No I know for MPT, but I really need bios flash for this time. Last night I tried to use Amdvbflash.exe but that last version dosen't have GUI so for me it very complicated without help. Thanks in advance for help and please forget MPT, I used it 2 years and know about it, but it not what I need right now.
Software side flashing of a different bios is not possible with rdna2 as far as I know and as it was said before.
Du bist hier im RDNA 2-Thread. Wechsle rüber in den RDNA 3-Thread und benutze die Suchfunktion nach "programmer".
Edit: gerade erst ein paar Links gepostet.
Vous êtes ici dans le fil de discussion RDNA 2. Basculez vers le thread RDNA 3 et utilisez la fonction de recherche pour « programmeur ».
Edit : je viens de poster quelques liens.
je talk about RDNA 2 ... hope you can help me @ShirKhan . Please read my couple message before this one for understand, thanks in advance
@Sectorz You don't flash, you wanna use the MPT. Look into my OC tutorial in my signature, there is everything written besides flashing. Everything.
Create your own powerlimit with the MPT. 500W. 600W. 1000W. 100.00W - the sky is the limit - or your power supply.
Create your own power limit with the MPT. 500W. 600W. 1000W. 100.00W - the sky is the limit - or your power supply.
No ! Thanks ApolloX we talked many time 2 or 3 years ago and we used MPT, but this time, I need to FLASH, no using MPT. Everyone it the 3 or 4 time you coming back with MPT, that card is for a 14 years old boy, I don't want him using MPT. I thinked to be on the best forum for requesting helps, but if nobody know how to use AMDbvFlash last version that have no GUI (Linux or Windows what ever) I am a little dissapointed 😟. I just need to know all command I need, because I have always used the GUI method excepted with Nvflash. Thanks you all for your understanding, but I request help for flashing bios.
Habe seit gestern eine 6900XT und habe mit MPT rumgespielt, dabei ist mir aufgefallen, dass die Karte taktet wie sie lustig ist. Keine feste Spannung und Takt möglich, da die wohl innerhalb eingegebener Parameter variieren. Nach GTX 1080 ziemlich verwirrend, da dort in Afterburner einfach die Spannung und die Frequenz eingestellt und die Karte lief mit den Werten.
Zum Schluss habe ich dann aber festgestellt, dass die Karte im idle und bei Schwachlast gar nicht richtig heruntergeht. Der Speicher ist bei 2 GHz festgetackert und bei der GPU sind die 0.7 Volt die Untergrenze. Wobei der Speicher schon heruntertaktet, nur darf dabei überhaupt nichts gemacht werden. Es reicht aus ein niedrig aufgelöstes Video in MPEG2 abzuspielen und schon geht der auf die maximale 2 GHz. Am Treiber kann sowas nicht liegen.
@Sectorz: Von welcher Karte kommt das BIOS und welche ist das Ziel? Genaue Modellnamen bitte. Am besten mit direktem Link zur jeweiligen BIOS-Seite bei TPU.
@Bimer: Alles richtig so weit. Was ist deine Frage?
Na warum die Karte sich nicht runtertaktet und die Spannungen reduziert? Es muss doch eine Art von Schwellen geben, die die nächsthöhere Takt- und Spannungsstufe unterbindet, sofern die vorherige z.B. nicht die Auslastung von 70-80 % erreicht. Ich kann nur mit GTX 1080 vergleichen, die beim gleichen Szenario etwa zwischen 12 und 20 Watt verbraucht hat. Die Taktrate des Speichers lag im 2-stelligen Bereich. Und jetzt sind es entweder 200 Mhz oder gleich 2.000.
Aus dem oberen Screenshot, sieht man, dass GPU-Kern-Spannung (VDDCR_GFX) bei 0.74 V und GPU-Speicher-Spannung (VDDIO) bei 1.156 V hängen. Dabei ist die Frequenz der GPU, sich im einstelligen Bereich befindet.
Die Veränderung von Leistungsaufnahme/Temperatur/Lautstärke durch Änderungen im VRAM-Takt mögen messbar sein, sind aber nicht zu spüren. Wenn dich das aktuelle Verhalten stört, vertief dich ins MPT. Dort gibt es jede Menge Stellschrauben auch für den Speicher.
Also Äpfel mit Birnen, besser: Äpfel mit Rosinen.
Der Idle-Verbrauch der großen AMD-Karten liegt bei den meisten Usern nicht höher. Einstellige Desktop-Wattwerte hab ich bei meinen verflossenen 6900 XT und 7900 XTX zuletzt in Erinnerung.
Das sind doch nur Zahlen. Sieh nicht hin oder gewöhn dich dran.
Ja, stört es dich so sehr das deine 6900xt völlig anders als deine gtx 1080 funktioniert? Mit deiner Karte stimmt alles. Ein Video abspielen ist kein IDLE, klar geht da die Spannung und Takt hoch.
Moderne Karten boosten nicht mehr mit fixen Taktraten bei x Spannung. Das funktioniert jetzt viel dynamischer. Zwischen 2016 und heute hat sich viel getan….
Na ja, auch bei den aktuellen RTX lassen sich Takt und Spannung noch weitgehend festtackern. Ist eher ein Unterschied AMD - Nvidia.
Beim Abspielen von einem PAL MPEG2 Video, wird keine nennenswerte GPU Leistung gebraucht und Speicherleistung erst recht nicht. Das ist kein 4K AV1 10 Bit Video. Was soll der Unsinn? Sowas kann man nur absichtlich missverstehen.
Das Bild muss trotzdem dargestellt werden. Ich habe dich nicht Missverstanden.
Mit 23.8.1 funktioniert es jetzt. 22 W beim Abspielen von einem DVD Video. Der Speicher bleibt jetzt bei 200 MHz. Eine tolle Entwicklung.
@ShirKhan
sehe ich das richtig das ein RDNA2 Bios Crossflash wie gehabt nur mit Programmer oder Linux geht?
Hab meine alte 6900XT Ref. heute auf Luft zurückgebaut und vergessen vom Liquid Devil Bios wieder auf AMD Ref. Bios per Programmer zu flashen und will sie ungerne wieder auseinanderbauen od. Linux installieren.
Linux reicht auf einem Stick.
Wunderbar..dann ist das ja ezpz ohne das wieder irgendwelche Boot-Tabellen etc. von Linux installiert werden.
P.S. Hat reibungslos geklappt,dank dir.
Hatte bedenken das wenn für die PSVR2 PC Support kommt ,der USB-Port nicht richtig angesprochen wird durch das Liquid Devil Bios.Nun bin ich auf der sicheren Seite.
@Sectorz: Which card does the BIOS come from and which is the target? Exact model names please. Best with a direct link to the respective BIOS page at TPU .
@Bimer: Everything is right so far. What's your question?
The bios of the card I don't have info in front of me but it sur 99% the same as all XFX 6950 XT Black here
I will confirm you if the version is not the same in a few hours.
For the one I wanted to flash, I really wanted that card bios, but I have not found it 😞, if you ever find it on a china website or others thanks to share.
My second choice was that one (Or anyone with same Power limite that work) https://www.techpowerup.com/vgabios/246281/powercolor-rx6950xt-16384-220315-1
For the Linux, do you have one to recommend ? Last time I used Linux it was 16 years ago ...😅
They have the same device ID. Flashing should work.
It's all there.
Can you help me step by step for what do do because your screenshot is in german 😕. Hope I don't ask you to much, your screenshot seem to have so much userfull info. I never flashed with command line, that my bigguest difficulty, I am very bad in that 😅. It was easy with Nvflash with juste 2 or 3 command to write but I know it look more complicated with AMD .
Sorry, hier endet mein Service. Wenn dir das Flashen so wichtig ist, wirst du die Anweisungen abtippen und in einen Übersetzer eingeben müssen.
Gestatte mir noch ein letztes Mal den Hinweis, dass die ganze Aktion unsinnig ist. Mit dem MPT ist das, was du erreichen willst – PL-Erhöhung – im Handumdrehen erledigt. Dem Argument, die Einstellung müsse kindersicher und deshalb permanent sein, kann ich nicht folgen. Ein Sprössling, der Games spielt, die eine gepimpte 6950 XT erfordern, wird sich die drei Mausklicks merken können, die es braucht, um ein gespeichertes MPT-Setting nach einem Treiberwechsel wiederherzustellen. Wenn nicht, sind die 50 Watt plus auch nicht wichtig. Viel Erfolg.
Sorry, my service ends here. If flashing is that important to you, you'll need to type up the instructions and enter them into a translator.
Allow me to point out one last time that the whole campaign is non-sensitive. With the MPT, what you want to achieve - PL increase - is done in no time. I cannot accept the argument that the setting must be child-safe and therefore permanent. A kid who plays games that require a pimped 6950 XT will be able to remember the three mouse clicks it takes to restore a saved MPT setting after a driver change. If not, the 50 watts plus are not important either. Good luck.
Ok thanks you, but at the end what ever is the reasons, helping someone is helping someone, not just what he wants to do, it not just me but plenty of people that it can help to. Can you at least use a translator from google on your phone for translate the part from the screenshot you taked but for take a screenshot of it in english this time ? I speak French from Canada as first language 😅. Hope your not angry from my message, it just that if I want to put 4 Turbo on a Honda Civic it my decision at the end ect 😅.
Edit: it not just the drivers change, but all drivers crash error or bad restart ect. Maybe no he don't need that, like many don't need to watercool their card and do it ect. If we go like that, yes he could have a 3800X and not a 13700K watercooled with old part that clefted here & here or 6400MHz ram when 4800MHz was enough? Just find bad everyone on my case for requesting simple help for a project.
Alle benötigten Informationen wurden dir zur Verfügung gestellt, in meiner, der Sprache dieses Forums. Ich verstehe, dass eine Sprachbarriere existiert. Sie zu überwinden ist mit etwas Arbeit möglich. Natürlich kann man versuchen, auch diese Arbeit an die Hilfegebenden zu delegieren.
Nicht ärgern, nur wundern ...
All the information you need has been provided to you, in my language and the language of this forum. I understand that there is a language barrier. Overcoming them is possible with a little work. Of course, you can try to delegate this work to those providing help.
Don't worry, just wonder...
I not sur I understand what you would say, but I just wanted you going back where you taked that image on the website, but just click translate in english and take again a screenshot for post it here not more 😞
Die Quelle des Screenshots ist bereits ein Bild. Da gibt es nichts zu übersetzen für Google.
If French is your mother tongue, what prevents you from translating the text yourself?
Self-initiative counts ;)
Self-initiative counts;)
because it will take 3 hour read letter by letter and type each single words + maybe missunderstood from the "traduction" ect. If it was in english at least ok I will have translate it, I can read words and spell it 😅
The source of the screenshot is already an image. There is nothing to translate for Google.
Oh ok now I understand, I thinked it was you that taked this image / Screenshot from link you shared. Yeah I understand that it not you that dosen't want, but just it not possible.
