jign
Semiprofi
Dfi LANParty P35 T2R
***sammelthread***
***sammelthread***
P35 T2R
I. Allgemeine Infos zum Chipsatz- Unterstützt Core2Duo/Quad (65nm/45nm) (1066Mhz/1333Mhz)
- Heatspreader auf der Northbridge
- Southbridge ICH9R
- Unterstützt PCIe 2.0 für Grafikkarten
- Unterstützt PCIe 1.0 für andere Erweiterungskarten
- Unterstützt DDR2 und DDR3 (wahlweise oder gemischt)
II. Technische Details zum Board [DFI P35-T2R]
# LGA 775 socket for: - Intel® CoreTM2 Quad, Intel® CoreTM2 Extreme, Intel® CoreTM2 Duo, Intel® Pentium® D or Intel® Pentium® 4
# Supports Intel Enhanced Memory 64 Technology (EMT64T)
# Supports Enhanced Intel SpeedStep Technology (EIST)
# Supports Intel Hyper-Threading Technology
# Supports 1333*/1066/800MHz system bus speed *Available only on CPUs that support 1333MHz FSB
Chipset
# Intel® chipset - Northbridge: Intel® P35 Express chipset (with Intel® Fast Memory Access technology) - Southbridge: Intel® ICH9R
Memory
# Four 240-pin DDR2 DIMM sockets
# Supports DDR2 533/667/800 MHz
# Delivers up to 12.8Gb/s bandwidth
# Supports dual channel (128-bit wide) memory interface
# Supports up to 8GB system memory
# Supports unbuffered x8 and x16 DIMMs
BIOS
# Award BIOS
# 8Mbit flash memory
Power Management
# ACPI and OS Directed Power Management
# ACPI STR (Suspend to RAM) function
# Wake-On-PS/2 Keyboard/Mouse
# Wake-On-USB Keyboard/Mouse
# Wake-On-LAN and Wake-On-Ring
# RTC timer to power-on the system
# AC power failure recovery
Hardware Monitor
# Monitors CPU/system/Northbridge temperature and overheat alarm
# Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
# Monitors the speed of the cooling fans
# CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
Storage
# Intel ICH9R chip - Intel Matrix Storage technology - Supports up to 6 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1, RAID 0+1 and RAID 5
# JMicron JMB363 PCI Express to SATA and PATA host controller - Supports up to 2 UltraDMA 100Mbps IDE devices - Supports 2 SATA devices - SATA speed up to 3Gb/s - RAID 0 and RAID 1
Audio
# Bernstein audio module - Realtek ALC885 8-channel High Definition Audio CODEC - Center/subwoofer, rear R/L and side R/L jacks - Line-in, line-out (front R/L) and mic-in jacks - 2 coaxial RCA S/PDIF-in/out jacks - 1 optical S/PDIF connector - 1 CD-in connector - 1 front audio connector
# DAC SNR/ADC SNR of 106dB/101dB
# Full-rate lossless content protection technology
LAN
# Marvell 88E8052 and Marvell 88E8053 PCIE Gigabit LAN controllers
# Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
IEEE 1394
# VIA VT6307
# Supports two 100/200/400 Mb/sec ports
Rear Panel I/O Ports
# 1 mini-DIN-6 PS/2 mouse port
# 1 mini-DIN-6 PS/2 keyboard port
# 1 IEEE 1394 port
# 6 USB 2.0/1.1 ports
# 2 RJ45 LAN ports
I/O Connectors
# 3 connectors for 6 additional external USB 2.0 ports
# 1 connector for an external COM port
# 1 connector for an IEEE 1394 port
# 1 connector for the Bernstein audio module
# 1 front audio connector (on the Bernstein audio module)
# 1 CD-in connector (on the Bernstein audio module)
# 1 S/PDIF connector (on the Bernstein audio module)
# 1 IrDA connector and 1 CIR connector
# 8 Serial ATA connectors
# 1 40-pin IDE connector and 1 floppy connector
# 1 24-pin ATX power connector
# 1 8-pin 12V power connector
# 2 4-pin 5V/12V power connectors (FDD type)
# 1 front panel connector
# 6 fan connectors
# 1 diagnostic LED
# EZ touch switches (power switch and reset switch)
Expansion Slots
# 3 PCI Express x16 slots (PCIE1 at x16, PCIE3 at x4 or x1 and PCIE4 at x1)
# 1 PCI Express x1 slot
# 3 PCI slots
PCB
# 6 layers, ATX form factor
# 24.4cm (9.6") x 30.5cm (12")
III. Tipps/Tricks und Problemlösungen
CPUz freze beheben *klick* (ACHTUNG funktioniert nicht immer)
Bios set und real VTT Tabelle: klick
IV. Sonstiges
Kleiner bench Vergleich zischen DFI P35 und Gigabyte p35 DS4: klick
Eine Version ohne HP Konstruktion also nur mit normalen (schwarzen) passiv-Kühlern ist ebenfalls erhältich der Preis liegt dadurch gute 20€ unter der Version mit HP.
ACHTUNG: Das bord verweigert offenbar gänzlich seinen Dienst in Verbindung mit einem Enermax Liberty 620w
V. Impressionen
*klick*
*klick*
VI. Layout [DFI P35-T2R]
VII. OC Liste
VIII.RAM Liste
Team Group Xtreem PC2-6400 DDR2-800 [4 Riegel getestet]
Cellshock DDR2 1150 CL5 (CS2221650) mit Micron D9GKX [4 Riegel getestet]
Crucial Ballistix DDR2 800 CL4 mit Micron D9
IX. Downloads/Links
VII. OC Liste
VIII.RAM Liste
I. Offizielle Hersteller Seite: klick
II. BIOS: klick
III. Beta BIOS: klick Oder offizielle DFI beta site: klick
IV. Geizhalslink: klick
V. DFI LANparty X38 Sammelthread klick
VI. DFI LANparty UT790FX Sammelthread klick
hoffentlich verursachen die keine bösartige geräusche
