Was für ein Tweak wenn ich fragen darf? oO ^^
r_DepthOfField=1
r_MotionBlur=3
r_sunshafts=1
r_UseEdgeAA=1
r_Flares=1
r_Coronas=1
r_colorgrading=1
r_GlowScreenMultiplier = 0.2
sys_spec_Quality=4
e_sky_type=1
e_sky_update_rate=1
r_DetailTextures=1
r_DetailNumLayers=2
r_DetailDistance=8
r_HDRRendering=2
r_SSAO=1
r_SSAO_quality=2
r_SSAO_radius=2
r_refraction=1
e_ram_maps=1
sys_flash_edgeaa=1
e_vegetation_use_terrain_color=1
e_terrain_ao=1
e_terrain_normal_map=1
e_max_entity_lights=16
r_UsePom=1
r_EnvTexUpdateInterval=0.05
r_TexturesFilteringQuality=0
r_HairSortingQuality = 1
r_FillLights = 14
e_particles_lights = 1
i_lighteffects = 1
g_ragdollMinTime = 15.0
g_ragdollUnseenTime = 2
g_ragdollDistance = 40.0
g_battleDust_enable = 1
e_obj_quality=4
e_proc_vegetation=1
ca_useDecals=1
e_decals_allow_game_decals=1
e_decals_life_time_scale=2
e_lod_ratio=6
e_lod_min=0
e_lods=1
e_view_dist_ratio_detail=30
e_view_dist_ratio_vegetation=45
e_vegetation_min_size=0
i_rejecteffects=1
e_vegetation_bending=2
sys_flash_curve_tess_error=2
e_view_dist_ratio=60
e_max_view_dst_spec_lerp=1
e_vegetation_sprites_distance_custom_ratio_min=1
e_vegetation_sprites_distance_ratio=1.5
e_detail_materials_view_dist_xy=2048
e_detail_materials_view_dist_z=128
es_DebrisLifetimeScale=1
e_cbuffer_resolution=256
e_dissolve=1
ca_DrawFaceAttachments=1
ca_AttachmentCullingRation=200
e_terrain_occlusion_culling_max_dist=200
r_WaterRefractions=1
r_WaterReflections=1
r_WaterUpdateFactor=0.05
e_water_tesselation_amount=10
e_water_tesselation_swath_width=10
r_WaterUpdateDistance=0.2
r_WaterCaustics=1
r_WaterReflectionsQuality=4
e_water_ocean_fft=1
q_ShaderWater=2
r_WaterReflectionsMinVisiblePixelsUpdate = 0.05
r_Beams=3
r_BeamsDistFactor=0.05
r_BeamsMaxSlices=200
e_Clouds=1
r_CloudsUpdateAlways=1
e_shadows = 1
r_ShadowBlur=3
e_shadows_max_texture_size=1024
r_ShadowJittering=2.5
e_gsm_lods_num=5
Also finde eleider schade, dass es unter Vista unspielbar ist @ Very High16 FPS...
aber wenn ich so chatten low und post proc. medium mache läufts so mit 30
Sagt mal bei dem very high tweak für xp kann ich aber im spiel trotzdem nicht auf Very high stellen. Ist das normal?
hab die SP demo...dumme frage, aber wo gebt ihr die ganzen sachen ein?hab die SP demo...
da eingeben wenn du iwelche sachen einfügst oder halt
ja Very high ist halt für DX10 elemente dasist halt Vistas aufgabe^^
@SebiG
naja 1024 wär übel, habe 1680x1050
ist mir schon klar, hab xp und Vista drauf. Nur ich dachte das durch die Config die "Very High" funktion freigeschalteten werden soll.
Dachte ich mir schon weil es plötzlich @1680x1050 schlechter lief.
Sagt mal warum kann mir keiner meine Frage beantworten die ich schon 100mal gestellt habe. Unter XP kann ich viele verschiedene Auflösungen einstellen, z.B. 1440x900 das bringt echt was und man sieht es kaum. Aber unter Vista habe ich nur 4 Auflösungen zu Auswahl. 1280x960 1280x1024 1024x768 und 1680x1050.
Warum kein 1440x900. Auf 1280x1024 läuft es zwar echt gut, Teils sogar auf Very high, schatten medium. Leider ist es halt etwas in die Breite gezerrt.
Für alle GTX/GTS Besitzer, die sonst nur mit high vorlieb genommen haben. Wenn man im Menü Schatten und PP auf medium setzt lässt sich das Spiel auch bei 1280x1024 in DX10 und Rest Very high (!!) sehr angenehm spielen, ohne sichtbaren Qualitätsverlust. Vielleicht ist das für einige ja neu.
Soll ich mal lachen? "Unspielbar"?![]()
Sind hier nur "Kinder" im Alter von 18 die nicht mal nen Post lesen können....![]()
Unter Vista ist es möglich auf "Very High" zu spielen!
In Verbindung mit "AA"!
Einfach mal lesen...
Auch an DICH!
Lies mal was ich schon vor Stunden! geschrieben habe...![]()
Das wird wohl DX10 bzw. Beta Treiber Bug sein. Ich wüsste keinen Grund warum das gewollt sein soll.
Nächste Woche soll doch angeblich nen neuer Treiber plus Demo Patch kommen, ma gucken was dann geht.
Auch an DICH!
Nur das mit 4x AA glaub ich nicht.
