blueice_haller
ein Freund hat eine Western Digital Elements 2620 die nicht mehr erkannt wird.
Verbindet ich sie mit dem USB Kabel mit meinem Notebook mit Windows 10, hört man den Sound für Geräteanschluss.
Im Gerätemanager erscheint vorübergehend die Meldung:
VirtualBox Linux, dmesg Meldungen, /dev/sdb
Vielen Dank im Voraus.
- Intel(R) USB3.0 eXtensible-Hostcontoller - 1.0 (Microsoft)
- USB-Root Hub (USB3.0)
- Unbekanntes USB-Gerät (Fehler beim Festlegen Adresse.)
[ 0.000000] Linux version 4.19.11-pmagic64 (root@darkstar) (gcc version 8.2.0 (GCC)) #1 SMP Fri Dec 21 07:23:14 CST 2018
[ 7.521299] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 7.537106] usb 2-1: New USB device found, idVendor=1058, idProduct=2620, bcdDevice=10.18
[ 7.537109] usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 7.537111] usb 2-1: Product: Elements 2620
[ 7.537112] usb 2-1: Manufacturer: Western Digital
[ 7.537113] usb 2-1: SerialNumber:
[ 12.925932] sd 2:0:0:0: [sdb] Very big device. Trying to use READ CAPACITY(16).
[ 12.927034] sd 2:0:0:0: [sdb] 9767475200 512-byte logical blocks: (5.00 TB/4.55 TiB)
[ 12.927036] sd 2:0:0:0: [sdb] 4096-byte physical blocks
[ 12.928860] sd 2:0:0:0: [sdb] Write Protect is off
[ 12.928864] sd 2:0:0:0: [sdb] Mode Sense: 47 00 10 08
[ 12.935111] sd 2:0:0:0: [sdb] No Caching mode page found
[ 12.935113] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 13.608616] udevd: 19 output lines suppressed due to ratelimiting
[ 15.048666] udevd[1545]: starting eudev-3.1.5
[ 48.892456] usb 2-1: Disable of device-initiated U1 failed.
[ 54.012576] usb 2-1: Disable of device-initiated U2 failed.
[ 54.140537] usb 2-1: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 54.152972] usb 2-1: device descriptor read/8, error -32
[ 54.260860] usb 2-1: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 54.272795] usb 2-1: device descriptor read/8, error -32
[ 54.516677] usb 2-1: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 54.529516] usb 2-1: device descriptor read/8, error -32
[ 54.636049] usb 2-1: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 54.648862] usb 2-1: device descriptor read/8, error -71
[ 55.500192] usb 2-1: USB disconnect, device number 2
[ 55.508223] sd 2:0:0:0: [sdb] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
[ 55.508227] sd 2:0:0:0: [sdb] tag#0 CDB: opcode=0x88 88 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00
[ 55.508229] print_req_error: I/O error, dev sdb, sector 0
[ 55.508232] Buffer I/O error on dev sdb, logical block 0, async page read
[ 55.508277] Dev sdb: unable to read RDB block 0
[ 55.508285] sdb: unable to read partition table
[ 55.510503] sd 2:0:0:0: [sdb] Read Capacity(16) failed: Result: hostbyte=0x01 driverbyte=0x00
[ 55.510506] sd 2:0:0:0: [sdb] Sense not available.
[ 55.510524] sd 2:0:0:0: [sdb] Read Capacity(10) failed: Result: hostbyte=0x01 driverbyte=0x00
[ 55.510525] sd 2:0:0:0: [sdb] Sense not available.
[ 55.510529] sd 2:0:0:0: [sdb] 0 512-byte logical blocks: (0 B/0 B)
[ 55.510530] sd 2:0:0:0: [sdb] 4096-byte physical blocks
[ 55.510546] sd 2:0:0:0: [sdb] Attached SCSI disk
[ 55.556466] udevd[2171]: inotify_add_watch(7, /dev/sdb, 10) failed: No such file or directory
), falls nein - abwegen wie viel die Datenwiederherstellung maximal kosten darf. Je weniger man die Festplatte jetzt einschaltet, desto besser wäre es.
