I tried to find the lowest E4800 vmin, 1.32v LLC6, 59/48/50 around 1.18vmin but I didn't run for long, keep in mind I have a Supercool 12th gen + chiller at 14°C :Yes i meant you, can you show me please coretemp or in HWInfo the Coretemps @ecores 4800.For me is important to know, one Cluster seems not the best on my chip.
Your chip i think is a little bit better as my one.
I dont know....if the mc voltage decoupled it can be that you can drive higher, but i'm carefull i wouldnt go over 1,6V Bios in daily.
The MC Voltage is the old IO Voltage, but they have changed something.But if i remember right, it gaves some people in OCN with high VDimm 1,7V there the chip was killed or degraded.
Perhaps it can be of the MC is 1:1 with VDimm, i don't know it, or to high Power draw over 400W+ over long time.
I have now the Z790 Strix D4, the Boards isn't better as the Z690 D4, more worse^^.But it has direct sense the difference are arround 70-80mV .
P.s.
1,28V SA@4400c15-15 and 4500 i think that is in my case not really stable and in faster as 4400 i need over 1,6V Vdimm.
Thank you very much, people here seems nicer than on OCN, I hope I won't have problems lol😅@kryptonfly welcome here @HardwareLUXX - make yourself comfortable and have a look around
This has been my impression alsoThank you very much, people here seems nicer than on OCN, I hope I won't have problems lol😅
scheinbar nichts, wurde paar Seiten vorher gesagt. Ich fragte dies auch.Was genau musste man nochmal am Iceman Direct Die kühler abschleifen/wegdremeln(?) damit das auf einem Apex Encore gut sitzt?
Ich finds nicht mehr
Danke im Voraus
Bin mir ziemlich sicher gelesen zu haben, dass der nicht ganz plan auf dem apex encore aufliegt und deswegen die Temperaturen nicht so toll wie erhofft waren. Irgendjemand hatte irgendwas gemacht (😂) und dann wars besser. (So mein Gedankenprotokoll - kann mich aber auch irren.)scheinbar nichts, wurde paar Seiten vorher gesagt. Ich fragte dies auch.
das Problem könnte denke so ausgesehen haben:Was genau musste man nochmal am Iceman Direct Die kühler abschleifen/wegdremeln(?) damit das auf einem Apex Encore gut sitzt?
Danke im Voraus
Ja klar haben die nen sinn, hab da nen streifen isoband drunter, somit ist es isoliert, druck ist da ja keiner drauf wirklichAber die Kunstoffpads haben ja ihren Sinn. Wäre es nicht besser diesee Teil abzuschleifen und trotzdem die pads behalten?
...da läuft vlt. ein wenig arg viel nebenher..... nun sicher um zu schauen wieviel der währenddessen brauch, klar... aber Discord war auch noch auf...Batch ist X337R138
6G allcore bei 22 Grad Wasser ist schon stark. 1.270V
Und max 84 Grad - super finde ich...SP nur 98!
Weniger Punkte heißt aber meist auch weniger last auf der cpu 😅. Also gut möglich das sie dann bei mehr last doch die Grätsche macht und mehr Spannung benötigt.Mir geht's nicht um Punkte...dafür nutze ich mein Bench OS...6068MHz R23 bei 1.341V
Show Off Screens or go home! 😁 😁Mir geht's nicht um Punkte...dafür nutze ich mein Bench OS...6068MHz R23 bei 1.341V
Gleiches Setup ja. Zufall...Einer aus einem.Nice! Zufallskauf oder haste das Ding selektiert (bekommen)?
Gleiches Testsetup wie bei den 13900KS damals?
Mache ich späterShow Off Screens or go home! 😁 😁
Was zählt ist die Realität. Mal sehen ob obs nen KS geben wird und wie der dann gebinnt ist ...sehr schön. Sorry, aber trotzdem hat da m.M.n. etwas ordentlich begrenzt - knapp 200W während CB? Und an der Tj-max wurde mit 115°C auch was verändert, oder etwa nicht?. Übrigens, als dieser RUN hier zu Ende war waren´s nur etwas mit 41,5K Punkte, da lief alles nebenher.Mir geht's nicht um Punkte...dafür nutze ich mein Bench OS...6068MHz R23 bei 1.341V
Sieht gut aus. Mach bitte mal mit e47 oder e48 sogar. Cache 5. P kannste auch 5.8.Batch ist X337R138
14600kf für das Daily wird sicher spaßig
Hier mit 4,7 und 5,1Sieht gut aus. Mach bitte mal mit e47 oder e48 sogar. Cache 5. P kannste auch 5.8.
Will mal sehen wie der skalliert.
Extra für Dich mit Last und noch mehr mem......sehr schön. Sorry, aber trotzdem hat da m.M.n. etwas ordentlich begrenzt - knapp 200W während CB? Und an der Tj-max wurde mit 115°C auch was verändert, oder etwa nicht?. Übrigens, als dieser RUN hier zu Ende war waren´s nur etwas mit 41,5K Punkte, da lief alles nebenher.
Lowest Vcore bei 5800....Ecores brauche ich mindestens 1,18v für 4700Sieht gut aus. Mach bitte mal mit e47 oder e48 sogar. Cache 5. P kannste auch 5.8.
