9500 Pro unlock?
frequence
Hi Leutz
Hat jemand einen link zu nem Guide wie ich eine 9500 Pro unlocke um sie takten bzw flashen zu können. Google und Forumsuche war mir keine hilfe.
danke schonmal
freq
Du brauchst bloss den ATI-Softmod Treiber zu installieren.
http://www.techpowerup.com/softmod/downloads.php
Hier ist die Anleitung, aber leider bloss Englisch:
You don't need to flash another BIOS.
Download the latest version of "Softmodded Display Driver" from the downloads page.
Run it.
Follow the instructions on screen (ATI Display Drivers Setup should start after extraction).
If you are prompted about a component that did not pass the Windows Logo Test, continue the installation. Windows just notified you that you are installing a patched file :)
Finish
Download and install "Control Panel" if you haven't done so yet.
If you have an All-In-Wonder card, download and install the "WDM Capture Driver". You may also want to install the latest version of ATI's Multimedia Center.
Reboot
Use ATITool to check the number of active pipelines (settings -> overclocking).
OR (if you already have the driver package and just want to download the patched driver file)
Run the driver installer and update your display drivers. Verify that the (still unmodified) driver works at this point.
Download the version of "Patched ati2mtag.sys" from the downloads page which matches the driver version you want to install.
Extract the "Patched ati2mtag.sys" zip file you just downloaded into an existing folder with a name similar to "2KXP_INF\B_xxxx" where the driver installer extracted the files to.
Delete the "ati2mtag.sy_" file there.
In Device Manager right-click on "Radeon 9700/9500 SERIES" or "All-In-Wonder 9800 Series"...
Update Driver...
Install from a list... (2nd option)
Don't search. I will choose the driver... (4th option)
Click "Have Disk" and navigate to the "2KXP_INF" driver directory...
Select the appropriate driver. If you have duplicate entries- choose any it does not matter.
Click "Finish", then reboot
Q: Will this work with a 9000/9200/9500 Pro/9600/9700 card?
A: Nope. Those can't be turned into anything better but you can still overclock them.
es gibt ein hardmod damit man die karte flashen kann. finde die seite aber nicht mehr mit der anleitung.
wenn ich mich nicht irre wahren früher nur die 9500 non-Pro modbar! Die 9500Pro kannst du nurnoch takten!!!
Freischalten auf 9700 ist nicht!
Mfg Stephan
der bios ist locked bei der 9500pro aber mit etwas silberleitlack konnte man ihn freischalten und flashen und genau danach suche ich.
@ frequence
dachte, die 9500 Pro hat auch n Bios Lock drin, damit man nicht übertakten kann. Ich kann bei meiner nicht mal 10 Mhz hoch, schon freezt das Ding :)
Gruss
oc ist kein problem per atitool aber ist halt nicht flashbar. nur wenn man brücken schließt.
ne, die 9500 pro war def. nicht freischaltbar, weil die, soweit ich mich erinnere ja schon 8 pipes hatte
nur war sie niedriger getaktet und hatte nur ein 128bit interface
wobei manche noch nen lock hatte, dass man sie net übertakten konnte
(geht aber mit den driver-mod weg)
