[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
...schade, dass es mit dem Foxconn Forum nicht klappt. Wollte dort mal wegen einer Kühlerliste schauen.
Aber wahrscheinlich haben die Meisten sowieso Wasser drauf.
jup ich z.B^^
ich mach feierabend mäddels geh boarden bis mogen in ner woche
servus!
Ömm also ich weiß net, was ihr habt, Quantum-Force funzt bei mir ohne Probs.
Aber sone Kühlerliste wär echt ma was feines....mein IFX-14 passt ja auch nru haarscharf...
Oder wollen wir mal für die erste Seite ne kleine Kompatiblitätsliste anfangen?
IFX-14 passt also schonmal mit leichten Veränderungen. ;)
Hast du die NB verbogen oder den Kühler abgesägt? :haha:
Spaß beiseite: Das Mars wäre mit dem IFX-14 wirklich extraklasse.
Könntest du vielleicht eine kleine Beschreibung incl. Foto posten?
Wenn das ohne Probleme passt und auch noch gut aussieht, habe ich meine Komponenten gefunden.
Kann morgen mal Fotos von schießen.
Das einzige, was ich machen musste, ist die 3 untersten Finnen am Kühler umzubiegen, was die Kühlfähigkeit ja nicht besonders beeinträchtigt, und dazu dann noch den Foxconn-Schriftzug abmontieren.
Ach und den kleinen Lüfter an der NB kann man auch nicht mehr anbringen.
Kühlt aber trotzdem wie ne 1. ;)
Den NB Lüfter wollt ich gern verwenden – auch wenn’s nur Spielerei ist. Mein Gehäuse ist noch kompakter als auf den Fotos des folgenden Links:
http://www.tech-talk.de/2008/02/29/thermalright-ifx-14/
Daher wähle ich wohl doch eine Nummer kleiner – vielleicht den Thermaltake 120 oder Xigmatek S963. Der Lüfter vom Xigmatek dreht über 2600 U/min, kühlt daher ordentlich und lässt sich über PWM regeln.
Ich wollt den eigentlich auch gern dran machen, einfach um noch n paar Grad einzusparen, aber geht leider net. Wenn irgendwann ma wieder n anderer Kühler reinkommt, dann werd ich den auch wieder verbauen.
Der Xigmatek is aber glaub ich auch ne sehr gute Wahl.
Die Foxconn Boards haben ja erfreulicherweise 3 Jahre Herstellergarantie.
Sind eure Mars– Boards denn alle mit einer Seriennummer versehen?
Die wird im Garantiefall gebraucht.
Wenn keine Nummer drauf steht, sind es Grauimporte. :haha:
http://www.foxconnchannel.com/support/RMA_Detail.aspx?ID=en-us0000002
Gibt es eigentlich eine Foxconn Service- Werkstatt in Deutschland, an die man sich direkt wegen eines Garantiefalles wenden kann? Wenn der Händler nur 2 Jahre Gewährleistung gibt, dann muss man sich sogar im dritten Jahr an den Hersteller wenden.
Also mein Board hat ne Seriennummer....bin ich ja beruhigt. :drool:
Und ne Werkstatt von Foxconn ist mir nicht bekannt, sollten die aber mal für uns einrichten. ;)
...ich werde den Foxconn Service deswegen mal anschreiben.
@loneclone
wie läuft denn dein RAID0 - besser als im Singlebetrieb? Hatte auch mal ein RAID0 am ICH9R auf einem Gigabyte P35- Board. Einen spürbaren Performanceschub konnte ich nicht erkennen.
Also ich muss sagen, dass es mich positiv überrascht hat. Viele haben mir vorher gesagt, dass man wohl keinen großen Unterschied merken wird, aber wenn ich Sachen installiere, oder große Dateien verschiebe, geht es wirklich nicht nur messbar, sondern auch spürbar schneller.
Bin sehr zufrieden!
Sorry falls es hier schonmal gefragt wurde, aber bedeutet das:
dass man übertakten muss, dass das Board DDR2 1066 unterstützt?
Weil ich hab noch mein G.Skill DDR2 1066 Kit zuhause welches ich damals auf dem GA P35 DS4 betrieben habe.
Das würde laufen ja?
Wenn die SPD deiner RAMs mit 1066 Mhz beschrieben sind, kann es vom Board auch als Standardtakt erkannt werden. Ging es denn beim DS4 standardmäßig?
Ja es sind RAMs die standart auf 1066 Mhz laufen und somit die SPD auch mit 1066 Mhz beschrieben ist! Genaue bezeichnung kann ich dir jetzt nicht sagen, da ich im Moment auf der Arbeit bin.
Beim DS4 ging das standartmäßig jup :)
Also die Rams werden auf jeden Fall laufen..
Und der Zusatz OC wird eigentlich nur angehängt, weil Intel den P35 halt nicht offiziell für 1066MHz freigegeben hat, aber Foxconn gibt das Board mit dem Zusatz doch frei.
Das habe ich aber vor gut einem halben Jahr zusammen mit einem e6750 & 8800 GTS verkauft, da mir das alles zu langsam wurde :shot:
Und das Foxconn Mars soll ja ziemlich gut für OC sein, was ich da bis jetzt so mitbekommen habe!
Das Mars ist das beste P35/X38 Board. Habe es mir auch bestellt. ;)
Die Möglichkeiten der VCore- Einstellungen sind einzigartig - und alles incl. EIST/C1E.
Hier hat doch einer den Thermalright Ultra 120 als CPU-Kühler drauf oda?
Wie habt ihr den angebracht?
Wenn horizontal, kann man dann alle 4 Ramslots nutzen?
Wenn vertikal, stört der NB-Kühler net?
Eigentlich sollte Board heute kommen, kacke...kommt wohl erst morgen.
...die Frage kam schon einmal ab Post #66. Leider keine Antwort.
Also eine Kühlerliste wäre echt nicht schlecht.
Eigentlich sollten die Hersteller aller Monsterkühler gleich eine Liste der kompatiblen Mainboards beifügen - oder umgekehrt.
Also der Thermalright Ultra-120 eXtreme passt. Daher sollte der Thermalright Ultra-120 auch passen. Sind ja von den Maßen her identisch.
Ich kann schon mal einige Kühler zu einer Kühlerliste beitragen: Thermalright HR-01 plus, Scythe Ninja Rev. B, Scythe Mugen (Infinity) mit Einschränkung (eine Lüfterklammer kann unten nicht richtig befestigt werden), Scythe Mine Rev. B, Thermalright Ultra-120 eXtreme.
Den Thermalright IFX-14 kann man dann auch schonmal mit dazu tragen. Der werkelt bei mir brav. Wenn man einen der Foxconn Schriftzüge vom NB-Kühler abmacht, passt der Kühler. Zwar nur grade so, der Lüfter ist etwas schwer zu montieren, aber es geht.
Und den NB-Lüfter kann man leider nicht anbringen.
moin jungs :)
mein MB ist am freitag gekommen *jippi*
nun eine frage (ist zwar noch nicht eingebaut aber ...) sollte ich den chipsatz lüfter montieren ??
wenn du ein gut belüftetes Gehäuse hast und der NB nicht max. Spannung gibts, dann ist das nicht unbedingt notwendig.
Den Lüfter kannst du dann aber auch regeln, somit wäre der auch nicht laut...
Ähnliche Themen
Antworten
9
Aufrufe
2K
