Cyprinus_Carpio
Banned
ich spar nochn bissi und hol mir ne geile wakü^^
und dann geht der @last nicht über 70°C???
from voodooextreme:
There was quite a debate about the benefits of Quad vs Dual cores for gaming at VE, so we decided to ask Epic Games' Main Man and Lead Programmer Tim Sweeney for his take on the situation.
VE - Assuming you were making a new rig to run today and tomorrow's games, which CPU would you recommend at the $266 price point? A Quad-core Q6000 2.4GHz or Dual-Core E6850 3.0GHz?
Tim - If you're buying a CPU primarily for gaming, the sweet spot of the market seems to be dual-core. There, you can get a higher clock rate than is available (at least economically) in quad-core. All UE3 games, for example, scale really well to two cores, and you get significantly more performance than single-core much of the time. Though UE3 and many other engines scale somewhat to 4 cores, the benefits aren't huge.
That will change in a couple of years, but that's another upgrade cycle.
If you plan to do heavy level-building and mod making, I'd recommend quad-core. The development tools scale well to quad-core, having lots of content authoring apps open in Windows benefits from quad-core, and if you're going to be running a dedicated server on your machine to test a mod while also playing on that machine, it helps for that.
Das habe ich gerade bei guru3d gelesen. Wurde von "dmonk" gepostet.
Link
nö wüsste nicht wofür ich einen quadcore bräuchte
games unterstützen ja grad mal mit müh und not dualcore
also würd ich doch eher nen höher getakteten dualcore nehmen - würd mehr sinn machen
werde auch den quad 6600 nehmen zusammen mit dem msi p35 platinum.wie hoch bekommt man den quad so mit nem guten zahlman.3,0 ghz währe ja der hammer,aber 2,66 würde mir schon reichen,dann ist er so schnell wie der quad 6700.aber nur halb so teuer.finde einfach kein Argument warum ich den 6850 eher nehmen sollte.
Aber Keller bestimmt...
B3 nat....takt auch noch standard...ich bau den nicht ein und übertakte ihn beim 1. hochfahren^^
soo...quad ist gekommen...eingebaut und coretemp druff...
nach 4 min prime folgende temps:
Tjunktion:100°C
Core0:61°C
Core1:56°C
Core2:59°C
Core3:56°C
kann man das so laufen lassen?
jop...boxed...
jetzt mein vorzeitiges ergebnis:
