9900K-second time not launched full amount memory - instability detected.
sew333
Banned
Hi. I have 9900K to 5ghz on 1.310V. I run REALBENCH with full amount memory 32GB RAM for 2 hours. It passed.But when i clicked run again just before test start ,said" Instability Detected". I check event log and it said something about memory pagefile etc.
So should i worry about that one fluke? It passed before 2 hours,but next click it crashed with this.
Ram is 2x16 GSKILL 3000MHZ XMP
mb Asus Prime Z390-A
Noctua NH-D15 on 9900K temps are 80-90+- max peaks in realbench
Hi sew333
A Question: Did You to check the "QVL"-List from your G.Skill-RAM's on the Webside from G.Skill of compatiblity from your Mainboard?
I ask you, because G.Skill did to have a "QVL"-List with tested compatiblity mainboard's from your RAM-Kit ;)
The G.Skill-XMP-Profile can work, but it doesn't to must, because you have OverClocking-RAM (Standart is 2133MHz) ;)
