[Sammelthread] OC Prozessoren Intel Sockel 1700 (Alder Lake-S & Raptor Lake-S)
Was genau musste man nochmal am Iceman Direct Die kühler abschleifen/wegdremeln(?) damit das auf einem Apex Encore gut sitzt?
Ich finds nicht mehr
Danke im Voraus
Yes i meant you, can you show me please coretemp or in HWInfo the Coretemps @ecores 4800.For me is important to know, one Cluster seems not the best on my chip.
Your chip i think is a little bit better as my one.
I dont know....if the mc voltage decoupled it can be that you can drive higher, but i'm carefull i wouldnt go over 1,6V Bios in daily.
The MC Voltage is the old IO Voltage, but they have changed something.But if i remember right, it gaves some people in OCN with high VDimm 1,7V there the chip was killed or degraded.
Perhaps it can be of the MC is 1:1 with VDimm, i don't know it, or to high Power draw over 400W+ over long time.
I have now the Z790 Strix D4, the Boards isn't better as the Z690 D4, more worse^^.But it has direct sense the difference are arround 70-80mV .
P.s.
1,28V SA@4400c15-15 and 4500 i think that is in my case not really stable and in faster as 4400 i need over 1,6V Vdimm.
I tried to find the lowest E4800 vmin, 1.32v LLC6, 59/48/50 around 1.18vmin but I didn't run for long, keep in mind I have a Supercool 12th gen + chiller at 14°C :
Around 10°C delta P-cores and E-cores.
Vmin at 1.205v, 60/48/52, same conditions than above except with ram at 4500, SA 1.4v, TX 1.42v, Vdimm 1.65v :
I try to avoid 60°C for now, these chips are still rare. I didn't know the Z790 Strix D4 had die sense ! Some Strix DDR5 don't even have it. 1.28v SA is really low for 4400, I need 1.4v and 1.65 Vdimm at 4500 but I'm not full stable in memtest, as long as I can run bench and games it's amply enough for me.
With optimized settings.
@kryptonfly welcome here @HardwareLUXX - make yourself comfortable and have a look around
Thank you very much, people here seems nicer than on OCN, I hope I won't have problems lol😅
@kryptonfly ...
I'll write to the admin at OCN that you're a renegade, no i´m just kidding . 😉 I had to google "renegade" in german. My english is normally for runaways .....😆
scheinbar nichts, wurde paar Seiten vorher gesagt. Ich fragte dies auch.
Bin mir ziemlich sicher gelesen zu haben, dass der nicht ganz plan auf dem apex encore aufliegt und deswegen die Temperaturen nicht so toll wie erhofft waren. Irgendjemand hatte irgendwas gemacht (😂) und dann wars besser. (So mein Gedankenprotokoll - kann mich aber auch irren.)
ja habe ich auch gesehen auf OCN, aber war mir nicht mehr sicher welches Board. Der hatte auf der unteren Seite, auf einer Seite abgeschliffen, quasi Platz gemacht für die SMDs. Es gibt ja Leute die aufem Apex encore unterwegs sind und diesen Kühler haben.
Danke im Voraus
das Problem könnte denke so ausgesehen haben:
und die Lösung so:
ich hab zusätzlich noch die Kunststoffpads entfernen müssen für ordentlichen Kontakt:
Aber die Kunstoffpads haben ja ihren Sinn. Wäre es nicht besser diesee Teil abzuschleifen und trotzdem die pads behalten?
Ja klar haben die nen sinn, hab da nen streifen isoband drunter, somit ist es isoliert, druck ist da ja keiner drauf wirklich
auf den Fotos ist er schon angeschliffen, zuvor hatte ich kontakt...
Batch ist X337R138
6G allcore bei 22 Grad Wasser ist schon stark. 1.270V
Und max 84 Grad - super finde ich...SP nur 98!
Batch ist X337R138
...da läuft vlt. ein wenig arg viel nebenher..... nun sicher um zu schauen wieviel der währenddessen brauch, klar... aber Discord war auch noch auf...
5,7, 4,5 ac 4,8 cache (8200Ram) - mit nix im Hintergrund laufen.
Mir geht's nicht um Punkte...dafür nutze ich mein Bench OS...6068MHz R23 bei 1.341V
@Dancop HWLUXX OC-Team , Extrem-OC Anfänger <--- immer wieder für nen schmunzler gut wenn du mal was schreibst 😅
Weniger Punkte heißt aber meist auch weniger last auf der cpu 😅. Also gut möglich das sie dann bei mehr last doch die Grätsche macht und mehr Spannung benötigt.
Nice! Zufallskauf oder haste das Ding selektiert (bekommen)?
Gleiches Testsetup wie bei den 13900KS damals?
Gibt im OCN auch son Ding aber der hat ne niedrigere VID bzw. höhere SP. Aber da scheiß ma ja eh drauf ;) Was zählt ist die Realität. Mal sehen ob obs nen KS geben wird und wie der dann gebinnt ist o_O
Magste mal testen, mit welcher adaptive VCore Du ein setup mit 6 Ghz Allcore und 6.2 Ghz auf den Favorite Cores bei 3-4 aktiven cores stabil und WHEA-Frei durch ein paar runden Geekbench 5 oder 6 bekommst?
Äh...nö.
Das ist mir zu aufwendig. Der Chip wird zum benchen getaktet. Gezockt wird mit asus ai
...sehr schön. Sorry, aber trotzdem hat da m.M.n. etwas ordentlich begrenzt - knapp 200W während CB? Und an der Tj-max wurde mit 115°C auch was verändert, oder etwa nicht?. Übrigens, als dieser RUN hier zu Ende war waren´s nur etwas mit 41,5K Punkte, da lief alles nebenher.
14600kf für das Daily wird sicher spaßig
Mein 13600K schafft die 5.3Ghz bei 1.215v. Absolut Stabil. Was brauchst du für eine Spannung bei 5.6Ghz?
Komme dort leider thermisch an die Grenzen von Luftkühlung.
Extra für Dich mit Last und noch mehr mem...
6000 r23 und r20
6050 r23@1,323V
Wasser jetzt bei 24 Grad und er kommt trotzdem verlässlich durch.
Aber mein BIOS zeigt mir nur 98er SP :d
Sieht gut aus. Mach bitte mal mit e47 oder e48 sogar. Cache 5. P kannste auch 5.8.
Will mal sehen wie der skalliert.
Lowest Vcore bei 5800....Ecores brauche ich mindestens 1,18v für 4700
