V
vr6freunde
Guest
Ich benutze XP 64 Bit. Ich finde die reg sachen nicht in meiner reg-datei. Index Dienst ist bei mir Automatisch OFF.
...denke in ca.1 jahr ist es mit den ssds viel besser und vor allen dingen billiger!
ssd 64gig 200€..velo.rap.300gig auch 200€Hast Du die Core an einem Controller(mit Cache)? Oder hast Du den OnBoard Controller nur mit Raid laufen.
An welchem Chipsatz hängen deine Platten?
Ich habe HDD und SSD an einem Controller, also mischbetrieb
die OCZ hängt alleine am Chipsatz-Controller (ICH9R). DAS SSD-Raid an einem Areca1210.
BTW .. bei mir ist die Performance vom Areca in den Keller gerutscht wenn ich da Mischbetrieb gefahren bin.
Es haben alle hier im Forum das Problem bei Mischbetrieb am Areca. Wer weiß wo es da hängt.![]()
jo alle ports hab ich durchgecheckt, werden auch angezeigt im menü..
XP-Pro loaded back on just fine. Am doing SP3 now and its progressing ok. The drive seems to be working as it was the first time around. I guess I suffered from the same data corruption problem everyone else has experienced. I also noticed that Tiger Direct anmd NewEgg have pulled the Core stuff off their web sites. And Amazon is the only place saying they actually have them at this time. After seeing them disappear from the sellers web sites I'm assumming there are big problems and that this drive will just become corrupt agin in a short time... so whats up guys? Should I return this thing and to whom?
Thanks,
Mark
I thought the mountain of problems reported here are only minor incidences and only caused by the incompatible controller. Man I was wrong.
My AMD machine has the same problem other people faced. Two days after I got the driver and installed Vista, it started to have disk corruptions. Also the whole system freezes when virus scan is in progress. I've disabled write cache and had Vista SP 1 installed, and moved the temporary files, user folder and browser cache to a different drive to reduce the disk writes. And I still get the same disk corruptions.
I begin to think this is either a firmware problem, or a design flaw. And I don't think RMA the drive would help. Also the retailer of the drive does not allow return on the drive. I would suggest OCZ stops selling the drive before someone stands up and files a law suit.
Haben die Core´s die gleiche Größe(Kapazität). Mal die Core einzel getestet?
les bitte meine ersten post nochma durch...
meine gehe auch zurück
Hinzugefügter Post:
habe ich gelesen. Ich meine aber es kann ja schon eine defekt sein.
Benutzt bitte die Suchfunktion. Dieses Thema gibt es X mal.
