[Übersicht] Speichertestprogramme 2026
Jeder kann testen, wie er es für richtig hält. Einen pauschal "richtigen" Weg, der für alle potenziellen Probleme und Fehler ideal ist, gibt es sowieso nicht.
Sachliche Diskussionen sind erlaubt und erwünscht, wer aber andere User ihrer Meinung wegen persönlich angreift wird von mir aus dem Thread verbannt (unbefristet).
1. Live DVD/USB Bootable
1.1. Passmark MemTest86
Homepage: MemTest86 - Official Site of the x86 Memory Testing Tool
Hardwareluxx Sammelthread:
Typ & Lizenz: Live-CD/DVD/USB, Freeware + Commercial + Business
MemTest86 is the original, free, stand alone memory testing software for x86 computers. MemTest86 boots from a USB flash drive or CD and tests the RAM in your computer for faults using a series of comprehensive algorithms and test patterns. The latest version of MemTest86 supports all the current technologies, including:
  • 13 different RAM testing algorithms
  • DDR5, DDR4 RAM, DDR3 & DDR2 support
  • XMP - high performance memory profiles
  • UEFI - The new graphical standard for BIOS
  • 64bit - From version 5, MemTest86 is native 64bit code
  • ECC RAM - support for error-correcting code RAM
  • Secure boot - With MemTest86 being code signed by Microsoft
  • Graphical interface, mouse support and logging of results to disk
  • Foreign language support (Chinese, German & more)
  • Self booting off USB or CD, without needing DOS, Linux nor Windows
  • Network (PXE) boot - Scalable, disk-less provisioning from a single PXE server
  • Dual booting - Will boot to V4 in BIOS and V7 in UEFI from a single flash drive
mt86Screen-1.png mt86Screen-2.png MemTest86-Screen-Caps-3.png MemTest86-Screen-Caps-4.png MemTest86-Screen-Caps-5.png
1.2. Stessfull application Test (Stressapptest, GSAT)
Homepage: stressapptest - Linux Mint Community
Source: stressapptest @ GitHub
Typ & Lizenz: Linux basiert, Live-CD/DVD/USB, Open Source
Stressful application test (or stressapptest, its unix name) tries to maximize randomized traffic to memory from processor and i/o, with the intent of creating a realistic high load situation in order to test the existing hardware devices in a computer. Stressapptest may be used for various purposes:
  • stress test
  • hardware qualification and debugging
  • memory interface test
  • disk testing
Bild1 Bild2 Bild3​
1.3. GoldMemory (Updated 09/2021)
Homepage: GoldMemory.cz
Typ & Lizenz: Live Medium, Freeware + Commercial (2016)
GoldMemory Advantages
  • an advanced professional memory testing software.
  • written in a "hand-tuned" pure x86 assembly language for x86 and x86-64 based computers
  • a standalone (not require operating system's)
  • supports booting from USB or CD
  • DOS-compatible (supports log file reporting)
  • allowing testing up to 64GB/1TB of memory size
  • uses proprietary algorithms customized for specific cases
  • where other standard solutions do not work
1.4. memtest86+ (Updated 01/2024)
Homepage: Memtest86+ - Advanced Memory Diagnostic Tool
Hardwareluxx Sammelthread: [Guide] Anleitung: Wie testet man RAM-Riegel mit Memtest86+ V2.01/V4.00?
Typ: Live Medium, Linux basiert
Based on the well-known original memtest86 written by Chris Brady, memtest86+ is a port by some members of the x86-secret team. Our goal is to provide an up-to-date and completly reliable version of this software tool aimed at memory failures detection.
- IMC polling for live RAM settings
- Preliminary support for ECC polling
- Add support for MMIO UART
- Add debugging options
- Bug fixes & optimizations
- Add support for Secure Boot Signing
- Add support for Headless EFI system
- Add various command line options
- Add support for legacy ATI SB400
- Fix an issue related to BadRAM pattern
- Fix disabling SMP using F2 at startup
- Fix crash on SuperMicro X10SDV
- Various bug fixes and optimizations
- Rewrite code for UEFI 32 & 64 bits
- Add support for x64 Long Mode Paging
- Add support for up to 256 cores
- Add detection for DDR4 & DDR5
- Add support for XMP 3.0
- Add detection for AMD Zen 1/2/3/4
- Add detection for Intel up to 13th Gen
- Add better support for AMD pre-ZEN CPUs
- Add support for older nVidia and AMD chipsets
- Add support for SDRAM
- Many enhancements
- Numerous bug fixes & optimization
2. Windows Anwendungen
2.1. HCI MemTest
Homepage: MemTest: RAM reliability tester for Windows
Typ & Lizenz: Windows Anwendung, Freeware + Commercial
MemTest is a RAM tester that runs under Windows. It verifies that your computer can reliably store and retrieve data from memory. A correctly functioning computer should be able to do this with 100% accuracy day in and day out. A computer that fails these tests, perhaps because of old hardware, damaged hardware, or poorly configured hardware, will be less stable and crash more often. Even worse, it will become even less stable over time as corrupted data is written to your hard disk.
By running MemTest you can ensure that your computer's RAM correctly functions. It is wise to test this when you buy a new computer, install new RAM, or change the configuration of your machine (for instance, to overclock it). Are you the sort of user who likes to push the performance of your machine to the edge? Relying upon whether your machine will boot after your new BIOS tweaks is a poor way to determine the safety of your new settings. Use Mem Test as a true test of stability.
Achtung seit 11/2019 EOL. Unterstützt MemTest Versionen bis 6.1 (Quelle).
Einstellungen: RAM to test, Number of threads, Number of rows, X/Y offset, X/Y spacing, Stop at coverage %, Stop on error (default), Start minimised (default), Window height,
Download: GitHub - integralfx/MemTestHelper: C# WinForms GUI to automate HCI MemTest
2.2. Linpack Xtreme
Homepage: https://www.ngohq.com/linpack-xtreme.html
Typ & Lizenz: Windows Anwendung & Bootable ISO, Freeware
Linpack Xtreme is a console front-end with the latest build of Linpack (Intel Math Kernel Library Benchmarks 2018.3.011). Linpack is a benchmark and the most aggressive stress testing software available today. Best used to test stability of overclocked PCs. Linpack tends to crash unstable PCs in a shorter period of time compared to other stress testing applications.
Linpack solves a dense (real*8) system of linear equations (Ax=b), measures the amount of time it takes to factor and solve the system, converts that time into a performance rate, and tests the results for accuracy. The generalization is in the number of equations (N) it can solve, which is not limited to 1000. Linpack uses partial pivoting to assure the accuracy of the results.
Linpack Xtreme was created because Prime95 is no longer effective like it used to be. LinX, IntelBurnTest, OCCT use outdated Linpack binaries from 2012. Modern hardware requires modern stress testing methodology with support for the latest instructions sets.
Linpack Xtreme is available for Windows, Linux, and as a bootable media. The bootable version is considered to be the most superior as the Linux SMP kernel is a lot more sensitive to hardware instabilities than Microsoft Windows. Watch this video for a short comparison of Prime95 vs. Linpack Xtreme.
Make sure to keep an eye on the temperatures as Linpack generates excessive amount of stress like never seen before.
2.3. Microsoft Windows Memory Diagnoctics Utility (mdsched.exe)
Homepage: -
Typ & Lizenz: Windows integriert (XP/Vst/7/8/8.1/10)
Windows includes built-in features to help you identify and diagnose problems with memory. If you suspect a computer has a memory problem that isn’t being automatically detected, you can run the Windows Memory Diagnostics utility by completing the following steps:
  • Click Start, type mdsched.exe in the Search box, and then press Enter.
  • Choose whether to restart the computer and run the tool immediately or schedule the tool to run at the next restart.
  • Windows Memory Diagnostics runs automatically after the computer restarts and performs a standard memory test automatically. If you want to perform fewer or more tests, press F1, use the Up and Down arrow keys to set the Test Mix as Basic, Standard, or Extended, and then press F10 to apply the desired settings and resume testing.
  • When testing is completed, the computer restarts automatically. You’ll see the test results when you log on.
Note that if a computer crashes because of failing memory, and Windows Memory Diagnostics detects this, the system will prompt you to schedule a memory test the next time the computer is restarted.
2.4. Karhu Software RAM Test
Homepage: RAM Test - Karhu Software
Hardwareluxx Sammelthread: [User-Review] RAM auf Stabilität testen mit RAM Test von Karhu Software
Lizenz: kommerziell
RAM Test is a fast and reliable memory testing software capable of detecting both faulty hardware and overclock instability. Its key features include:
  • An easy-to-use graphical user interface
  • Support for up to 8 TB of RAM and 64 threads
  • Optimized code paths for AVX/AVX2 capable processors
  • Portability (i.e. can be run from a USB flash drive)
User Rezensionen:
KGuiX schrieb:
Custom GUI (von jjgraphix)
Karhu-Reous-4200 16-16-19-16 10000_ 2.png Karuhu-Reous-6000 30-36-36 10000_ K259 1375 55.9 7600X2.png
2.5. TestMem5 0.13
Homepage: CoolCmd Github - TestMem5
Lizenz: Freeware
Es handelt sich um ein Rework des ursprünglichen TestMem5 0.12 von Serj (welches hier im Startbeitrag nun mit Legacy-Status geführt wird) mit diversen Fixes und Usability-Updates.
Unter anderen können in den Einstellungen des GUI nun direkt verschiedene Community-Konfigurationen ausgewählt und auch die Laufzeit direkt angepasst werden.
2.6 Aida64 Stabilitätstest
Homepage: Aida64
Typ: Windows Anwendung, kommerziell (Demo verfügbar)
Hinweis: zu finden im Menu Tools / Werkzeuge, es kann ausgewählt werden ob nur der RAM selbst oder in Kombination mit CPU/FPU/Cache getestet werden soll
AIDA64 Extreme has a hardware detection engine unrivaled in its class. It provides detailed information about installed software and offers diagnostic functions and support for overclocking. As it is monitoring sensors in real time, it can gather accurate voltage, temperature and fan speed readings, while its diagnostic functions help detect and prevent hardware issues. It also offers a couple of benchmarks for measuring either the performance of individual hardware components or the whole system. It is compatible with all 32-bit and 64-bit Windows editions, including Windows 10 and Windows Server 2019.
2.7 OCCT
Homepage: ocbase.com
Lizenz: Personal (Freeware max 1H Testdauer, oder kostenpflichtig) & Pro/Enterprise Editionen (kostenpflichtig)
OCCT is the most popular all-in-one stability check & stress test tool available.
It generates heavy loads on your components while checking for errors, and will detect stability issues faster than anything else.
OCCT embeds HwInfo's monitoring engine to get precise readings and diagnose issues faster.
2.8 RAM Test Pro
Homepage: PC Stonks (RU)
Lizenz: Freeware
RAM Test Pro – Stress Testing and Benchmarking DDR5, DDR4, DDR3 memory
Features
  • RAM stability test for modern gaming processors, workstations and server NUMA systems
  • Configurable maximum number of errors and test duration, with an optional sound alert on error detection
  • Over 10 fully customizable test algorithms
  • Built-in RAM performance benchmark
System requirements
  • CPU with SSE2 support is required, AVX2 support is mandatory when using IOAVX-Test function
  • OS: 64-bit Windows 10/11
  • RAM: at least 1 GB
2.9 Y-Cruncher
Homepage: https://www.numberworld.org/y-cruncher/ & https://github.com/Mysticial/y-cruncher
Lizenz: Freeware / Open Source
y-cruncher is a program that can compute Pi and other constants to trillions of digits. It is the first of its kind that is multi-threaded and scalable to multi-core systems. Ever since its launch in 2009, it has become a common benchmarking and stress-testing application for overclockers and hardware enthusiasts.
The main computational features of y-cruncher are:
  • Able to compute Pi and other constants to trillions of digits.
  • Two algorithms are available for most constants. One for computation and one for verification.
  • Multi-Threaded - Multi-threading can be used to fully utilize modern multi-core processors without significantly increasing memory usage.
  • Vectorized - Able to fully utilize the SIMD capabilities for most processors. (SSE, AVX, AVX512, etc...)
  • Swap Space management for large computations that require more memory than there is available.
  • Multi-Hard Drive - Multiple hard drives can be used for faster disk swapping.
  • Semi-Fault Tolerant - Able to detect and correct for minor errors that may be caused by hardware instability or software bugs.
Empfehlung für Speicher-Tests: FFTv4. N63 & VT3
Code:
@echo off
echo Start R.B.R.T Stress Test ...
y-cruncher.exe skip-warnings pause:-2 stress -D:600 -TL:6000 FFTv4 N63 VT3
echo Fin!
pause
3. Legacy Software
3.1 TestMem5
Homepage: TestMem support page - TestMem V
Lizenz: Freeware
Weitere Infos: Memory Testing with TestMem5 & Custom Configs @ Overclock.net
Features
- mehrere Testalgorithmen
- unterstützt manuelle Konfiguration aller Tests (u.a. CPU-Kerne, Speichermenge, Block Size, Laufzeit)
Es wird empfohlen für moderne Systeme ein Custom Configuration File zu verwenden.
Custom Settings - für Ryzen:
1) TM 5 0.12 1usmus config v3 (Quelle)
TM5 0.12 v3 config
TM5 @ Google Drive
after the first start of the program, delete the file cfg.link otherwise, v3 config will not work
* fixed test crash , when a certain cycle there was a shortage of memory
* 2 new test added
* test number 14 was temporarily removed, because there were few situations in which an error was found there
* special config for HEDT with 4 channel mode
2) TM 5 0.12 1usmus config v2 (Quelle)
Why this test/config?
Most of the tests work on a strict template. I think it's all a waste of time. In this configurator, the pattern is random. There is a re-allocation of memory for tests. Also, temperature-related tests for errors are added, tests in which the write and read offset occurs. For a dual rank of 5 cycles, for a single - 10, (recommendation).
Download config: Google Drive
Replace MT.cfg with it in the BIN folder.
3) anta777 Universal 2
Memory Test config file v0.02
Copyrights to the program belong to me.
Serj
testmem.tz.ru
serj_m@hotmail.com
[Main Section]
Config Name=Universal2
Config Author=LMHz
Cores=0
Tests=16
Time (%)=100
Cycles=3
Language=0
Test Sequence=4,12,2,7,9,1,14,15,2,10,11,1,5,13,2,12,4,1,9,7,2,15,14,1,13,5,2,3,1,8,2
[Global Memory Setup]
Channels=2
Interleave Type=1
Single DIMM width, bits=64
Operation Block, byts=64
Testing Window Size (Mb)=1024
Lock Memory Granularity (Mb)=16
Reserved Memory for Windows (Mb)=128
Capable=0x0
Debug Level=7
[Window Position]
WindowPosX=653
WindowPosY=397
[Test0]
Enable=1
Time (%)=100
Function=RefreshStable
DLL Name=bin\MT0.dll
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
Test Block Size (Mb)=0
[Test1]
Enable=1
Time (%)=250
Function=MirrorMove
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=4
[Test2]
Enable=1
Time (%)=250
Function=MirrorMove128
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=2
[Test3]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=1
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=256
Test Block Size (Mb)=4
[Test4]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
[Test5]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
[Test6]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=2
[Test7]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
Test Block Size (Mb)=8
[Test8]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=2
Pattern Param0=0x88888888
Pattern Param1=0x88888888
Parameter=0
[Test9]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=256
[Test10]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
Test Block Size (Mb)=1
[Test11]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=256
[Test12]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=256
[Test13]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=256
[Test14]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
Test Block Size (Mb)=16
[Test15]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=256
4) anta777 Extreme1 (Quelle)
Serj
testmem.tz.ru
serj_m@hotmail.com
[Main Section]
Config Name=Extreme1
Config Author=anta777
Cores=0
Tests=16
Time (%)=500
Cycles=3
Language=0
Test Sequence=4,6,1,12,2,4,12,2,5,7,1,13,2,5,13,2,8,9,1,14,2,8,14,2,10,11,1,15,2,10,3
Channels=2
Interleave Type=1
Testing Window Size (Mb)=1408 ; еще лучше установить 1536 но не во всех железных конфигах получится
Capable=0x0
Debug Level=7
[Window Position]
WindowPosX=63
WindowPosY=124
[Test0]
Enable=1
Time (%)=100
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
[Test1]
Enable=1
Time (%)=20
Function=MirrorMove
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=4
[Test2]
Enable=1
Time (%)=100
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=2
[Test3]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=1
Pattern Param0=0x1E5F
Pattern Param1=0x45357354
Parameter=256
[Test4]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
[Test5]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
[Test6]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=2
[Test7]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=2
[Test8]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=2
Parameter=0
[Test9]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=2
Pattern Param0=0x2305B
Pattern Param1=0x97893FB2
Parameter=2
[Test10]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=2
Pattern Param0=0x98FB
Pattern Param1=0x552FE552
Parameter=0
[Test11]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=2
Pattern Param0=0xC51C
Pattern Param1=0xC5052FE6
Parameter=2
[Test12]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=256
[Test13]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=256
[Test14]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=2
Pattern Param0=0xB79D9
Pattern Param1=0x253B69D4
Parameter=256
[Test15]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=2
Pattern Param0=0x2305A
Pattern Param1=0x1789AB54
Parameter=256
5) anta777 absolute (Quelle)
Serj
testmem.tz.ru
serj_m@hotmail.com
[Main Section]
Config Name=ABSOLUT(01102021)
Cores=0
Tests=16
Time (%)=1250
Cycles=3
Language=0
Test Sequence=1,4,6,15,3,2,7,15,5,2,8,15,4,2,9,15,3,2,10,15,5,2,11,15,4,2,12,15,5,14,15
Channels=2
Interleave Type=1
Testing Window Size (Mb)=1536
Lock Memory Granularity (Mb)=64
Reserved Memory for Windows (Mb)=512
Capable=0x0
Debug Level=7
[Window Position]
WindowPosX=400
WindowPosY=400
[Test0]
Enable=1
Time (%)=8
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
[Test1]
Enable=1
Time (%)=240
Function=SimpleTest
Pattern Mode=2
Pattern Param0=0x77777777
Pattern Param1=0x33333333
Parameter=0
[Test2]
Enable=1
Time (%)=8
Function=SimpleTest
Pattern Mode=1
Pattern Param0=0
Pattern Param1=0
Parameter=0
[Test3]
Enable=1
Time (%)=20
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=2
[Test4]
Enable=1
Time (%)=20
Function=MirrorMove
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=4
[Test5]
Enable=1
Time (%)=20
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=1
[Test6]
Enable=1
Time (%)=240
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
[Test7]
Enable=1
Time (%)=120
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
[Test8]
Enable=1
Time (%)=60
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
[Test9]
Enable=1
Time (%)=30
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
Test Block Size (Mb)=32
[Test10]
Enable=1
Time (%)=16
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
Test Block Size (Mb)=64
[Test11]
Enable=1
Time (%)=8
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
Test Block Size (Mb)=128
[Test12]
Enable=1
Time (%)=8
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
Test Block Size (Mb)=256
[Test13]
Enable=1
Time (%)=8
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
Test Block Size (Mb)=512
[Test14]
Enable=1
Time (%)=8
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
[Test15]
Enable=1
Time (%)=8
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=256
3.2. RightMark Memory Analyser (2008)
Homepage: RightMark Memory Analyzer. Products. CPU Rightmark
Typ: Windows Anwendung, Open Source
Before this test packet was created there was no proper software for measuring vital system parameters such as CPU/Chipset/RAM providing steady and reliable (reproducible) test results and allowing for changing test parameters in a wide range. Vital low-level system characteristics include latency and real RAM bandwidth, average/minimal latency of different cache levels and its associativity, real L1-L2 cache bandwidth and TLB levels specs. Besides, these aspects are usually not paid sufficient attention in product technical documentation (CPU or chipset). Such test suite, which combines a good deal of subsets aimed at measuring objective system characteristics, is a must have for estimating crucial objective platform parameters.
3.3 TechPowerUp Memtest64
Homepage: MemTest64 - Memory Stability Tester
Hardwareluxx Sammelthread: [Sammelthread] TechPowerUp MemTest64 (Windows XP/Vst/7/8/10)
TechPowerUp Memtest64 is a free lightweight, standalone utility that lets you check your system memory for problems at the hardware-level. It has a graphical interface, and can be run from within Windows.
Features
  • Runs on Windows XP, Vista, Windows 7, Windows 8, Windows 10. 64-bit OS only
  • Supports all modern processors, including Intel Core and AMD Ryzen
  • No reboot or DOS-mode required
  • You can control how much memory to test, to reduce operational impact
  • Memory is tested using various detection algorithms
  • Errors will be detected automatically
  • Does not require Administrator privileges
  • No installation or registry modifications required
attachment.php
Corsair Vengeance RGB CMR32GX4M4C3000C15 - XMP - MemTest64 V1.0 - 26 loops.png
Link zum Vorgänger-Thread (aus 2007): Speichertestprogramme Übersicht
hci hat seit version 7 glaub ich in der kauf version diesen ram:threads calculator (so nenn ich's jetzt mal :d) integriert. ggf. liegt's ja daran. hatte den irgwann mal gekauft (für updates muss man den entwickler übr. anschreiben, das prog hat keine update funktion und die website nichts im login bereich) und kenne die free version nicht, denke aber dass das update mit dem helper vllt. deshalb quer schießt?
(späte antwort, ich weiß :shot: )
Meine leicht übertaktete Ballistix 4000er liefen bis jetzt gut. Vor kurzem hatte ich einen komischen Absturz und wollte RAM nochmal ausgiebig testen. GSat und Karhu über 7000% laufen ohne Fehler. Aber Memtest86 von Passmark läuft mal ohne Fehler, dann meldet er doch Fehler, was mir bei Memtest86 aufgefallen ist, bei Fehlern (mal Test 4,6,7,9) tauchen verschiedene Adressen, aber dabei trotzdem werden in einer bestimmten gleichen Adresse auffällig oft Fehler gemeldet. Ich habe es mit verschiedene Einstellungen und letztendlich auch mit XMP Profil probiert. Und nicht immer, aber trozdem kommen im Memtest86 von Passmark sporadisch Fehler.
Kann ich jetzt davon ausgehen, dass mit RAM etwas nicht in Ordnung ist, insbesondere wenn es oft in gleicher Adresse Fehler gemeldet werden? Oder kann es eventuell auch an Board oder CPU liegen?
Ist möglich, aber nicht sehr wahrscheinlich. Würde beide Module mal einzeln testen, vielleicht ist das Ergebnis dann eindeutiger.
Welches Tool nehm ich denn wenn ich meine neuen zwei Riegel verbaue und mal testen will so grob vorweg? Ist 3600er der jetzt auf 32GB aufgestockt wird.
So der neue Speicher ist drin und memtest vom stick lauft mit welchen Einstellungen und wie lange muss ich den hci bei 32gb und 9900k testen ?
Würde für Daily-Settings mindestens 1000% laufen lassen und anschliessend noch mit einem anderen Programm und für dich relevanten Anwendungen gegen testen.
Ich wollte gerade mal meinen RAM auf Fehler testen mit Memtest. Mit welchem Programm testet man denn am besten größere Riegel (32 GB). Die 128 GB auf einmal haben mit der Anzahl von Instanzen den Rechner buchstäblich lahmgelegt. :-)
Wieso fehlt in der Liste der "System Stability Test" von Aida64?
Habe den schon für zwei Ram Sets mit jeweils zwei Test Sessions benutzt und mir eine eigen Test Methode . Zum ausloten wie niedrig ich timings setzen kann hab ich immer einen schnellen 3min Lauf gemacht. Zum fixen des Timings eine 15 Lauf. Und wenn ich mit dem kompletten Setting fertig war hab ich >60min laufen lassen.
Das mit den 60min Aida64 habe ich sogar hier aus dem Forum aus irgendeinem Sammelthread.
btw: Bei den Spielen reagiert Gears 5 sehr empfindlich auf einen nicht perfekt stabilen Ram. :)
Startbeitrag aktualisiert:
1) MemTest86+ auf Grund des 2020er Updates aus Legacy verschoben
2) TestMem5 Anta777 Konfigurationen hinzugefügt
3) Aida64 Stabilitätstest hinzugefügt
4) kleine Fehlerkorrekturen und Anpassungen der Formatierung
@Seventy7 Hast du auch noch einen Link zur Quelle, den ich verlinken könnte? Wäre auch interessant, für welche Config dies gilt.
Update: diverse Fehlerkorrekturen im Startbeitrag und OCCT hinzugefügt
Funktionierte bei mir auch ähnlich gut wie Aida64. Dabei wird aber noch stark die CPU mitbeansprucht. Weiß deswegen nicht ob das hier rein passt.
Man kann Prime95 konfigurieren um neben der CPU selbst auch den gesamten Cache und zumindest Teile des Arbeitsspeichers zu testen, aber ich würde es nicht unbedingt als Speichertest bezeichnen. Wenn jemand sich aber jemand die Mühe machen möchte und einige Konfigurationen mit RAM-Auslastung für den Startbeitrag screenshottet, trage ich es gern nach.
TechPowerUp Memtest64 schießt mir beim testen unter Server 2019 Standard reproduzierbar das System ab...
(RDP Verbindung bzw. Netzwerkverbindung bricht kurz ab, per BMC komm ich noch drauf da hängts auch schon und es hilft dann nur Hardreset)
Zudem schaffts das Tool nicht mehr den RAM zu belegen...(Server hat 512GB, aber bekomme maximal 20-25GB)
Ich habs jetzt auf 4 verschiedenen Servern getestet (alle Server 2019, 3x Xeon, 1x Epyc), überall das selbe...
Hab ich bisher immer genutzt, aber das Tool taugt nichts mehr...
Bei Memtest86+ (memtest86.org) ist seit einigen Tagen wieder Bewegung.
Eines der Urprogramme zum testen "geht der RAM überhaupt".
Dickster Punkt:
UEFI Support ist jetzt drin!
Allerdings wird Version 6 noch als Beta geführt.
Danke für den Hinweis. Eintrag aktualisiert und Screenshots ausgetauscht/ergänzt.
@scars Wenn es tatsächlich aktiv weiterentwickelt wurden wäre, hätte was daraus werden können. Aber da die Entwicklung mit Ver1.0 eingestellt wurde, wird es langfristig auch hier im Thread auf der "roten" Liste landen. Für Server gibt es aber ohnehin andere und sinnvollere Tests wie GSAT. Selbst ein Sysinternals Tool wie Testlimit64 kann man theoretisch dafür zweckentfremden.
Update: MemTest86+ V6.00
Changelog schrieb:
Released: 2022-10-23
- Many enhancements
Download: https://www.memtest.org/download/v6.00/mt86plus_6.00_USB_Installer.exe
nachdem ich meinen Ram nochmal ausgelesen habe mit Thaiphoon Burn, möchte ich der Community nochmal eine kurze Anleitung hinterlassen zur Nutzung dieses Tools unter dem aktuellen Win 11 22H2.
Liegt unten als .pdf dabei.
http://softnology.biz/files.html
Für die Installation Thaiphoon Burn Version 17 muß man die Speicherintegrität als Administrator abstellen unter folgendem Pfad
A) Systemeinstellungen
- Einstellungen
- Datenschutz und Sicherheit
- Windows Sicherheit
- Gerätesicherheit
- Kernisolierung
- Details zur Kernisolierung
Option Speicherintegrität aus
Dann Neustart notwendig
B) Registry-Einstellungen von Win11 - Regedit ändern
- Terminal öffnen (geht einfach über windows suche „terminal“ eingeben)
- regedit.exe eintippen
- open the key
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\CI\Config]
and set “VulnerableDriverBlocklistEnable”=dword:00000000
Dazu Vulnerable mit rechts anklicken- „ändern“
dann den Wert von 1 auf Null setzen und speichern (Einstellung hexa unverändert)
C) Nun kann man Thaiphoon nutzen
D) Uninstall und Rollback von Thaiphoon
Wenn man die Screenshots von Thaiphoon gespeichert hat, daran denken in den Systemeinstellungen die Speicherintegrität bei der Kernisolierung wieder zu aktivieren.
D.h. den kompletten Schritt A) wieder rückgängig
B) regedit rückgängig ist optional (d.h. Wert wieder auf 1 setzen. Geht aber schnell, weil regedit noch im pfad aufmacht)
E) Treiber deinstallieren – ssgdio64.sys
Nachdem D) erledigt ist kommt beim nächsten Neustart die Fehlermeldung, dass der Treiber nicht geladen werden konnte: ssgdio64.sys
Dieser ist im Verzeichnis c:\Windows\SysWoW64\drivers
Diese Datei einfach manuell löschen. Dann ist es erledigt
  • Thaiphoon-Meine eigene Beschreibung unter Win11.pdf
Memtest86+ v6.10 (03.02.23) @ https://www.memtest.org/
Welcher Test reagiert am sensibelsten auf zu niedrige VDIMM? Ich möchte da gern möglichst zeiteffizient etwas ausloten.
soweit ich weiss, sind Linpack und y-cruncher die härtesten RAM- tester. ich sehe seit längerem, dass buildzoid y-cruncher VST nutzt, weil seine overclocking versuche mit anderen Tests ohne Fehler durchlaufen, mit y-cruncher VST aber instabil sind.
ich weiß nicht ob ich hier richtig bin, wenn nicht erbitte ich eine Verschiebung.
Ich möchte gerne wissen wie man es am besten testet, ob der Speichercontroller in der CPU den gewählten RAM-Takt stabil in allen lagen betreiben kann?
Gibt es dazu einen speziellen Test mit einem Programm, zum Beispiel mit einem Test bei Aida64?
Das Mainboard und die RAM unterstützen höhere Taktraten, daher gilt mein Augenmerk dem Speichercontroller der CPU.
Danke
Gibt es dazu einen speziellen Test mit einem Programm, zum Beispiel mit einem Test bei Aida64.
Danke
Ja, Aida64 -> Systemstabilitätstest -> Häkchen nur bei "cache" und "memory" dann wird nur der Speichercontroller gestresst und nicht die CPU.
Ist mein Goto-Testprogramm, wenn ich neue Timings oder einen höheren Takt oder beides ausprobiere. Nach meiner langjährigen Erfahrung sollte man wenigstens Test 5-9 durchlaufen lassen. Wenn diese Tests fehlerfrei waren, sollte win ohne weiteres starten können.
Bei meiner P45 Platform traten Speicherfehler immer erst bei Testnummer 8 auf. Bei DDR5 Speicher kann man schön am Anfang sehen, ob die Einstellungen so okay waren oder nicht. Da kommen die Fehler gleich bei Test 5 bzw. Test 6. Nur selten tritt ein Fehler erst am Ende von Test 9 auf.
Bei 64 GB DDR5 Speicher dauert das etwa 20 Minuten und bei 32 GB DDR5 Speicher nur so ca. 10 Minuten.
TestMem5 0.12 nun in die Legacy Kategorie verschoben und durch CoolCmd TestMem5 (0.13) ersetzt. Es handelt sich dabei um ein Rework mit diversen Fixes und Usability-Updates. Unter anderen können in den Einstellungen des GUI nun direkt verschiedene Community-Konfigurationen ausgewählt und auch die Laufzeit direkt angepasst werden.
