ABIT AW9D/MAX (i975X) Sammelthread+ FAQ (Part 3)
9800ProZwerg
Semiprofi
Hamburg
Ich bin mal so frei und eröffne, da heute offiziell die ABIT AW9D Series vorgestellt wurde, einen Sammelthread:) !
Specs:
AW9D
Preis: http://www.geizhals.at/eu/a214105.html
Bios Downloads:
http://www.abit.com.tw/page/de/download/download_bios_detail.php?pFILE_TYPE=Bios&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AW9D&pSOCKET_TYPE=LGA775
CPU
* Designed for Intel® LGA775 processors with1066/800MHz FSB
* Supports Intel® Core™ 2 Duo & Pentium® Extreme Edition & Pentium® D & Pentium® 4 Processors
* Supports Intel® Hyper-Threading / XD-bit / EM64T / EIST Technology / Virtualization Technology
* Intel® Quad Core ready.
Chipset
*Intel® 975X / Intel® ICH7R Express Chipset
Memory
* 4 X 240-pin DIMM sockets support max. memory capacity 8GB
* Supports Dual channel DDR2 800/667 Un-buffered / Non-ECC memory
Graphics
* Supports Dual PCI-Express X16 slots (dual ATI® CrossFire™ Graphics)
LAN
* On-board PCI-E Gigabit LAN controller supports 10/100/ 1000M Ethernet
Audio
* abit AudioMAX™ HD 7.1 CH
* Supports Jack Sensing and S/PDIF In/Out
* Dolby® Master Studio Certificated
Expansion Slots
* 2xPCI-EX16, 2xPCI-EX1, 1xPCI, 1xAudioMAX™
Internal I/O Connectors
* 1 x Floppy port, 1 x UDMA 100/66/33 connector,
* 4 x SATA 3Gb/s connectors
* 2 x USB 2.0 headers
* 1 x FP-Audio header, 1 x CD-IN
Back Panel I/O
* 1 x PS/2 Keyboard, 1 x PS/2 Mouse
* 4 x USB 2.0, 1 x RJ-45 LAN
Serial ATA
* ICH7R: 4 x SATA 3Gb/s supports Intel® Matrix Storage SATA RAID 0/1/0+1/5
* Support SATA AHCI, providing native command queuing and native hot plug
abit Engineered
* abit µGuru™ Technology
* abit OTES™ Technology
* Quick Power & Reset Buttons
* Low ESR and high ripple conductive polymer aluminum solid capacitors
RoHS
* RoHS Compliancy
Form Factor
* ATX form factor 305 x 245mm
* PCB Color: Black
AW9D-MAX
http://img208.imageshack.us/my.php?image=aw9dmaxangle500lz4.jpg
http://img209.imageshack.us/my.php?image=aw9dmaxtop500al3.jpg
http://img234.imageshack.us/my.php?image=maxof9.jpg
Preis: http://www.geizhals.at/eu/a214107.html
Lieferumfang:
- AudioMax HD 7.1 Soundkarte
- SLI Bridge
- Quick Setup Manual, ausführliches Manual, **** Manual
- Jumper Settings Aufkleber
- 7! SATA Kabel
- 3 SATA RAID Floppys (32 und 64 Bit Sil, Intel RAID)
- Treiber CD
- Optisches Audiokabel
- Je 1 IDE und Floppy Kabel, gerundet
- Bracket mit 2x USB und 1x Firewire
Bios Downloads:
http://www.abit.com.tw/page/de/download/download_bios_detail.php?pFILE_TYPE=Bios&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AW9D-MAX&pSOCKET_TYPE=LGA775
CPU
* Supports Intel® Core™ 2 Duo(Extreme Edition) & Pentium® Extreme Edition & Pentium® D & Pentium® 4 Processors
Chipset
Memory
Graphics
LAN
* On-board Dual PCI-E Gigabit LAN controller supports 10/100/ 1000M Ethernet
Audio
Expansion Slots
* 2xPCI-EX16,2xPCI-EX1,1 xPCI, 1x AudioMAX™
* 7 x SATA 3Gb/s connectors
* 2 x USB 2.0 headers, 2 x IEEE1394 headers
Back Panel I/O
* 4 x USB 2.0, 2 x RJ-45 LAN,
* 1 x eSATA
Serial ATA
* ICH7R: Support SATA AHCI, providing native command queuing and native hot plug & play
* Silicon Image:3132: 4 x SATA 3Gb/s, two SATA connectors of the same area can support SATA RAID 0/1
IEEE 1394
* 2 ports IEEE1394a at 400 Mb/s transfer rate
abit Engineered
* abit Silent OTES™ 2 Technology
* Back-light Blue LED's
RoHS
* RoHS Compliancy
Form Factor
* PCB Color: Black & Blue
FAQ zum ABIT AW9D-MAX (Vielen Dank an Sicness):
Wichtige Links:
Produktseite bei abit
BIOS download
Manual download
abits interne Kompatibilitätstests
Thread @ XtremeSystems.org
Gelten die folgenden Angaben auch für das non-Max oder Fatality?
Nein, beide Boards sind bis heute nicht erhältlich. Daher gilt dieses FAQ ausschliesslich für die Max Version.
Passt meine PCI-Karte in den PCI Slot wenn ich CF/SLI nutze?
Wenn die GraKa nen Single Slot Kühler hat wird der PCI nicht blockiert, bei einer Flachen WaKü a la Inno oder AC ebenfalls nicht.
Hey, da ist ja ne SLI Bridge dabei. Wird SLI offiziell unterstützt?
Nein, SLI ist nur mit gehackten Treibern möglich.
Bei mir funzt µGuru nicht richtig! Was ist los?
Das Problem tritt beim Release Bios in Verbindung mit einem Raid auf!
Lösung ist das neue .12 Bios!
Laufen 7900/7950GX2 problemlos auf dem Board?
Ja, die 7900GX2 läuft absolut problemlos.
Meine 7950GX2 bringt nur die halbe Leistung! Was ist hier los?
Laut dem User Dr.Wakeman liegt das an der µGuru Software.
Es verträgt sich nicht mit den aktuellen Forceware Treibern!
Der SLI Algorithmus läuft weder mit SFR, AFR oder AFR2.
Gibt es bekannte Probleme mit irgendwelchen RAMs?
Bisher nur eine Meldung, OCZ XTC Gold PC6400 C5 mit Elpida Chips laufen nicht mit 1:1, mit anderen Teilern jedoch problemlos. Micron D9 laufen einwandfrei.
Kann ich die Heatpipe entfernen und die Passivkühler in Kombination mit meiner Chipsatzwakü nutzen?
Nein, die Heatpipes sind fest verlötet. Es müssten in diesem Fall seperate passive Kühlkörper besorgt werden.
Falsch! Turrican bestätigt dass die Heatpipe nicht verlötet ist!
Bilder:
Was taugt die Heatpipe Konstruktion?
Die Kühlung arbeitet überraschend effizient, einen gewissen Luftstrom vorrausgesetzt lassen sich moderate Übertaktungen ohne zusätzliche Kühlung bequem bewältigen.
Sehe ich richtig? Das Board hat Lochhalterungen? Ich dachte Intel benutzt Ösen.
Richtig, abit bildet hier eine Ausnahme.
Wie hoch geht denn nun der FSB?
Die bisher höchsten Meldungen liegen im Bereich 450-460MHz, jedoch sind hier wohl die Chipsatztimings straffer als bei anderen 975X Boards. Sicher ist aber wohl ~420 MHZ!
hipro5 schrieb:
I also would like to add that ABIT "played" my Fadbodies a bit tighter that ASUS or Bad Axe......In 2k5 I got about 80 to 100 points more with ABIT with the EXACT same config as with ASUS/INTEL.......No big deal especially on air BUT when you go for the max, it counts.....Those points will be 200 - 300 on LN2 so as for me it counts.....
Ist es besser als die anderen 975X Bretter?
Lässt sich bisher noch nicht sagen, das Board hat bisher noch kein offizielles BIOS Update erfahren und ist wesentlich kürzer am Markt als Asus & Co. Es ist in jedem Fall vielversprechend und scheinbar sein Geld wert.
Welche Spannungsoptionen sind vorhanden?
VCore: 1,32V - 1,725V
VDIMM: 1,80V - 2,65V
MCH: 1,50V - 2,00V
Hat das Board auch das Shutdown Problem nach Übertaktung (vgl. Asus P5WDH)?
Nein.
Welche Straps und Teiler gibt es?
PSB533: 1:2
PSB800: 3:4, 3:5, 1:2
PSB1066: 1:1, 4:5, 2:3
Wieviele Lüfter kann ich anschliessen und was kann die Lüftersteuerung?
Das Board hat 7 Lüfteranschlüsse, jeder Lüfter ist zwischen 6 und 12V regelbar. Ausgenommen ist der CPU Lüfter, dieser kann nach Temperatur geregelt werden.
Was taugt die **** Software?
Die Software liest unter Windows Temperaturen, Spannungen, Lüftergeschwindigkeit und sogar Power Cycles aus. Übertakten in Windows ist hiermit kinderleicht möglich und funktioniert absolut einwandfrei, sofern man nicht die Grenzen der Hardware überschreitet ;)
Gibt es schon Alternativen zur **** Software?
W1zzard wird diese Woche (18.09.2006 ff) ein AW9D-Max bekommen und Support fürs Brett in SysTool einbauen.
Hilfe! Mein Board bootet einwandfrei aber ich habe trotzdem ein Piepkonzert! Ich benutze eine Wasserkühlung.
Sehr wahrscheinlich handelt es sich um das Notsignal des Boards zu Warnung vor 0 RPM am CPU Lüfter Anschluss. Das lässt sich im BIOS (abit EQ) deaktivieren.
Was hat es mit den LEDs auf sich?
Das Board besitzt blaue LEDs, die folgende Optionen besitzen: Alle LEDs an, aus oder verschieden blinkende Modi.
Ich habe von einem fehlerhaften 8 Pin EPS Stecker gelesen. Muss ich beim Board Kauf aufpassen?
Nein, ein solch fehlerhaftes Modell ist bisher weltweit nur ein einziges Mal aufgetaucht und der Fall wurde von abit direkt untersucht. Dies wird nicht mehr vorkommen.
Mein Netzteil hat nur einen 4 Pin 12V Stecker, kann ich das Board auch damit betreiben?
Ja.
Funktioniert EIST mit einem übertaktetem System?
Ja.
Hat abit auch ein BIOS Flashtool für Windows?
Ja, das abit Flashmenu ist im **** Softwarepaket enthalten und funktioniert problemlos.
Kann ich den Multi meiner CPU verstellen?
Ja, seit dem beta BIOS vom 15.09. ist es möglich, den Multi nach unten hin zu ändern. Dies gilt sowohl für ES als auch Retail CPUs.
Seit Alpha Bios 13 ist es auch möglich Multi nach oben zu verändern!
Wie gut ist der Support seitens abit für das Board?
Exzellent. abit ist bestrebt alle auftretenden Probleme so schnell wie möglich aus der Welt zu schaffen und arbeitetet dazu mit Speicherherstellern und einigen Leuten von Anandtech und XtremeSystems.org zusammen. Fortschritte werden umgehend in BIOS Updates umgesetzt.
Welche RAM Bänke soll ich nutzen? 1 und 3 oder 2 und 4?
Macht nach bisherigem Kenntnisstand keinen Unterschied.
Ein paar Bilder des Boards und der OVP bitte!
Die LEDs möcht ich auch mal sehen!
Das BIOS dann bitte auch noch.
Warum zum Teufel komme ich nur bis zu einem FSB von 350MHZ?
Fürs schnelle Testen (natürlich auf eigene Gefahr!!) am besten folgendes einstellen:
C1 und EIST disabled
VMCH: 1,75V-1,9V
DDR2 Voltage: 2,0-2,1V
Ram Timings by SPD / oder manuell
Vcore: 1,4V
Speicherteiler 1:1
Dann Testen und vorsichtig heran tasten! Gegebenfalls dann Spannungen nach unten senken!
Das ABIT ist anscheinend sehr abhängig vom richtigem RAM!
Deshalb nicht gleich aufgeben:)
WICHTIG:
Laut Hipro aus Xtremesystems undervoltet die MCH Spannung mit 0,2V!
Hier der Link zum Statement und Mod:
http://www.forumdeluxx.de/forum/showpost.php?p=4447534&postcount=1118
Hier die Vcore Tabelle von w1zzard (THX):
MIPS Wasserkühler für das ABIT AW9D-MAX
Preise:
Freezer: 39,90€
Mosfet Bridge: 43,00€
Komplettset : 155,00€
die freezer sind wie immer aufgebaut, d.h. kupferboden 5mm, messingdeckel
5mm.
Unterschiede zwischen AW9D und AW9D MAX:
Das MAX hat ne Blaue LED Rückseitenbeleuchtung+
den angewinkelten IDE Port + Firewire
Links & Downloads:
Final Bios 12 (THX@Kabautermann):
http://www.hardwarextreme.de/dave/aw9d12.rar
BIOS Downloads vom ABIT ftp server:
ftp://ftp.abit.com.tw/pub/download/bios/
Die Biosversionen fürs Non-MAX und MAX sind anscheinend die gleichen, da nur ein
AW9D Verzeichnis vorhanden ist!
Thread zum Retail Board bei Xtremesystems (Sicness:):
http://www.xtremesystems.org/forums/showthread.php?t=115839
Thread zum Retail Board im ABIT Forum (Danke Sicness):
http://forum.abit-usa.com/showthread.php?t=112896
Vielen Dank an TuricanM3 und Latest für die Pics und Scines für die FAQ
Hm, das wird genau garnichts bringen... wenn ich mir das changelog so ansehe sind das 1:1 die Änderungen die bis zum 13 beta 4 gemacht wurden.
Aber ich werds natürlich trotzdem testen ;)
hmm, klingt nicht so toll. bestimmt ist abit der meinung das man den 1333er strap erst einbauen wird, wenn die ersten 1333FSB CPUs verfügbar ist. trozdem wäre es ganz nett einem OC board schon mit dem 1.3final auszuliefern.
kann man das BIOS auch über floppy machen oder nur über die µguru software?
So Jungs habe alles bekommen aber 2 "derbe" Probs. Habe den Sonic Tower montiert. Die Lamellen passen nur von unten nach oben statt quer. Richtig?
Der Sonic Tower hat an der CPU-Seite aus Kupfer einen Ausschnitt. Dieser ist wohl für das AW9D max nicht wichtig, oder?
Das größere Prob: Mein Board hat einen Stecker Namens ATX 1 ? Der ist 8polig? Oben neben dem Anschluss für den CPU Kühler. Ich habe aber nur einen 4poligen am Netzteil ? Shit :(
OK der hier sollte es tun ja ?
http://www.yatego.com/hardwareshop4...---atx2-?sid=04Y1166731423Yef20555f54a69232fb
Steck einfach nur deinen 4poligen rein. Das geht auch. So ein Adapter kannste dir sparen.
Allerdings würde ich dir trotzdem mal demnächst zu einem neuen Netzteil raten, dass nen 8poligen hat. Ist besser.
Nitemare ausm xtremesystems Board schrieb:
That BIOS is a strike against all Abit Fans programmed by a genius !!!
Flashed it just 30 Minutes ago. After flashing I cleared CMOS. Now Im not able to overclock just 1 (ONE) single MHz !!! GRRRRRR !!!!
Everytime I set any clock frequencies in bios, save cmos and exit my system turns off, after few seconds turns on again by itself and all I´ve set is on default again !!!! But thats not all:
Im sure there are much more bugs in this time busting bios, another I´ve discovered is, I disabled Silicon Image S-ATA Raid but its still alive and wants to install in windows. Went back to check bios maybe i did something wrong but its disabled. Booted again but still in POST display both SI Raid Controller.
Shooot mee I did buy an Abit board !!!
Was bei Abit (oder eher Universal Abit) im Moment abgeht, geht echt garnicht! Und nichtmal der 1333er Strap hats ins BIOS geschafft !!! LOL
Greetz!
Greetz!
Für was 1333er Strap?
Es gibt noch keine offiziellen CPU´s von Intel mit 1333 FSB.
Weiterhin gibt es noch kein offizielles 1.3er Bios.
Auf www.abit-usa.com ist bei den Downloads 1.2 als aktuelles Bios genannt. Daher ist 1.2 das momentan stabile bzw. aktuelle.
Solange da nicht 1.3 steht ist es inoffiziell.
Irgendwelchen dubiosen Postings in den Foren hier haben überhaupt keine Bedeutung und sind mehr oder weniger Spekulation und teilweise Biose aus illegalen Quellen.
hi,
hab mal ne kleine Speicherfrage :
hatte mir 2Gb Adata Vitesta Extreme mit Micron-Chips bestellt...jedoch sind die einfach nicht mehr lieferbar :( (als ich bestellt hatte waren sie noch lieferbar..aber die Überweisung hat halt länger gedauert)
naja, jedenfalls such ich jetzt ne Alternative in der gleichen Preiskategorie, also max 240€
Da sind mir die OCZ Platinum Rev. 2 ins Auge gefallen, soll ich die nehmen, oder noch warten bis meine Adata wieder lieferbar sind?
Hab gelesen das die OCZs des öfteren Probleme auf den Intel-Borads machen, kann das jemand bestätigen?
will eigentlich 400 1:1 fahren eventuell auch mehr, sofern die CPU das schafft.
1.) 1333er Strap = entschärfte Chipsatztimings = höherer zu erwartender FSB = Geil, weil alle genau darauf seit Release des Boards warten !
2.) Zumindest soll es das Final 13 sein. Ob es schon offiziel auf der Abit Website angeboten wird oder nicht. Man findet auf dem Abit FTP auch mehr BIOSe beispielsweise fürs IC7 als auf der www. Website.
3.) Was meinst Du mit dubios und illegalen Quellen? Habe noch nie von illegalen BIOSen gehört. Selbst MOD-Biose sind meines Wissens nach net illega und werden zum Teil auch hier im Forum verlinkt oder zum Download angeboten.
GreetZ!
hi,
Da biste bei mir richtig.
ich hab davor OCZ (leider nicht Rev.2) und jetzt a-DATA. leider kommt ich mit OCZ nicht über 385. mit A-DATA komme ich jetzt noch mit 410, aber leider auch nicht Stable.
@ All
zugleich möchte ich mal um euren RAT bitten.
hab grad mit dem neuen Bios getestet. die Entscheidung ist gefallen. mein CPU ist einfach schlecht..... für 380 braucht er schon 1,475V um blend stable laufen zu können. ich bin auf 400 hoch gegangen. gleiche Vcore stoppt Orthos bei 2 Sec. Danach hab ich Vcore mal zum Testen auf 1,55v :eek: (naja, natürlich nur für kurze Zeit, hab ja Lukü :P) eingestellt. und da ist dann 1 min gelaufen.
hat jemand nen Rat für mich? soll ich etz die IHS von der CPU abschleifen um niedrigere Temp zu kriegen?
@ jcool
meinst du das liegt etz wirklich am Board, dass wir keine 400 FSB schaffen? Also das Board macht bei mir auch bei 1,85v @ 400 FSB mit.
Wenn ein Bios illegal sein soll - was erwartet mich dann bei einer ES CPU? Lebenslänglich? Nee :)
Aber fakt ist Beta Bios oder Mod Bios - die Garantie ist futsch. Das ist das Problem dabei.
@Japs: die Rev. 2 hat ja laut dem Threat hier
Powerchips oder Promoschips und die alten Elpida.
kannst dazu etwas sagen od die Promos auf dem Abit besser laufen könnten?
oder doch lieber darauf warten bis die Adatas lieferbar sind?
Und das ist aus meiner Sicht der springende Punkt.
Bios Versinen die auf dem offiziellen FTP Server von Firmen wie Abit, Asus etc. liegen dürfen selbstverständlich auch benutzt werden.
Vergess mal das Wort illegal. Das war vielleicht etwas hart ausgedrückt. Auf jeden Fall ist auch das jetzt angebliche Final 1.3 Bios nicht offiziell und von daher ist alles was hier im Forum steht inofiziell und mit einem eventuellen Garantie Verlust verbunden.
Daher würde ich lieber warten bis es offiziell auf dem Abit FTP liegt oder von der Abit Webseite verlinkt wird.
Somit bist du 100%ig immer auf der sicheren Seite.
Wegen dem 1333er Strap:
Hat Abit jemals offiziell gesagt, dass dieser 1333er Strap per Bios Update kommen soll?
Also bei mir liefen die OZC6400 Rev2 gar nicht (kein Boot Rechner geht immer An-Aus-An-...)
Hab die dann gegen die Rev1 getauscht, die laufen super.
Jo so sehe ich das auch :)
Die 1333er Strap soll für das Abit kommen? Na dann bin ich mal gesoannt wie dann die Performance aussieht
...ja, es wurde bei Release angekündigt und einen Screenshot eines Alpha BIOS mit dem besagten Strap gibt es auch schon. Der den Screenie geuppt hat ist als glaubwürdig einzustufen. Falls Dir "Hipro5" etwas sagt!? Ist sowas wie der ABit Board Mod-Gott !!!
GreetZ!
aber die scheinen ja auch nicht grad so gut auf dem Board zu laufen...also muss ich doch warten...naja bleibt wohl nix anderes übrig
Mit 2,10 V laufen die spitzenmäßig.
Ich hatte bisher mit den Speichern (siehe Signatur) absolut keine Probleme. Keine Ahnung, warum jeder schreibt, dass die Probs machen würden.
Diese Probleme betreffen mehr oder weniger alte Versionen von den Rev.2 die kein aktuelles SPD drauf haben.
Aber die neuen (also alles was die letzten 1-2 Monate ausgeliefert wird) läuft problemlos.
Also ich hatte Rev 2 die ganz frisch geliefert wurden(Vor 2 Wochen). 2 verschiedene Paar ausprobiert. Liefen beide nich.
also ich weiss nicht, ich hab mal den HS von OCZ abgemacht und auf dem RAM steht nur OCZ, mehr ist nicht zusehen. ich hab keine Ahnung was OCZ für Chips bauen. aber die laufen fast genauso gut wie die A-DATA.
Ich an deiner Stelle würde aber zur Sicherheit auf die A-DATA warten. da ist sicher dass es Micron sind. Auch wenn es nur die 3. besten Chips (D9GCT) zur Zeit verbaut ist.
kannst du 400 1:1 fahren mit denen?
Problemlos.
Zudem laufen auch alle Teiler. Egal ob DDR2-667, DDR2-800, oder halt der beliebte DDR2-533 1:1 Teiler.
Laut OCZ liegt die Betriebsspannung bei 2,00 - 2,20.
Mit 2,0 laufen die Speicher auch Top.
Zur Sicherheit gebe ich 2,10 da ich die Speicher momentan leicht übertakte. Also so ca. DDR2-838er Mode.
Mir reichen jedoch 3 GHz mit 335 FSB und DDR2-667 Teiler.
Aber wie gesagt 400 bei 1:1 machen die Teile Problemlos mit. Ich fahre diesen Takt eigentlich nur deswegen nicht, weil ich nicht die MCH erhöhen will und mir die 3 GHz momentan vollkommen ausreichen.
Ist mein Post "dubios"?
Das ist sehr seltsam.
Warum laufen meine dann ohne Probs?
Gibt es da bei OCZ solche Unterschiede?
Oder hast du vielleicht dummerweise "defekte" erwicht? Also das es mit den Speichern gar nichts zu tun hatte...
Hinzugefügter Post:
Nein, aber es ist nicht offiziell von Abit.
Damit ist deine Information inofiziell. Dubios war vielleicht etwas "schlecht" ausgedrückt.
Vielleicht kannst du mal was zu den OCZ sagen und dessen lauffähigkeit auf dem ABIT AW9D. Meine laufen ohne jegliche Probleme und bei manchen hier gehts gar nicht.
na das hört sich ja schon besser an...also das mit den 460 Rev 2
hm...mal noch wieter Erfahrungen anhören
Hinzugefügter Post:
naja, vllt kommt es ja noch auf der Abit-HP. mal warten.....
Ich habe nie Anspruch darauf erhoben, ein "offizieller abit Poster" zu sein, oder? :)
Habe die Datei aus zuverlässiger Quelle bekommen und wollte sie hier weitergeben. Es steht jedem frei, sie zu nutzen - oder eben auch nicht.
Sorry, komme nicht dazu den Thread gründlich zu lesen, was gibts für Probleme mit OCZ RAM?
Wenn du Speicher haben willst, die mit Garantie (also mit großer Sicherheit) richtig viel machen solltest du mal über Cellshock nachdenken.
Das ist so momentan das beste was du kriegen kannst.
Aber für OC im Bereich von sagen wir mal 2,8 - 3,6 GHz sollten eigentlich Rams wie die OCZ, ADATA etc. vollkommen langen und das sollte mit denen auch problemlos klappen.
Kommt halt drauf an, wie hoch du gehen willst?
Hinzugefügter Post:
Es geht um diese Rams:
OCZ Rev.2 PC800 Platinum XTC
Bei manchen (mir z.b.) laufen diese Rams auf dem Abit AW9D richtig gut (alle Teiler gehen) und die Speicher machen auch ordentlich Takt mit.
Bei anderen hingegen laufen die Rams überhaupt nicht. (schwarzer Bildschirm) also geht gar nichts.
Weisst du an was das liegen kann? Ich dachte es wären nur ältere Versionen von den OCZ Rev.2 PC800 Platinum XTC betroffen, die auf dem Abit Board probs machen. Aber wenn man die Postings hier liest, scheinen auch welche betroffen zu sein, die gerade mal 2 Wochen alt sein.
Uns würde mal interessieren, woran das liegen könnte..?
