Betriebssystem ist XP Prof. SP2,ATI 9800 Pro mit Silencer Rev.3 und Standardtakt,Catalyst 7.2,DirectX9.0c,2 x 512MB Samsung(1x PC2100,1x PC2700, im BIOS auf DDR266 eingestellt,läuft als Dual-Channel),Betriebssystem neu aufgesetzt,Ereignisanzeige ist sauber,alle Geräte im Gerätemanager korrekt erkannt.
3DMark05 hängt sich nach kurzer Zeit auf,06er startet,aber Bildschirm bleibt schwarz,nur rechts oben steht eine rote 2 (Frames).
Prime95 Benchmark:
[Tue Mar 07 01:40:36 2006]
Self-test 1024K passed!
[Tue Mar 07 02:10:35 2006]
Compare your results to other computers at
http://www.mersenne.org/bench.htm
That web page also contains instructions on how your results can be included.
Mobile Intel(R) Pentium(R) 4 CPU 3.06GHz
CPU speed: 1591.53 MHz
CPU features: RDTSC, CMOV, Prefetch, MMX, SSE, SSE2
L1 cache size: 8 KB
L2 cache size: 512 KB
L1 cache line size: 64 bytes
L2 cache line size: 128 bytes
TLBS: 64
Prime95 32-bit version 24.14, RdtscTiming=1
Best time for 512K FFT length: 26.542 ms.
Best time for 640K FFT length: 34.316 ms.
Best time for 768K FFT length: 42.635 ms.
Best time for 896K FFT length: 50.195 ms.
Best time for 1024K FFT length: 56.071 ms.
Best time for 1280K FFT length: 71.810 ms.
Best time for 1536K FFT length: 88.452 ms.
Best time for 1792K FFT length: 104.529 ms.
Best time for 2048K FFT length: 116.748 ms.
Best time for 2560K FFT length: 152.220 ms.
Best time for 3072K FFT length: 191.814 ms.
Best time for 3584K FFT length: 226.571 ms.
Best time for 4096K FFT length: 256.730 ms.
Best time for 58 bit trial factors: 18.130 ms.
Best time for 59 bit trial factors: 18.265 ms.
Best time for 60 bit trial factors: 18.213 ms.
Best time for 61 bit trial factors: 18.122 ms.
Best time for 62 bit trial factors: 19.804 ms.
Best time for 63 bit trial factors: 19.862 ms.
Best time for 64 bit trial factors: 24.250 ms.
Best time for 65 bit trial factors: 24.224 ms.
Best time for 66 bit trial factors: 24.083 ms.
Best time for 67 bit trial factors: 24.011 ms.
