[Sammelthread] Futuremark Port Royal Benchmarkthread - Rangliste
dante`afk
Legende
New York
3D Mark Port Royal ist ein Benchmark der in 3D Mark 2013 mitreinintegriert wurde. Er testet die RTX und DLSS performance.
TEMPLATE:
NICKNAME - [ url=3D MARK URL]SCORE[/url ]
Windows 10 x64 - Intel i7-4790k @ 4,6 Ghz – Asus Maximus Hero VII Z97 - 4x4GB DDR3-2133 - 2xGTX 1080 EVGA FTW 2113/5500
Rangliste Single GPU
1- 👑👑👑Dwayne_Johnson - 29269
Windows 11 x64 - Intel Core i9-13900K @ 6,0GHz (allcore) - ASUS ROG MAXIMUS Z790 APEX - 32GB DDR5-8000 MHz CL34 - 4090 ASUS TUF GAMING @ 3.195/1.494MHz
2- 👃👃👃Wolverine6 - 25 991
Windows 11 x64 - AMD Ryzen 5950X @ 4,9 Ghz – MSI MEG X570 ACE - 4x8GB DDR3-3600 G.Skill RGB - 1xRTX 4090 MSI Gaming Trio Stock
3- 🐌🐌🐌 domdtxdissar 16023
Windows 10 x64 - 5950x @ 4950mhz - MSI Unify X Max - 2x16GB DDR4-3800MT/s CL13 14 12 22 - RTX3090 MSI Suprim X 2235/1413MHz
4 - arch3990 - 15742
Windows 10 Pro x64 - Intel 11900K @ 5.60GHz - ASUS ROG Maximus XIII Apex - 16GB DDR4 3.733MHz CL14 - KFA2 RTX 3090 SG (KP-Bios)
5 - NightFly2 - 14 423
Windows 10 Pro x64 - Intel i9-9900K @ 5,0 Ghz – Asus Maximus Apex XI - 2x16GB DDR4-3900 - Asus RTX 3090 Strix OC @ 1.995 MHz/1.357
6- ZuckerKuss - 14023
Windows 10 Pro x64 - Ryzen 5 3600 @4,2GHz - ASUS X570 TuF Gaming Plus - 32GB DDR4 3.066MHz CL16 - 3090 FE @ 1983/1313
7- zebra_hun - 13041
Windows 10 x64 - Intel I9 10850k @ 5.4/5.1 Ghz – Asus Maximus Apex XIII - 2x16GB DDR4-4600MHz CL16 18 18 - RTX3080 Gigabyte Gaming OC 2190/1330MHz
8- Phoenix 12984
Windows 10 x64 - Intel i9-9900k @ 5,2 Ghz – Asus Maximus Wifi XI Z390 - 4x8GB DDR4-4400 - RTX 3080 Asus TufOC 2175/1357
9- Schmidde - 12 267
Windows 10 x64 - Intel i9-9900k @ 5,0 Ghz – Asus Maximus XI Hero - 2x16GB DDR3-3600 - RTX 3080 ASUS TUF 2100/1250
10- ApolloX - 10876
Windows 10 x64 - AMD Ryzen 7 5800X @ 4,7 Ghz – MSI B550 Gaming Edge - 2x16GB DDR4-3800 -AMD Rdeon RX 6800 XT
11- Deadeye04 10294
Windows 10 x64 - Ryzen 3700x @ 4,3 Ghz – Gigabyte AX370M-DS3H - 2x8GB DDR4-3733 CL16 - GTX 2080 ti MSI GamingTrio X 2100/8330
12- phanluxx - 10222
Windows 10 x64 - Intel 4770k @ 4,5GHz – Asus Z87 Deluxe- 4x8GB DDR3 @ 2400 MHz - AMD 6800 XT (ref) @ 2800/2150
13- Janchu88 9710
Windows 10 x64 2020H2 - Ryzen 3900X @ -0,1v – Asus TUF Gaming Plus X570 - 2x8GB DDR4-3600 CL14 - Zotac 2080TI non A 2000/8000
update #41
Rangliste Multi GPU
Last update: #17
Deadeye04 10294
mein moderates 24/7 Setup
Janchu88 9710
Mit allem auf Anschlag komme ich auch plus minus bei deadeye raus.
NightFly2 - 14 423
phanluxx - 10222
(Direktlink geht - warum auch immer, freigegeben ist es - aktuell nicht. Das scheint sich auf sämtliche 6800 XT Karten zu beziehen, geht auch bei anderen nicht. Allerdings ist es in der Topliste unter Phanni zu finden und zumindest dort sichtbar, momentan Platz 1)
Schmidde - 12 267
dante`afk - 15614
Windows 10 Pro x64 - AMD Ryzen 9 5950x @ 4,9GHz - ASUS ROG Crosshair VIII Hero - 32GB DDR4 3.800MHz CL14 - 3090 FE
ZuckerKuss - 14023
Dwayne_Johnson - 15464
Windows 10 Pro x64 - AMD Ryzen 9 5950x @ 5,15GHz - ASUS ROG Crosshair VIII Hero - 32GB DDR4 3.800MHz CL14 - Asus RTX 3090 Strix OC (mit KP-BIOS, ohne Hardware-Mod)
arch3990 - 15742
ApolloX - 10876
13 630 by p A r A
Windows 11 x64 - Intel i9-9900k @ 5,0 Ghz – Asus Maximus XI Apex Z390 - 2x16GB DDR4-3900 - RTX 3090Ti FE 1935/1188
update #13
zebra_hun - 13041
domdtxdissar 16023
Dennis50300 4604
Windows 11 x64 - 2600X @ 4gHz - MSI B450-A Pro - 2x16GB DDR3 @2800 - RTX2060 MSI XS OC
Da hatte ich mal mit am meisten rausgequetscht aus meiner 2060er in dem Bench
Gruss Dennis
update #17
Wolverine6 - 25 991
Dwayne_Johnson - 28424
Windows 11 x64 - AMD Ryzen9 5950X @ 5,2GHz - ASUS ROG STRIX X570-E GAMING - 32GB DDR4-3733 MHz CL14 - 4090 ASUS TUF GAMING @ 3.090/1.485MHz
DamirRS4 - 30 349
Windows 11 x64 - Intel 13900K 5.9 Ghz allcore - Apex Z690 - 32GB DDR5 6600MHz CL34 - RTX 4090 MSI SuprimX (mit 666 Watt Galax Bios) @ 3105/1513 mhz
Noch nicht…
War nur ein Fenster-Mod
hmm
Du Schelm :ROFLMAO:
Oder hattest du den Chiller bei deinem 3D Mark Run noch nich und hast da halt Nachts bei Minus Grade drausen das Fenster aufgemacht und so die Temp geschafft ? Aber im Dezember wars recht warm hmmm
Sind halt mal eben 17 Grad unterschied zwischen deiner Temp und meiner und ich hatte auch Fenster Mod und 19 Grad Wasser .. muss an dem Tag wo du getestet hast also sehr sehr Kalt drausen gewesen sein :d
Aber jetzt hast du ja zumindest ein Chiller was auch deine Temp erklärt
Aber ich hab dich drüben im anderen Thread bei Superposition auch schon geknackt mit meiner Strix :d .. den Ersten Pack ich aber leider nich aber zumindest Platz 2 hab ich momentan sicher
Eine Frage - hab Port Royale immer links liegen lassen, da der nur einen einzigen Kern bei mir nutzt. Ist das standard? Kann ich mir kaum vorstellen. Alles andere rannte schon immer normal.
Wie du Links oben im blauen CPU Bereich sehen kannst sind alle Kerne etwas ausgelastet
Okay danke dir. Merkwürdig. Konnte auf die Schnelle auch nichts über google finden.
hmm
Du Schelm :ROFLMAO:
Wie gesagt, der Chiller war nicht angeschlossen. Ich hab eine Differenz zwischen GPU und Wasser von nicht mal 20K und die 4 Lüfter am Mora zogen alleine schon 60W :d Da hat das Wasser quasi die gleiche Temperatur, wie die Luft am offenen Fenster ;) (Die 4090 war alleine im Loop)
Der große Chiller (über 1.700W Kühlleistung) schafft 1 Grad Wasser. Hatte aber noch keine Zeit zu verschlauchen. Kommt aber noch… ;)
:oops:
Na warte… :fire::d
19 Grad am Fenster? :hmm:
Oder mit Chiller, DICE etc.? :)
Ok dann wirst du mich ja bald wieder haben bei den Benches wenn dein Großer Chiller abchillt :d ... mehr kommt von mir wohl nich mehr da bin ich nun echt am Limit überall bei dem was mir
zur verfügung steht.... son Chiller hab ich nich sondern nur normale Wakü und ihr habt ausserdem ja noch den CPU Vorteil .. bin aber dennoch mit meiner 4090 Strix sehr zufrieden
is genau wie meine alte 3080 Strix ne super karte
Das tuhe ich .. wird sicher nich lange dauern dann hast mich wieder bei SuperPosi
Nur Fenster offen bei 10 Grad drausen über mehrere Stunden offen gelassen das Fenster ( PC steht nich direkt an dem Fenster was ich offen hatte )
hab Heute bzw von Gestern auf Heute nen Bench Marathon gemacht mit verschiedensten Benches
aber damit bin ich nun durch mehr bekomm ich da überall nich raus
Bei Superposi und bei 3D Mark Firestrike Ultra hab ich die 3195 mhz geknackt .. aber bei Superposi hatte ich mit 3180 mhz mehr punkte als mit 3195 mhz die zu 50 % der Zeit des Benchlaufs anlagen bei Posi
