V
VorauseilenderGehorsam
Guest
Sehr sexy
ok, danke und sorry. Verfolge den Thread erst seit vorgestern.![]()
[Projekt] - DAN C4-SFX & C4-MATX
Es kommt auf die Karte an. Welche Karte und welcher Block soll verbaut werden?www.hardwareluxx.de
NH-D12LVielleicht habe ich es auch nur überlesen aber welcher Noctua Kühler ist auch den Bilder verbaut?
| Dimension | C4-SFX 13.37L | C4-SFX 14.7L | |
| AMD RX 7900 XT | L=276 W=113 2.5 Slot | fit | fit |
| AMD RX 7900 XTX | L=287 W=123 2.5 Slot | fit | fit |
| AsRock RX 7900 XTX Taichi 24GB OC | L=345 W=140 3 Slot | not fit | not fit |
| AsRock RX 7900 XTX Phantom Gaming 24GB OC | L=330 W=140 2.8-slot | not fit | fit |
| Asus RX 7900 XTX TUF | L=352.9 W=158.2 3.6 Slot | not fit | not fit |
| Gigabyte AORUS RX 7900 XTX ELITE | L=335 W=137 3.5 Slot | not fit | fit |
| Gigabyte RX 7900 XT GAMING OC | L=331 W=138 2.5 Slot | not fit | fit |
| PowerColor RX 7900 XTX Hellhound | L=320 W=130 3 Slot | fit | fit |
| PowerColor RX 7900 XTX Red Devil | L=335 W=135 3.5 Slot | not fit | fit |
| Sapphire RX 7900 XTX NITRO | L=320 W=137 3.5 Slot | not fit | fit |
| Sapphire RX 7900 XTX Pulse | L=313 W=134 2,7 Slot | fit | fit |
| XFX RX 7900 Merc 310 | ~L=340 W=139 3 Slot | not fit | maybe fit |
| Asus RTX 4080/4090 ROG Strix | L=357 W=150 3,5 Slot | not fit | not fit |
| Asus RTX 4080/4090 TUF | L=348 W=152 3,65 Slot | not fit | not fit |
| ColorFul RTX 4080/4090 BattleAx | L=326 W=140 3 Slot | not fit | fit |
| ColorFul RTX 4080/4090 iGame Vulcan | L=340 W=145 3,25 Slot | not fit | not fit |
| Gainward RTX 4080/4090 Phantom | L=329 W=141,5 3,75 Slot | not fit | fit |
| Gainward RTX 4080/4090 Phoenix | L=329 W=131 3,1 Slot | not fit | fit |
| GIGABYTE RTX 4080/4090 AORUS MASTER | L=358,5 W=162,8 3,75 Slot | not fit | not fit |
| GIGABYTE RTX 4080/4090 GAMING OC | L=340 W=150 3,75 Slot | not fit | not fit |
| GIGABYTE RTX 4080/4090 WINDFORCE | L=331 W=146 3,5 Slot | not fit | fit |
| INNO3D RTX 4080/4090 iChill X3 | L=336 W=146 3,25 Slot | not fit | fit |
| INNO3D RTX 4080/4090 X3 OC | L=336 W=145 3 Slot | not fit | fit |
| KFA2/Galax RTX 4080/4090 Serious Gaming | L=336 W=138 3,5 Slot | not fit | fit |
| MSI RTX 4080/4090 Ventus X3 | L=322 W=136 3 Slot | fit | fit |
| MSI RTX 4080/4090 Gaming Trio | L=336 W=140 3,25 Slot | not fit | fit |
| MSI RTX 4080/4090 Suprim | L=336 W=142 3,75 Slot | not fit | not fit |
| Nvidia 4080/4090 Founders Edition | L=305 W=137 3 Slot | fit | fit |
| Palit RTX 4080/4090 GameRock | L=329 W=137 3,5 Slot | not fit | fit |
| PNY RTX 4080/4090 XLR8 | L=332 W=137 3,5 Slot | not fit | fit |
| Zotac RTX 4080/4090 Trinity | L=356 W=165 3,5 Slot | not fit | not fit |
| Zotac RTX 4080/4090 EMp Extreme | L=356 W=165 3,5 Slot | not fit | not fit |
Da schließe ich mich an, ich will endlich bestellenRan an den Speck. Ich bin so ready!
August 2022... was ne Zeit.Wäre es möglich diese Unikate zu erwerben?Nichts.
Triple slot GPUs are supported with a maximum length of 330mm and maximum width of 156mm
Die meisten 4070 Ti passen und auch die Asus RTX 4070Ti TUF
Selbst die Strix könnte mit etwas glück passen.Ich mache das klüger. Wenn die Frau nichts davon erfährt, muss ich nichts erklären.Muss ich nur noch meine Frau überzeugen dass das unbedingt notwendig ist.![]()
