[Sammelthread] DFI LANparty DK 790FXB-M2RS / -M2RSH / -M3H5 / 790GX-M2RS (AMD 790FX / 790GX)
lord86
Bienchen, Graue Eminenz
Da wo es kein Sleeve gibt
Sammelthread
Inhaltsverzeichniss:
top
AM2+
AM3
Anhang:
AM2+
AM3
Vorwort:
Da die Boards nahezu identisch ausgestattet sind habe ich nur die Details zusammengefasst, die sich von den anderen unterscheiden. Die Features die fehlen, kann man vom M2RSH übernehmen.
Nun gehts also los mit dem Sammelthread der DFI Lanparty DK series:
AM2+:
790FXB
DFI Lanparty DK 790FXB-M2RS
I. Technische Details zum Board:
CPU:
  • AMD Phenom / Athlon 64 X2 / Athlon 64 FX / Athlon 64
  • Socket 940 AM2 65nm
Chipset:
  • Northbridge: AMD 790FX
  • Southbridge: AMD SB750
System Memory:
  • Four 240-pin DDR2 DIMM sockets
  • Supports DDR2 667 and DDR2 800 DIMMs
  • Supports dual channel (128-bit wide) memory interface
  • Supports up to 8GB system memory
  • Supports unbuffered non-ECC x8 and x16 DIMMs
Expansion Slots:
  • 3 PCI Express (Gen 2) x16 slots
    - 2-way or 4-way CrossFire at x16/x16/NC bandwidth
    - 3-way CrossFire at x16/x8/x8 bandwidth
    - 2-way CrossFire + Physics at x16/x8/x8 bandwidth
  • 3 PCI slots
BIOS:
  • Award BIOS
  • CMOS Reloaded
  • CPU/DRAM overclocking
  • CPU/DRAM/Chipset overvoltage
  • 8Mbit flash memory
Audio:
  • Realtek ALC885 8-channel HD Audio Codec
  • High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight)
LAN:
  • Marvell 88E8053 PCIE Gigabit LAN controller
  • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
Power Management:
  • ACPI and OS Directed Power Management
  • ACPI STR (Suspend to RAM) function
  • Wake-On-PS/2 Keyboard/Mouse
  • Wake-On-USB Keyboard/Mouse
  • Wake-On-Ring
  • Wake-On-LAN
  • RTC timer to power-on the system
  • AC power failure recovery
Hardware Monitor:
  • Monitors CPU/system/chipset temperature
  • Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
  • Monitors the speed of the cooling fans
  • CPU Overheat Protection function monitors CPU temperature during system boot-up
IDE:
  • One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
Serial ATA with RAID:
  • Supports up to 6 SATA devices
  • SATA speed up to 3Gb/s
  • RAID 0, RAID 1 and RAID 0+1
Rear Panel I/O:
  • 1 mini-DIN-6 PS/2 mouse port
  • 1 mini-DIN-6 PS/2 keyboard port
  • 1 optical S/PDIF-out port
  • 1 coaxial RCA S/PDIF-out port
  • 6 USB 2.0/1.1 ports
  • 1 RJ45 LAN port
  • Center/subwoofer, rear R/L and side R/L jacks
  • Line-in, line-out (front R/L) and mic-in jacks
Internal I/O:
  • 2 connectors for 4 additional external USB 2.0 ports
  • 1 connector for an external COM port
  • 1 front audio connector
  • 1 CD-in connector
  • 1 IrDA connector
  • 1 CIR connector
  • 4 Serial ATA connectors
  • 1 40-pin IDE connector
  • 1 floppy connector
  • 1 24-pin ATX power connector
  • 1 8-pin 12V power connector
  • 2 4-pin 5V/12V power connectors (FDD type)
  • 1 front panel connector
  • 6 fan connectors
  • EZ touch switches (power switch and reset switch)
PCB:
  • ATX form factor
  • 24.5cm (9.64") x 30.5cm (12")
II. Layout:
III. Reviews:
http://www.ur-hardware.com/mainboard/40-review-dfi-lanparty-dk-790fx
IV. Links:
Herstellerseite: http://www.dfi.com.tw:8080/portal/C...ormal&mode=view&downloadFlag=false&itemId=539
Treiber: http://www.dfi.com.tw:8080/portal/C...normal&mode=view&downloadFlag=true&itemId=539
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a383889.html
M2RSH
DFI Lanparty DK 790FX-M2RSH
CPU:
  • AMD® AM2+ processors: Phenom FX / Phenom / Athlon / Sempron
  • HyperTransport 3.0 (5200MT/s for AM2+)
  • AMD OverDrive provides tuning options using the new“Advanced Clock Calibration” overclocking feature.
  • Socket 940 AM2+ 65nm
Chipset:
System Memory:
  • Supports DDR2 667/800/1066 MHz DIMMs
Expansion Slots:
  • 3 PCI slots
II. Layout:
III. Reviews:
http://www.modreactor.com/english/R...XB-M2RSH-AMD-LanParty-Motherboard-Review.html
http://www.overclock.net/amd-motherboards/399854-smt-review-dfi-lanparty-790fxb-m2rsh.html
IV. Links:
Herstellerseite: http://www.dfi.com.tw:8080/portal/C...g=false&action=e&windowstate=normal&mode=view
Treiber: http://www.dfi.com.tw:8080/portal/CM/cmproduct/XX_cmproddetail/XX_WbProdsWindow?action=e&downloadType=driverTab&windowstate=normal&mode=view&downloadFlag=true&itemId=547
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a383891.html
790GX
DFI Lanparty DK 790GX-M2RS
CPU:
Chipset:
  • Northbridge: AMD 790GX (RS780)
Expansion Slots:
  • 2 PCI Express (Gen 2) x16 slots
    - Hybrid CrossFireX - combination of the integrated graphics and a discretegraphics card in a PCIE slot (8-lane port).
    - Two graphics cards support CrossFireX; each operating at x8 (8-lane ports)bandwidth
  • 1 PCI Express x1 slot
  • 3 PCI slots
Graphics:
  • Integrated ATI Radeon HD 3300 graphics core
  • One DVI-I connector for digital LCD display (ACHTUNG!! DVI Anschluss nur als Pin-Connector ausgeführt)
  • Microsoft® DirectX 10
  • Hybrid CrossFireX technology combines the onboard GPU and adiscrete PCIE graphics card
  • Onboard Performance cache for added performance
II. Layout:
III. Reviews:
http://www.madshrimps.be/?action=getarticle&articID=894
IV. Links:
Link zum "DVI-Problem": http://www.csd.dficlub.org/forum/showthread.php?t=8221
Treiber: http://www.dfi.com.tw:8080/portal/C...g=false&action=e&windowstate=normal&mode=view
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a356442.html
hex
Anhang:
Für erweiterte Optionen im BIOS F9 drücken!
Achtung an alle Extrem-OC´er: das Board zeigt nur maximal -83°C an !
Hexcode Tabellen Für CPU-NB-VID und NB-Multi(790FXBM2RS/H):
tabelle
Vergleich zwischen den Boards:
kühler
Kompatible Kühler:
790FXB-M2RS(H):
passt:
Cooler Master Hyper TX (bläst nach hinten)
EKL Alenföhn Groß Clock'ner Blue Edition (bläst nach hinten)
EKL Alpenföhn Brocken (bläßt nach oben)
Scythe Infinity/Mugen (bläst nach oben)
Thermaltake GunMetal Orb (bläst nach unten)
OCZ Vanquisher (bläst nach oben)
Xigmatek HDT-S1283 (bläst nach oben)
Zalman CNPS 9500AM2 (nach hinten)
passt mit Modifikationen:
passt nicht:
790GX-M2RS:
passt:
passt nicht:
passende Wasserkühler für NB/SB und Spawa´s gibt es bei Anfi-tec oder Watercool
Lochabstände vom NB-kühler, Danke an Andreoid von Anfi-tec :bigok:
ram
RAM Kompatibilitätsliste:
790FX-M2RS/H:
läuft:
Cellshock 2x 1GB DDR2-667 (CS2110650)
GeIL DIMM 4 GB kit DDR2-800 (GX24GB6400C4UDC)
G.Skill Pi Series 4GB DDR2 1100 (F2-8800CL5D-4GBPI)
G.Skill 4GB kit DDR-1000 (F2-8000CL5D-4GBPQ)
Kingston HyperX 4GB kit DDR-1066 (KHX8500D2K2/4G)
Mushkin 4GB kit DDR-1066 (996599)
OCZ Platinum XTC 4GB kit DDR-800 (OCZ2P10004GK)
OCZ Titanium 4GB kit DDR-1150 (OCZ2T11504GK)
OCZ Reaper HPC Edition 2GB kit DDR2-800 (OCZ2RPR800C32GK)
OCZ Reaper HPC Edition 2GB kit DDR2-800 (OCZ2RPR800EB2GK)
OCZ Reaper HPC 2x2GB kit DDR2-1066 (OCZ2RPR10662G), (Tony´s SPD)
OCZ XTC Platinum 2 GB kit DDR2-1066 (OCZ2N10662GK)
macht Probleme:
läuft nicht:
Vollbestückung:
4GB
2x1GB OCZ Reaper (OCZ2RPR800C32GK) + 2x1GB OCZ Reaper (OCZ2RPR800EB2GK)
DDR800 | CL4-4-4-12 | Vdimm 2,0V
4x1GB Aenon Xtune DDR1066 | CL5-5-5-15 | Vdimm 1,85V
6GB
2x2GB Geil Ultra Plus (GX24GB6400C4UDC) + 2x1GB Cellshock
DDR800 | CL4-4-4-10 | Vdimm 1,85V
8GB
4x2GB G.Skill Pi Series (F2-8800CL5D-4GBPI) | DDR800 | CL5-5-5-18 | Vdimm 1,9V
2x4GB kit Mushkin XP2-8000 (996591) | DDR1000 | CL5-5-5-15 | Vdimm 2,1V
2x4GB kit
Mushkin DDR-1066 (996599) | DDR1066 | CL5-5-5-15 | Vdimm 2,05V
790GX-M2RS:
läuft:
Aeneon Xtune DIMM 2 GB DDR2-1066 Kit (AXT760UD00-19DM97-K-2G)
macht Probleme:
OCZ Reaper HPC 2 GB DDR2-1066 Kit (OCZ2RPR10662GK); (abstürtze mit 1066Mhz)
läuft nicht:
Vollbestückung:
4GB
6GB
8GB
Tipps für 8GB RAM bei 1066Mhz *klick*
AM3:
m3h5
DFI Lanparty DK 790FXB-M3H5
CPU:
  • AMD Phenom II processor
  • HyperTransport 3.0 (5200MT/s), HyperTransport 1.0 (2000/1600MT/s)
  • AMD OverDrive provides tuning options using the new "Advanced Clock Calibration" overclocking feature.
  • Socket 938 AM3 45nm
Chipset:
System Memory:
  • Four 240-pin DDR3 DIMM sockets
  • Supports DDR3 1600 (O.C.)/1333/1066Mhz
  • Supports non-ECC unbuffered DIMMs
  • Supports up to 16GB system memory
Expansion Slots:
  • 3 PCI Express (Gen 2) x16 slots - 2-way crossfire at x16/x16 or x16/x4 bandwith - 3-way crossfire at x16/x16/x4 bandwith
  • 3 PCI-Slots
BIOS:
  • Award BIOS
  • CMOS Reloaded
  • CPU/DRAM Overclocking
  • CPU/DRAM/Chipset Overvolting
  • 8Mbit SPI Flash Memory
Audio:
Lan:
  • Marvell 88E8056 PCIE Gigabit LAN controller
  • SATA speed up to 3GB/s
  • RAID 0, RAID 1, RAID 0+1 and RAID 5
IDE:
  • One IDE connector allows up to two UltraDMA 133Mbps hard drives
Rear Panel I/O Ports:
  • 1 RJ45 LAN port
  • line-in, line-out (front R/L) and mic-in jacks
I/O Connectors:
  • 3 connectors for 6 additional external USB 2.0 ports
  • 1 CD-in connector
  • 1 IrDA connector
  • 1 CIR connector
  • 6 Serial-ATA connectors
  • 6 fan connectors
  • 1 diagnostic LED
  • EZ touch switches (power and reset switch)
Power Management:
  • ACPI STR (Suspend to RAM) funktion
  • Wake-On-Ring
  • Wake-On-LAN
Hardware Monitor:
  • Monitors 12V/5V/3,3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
  • CPU Over Heat Protection function monitors CPU temperature during system boot-up
PCB:
  • ATX form factor
  • 24,5cm (9,64") x 30,5cm (12")
II. Layout:
III. Reviews:
User-Review von Öse:
http://www.hardwareluxx.de/community/showpost.php?p=11771090&postcount=1
http://www.ninjalane.com/reviews/motherboards/lanpartydk-790fxb-m3h5
IV: Links:
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a417781.html
kühler
Anhang:
Kompatible Kühler:
Die Sockelhalterung entspricht exakt der AM2(+) version, daher passen alle Kühler die auch mit dem M2RS(H) kompatibel sind.
Passende Wasserkühler:
Das Boardlayout entspricht ebenfalls dem des M2RSH, daher passen alle Wasserkühler die auch mit dem 790FXB-M2RS(H) verwendet werden können.
Soweit ganz ok das Board wie ich finde.
Vor allem endlich mal meiner Meinung gutes Layout, auch von der Aufteilung der Steckplätze.
Kann man gut 3 Grafikkarten verbauen!
ABER:
Supports up to 4 SATA devices
Das sind mir 2 zu wenig. Hängt mit der SB 600 zusammen klar, aber ich brauche mind. 5. Daher etwas schade.
Was mich wundert ist die Kühlung, entweder die Kühler reichen wirklich, oder DFI hat vertrauen in die Hardware. Finde beide sehr klein Dimensioniert.
mfg.TK
gerade weil es so schlicht gehalten ist gefällt es mir so gut, ich finde die ganzen heatpipe konstruktionen teilweise ziemlich übertrieben, außerdem kommt bei mir sowieso wakü drauf ;)
Ja das stimmt schon, dachte nur gerade an die Luftkühler unter uns, die nicht ersteinmal das Board zerlegen um Wakü oder die Thermalright usw. draufzu bauen.
Was mir auffällt:
Hat DFI einen Steckplatz nicht belegt? Und zwar den zwischen ersten PCIe und ersten PCI Steckplatz? Könnte da nicht noch einer hin?
habe ne kleine tabelle mit den unterschieden zwischen dem M2RS und dem großen bruder beigefügt, wem noch ein unterschied einfällt kann ihn hier posten und ich werde es bei gelegenheit einfügen
So langsam könnte das Board bei uns mal verfügbar werden. In Asien haben es schon einige und bei Newsegg kann mans auch schon bestellen...
Schreibe gerade mit HPM-Computer, die können das Board bei DFI bestellen, sind sich aber nicht sicher ob das Board "genug" Abnehmer findet. Preis soll zwischen 115 und 120 Euro liegen.
/edit: der Vorschlag wird an den Einkauf von HPM weitergeleitet. Hoffen wir mal, dass es klappt :)
die sind schon lustig, aber das M2-R, was gute 60€ teurer ist haben sie da
edit:
ich hab mal ne email an den support geschrieben, vielleicht bekomm ich ja ne antwort
Das M2RS kam ja auch erst später raus. Und ich kann mir denken, dass das M2R schon nicht in Massen gekauft wurde, da der Phenom im B2 Stepping ja nicht allzu attraktiv war.
Hoffen wir mal, dass das Board nun ins Sortiment aufgenommen wird. Asus und Co werde ich mir nämlich nicht holen.
ein asus will ich auch nicht unbedingt, obwohl das am2+ von denen nicht schlecht sein soll. das M2RS ist ja schon im februar offiziell vorgestellt worden, also sollte es schon langsam mal auf den markt kommen
Naja, auf dem Markt ist es ja, aber ich denke mal, dass die Shops mit den AM2+ Boards bis jetzt wenig Umsatz gemacht haben (im Vergleich zu den 775 Boards). Also geht man an neue Boards auch sicher vorsichtiger ran.
Habe aber HPM geschrieben, dass hier im Luxx sicher einige Leute Interesse an dem DFI haben werden, da es sicher eine gute Alternative zu Asus und GB ist.
Also hoffen wir das HPM das M2RS ins Sortiment aufnimmt :)
Zum Asus - ja was man so hört scheints echt nicht so schlecht zu sein, aber der Support von Asus ist ein schlechter Witz. Solange man ohne RMA auskommt würde ich die Boards auch nehmen, aber wenn mal was ist... Nee nee, da warte ich lieber auf ne Alternative.
/edit: lord an den DFI Support?
Hast du schon ne Antwort?
Haben will! ^^
Man könnte ja mal hier eine Sammelbestellung machen und dann höflich bei nem Online Shop nachfragen ob die es in der Menge bestellen. :)
Mein Abit AX78 ist leider nicht so der Knaller iwie.
Hatte schon Probs mit meinen Cellshock RAMs und mit den OCZ die angeblich drauf laufen sollen muckts auch nur rum wenn ich die versprochenen 4-4-4-15
einstelle. -.-
Michael
@ Sonny C.
hat sich hpm compter schon bei dir gemeldet? ich habe immer noch keine antwort vom dfi support und da wird wohl auch nix mehr kommen...
Nein, habe bis jetzt auch nichts mehr von HPM gehört...
Bald lohnt das Board auch nicht mehr, wenn dann die SB750 Boards kommen.
Hoffe auch, dass es hier in Deutschland erscheinen wird.
Beim P35 DK war es auch erst fraglich, ob sie in DT kommen.
Ich schreibe mal HPM und Trend4PC an.
Hm, von HPM hab ich nichts mehr gehört. Scheinen wohl eher kein Interesse daran zu haben es ins Sortiment aufzunehmen.
wenn es in 2-3 monaten noch nicht verfügbar ist hol ich´s mir direkt aus den usa, kann ja wohl nicht sein dass es hier kein händler auf die bahn bringt
HPM:
Hallo Herr Stangel,
wir können das Board bei DFI bestellen. Noch ziert sich unser Einkauf aber, da die Nachfrage nach AMD Boards von DFI nicht allzu groß ist. Ich werde das aber mal anfragen und auf ein größeres Kundeninteresse hinweisen.
Mit freundlichen Grüßen
HPM-Computer
Trend4PC:
Guten Morgen,
noch taucht das Board nicht auf der Liste von DFI EU auf, kann sich aber mit der nächsten Liste schon ändern (die kommt am 23.05.08). "Geplant" war das Board nicht für die EU, aber wie beim P35DK kann sich das ja schnell Ändern.
Antwort von denen :)
das wäre extremst scheisse wenn es nicht auf den deutschen markt kommt, aber wenn hpm es besorgen kann isses ja nicht ganz so übel. btw hab ich immer noch keine antwort vom dfi support erhalten, da wird wohl auch nix mehr kommen
Ich habs ja gesagt :fresse:
Alle an HPM noch ne Mail schreiben :bigok:
Wobei, wann sollen denn die SB7x0 Boards kommen?
also wirklich viele vorteile hat die sb750 nicht gegenüber der sb700, nen par raid funktionen mehr und nen integrierter taktgeber anstatt eines externen. aber wer von uns verwendet schon raid? ich nicht, und der externe taktgeber stört mich auch nicht wirklich. wenn noch nen par leute an hpm schreiben nehmen sie das board bestimmt bald ins programm auf :d
hab ein bild frisch von der computex, wird das der nachfolger unseres sehnsüchtig erwarteten m2rs und wird es wohl diesmal bei uns erhältlich sein? fragen über fragen...
Das Board wird ab Ende des Monats erhältlich sein (Zitat: 'Die 790FX-Serie ist laut DFI für den Monat Juli angekündigt. Preislich wird das Board (abhängig vom Dollar) zwischen 115 und 120 EUR liegen.') - Ich hatte bei HPM deswegen per E-Mail nachgefragt.
Es ist inzwischen auch bei mehreren Händlern gelistet. :banana:
wie nice, die boards kommen genau richtig, hab gerade heute meine neue arbeitsstelle angetreten nach dem zivi :d btw. steht das m2-rs schon bei hpm in der liste http://www.hpm-computer.de/product_info.php?info=p8891_DFI-LANparty-DK-790FX-M2RS.html
nur welche version nimmt man dann, mittlerweile sind 4 dfi´s gelistet bei alternate, wobei mir das 790FXB-M2RS atm am besten gefällt, ich glaub ich erweitere mal meinen sammelthread um die komplette DK serie wenn es mehr infos gibt
/edit
mini update für post #1
hab gestern schonmal bilder angehängt aber die spärlichen infos die darauf zu erkennen sind kann jeder selber ablesen ;) wenn es mehr gibt werde ich die erste seite updaten. ich freu mich schon tierisch auf das 790FXB, das wird wohl mein board und wenn der preis bei alternate stimmt, wird es nichtmal so teuer
