Promise SuperTrak EX4350,EX8300,EX8350,EX12350,EX16300,EX16350 <== Sammeltread ==>
Controller Versionen:
* SuperTrak EX4350 PCIe
* SuperTrak EX8300 PCI-X
* SuperTrak EX8350 PCIe
* SuperTrak EX12350 PCIe
* SuperTrak EX16300 PCI-X
* SuperTrak EX16350 PCIe
SuperTrak SR2 includes the following components:
* BIOS version 2.04.0.12 (for SuperTrak EX4350)
* BIOS version 2.09.0.28 (for SuperTrak EX83x0 & EX163x0)
* BIOS version 2.03.0.12 (for SuperTrak EX12350)
* Firmware version 1.03.0.24
* Redboot version 1.01.0.16
* Windows Driver 3.0.0.8
* Linux Driver for 2.4 kernel version 2.24.0.10 (Include Open Source Code)
* Linux Driver for 2.6 kernel version 2.9.0.22 (Include Open Source Code)
* WebPAM for Windows version 2.2.0.53
* CLI Utility version 2.05.0.25
* PFlash (Installation Utility) version 2.08.0.11
____________________________________________________________
Operating System Support
Microsoft:
* Windows 2003 Server R2 (32/64-bit)
* Windows Vista
RedHat (kernel 2.4)
* 9.0 (32-bit)
* RHEL 3.0 (32/64-bit)
* RHEL 3.0 Update 4 (32/64-bit)
* RHEL 3.0 Update 5 (32/64-bit)
* RHEL 3.0 Update 6 (32/64-bit)
* RHEL 3.0 Update 7 (32/64-bit)
* RHEL 3.0 Update 8 (32/64-bit)
Miracle/Asianux Linux (kernel 2.4)
* 3.0
(32/64-bit)
* 3.0 SP1
(32-bit)
RedHat (kernel 2.6)
* RHEL 4.0 (32/64-bit)
* RHEL 4.0 Update 1 (32/64-bit)
* RHEL 4.0 Update 2 (32/64-bit)
* RHEL 4.0 Update 3 (32/64-bit)
* RHEL 4.0 Update 4 (32/64-bit)
Miracle/Asianux Linux (kernel 2.6)
* 4.0 (32/64-bit)
Fedora (kernel 2.6)
* Fedora Core 5 (32/64-bit)
* Fedora Core 6 (32/64-bit)
SuSE (kernel 2.6)
* 9.1 (32-bit)
* 9.2 (32/64-bit)
* 9.3 (32/64-bit)
* 10 (32/64-bit)
* 10.1 (32/64-bit)
* 10.2 (32/64-bit)
* ES9 (32/64-bit)
* ES9 SP2 (32/64-bit)
* ES9 SP3 (32/64-bit)
* ES10 (32/64-bit)
* ES10 SP1 (32/64-bit)
BIOS Revision History
BIOS changes from v2.9.0.22 to v2.9.0.28:
* fix a issue of system hang when creating spare drive by testing EX16350
* fix issue that user could not select HDD on channale 1 & 9 physical drive
into a logical drive
* add a feature for BIOS exit without reboot system,
* add BIOS disable feature in BIOS GUI
* add a hotkey to select all physical drives during logical drive creation
* add showing BGA status in Logical Driver sub-menu
* add feature to support "Automatic Rebuild Managemnet"
* add feature to support "Spare Drive Management"
* fix bug: -- In a two controller (EX4350 or EX8350) configuration, each with
an LD on each controller, ¡°Fdisk¡± will return an error when trying to
partition the LD on the second controller using either a Win98 or Win95
startup FDD
* fix bug: -- Firmware version 1.3.300.1 is falsely displayed 1.3.44.1
* fix bug: -- Each EX4350 controller has a RAID 5 array with a bootable DOS
partition on each LD. Floppy, onboard arrays, CDROM and EX4350 LDs cannot
boot in this configuration.
* fix bug: -- When accessing the superbuild utility, interfacing the menu
runs slow and buggy
noch mehr Infos gibs hier
http://www.promise.com/upload/Support/BIOS/ReadMe(SR2) of Shasta Series.txt
ATTO Bench ergebnisse:
Übersicht über Alle Raids
Vergleich Raid 0
Vergleich Raid 5
Fotos:
EX16350:
Vergleich EX16350 zu EX8350
Vergleich EX8300 zu EX8350
was können wir noch mit rein nehmen?
Bei Fragen oder Verbesserungsvorschlögen Posten
thx feichti
Microsoft:
* Windows Vista
RedHat (kernel 2.4)
* 9.0 (32-bit)
* 3.0
(32/64-bit)
* 3.0 SP1
(32-bit)
RedHat (kernel 2.6)
* 4.0 (32/64-bit)
Fedora (kernel 2.6)
SuSE (kernel 2.6)
* 9.1 (32-bit)
* 9.2 (32/64-bit)
* 9.3 (32/64-bit)
* 10 (32/64-bit)
* 10.1 (32/64-bit)
* 10.2 (32/64-bit)
* ES9 (32/64-bit)
* ES10 (32/64-bit)
startup FDD
runs slow and buggy
Vergleich Raid 0
Vergleich Raid 5
Fotos:
EX16350:
thx feichti
