[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
Moin moin!
Ich wollt mir auch erst das DFI holen, da ich noch sehr gute Erinnerungen an mein DFI aus Sockel 939 Zeiten habe...im Grunde hab ich auch nur das Mars genommen, da ich sehr günstig drangekommen bin. Aber ich muss sagen ich bereue den Kauf keineswegs, das Bios ist vollkommen ausreichend für alle erdenklichen OCs. Kannst auch alles in verschiedenen Speicherslots wegspeichern und wieder bei Bedarf laden, das Bios lädt von selbst mit bootalbe Einstellungen, wenn man den OC mal übertrieben hat...weiß nicht, was das DFI da besser kann.
Außerdem ist die Kühllösung vom Mars besser.
Und die Quantum-Force Seite ist MOMENTAN nur für das Mars. Auf der Cebit wurden schon weitere Boards angekündigt, eins mit 780i Chipsatz und eins mit 780a Chipsatz.
Also ich glaub da hat Foxconn ne sehr gute Serie geboren, hoffe das geht munter so weiter, dann bleib ich Foxconn auch treu.
genau so wars bei mir auch
wollte auch erst das DFI kaufen, aber MARS scheint ja wohl noch ne Ecke besser zu sein
ja schade nur, das man schwer an des board rankommt.
bin aber auch äußerst zufrieden.
wegen Q9450
sollte gehen, gibts ein beta bios dafür das 45nm support bietet. wie soll den eigentlich einer ham, wenn die auslieferung von intel erst nächste oder übernächste woche beginnt?
Och es gibt genug Leute, die die Teile schon durch irgendwen von irgendwoher bekommen haben...aus dem Striker Extreme Thread ist auch schon einer am testen. Warte schon auf Ergebnisse von ihm. ;)
Man kann sich auch so registrieren, aber ich glaub für die Downloads und so Krams braucht man die SN.
Hat eigentlich jemand ne Antwort hierdrauf?
*selfquote* schrieb:
Mal ne andere Frage...mich würd ja mal reizen, Crossfire zu testen.
Da der 2. PCIe ja aber nur mit 4x angebunden ist, wird da ja bestimmt ne Menge skaliert...hat einer Erfahrung, wie hoch die Skalierung im Gegensatz zu 2 16x PCIe auf nem X38 zum Beispiel wäre?
Na denn is die SN wohl nur interessant für Foxconn. :p
€dit: Falls jemand die Scaling - Fähigkeit vom Mars interessiert, hier mal n Test im Vergleich mit dem X38 dazu. Sieht irgendwie überhaupt nicht gut aus... Review CF Scaling
N
naja so schelcht finds ich des etz fei nicht. hab allerdings nur crysis angeschaut.
hätte mir da deutlich schlechtere werte erdacht.
und etz ne schön dicke 3870 bzw 3870 GX2
und in paar jahren dann noch mal ne billige gebrachte zustecken.
aber
1. hab ich ne nvidia 8800gts (G92):hail::love::d:d
und
2. find ich sli und crossfire doof, zumindest mit 2 karten
mit 2 gpus auf einem pcb find ich es ein bissl sinnvoller.
das beste wäre natürlich 2gpus auf einem DIE
EDIT:
kann mir einer sagen was Everest beim AUX-Anschluss für ne TEMp ausliest?
Also die Werte finde ich mehr als bescheiden zum großen Teil..Crysis ist da noch mit das positivste...
Zum Beispiel bie CoD4, da hat man mit 2 Karten wirklich weniger Frames, als mit ner Single-Karte. Das find ich schon etwas sehr merkwürdig..:fresse:
Aber naja, ich hab ja auch ne GT, die geht ab wie Schmitz Katze, die bleibt auch noch hoffentlich n Weilchen drinne.
Aux...dat hab ich mich auch schon mehrmals gefragt, aber weiß leider net, was das ist...muss aber eigentlich von der Graka kommen.
Ja AUX hab ich mal gedacht is irgend ein EIN/AUSgang von iwas. aber warum wird die temp davon angegeben?
Ja wiegesagt des einzige war crysis alles andere läuft ja mehr als flüssig!^^ auch ohne CF SLI oder weis ich noch was.
langsam kann man es richtig sammelthreat nennen^^
aber trotzdem exklusiv bleibt!^^
ja schon weil man kaum mehr an das board rankommt!
vielleicht steigt ja irgendwann mal der wert!:banana::lol:
Hi!
Bei CaseUmbau.de wurde das Mars und auch das X38 von Foxconn getestet - interessanterweise in beiden Tests mit den gleichen Hardwarekomponenten und Einstellungen:
E6300 @3,00 Ghz / VCore @default / RAM @ 1033 Mhz
Unter Everest werden bei den Timings angezeigt:
Mars: 5-5-5-15
X38: 5-5-5-18
Sieht ganz so aus, dass mit dem Mars die schärferen Timings gehen. Dementsprechend besser sind auch die Werte. ;)
http://www.caseumbau.de/index.php?page=test524/test524_4
http://www.caseumbau.de/index.php?page=test517/test517_4
Moin,Moin@all
ich will mich auch als sehr zufriedener Mars Besitzer outen :)! Kann auch
behaupten das ich schon einige Boards im Besitz hatte : 2xGiga P35DQ6 ,
ASUS P5WDH , Blitz Formula , P5E-WSPro , Maximus Formula , DFI LANparty UT / LT
P35-T2R , EVGA 680i SLI , MSI P35 Neo2 ,Abit IX38 Quad GT , IP35 Pro :d.
Jedes für sich genommen, sind es gute Boards !
In der Summe aller Eigenschaften hebt sich für mich, das Mars dann doch
hervor, hier stimmt für mich einfach alles OC , Stabilitaet , Stromverbrauch
Layout und der Support:bigok:.
Gruss
little-oak
So bestellt, pack mir doch nun erstmal nur nen E8400 drauf. Dann mal auf Montag warten :>
gute Kombination :d
Was solls denn später für eine CPU werden?
Wollte mir eigentlich nen Q9450 reinpacken, aber der ist ja so gut wie gar nicht lieferbar.
Werd dann den E8400 dick OCn und als nächstes kommt dann wohl en nahelem.
Wollte ja eigentlich noch ne 8800gtx dazu packen, aber laut letzten 9800gx2 benches fiel die entscheidung nicht schwer. 13k punkte @3dmark 2560x1600.
Wird jedenfalls en geiles sys, mal wieder up2date sein, wenigstens für paar tage :>
Hi!
Seit Tagen versuche ich über quantum-force.net ins Foxconn Forum zu kommen. Jedes Mal kann die Seite nicht gefunden werden.
Klappt es bei euch?
Ähnliche Themen
