Hallo ich hab mal eine Frage... ich bin grad bei einer freundin und ihr
rechner läuft angebliche plötzlich so langsam...
Kann mir jemand sagen ob das so richtig sein kann ?
750 Mhz und DDR speicher ?
CPU-Z version 1.39
Processors Map
Number of processors 1
Number of threads 1
Processor 0
-- Core 0
-- Thread 0
Processors Information
Processor 1 (ID = 0)
Number of cores 1
Number of threads 1 (max 1)
Name AMD Athlon
Codename Thunderbird
Specification AMD Athlon(tm) Processor
Package Socket A (462)
CPUID 6.4.2
Extended CPUID 7.4
Core Stepping A4
Technology 0.18 um
Core Speed 747.0 MHz (7.5 x 99.6 MHz)
Rated Bus speed 199.2 MHz
Instructions sets MMX (+), 3DNow! (+)
L1 Data cache 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 256 KBytes, 16-way set associative, 64-byte line size
FID/VID Control no
K7 Thermal sensor no
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 02001001h
Max CPUID level 00000001h
Max CPUID ext. level 80000006h
Function eax ebx ecx edx
0x00000000 0x00000001 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00000642 0x00000000 0x00000000 0x0183F9FF
0x80000000 0x80000006 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00000742 0x00000000 0x00000000 0xC1C7F9FF
0x80000002 0x20444D41 0x6C687441 0x74286E6F 0x5020296D
0x80000003 0x65636F72 0x726F7373 0x00000000 0x00000000
0x80000004 0x00000000 0x00000000 0x00000000 0x00000000
0x80000005 0x0408FF08 0xFF18FF10 0x40020140 0x40020140
0x80000006 0x00000000 0x41004100 0x01008140 0x00000000
MSR 0xC0010015 edx = 0x00000000 eax = 0x09001008
Chipset
Northbridge SiS 735 rev. 01
Southbridge SiS LPC Bridge rev. 00
Graphic Interface AGP
AGP Revision 2.0
AGP Transfer Rate 4x
AGP SBA not supported, not enabled
Memory Type DDR
Memory Size 512 MBytes
CAS# 2.5
RAS# to CAS# 3
RAS# Precharge 4
Cycle Time (tRAS) 6
Bank Cycle Time (tRC) 10
Memory SPD
DIMM #1
General
Memory type DDR
Manufacturer (ID) MCI Computer (7F7F640000000000)
Size 512 MBytes
Max bandwidth PC3200 (200 MHz)
Part number MDT512M PC400 CL2.
Serial number 7A272008
Manufacturing date Week 37/Year 05
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
Timings table
Frequency (MHz) 166 200
CAS# 2.0 2.5
RAS# to CAS# delay 3 3
RAS# Precharge 3 3
TRAS 7 8
Dump Module #1
0 1 2 3 4 5 6 7 8 9 A B C D E F
00 80 08 07 0D 0A 02 40 00 04 50 50 00 82 08 00 01
10 0E 04 0C 01 02 20 C0 60 70 00 00 3C 28 3C 28 40
20 60 60 40 40 00 00 00 00 00 37 41 28 28 50 00 0A
30 01 26 29 22 0C 0C 18 05 00 00 00 00 00 00 11 0A
40 7F 7F 64 00 00 00 00 00 00 4D 44 54 35 31 32 4D
50 20 50 43 34 30 30 20 43 4C 32 2E 35 31 05 25 7A
60 27 20 08 57 57 57 2E 4D 44 54 2E 44 45 20 50 31
70 35 38 30 37 20 20 20 20 20 4D 32 45 2D 30 00 00
Monitoring
Sensor Chip ITE IT8705
PCI Device List
Host Bridge
bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1039
Model ID 0x0735
Revision ID 0x01
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x20
Header 0x80
PCI header
Address 0 (memory) 0xD0000000
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Capabilities
AGP Capability
Offset C0h
Version 2.0
Status enabled
Transfer rate 4x (max 4x)
Queue lenght 67 (max 32)
Dump
00 39 10 35 07 07 00 10 22 01 00 00 06 00 20 80 00
10 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 07 A4 77 F7 AA D4 E8 F0 20 29 08 03 12 C5 03 00
60 40 6B 40 40 02 00 00 00 01 08 18 20 00 10 00 00
70 00 88 00 08 00 00 00 00 00 00 00 00 00 00 00 00
80 02 42 10 00 85 00 80 01 20 0C 00 04 00 00 00 00
90 00 20 00 00 43 01 00 01 00 16 B3 41 00 00 00 20
A0 42 2A 22 01 00 00 00 00 00 00 00 00 00 00 00 02
B0 00 00 00 00 7B 02 09 6B 36 58 48 D6 17 F5 00 40
C0 02 00 20 00 07 02 00 1F 04 01 00 00 00 00 00 00
D0 02 42 33 00 09 FF FF 00 60 60 AA 00 00 80 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CPU-Z version 1.39
Processors Map
Number of threads 1
Processor 0
-- Core 0
-- Thread 0
Number of cores 1
Name AMD Athlon
CPUID 6.4.2
Extended CPUID 7.4
Core Stepping A4
Technology 0.18 um
FID/VID Control no
Thread dumps
CPU Thread 0
APIC ID 0
Type 02001001h
Chipset
AGP Revision 2.0
Memory Type DDR
CAS# 2.5
RAS# to CAS# 3
RAS# Precharge 4
Cycle Time (tRAS) 6
Memory SPD
DIMM #1
General
Memory type DDR
Size 512 MBytes
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
Timings table
CAS# 2.0 2.5
RAS# Precharge 3 3
TRAS 7 8
Dump Module #1
Monitoring
PCI Device List
Host Bridge
Common header
Vendor ID 0x1039
Model ID 0x0735
Revision ID 0x01
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x20
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Capabilities
AGP Capability
Offset C0h
Version 2.0
Status enabled
Dump
