Micki_Krause
Semiprofi
ALiveNF7G-HDready:
1. Socket AM2 for AMD Athlon™ 64FX / 64X2 / X2 / 64 and Sempron processors
2. NVIDIA® GeForce 7050 / nForce 630A MCP Chipsets
* AMD LIVE!™ Ready
* Supports Dual Channel DDRII800/667/533 with 4 DIMM slots, maximum capacity up to 8GB
* ASRock AM2 Boost: ASRock Patented Technology to boost memory performance up to 12.5%
* Integrated NVIDIA® GeForce7 Series (NV44) DX9.0 VGA, Pixel Shader 3.0, Max. shared memory 256MB
* 1 x PCI Express x 16 slot
* Hybrid Booster - ASRock Safe Overclocking Technology
* Untied Overclocking : During Overclocking, FSB enjoys better margin due to fixed PCIE/ PCI Buses
* Dual VGA Output: Support DVI-D and D-Sub ports by independent display controllers
* Supports HDCP function with DVI-D port, to enjoy better quality with High Definition HDCP Encryption contents
* Supports 720p Blu-ray (BD) / HD-DVD playback
* NVIDIA® PureVideo™ Ready
* 4 x Serial ATAII 3.0 Gb/s, support RAID (RAID 0, RAID 1, RAID 0+1, RAID 5, JBOD), NCQ, AHCI and "Hot Plug" functions
* Supports Gigabit LAN 10/100/1000 Mb/s
* Supports 2 x IEEE 1394 headers (one port on back panel, one header on board)
* HDMI_SPDIF header, providing SPDIF audio output to HDMI VGA card, allows the system to connect HDMI Digital TV/projector/LCD devices.
* Chipset embedded HDMI Audio which supports HDMI signal through DVI-D port by using DVI to HDMI adapter (not bundled)
* 7.1 CH Windows® Vista™ Premium Level HD Audio (ALC888 Audio Codec)
* Windows® Vista™ Premium 2007 Logo Ready
* ASRock DVI_1394 I/O: 1 x VGA/DVI-D Port, 1 x VGA/D-Sub Port, 1 x IEEE 1394 port
2. FAQ - Frequently Asked Questions
- lassen sich 3 Pin Lüfter steuern? Nein das geht nicht.
- ist ein weiterer als der CPU Lüfter steuerbar? Nein auch das nicht.
3. Links & Downloads
3.1 Links zu Treibern, BIOS,Programmen
HDready:
http://www.asrock.com/mb/download.asp?Model=ALiveNF7G-HDready&s=
720p:
http://www.asrock.com/mb/download.asp?Model=ALiveNF7G-HD720p&s=
Neueste Biosversionen mit Lüftersteuerung finde man unter:
http://www.pctreiber.net/filebase.php?lim=0&cat=142
USB Stick bootfähig machen
http://www.forumdeluxx.de/forum/showpost.php?p=7080307&postcount=442
3.2 Reviews
http://www.ocworkbench.com/2007/asrock/ALiveNF7G-HDREADY/g1.htm
http://www.hkepc.com/bbs/hwdb.php?tid=810664&tp=NVIDIA-MCP68&rid=810664 (mit Vergleich zum 690G)
http://www.virtual-hideout.net/reviews/ASRock_AliveNF7G-HDready/index.shtml
http://www.phoronix.com/scan.php?page=article&item=771&num=1
3.3 Interessantes:
- der sehr kleine GPU Kühler
- 4 Ram Bänke mit bis zu 8gb Speicher
- HDMI Anschlussmöglichkeit, wenn auch nur über den DVI Anschluss
- Single Chip Design
- Videobeschleunigung, die der ATI 690G Chip teilweise nicht bietet
- umfangreiche Bioseinstellungen. U.a. CPU Parameter, GPU Takt nicht einstellbar
- günstig im Vergleich zu anderen 7050er Boards.
- 4 Sata II Plätze
3.4. Overclocking
Im Review lief das Board stabil mit 280mhz. Für die erste Biosversion kann sich das doch sehen lassen.
4. Preise
HDready bei Geizhals.at
720P bei geizhals.at
5. Bekannte Probleme:
- Die Auflösung von 1600x1200 wird nicht korrekt dargestellt.
- Beim Biosupdate von Version 1.60 auf 2.00 kann es zur Zerstörung des Bios kommen. Daher sollte vorher auf der Umweg über das 1.90er oder ein anderes Bios gemacht werden!
6. Fixes:
- schlechte USB Performance:
http://www.forumdeluxx.de/forum/showpost.php?p=6701416&postcount=165
- Grafikproblem bei 1600x1200er:
http://www.forumdeluxx.de/forum/showpost.php?p=6705173&postcount=166
- Lüftersteuerung dreht zu hoch:
http://www.forumdeluxx.de/forum/showpost.php?p=7076113&postcount=434
* AMD LIVE!™ Ready
Das ALiveNF7G-HD720p hat im Gegensatz zum HDready keine Firewire Schnittstelle.
HDready:
720p:
3.2 Reviews
3.3 Interessantes:
- 4 Sata II Plätze
3.4. Overclocking
4. Preise
6. Fixes:
