX-4350 ==> http://www.cpu-world.com/CPUs/Bulldozer/AMD-FX-Series FX-4350.html
FX-4300 ==> AMD Processors for Desktops: AMD Phenom
CPU-Z:
FX-8370 @ LN2 @ 8,723 GHz ==> The Stilt`s CPU Frequency score: 8722.78 mhz with a FX-8370
FX-8350 @ LN2 @ 8,670 GHz ==> AndreYang`s CPU Frequency score: 8670 mhz with a FX-8350
FX-9370 @ LN2 @ 8,505 GHZ ==> The Stilt`s CPU Frequency score: 8505.21 mhz with a FX-9370
FX-9590 @ LN2 @ 8,343 GHZ ==> CtrlFix`s CPU Frequency score: 8343.92 mhz with a FX-9590
FX-8320 @ LN2 @ 8,171 GHz ==> slamms`s CPU Frequency score: 8171 mhz with a FX-8320
WPrime 32m
FX-8350 @ LN2 @ 7,430 GHz @ 4,381s ==> CherV`s wPrime - 32m score: 4sec 381ms with a FX-8350
FX-8350 @ LN2 @ 7,207 GHz @ 4,532s ==> CherV`s wPrime - 32m score: 4sec 532ms with a FX-8350
FX-8350 @ AIR @ 5,412 GHz @ 5,991s ==> TheMadDutchDude`s wPrime - 32m score: 5sec 991ms with a FX-8350
FX-8350 @ H2O @ 5,178 GHz @ 6,374s ==> NoMS`s wPrime - 32m score: 6sec 374ms with a FX-8350
WPrime 1024m
FX-8350 @ LN2 @ 7,400 GHz @ 141,740s ==> Radi`s wPrime - 1024m score: 2min 21sec 740ms with a FX-8350
FX-8350 @ LN2 @ 7,146 GHz @ 143,766s ==> CherV`s wPrime - 1024m score: 2min 23sec 766ms with a FX-8350
FX-8350 @ AIR @ 5,412 GHz @ 190,055s ==> TheMadDutchDude`s wPrime - 1024m score: 3min 10sec 55ms with a FX-8350
FX-8350 @ H2O @ 5,350 GHz @ 196,825s ==> brutus99`s wPrime - 1024m score: 3min 16sec 825ms with a FX-8350
Superpi 1m
FX-8350 @ LN2 @ 8,221 GHz @ 9,125s ==> der8auer`s SuperPi - 1M score: 9sec 125ms with a FX-8350
FX-9590 @ LN2 @ 7,870 GHz @ 9,625s ==> CtrlFix`s SuperPi - 1M score: 9sec 625ms with a FX-9590
FX-8350 @ LN2 @ 7,805 GHz @ 11,437s ===> Wizerty`s SuperPi - 1M score: 11sec 437ms with a FX-8350
FX-8350 @ H20 @ 5,377 GHz @ 16,797s ===> Luebke`s SuperPi - 1M score: 16sec 797ms with a FX-8350
Cinebench R15 Multicore
FX-8350 @ LN2 @ 7,649 GHz @ 1196 Punkte ==> l0ud_sil3nc3`s Cinebench R15 score: 1196 cb with a FX-8350
FX-9590 @ LN2 @ 6,722 GHz @ 1071 Punkte ==> NoMS`s Cinebench R15 score: 1071 cb with a FX-9590
FX-8320 @ LN2 @ 6,125 GHz @ 991 Punkte ==> tiborrr`s Cinebench R15 score: 991 cb with a FX-8320
FX-8350 @ H2O @ 5,533 GHz @ 887 Punkte ==> Johan45`s Cinebench R15 score: 887 cb with a FX-8350
FX-9590 @ H2O @ 5,344 GHz @ 856 Punkte ==> Olsen`s Cinebench R15 score: 856 cb with a FX-9590
FX-8320 @ H2O @ 5,268 GHz @ 842 Punkte ==> darkage`s Cinebench R15 score: 842 cb with a FX-8320
Max Mem Clock
1948 Mhz ==> CherV`s Memory Clock score: 1948.1 MHz with a DDR3 SDRAM
5,0 GHz @ All Cores @ Prime95
FX-8370E @ WAKÜ @ 1.464V | Hasestab | Link
FX-9590 @ WAKÜ @ 1.488V | Reous | Link
FX-8350 @ WAKÜ @ 1.536V | Reous | Link
4,5 GHz @ All Cores @ Prime95
FX 8370E @ WAKÜ @ 1.264V | Hasestab | Link
FX-9590 @ WAKÜ @ 1.296V | Hasestab | Link
FX-9590 @ WAKÜ @ 1.308V | Reous | Link
FX-8350 @ LUKÜ @ 1.320V | Reous | Link
FX-8350 @ WAKÜ @ 1.332V | Reous | Link
FX-8350 @ LUKÜ @ 1.368V | digitalbath | Link
FX-8350 @ WAKÜ @ 1.368V | Flayer | LINK
FX-8350 @ LUKÜ @ 1.392V | k3im | Link
4,0 GHz @ All Cores @ Prime95
FX-8370E @ WAKÜ @ 1.164V | Hasestab | Link
FX-9590 @ WAKÜ @ 1.164V | Hasestab | Link
FX-9590 @ WAKÜ @ 1.176V | Reous | Link
FX-8350 @ LUKÜ @ 1.188V | Reous | Link
FX-8350 @ WAKÜ @ 1.224V | Reous | Link
FX-8350 @ WAKÜ @ 1.224V | Flayer | LINK
FX-8350 @ LUKÜ @ 1.224V | digitalbath | Link
FX-8350 @ LUKÜ @ 1.260V | k3im | Link
FX-8320 @ LUKÜ @ 1.284V | Reous | Link
FX-8320 @ WAKÜ @ 1.308V | Mondrial | Link
WPrime 32m
WPrime 1024m
Superpi 1m
Max Mem Clock
Bulldozer Overclocking Guide´s
OC TIP's MAINBOARD
Je mehr Spannungswandler ein Mainboard hat, desto stabile hällte es zumeist die Spannung.
Da beim Übertakten oftmals die Spannungswandler sehr warm werden, kann dies zu Instabilität führen. Daher ist es ratsam, sofern ausreichend Platz im Tower ist, die Spannungswandler aktiv zu kühlen.
Weites bringt zumeist auch der Wärmeleitpädtausch gegen ein hochwertiges Wärmeleitpad oder Wärmleitpaste eine bessere Wärmeableitung. Birgt jedoch die Gefahr dass bei falscher Montage ein oder mehrere Spannungswandler nicht gekühlt werden und die Hardware kaputt geht.
Um Spannungsschwankungen zwischen Load und IDL anzupassen und zu minimieren gibt es die LLC (Load Line Calibration) Bei normalem OC für 24/7 Nutzen ist zumeist die goldene Mitte Bzw 50% optimal.
> Mehr Informationen dazu <
> Forumsbeitrag <
OC TIP´S CPU
Bei den FX Prozessoren ist es so dass sich manche Mutil (CPU, HT & NB) Kombinationen besser und andere schlechter miteinander vertragen. Bei Kombinationen die sich gut miteinander vertragen braucht der Prozessor weniger spannung, bleibt kühler und schafft mehr Ramtakt.
Gut vertragen sich gerade CPU Multiplikatoren und derew Halben Multiplikatoren mit geraden CPU-NB & HT Link Multis.
Ebenso vertragen sich ungerade CPU Multiplikatoren und deren Halben gut mit ungerades CPU-NB & HT Link Multis.
Hier ein Screenshot welche sich mit einander gut vetragen. Jeweils GELB und GRÜN gehört zusammen
Hier sowohl als Screenshot bis Reftakt 250 bzw als auch als XLS bis Reftakt 350
AMDFXKalkulator.xlsx
Beim Übertakten empfiehlt es sich Turbo, C3, C6, Cool n' Quiet, Spread Spectrum,.... zu deaktivieren, da er zumeist für mehr Stabilität sorgt
Bei FX CPU´s mit C0 Stepping sind die Coretemps nicht kalibriert. Darum immer nach dem Tempsensor dess Mainboards richten und nicht den Core Temps ==> > Link <
Je kühler, desto besser lassen sie sich Prozessoren takten und desto weniger V-Core und CPU-NB benötigen sie
Je weniger V-CORE und CPU-NB anliegt um so kühler bleiben der Prozessor und besser takten lässt er sich
Wenn der HT Link den selben Takt wie die NB hat, bringt es ein Leistungsplus. Ein hoher HT-Link kann aber auch zu Instabilitäten führen. Ältere Mainboards sind davon äher betroffen als Neuere.
OC TIP´S RAM
Bei der Speicherbestückung sollte man darauf achten gleiche Speicher zu verwenden.
Wichtig dabei ist jedoch nicht dass Aussehen der Speicher, sondern die Chipbestückung.
Im Idealfall sind alle Speicher von der selben Charge. Dennoch kann es je nach Selektion auch bei gleichen Chargen zu Streuungen kommen. Wer also besonderes Gute Ramspeicher haben möchte, sollte sich mehrere von einer Charge kaufen und dann die Riegel einzeln testen und selektieren.
Wenn man nur 2 Speicher Sticks verwendet, sollte man testen ob die Inneren oder Äusseren Ramslots besser funktionieren. Dies kann von Speicherbestückung zu Speicherbestückubg variieren.
Manche Chips laufen auf den Inneren besser und andere auf den Äußeren.
Dass weiteren sollte man die Speicher und Slots auch einzeln testen und den besseren Speicher im schlechteren Slot verbauen bzw den schlechteren Speicher im besseren Slot.
Wenn man 4 Speicher Sticks verwendet, empfiehlt es sich jeden Speicher einzeln zu testen. Weiters auch jeden Slot einzeln zu testen. Danach den besten Ramspeicher in den schlechtesten Slot zu verbauen. Zweitbesten Ramspeicher in den zweitschlechtesten Ramslot Usw.....
Es gibt Single Ranked, Dual Ranked, Quad Ranked,...Ramspeicher.
Je höher der Rank, desto mehr wird dass IMC der CPU belastet und so geringer ist zumeist der Maximaltakt. Daher sind Single Ranked Ramspeicher zu bevorzugen.
Weiters wird dass IMC um so mehr belastet, je mehr Ramspeicher verwendet werden.
Bezüglich IMC Belastung kann man grob sagen dass 2 bzw 4 Single Ranked Ramspeicher ähnlich stark belasten wie 2 Bzw 2 Dual Ranked Ramspeicher
Im RAM Menü kann man zwischen Ganged und Unganged wählen. Bei Ganged profitieren Single Thread Anwendungen und bei Unganged Multithread Anwendung.
Jedoch bleibt die CPU bei Ganged etwas kühler und benötigt auch etwas weniger V-Core!
tRAS = CL + tRCD + tRP
> Link <
Ein gemeinsames Anheben kann Mehrtakt bringen. Manche Ramspeicher skalieren hauptsächlich auf idente Timings wie zB 8-8-8-8-16 oder 9-9-9-24 Bzw 10-10-10-30.
Hingegen andere sehr gut auf zB 8-9-9-23 oder 9-10-10-29 Bzw 10-11-11-32
Wiederum andere mögen 8-9-8-22 oder 9-10-9-25 oder 10-11-10-31
Es gibt jedoch auch noch andre Kombination die die jeweiligen Ramspeicher besonderes mögen
Information dazu findet man zumeist im SPD
Durch Herumprobieren können die Speicher aber teilweise noch besser laufen!
tRC = tRAS+tRP
> Link <
Jedoch je höher der tRC des Ramspeicher ist um so weniger V-Core & CPU-NB benötigt der Prozessor und um so kühler bleibt er und lässt sich besser takten
Write to Read Delay + CAS Lese zu Precharge Zeitspanne = Zeitspanne der Schreibewiederherstellung
> Link <
Ein gemeinsames Anheben kann mehrtakt bringen.
Ein anheben der RAS to RAS Delay kann mehrtakt bringen ==> > Link <
Zeilen Refresh Zyklus 0-3 von den originalen 60 auf bis zu 350ns anheben kann einen höhren Ramtakt ermöglichen.
> Link <
Wichtig ist dabei dass beide Kanäle gleich sind. Wie viele ns für die verwendeten Ramspeicher optimal ist, muss man austesten.
On die Terminierung A & B von den originalen 80 auf bis zu 240 Ohm anheben oder auf 60 herunter setzen kann einen höhren Ramtakt und CPU Takt ermöglichen.
> Link <
Wichtig ist dabei dass beide Kanäle gleich sind. Wie viele Ohm für die verwendeten Ramspeicher optimal ist, muss man austesten.
Max Lese Latenz auf 56 sowie 4 Bank Akt. Fenster auf 32 bringt ein Leistungsplus ==> > Link<
Diese Drive Skew Einstellungen haben sich bei mir als stabil bewiesen ==> Link
Jetzt noch eine Erklärung wie man richtig Ramspeicher mittels Prime Blend Custom teste.
Wichtig ist dies mit einem frischen OS zu machen bei dem möglichst keine Programme im Hintergrund laufen.
Dazu zuerst auf "1" klicken, danach auf "2" und zuletzt unter "3" die zu testende Rammenge in MB eingeben. Diese Rammenge muss so gewählt werden dass nachdem Prime startet im Taskmanager unter "4" noch Ca 3000 MB frei sind. Diesen Test danach mindestens 3-4 Stunden laufen lassen.
1. Deaktivieren: Turbo, C3, Cool n' Quiet, Spread Spectrum, APM,....
2. Neu Booten, da sich die V-Core nach dem Deaktivieren des Turbos ändert
3. AOD starten und kontrollieren ob Grün aktiviert ist und notfalls aktivieren und übernehmen ==> > Link <
4. In AOD kontrollieren ob der Turbo deaktiviert ist und notfalls deaktivieren und übernehmen. ==> Link
5. MIt CPU-Z und AOD kontrollieren ob der Turbo unter Last wirklich dektiviert ist und alle Cores gleich hoch takten
6. Minimale RAM Spannung bei gewünschtem Takt & Timings ausloten (Im Windows undter Load erspart dauernde Biosresets) CPU & NB dabei herunter Takten um die als Fehlerquelle auszuschließen. Mindestens 1 Stunde Prime Custom Blend ist dabei sehr zu Empfehlen. Je länger um so besser. Testspeichermenge dabei so wählen dass gerade nicht ausgelagert wird. Etwas Puffer sollte man allerdings lassen da die Speichernutzung von Windows etwas schwankt. Etwa 3 GB funktionieren im Normalfall als Puffer recht gut. Wer auf Sicherheit bedacht ist macht 24h.
7. Minimale CPU NB Spannung bei gewünschtem Takt ausloten. CPU & RAM dabei herunter Takten um die als Fehlerquelle auszuschließen. Prime Large über mindestens 3-4 Stunden. Wer auf Sicherheit bedacht ist macht 24h.
8. Minale V-Core testen. CPU NB und RAM dabei herunter Takten und es als Fehlerquelle auszuschließen. Prime Large über mindestens 3-4 Stunden. Wer auf Sicherheit bedacht ist macht 24h.
9. CPU NB zusammen mit dem RAM testen. CPU heruntertakten und sie als Fehlerquelle auszuschließen.
Jetzt kann es unter Last zu Einbrüchen der der Spannung kommen und man muss bei Bedarf nachjustieren. (Takt und/oder Spannung) Prime Large über mindestens 3-4 Stunden. Wer auf Sicherheit bedacht ist macht 24h.
10. CPU zusammen mit dem RAM testen. CPU NB heruntertakten um sie als Fehlerquelle auszuschließen
Jetzt kann es unter Last zu Einbrüchen der Spannung kommen und man muss bei Bedarf nachjustieren. (Takt und/oder Spannung) Prime Large über mindestens 3-4 Stunden. Wer auf Sicherheit bedacht ist macht 24h.
11. CPU Zusammen mit der CPU NB testen. RAM dabei heruntertakten um ihn als Fehlerquelle auszuschließen. Jetzt kann es unter Last zu Einbrüchen der Spannung kommen und man muss bei Bedarf nachjustieren. (Takt und/oder Spannung) Weiters kann es hier zu Temperaturproblemen kommen da CPU & NB zusammen eine erhöhte Temperatur als einzeln erzeugt. Prime Large über mindestens 3-4 Stunden. Wer auf Sicherheit bedacht ist macht 24h.
12. Alles zusammen testen. Jetzt kann es abermals unter Last zu Einbrüchen der Spannungen kommen und man muss bei Bedarf nachjustieren. (Takt und/oder Spannung) Prime Large über mindestens 3-4 Stunden. Wer auf Sicherheit bedacht ist macht 24h.
Nützliche Programme
CPU schleifenAMD Overdrive (AMD Auslese und Einstellungs Tool ==> > Link <
SIW (Auslesesoftware) ==> > Link <
Everest (Auslesesoftware) ==> > Link <
HWinfo (Auslesesoftware) ==> > Link <
SIV (Auslesesoftware + Stabilitätstest) ==> > Link <
CPU-Z (Auslesen von Taktraten) ==> > Link <
HWMonitor (Auslesesoftware) ==> > Link <
Aida64 (Auslesesoftware) ==> > Link <
Coretemp (Auslesesoftware) ==> > Link <
TMonitor (Liest Taktraten in Echtzeit aus) ==> > Link <
Prime95 (Stabilitätstest) ==> > Link <
LinX (Stabilitätstest) ==> > Link <
y-cruncher (Stabilitätstest) ==> > Link <
BurnInTest (Stabilitätstest) ==> > Link <
Intel Burn Test (Stabilitätstest) ==> > Link <
OCCT (Stabilitätstest) ==> > Link <
Core Demage (Stabilitätstest) ==> > Link <
Memtest (RAM Stabilitätstest) ==> > Link <
Testmem 5 (RAM Stabilitätstest) ==> > Link <
S & M (RAM Stabilitätstest) ==> > Link <
RAMMon (RAM Auslesesoftware) ==> > Link <
Thaiphoon Burner (RAM Auslesesoftware) ==> > Link <
ROG Mem Tweak It (RAM Timings & Sub) ==> > Link <
Realbench (Benchmark) > Link <
WPrime (Benchmark) > Link <
Cinebench (Benchmark) > Link <
SuperPiMod (Benchmark) > Link <
Nuclearus (Benchmark + Stabilitätstest) ==> > Link <
Bildschutz Pro (Bildsignatur) > Link <
Stilt Bulldozer Conditioner (Tuning Tool für SuperPI und mehr) ==> > Link <
Amdmsrtweaker (Softwarelösung zum Aktivieren / Deaktivieren von APM und Turbo sowie Konfigurieren der P Stats
Deaktivieren von APM: Eine TXT mit dem Inhalt "AmdMsrTweaker.exe turbo=0 APM=0" und dem Namen APM.bat erstellen und als .bat sprichern und starten. Damit es reibungslos funktioniert sollte AOD jedoch deinstallieren werden da es ansonsten zu Komplikationen kommt.
Konfigurieren der P Stats:> Link <
Amdmrstweaker kann man auch dem Autostart hinzufügen > Link <
Zuerst den Prozessor in den beiliegenden Schaumgummi drücken, damit sich die Pins nicht so leicht verbiegen.
Danach mit Nassschleifpapier mit flächigem Druck auf den Schaumgummi kreuzweise auf einer Glaspaltte schleifen (Handballen)
Wer sich Zeit ersparen möchte, kann am Beginn ein Gröberes in der Stärke 500-600 verwenden
Für den Endschliff empfehle ich 1000-1500
Nach dem Schleifen den Schaumgummi enfernen und mit einer Kreditkarte prüfen ob alle Pins gerade sind
Falls Pin´s verbogen sind, so kann man diese mit der Kreditkarte vorsichtig gerade biegen
Sollte noch Feuchtigkeit auf der CPU oder den Pins sein, entweder trockenen lassen oder einen Föhn zur Hilfe nehmen
Hier Fotos von einer CPU, welche ich vor längerer Zeit geschliffen habe
Hier noch ein weiterer sehr guter Thred bezüglich HS schleifen incl Testergebnisse
Lapped my FX-8350, 4.3GHz OC'ed temps lowered by 9°C - AnandTech Forums
