hallo...
hab grad ne mail an abit gschrieben, weil mein x48 kein 400mhz fsb mehr packt.
da kam die nachricht vom support:
Dear Sir,
The motherboard only supports fsb 1333 processor so when you are using the 400FSb you are overclocking your system the fsb for a 1333FSB cpu should be 333 instead of 400fsb. Since overclocking is at your own risk and values cannot be garantueed this is not a warranty case.
Please use the motherboard within its specifications.
Specifications
CPU Designed for Intel® socket 775 processors with 1333/1066 MHz FSB
Support Intel® Core 2 Extreme & Core(tm) 2 Quad & Core(tm) 2 Duo & Pentium® Dual Core & Celeron® Dual Core
Chipset Intel® X48 Express/ICH9R
Memory 4 X 240-pin DIMM sockets support max. memory capacity 8GB
Supports Dual channel DDR3 1333/ 800/667 Un-buffered Non-ECC memory
LAN On board PCI Gigabit LAN controller supports 10/100/1000M Ethernet
Audio On board 7.1 CH Dolby/DTS HD Audio CODEC
Supports optical S/PDIF In/Out
HDMI Audio ready header
Expansion Slots 2 x PCI-E X16, 1 x PCI-E X16 (X4 bandwidth), 1 x PCI-E X1, 2 x PCI
Internal I/O 1 x Floppy Port supports up to 2.88 MB
1 x ATA 133/100/66 IDE connector
6 x SATA 3Gb/s connector
1 x IEEE1394, 4 x USB header (support 8 ports)
1 x FP-Audio
Back Panel I/O 1 x PS/2 Keyboard, 1 x PS/2 Mouse
abit OTES(tm)
1 x S/P DIF In, 1 x S/P DIF Out, 2 x eSATA
7.1 CH Audio connector (Front, Line-in, MIC-in, Center/Subwoofer, Surround, Rear Surround)
4 x USB 2.0, 1 x 1394, 1 x RJ-45 LAN connector
Clear CMOS Button
Serial ATA 6 x SATA 3Gb/s offer by Intel® ICH9R support Intel® Matrix Storage Tech(AHCI & RAID0/1/5/10) Command Based Port Multiplier
2 x SATA 3Gb/s offer by JMicron® JMB363 support up to 0,1JBOD RAID function
IEEE 1394 PCI controller supports 2 Ports IEEE 1394
Form Factor ATX form factor 305 x 245mm
PCB Color: Black
RoHS 100% lead-free process and RoHS compliant
abit Engineered abit µGuru(tm) Technology
abit OTES(tm) Technology
100% Low ESR solid capacitor
Back Blue LED
Quick Power/Reset button
Digital PWM
EZ CCMOS Button
R-angle SATA connector
Danke. / Thank You / Bedankt.
please reply with former messages included,
Bitte Antworten sie mit vollem Inhalt vorheriger Nachrichten,
Met vriendelijke groet,
Mit freundlichen Grüßen,
Best Regards,
Jos Mommersteeg
Technical Support Europe.
Jan van Riebeeckweg 15, 5928 LG, Venlo, The Netherlands
Tel. +31 (0) 77 320 44 28 / Fax. +31 (0) 77 320 44 20
http://www.abit.nl/
Diese E-Mail enthält vertrauliche und/oder rechtlich geschützte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den Absender und vernichten Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and destroy this e-mail. Any unauthorised copying, disclosure or distribution of the material in this e-mail is strictly forbidden.
-----Original Message-----
avo92@web.de]
Sent: woensdag 8 april 2009 15:32
To: Technical Support NL
Subject: Ix48gt3 motherboard
Hello. I bought a abit ix48gt3 motherboard at the 19. October 2008. Now i realised that the board dont work at the specification it normally should do. The board doesnt start if the front side bus iS 400mhz. So i think the board should be repaired. I am sorry because of my bad english. Yours sincerly
nicht über mein scheiß englisch wundern, bin schüler^^
und da kamen noch 7 solche nachrichtn, wo sie immer behaupten , dass der qx9770 nicht supportet wird...
was soll ich tun???
mgfg und thx
Dear Sir,
Specifications
1 x FP-Audio
abit OTES(tm)
Clear CMOS Button
PCB Color: Black
Back Blue LED
Digital PWM
EZ CCMOS Button
Best Regards,
Jos Mommersteeg
http://www.abit.nl/
avo92@web.de] Sent: woensdag 8 april 2009 15:32
was soll ich tun???
mgfg und thx
