Butanding1987
Profi
- Ort
- Philippines
- Delidded 7950X3D / 5950x
- Asrock X670E Taichi / MSI X570s Unify-X Max
- Custom loop — 2x360mm RAD, Bykski GPU block, Mycro, 3xD5/3x360mm RAD, GPU Eisblock, TechN AM4, 1xD5
- Patriot 8000@6400 CL28 / G.Skill 3800 CL14
- Sapphire 7900 XTX Nitro+ / Sapphire RX 6800 XTk Nitro+
- 3440x1440p / 3440x1440p
- 2TB Kingston Fury Renegade / 1TB Kingston KC3000
- Asus GT501 / Asus GT 502
- Corsair HX1500i / Seasonic Prime Platinum 1300w
- Windows 11
It’s pretty much the same for all cards. Remove backplate screws (and sometimes, two small screws on the bracket), then disconnect fan and RGB cables from the PCB before lifting the cooler. Remove more screws on the PCB to remove the backplate. The steps will vary depending on the card. I suggest you watch Gamers Nexus on YouTube in their disassembly of the 6900 XT card.Ok will do!!...my next step will be opening the card 😆😆 wish me luck 😑😁
Any guides on opening up a gigabyte waterforce? 😆😆😆
LOL. He might still have used the EVC2 because it’s possible to use both at the same time. It’s hard to believe he only used 1.2v.Nein, du siehst doch, dass TDV aktiviert und hochgestellt ist. @ApolloX hat den EVC2 nur, weil er die Lötstellen so hübsch findet.![]()
