[Sammelthread] Boundary Benchmark Benchmarkthread
Dennis50300
Banned
Braunschweig
Dennis50300 | 2600X@4ghz | SMT=ON | RTX 2060 MSI Ventus XS OC UV -100mhz(Curve Editor)/RAM +500 | LPX 3000@2800 (DRAM Calc.) | 43.9
Ich übernehme das mal so hier für diesen Benchmark
Holzmann | 13900KF stock| SMT=ON | RTX 4090 3GHZ/RAM 1500mhz | Ram DDR5 6600 CL30 | 234.1 FPS
Domdtxdissar | 5950x5.05/4.9 | SMT=off | RTX 3090 2.235GHZ/RAM 1412mhz | Ram DDR4 3800 CL13 | 138.2
Holzmann | 12900KS 5.4/5.6 | SMT-ON/RTX 3090 2.25ghz/RAM 1440 | RAM DDR5 6800 CL34 | 133.9 fps
Holzmann | 12900KS@ 5.4ghz | SMT=ON | RTX 3090 2.2GHZ/RAM 1440mhz | Ram DDR5 6800 CL34 | 123.6 fps
RoE187 | 5800x@4,7 ghz Allcore | SMT/HT=on | 3080Ti OCUV | GSKILL 4*8gb 4133c17+19 @3800 1t C16-17-16-34-50 | 114.1 fps
DaHell63 | R9 3900X stock | HT=ON | RTX 3070 oc | 4x8 GB DDR4-3733 CL16 | 102.0 FPS
Simply1337 | 10850k @ 5.0 gHz | HT=ON | RTX 3080 UV @1850mhz | 2x8 GB DDR4-4000 CL18 | 101.7 fps
DaHell63 | R9 3900X stock | HT=ON | RTX 3070 oc | 4x8 GB DDR4-3733 CL16 | 89.2 FPS
PogoPunk | AMD Ryzen 7 5800X | SMT=ON | RTX 3070ti | 84.7 fps
Rick001 | intel i7-8700k@3,7gHz | SMT=ON | 3060ti | 69.9 fps
kmwteam | Ryzen 9 5950X | SMT=ON | RX6900XT | 53.1 fps
el_froggo | 5800X@UV | SMT=ON | 6900XT Referenz@UV | DDR4 3800@16-19-16-16 | 51.2 fps
snakeeyes | 12900kf€5,3gHz | SMT/HT=? | 6900XT | Kingston 6000c40 @6800 2t C30 | 49.8 fps
Dennis50300 | 2700X | SMT=ON | RTX 2060 MSI Ventus XS OC +160mhz(Curve Editor)/RAM +900 | LPX 3000@2800 (DRAM Calc.) | 47.0 fps
Dennis50300 | 2600X@4ghz | SMT=ON | RTX 2060 MSI Ventus XS OC UV +140mhz(Curve Editor)/RAM +500 | LPX 3000@2800 (DRAM Calc.) | 45.7 fps
Dennis50300 | 2600X@4ghz | CPU0 & SMT=OFF | RTX 2060 MSI Ventus XS OC UV -100mhz(Curve Editor)/RAM +500 | LPX 3000@2800 (DRAM Calc.) | 44.4 fps
Dennis50300 | 2600X@4ghz | SMT=ON | RTX 2060 MSI Ventus XS OC UV -100mhz(Curve Editor)/RAM +500 | LPX 3000@2800 (DRAM Calc.) | 44.2 fps
Dennis50300 | 2600X@4ghz | CPU0 & SMT OFF, SMT=ON | RTX 2060 MSI Ventus XS OC UV -100mhz(Curve Editor)/RAM +500 | LPX 3000@2800 (DRAM Calc.) | 44.0 fps
Dennis50300 | 2600X@4ghz | SMT=OFF | RTX 2060 MSI Ventus XS OC UV -100mhz(Curve Editor)/RAM +500 | LPX 3000@2800 (DRAM Calc.) | 44.0 fps
Dennis50300 | 2600X@4ghz | CPU0 and first SMT=OFF | RTX 2060 MSI Ventus XS OC UV -100mhz(Curve Editor)/RAM +500 | LPX 3000@2800 (DRAM Calc.) | 43.9 fps
720p DLSS off
RoE187 | 5800x@4,7 ghz Allcore | SMT/HT=on | 3080Ti OCUV | GSKILL 4*8gb 4133c17+19 @3800 1t C16-17-16-34-50 | 129.2 720p dlss off
snakeeyes | 12900kf€5,3gHz | SMT/HT=? | 6900XT | Kingston 6000c40 @6800 2t C30 | 100.6 fps (720p DLSS off)
Dennis50300 | 2700X | SMT=ON | RTX 2060 MSI Ventus XS OC +160mhz(Curve Editor)/RAM +900 | LPX 3000@2800 (DRAM Calc.) | 54.5 fps (GPU-Skalierung aus)
Dennis50300 | 2700X | SMT=ON | RTX 2060 MSI Ventus XS OC +160mhz(Curve Editor)/RAM +900 | LPX 3000@2800 (DRAM Calc.) | 54.3 fps (GPU-Skalierung an)
Dennis50300 | 2600X@4ghz | SMT=ON | RTX 2060 MSI Ventus XS OC UV +140mhz(Curve Editor)/RAM +500 | LPX 3000@2800 (DRAM Calc.) | 52.1 fps (720p DLSS off)
Dennis50300 | 2600X@4ghz | SMT=ON | RTX 2060 MSI Ventus XS OC UV -100mhz(Curve Editor)/RAM +500 | LPX 3000@2800 (DRAM Calc.) | 50.6 fps (720p DLSS off)
Holzmann | 12900KS 5.4/5.6 | SMT=ON | RTX 3090 2.2GHZ/RAM 1440mhz | Ram DDR5 6800 CL34 | 123.6
Dennis50300 | 2600X@4ghz | CPU0 SMT OFF, SMT=ON | RTX 2060 MSI Ventus XS OC UV -100mhz(Curve Editor)/RAM +500 | LPX 3000@2800 (DRAM Calc.) | 44.0
Kern0 und SMT dazu weg, ist schonmal interessant, aber kaum der Rede Wert
Gruss Dennis
CPU0 und SMT allgemein raus, hier geht wohl was :-)
@Holzmann
Wenn ich nur wüsste wie @Simply1337 so eine schöne Tabelle macht :d
Gruss Dennis
Gruss Dennis
Läuft im Prinzip also auf 5 Kernen genauso wie auf 6 :d
quasi normal
Grafikkarte mal einen auf den Datz geben :d
Gruss Dennis
Dennis50300 | 2600X@4ghz | CPU0 & SMT=OFF | RTX 2060 MSI Ventus XS OC UV +140mhz(Curve Editor)/RAM +500 | LPX 3000@2800 (DRAM Calc.) | 45.5
Gruss Dennis
Also auch hier kann mal so festhalten SMT abschalten sowie 1 Kern den allerersten stehlen macht hier den Kohl nicht so fett wie bei CS:GO :-)
Gruss Dennis
Dennis50300 | 2600X@4ghz | CPU0 & SMT=OFF | RTX 2060 MSI Ventus XS OC UV +140mhz(Curve Editor)/RAM +500 | LPX 3000@2800 (DRAM Calc.) | 46.0
Blöderweise hatte ich nun ne ganze Zeit den Futuremark SystemInfo Dienst laufen gehabt, entdeckt im Task-Manager und nochmal einen drauf :d
Soviel dann auch zu dem Geschwafel das mit den Diensten würde nichts bringen und blablubber...
@Holzmann
Du solltest mal aussschau bei Intel halten nach "Engine Management" also dieses IMEI, im Geräte-Manager deaktivieren und die Dienste dazu abschiessen ;-)
Das kostet nämlich auch ganz nett Leistung, i7 2600 mit GTX 1060 hätte sonst in CS:GO auch keine 260 avg geschafft im Ulletical FPS Benchmark, wieviel das gekostet hat weiss ich allerdings nicht mehr, das ist schon zu lange her.
Gruss Dennis
Meinst du im Task Manger?
Dort finde ich IMEI oder "Engine Management" aber auch nicht.
AMD = 100% GPU limit ^^
Nenee Geräte-Manager, ansonsten im Task-Manager natürlich unter Dienste, da müsste man halt die Dienste abklappern.
Das befindet sich wenn dann hier irgendwo:
Long Story short, IMEI ist ne Abkürzung, für ich glaube so richtig benannt ist es dann mit "Intel Management Engine Interface" so müsste man es wohl richtig bezeichnen.
Kann man meistens nicht im Bios deaktivieren, aber es reicht es im Geräte-Manager zu deaktivieren und die entsprechenden Dienste eben zu deaktivieren.
Am Ende des Tages hast du besser Benchwert und mit LatencyMon lässt sich eine Verbesserung der Reaktionszeiten reproduzierbar nachweisen.
Gruss Dennis
so dann richtig ?
Gruss Dennis
Ach das sollte kein Eintrag werden, aber kannst du gerne mit aufnehmen.
5.2 4.1 4.3 und ht on
P core , e cores, chache
Soll der thread hier für nen cpu oder gpu test sein?
Welche 6900XT hast Du? Läuft sie stock? Ich konnte wohl noch etwas mehr herauskitzeln, obwohl ich auf dem Papier mit dem 5800X langsamer sein solte :)
Auf 47.8 FPS komme ich, wenn ich die 6900XT in meinem sweetspot ecomode laufen lasse (also UV bei 900mV)
Ist eigentlich die Windows Version entscheidend? :d Habe noch Windows 10 drauf :bigok:
Der Bench ist voll im GPU Limit, daher spielt die CPU keinerlei Rolle.
Die Karte läuft mit UV (1.05v), zieht im bench dann ca 230w. Das war kein max run, einfach nur mein daily.
Kk. Also auch die Referenz AMD Karte? Mein bench lief bei 1.125v, deswegen hatte ich gefragt :)
Ist ne LC aber halt im Refdesign. Macht aber keinen Unterschied.
Windows 10 kann in manchen Anwendungen/Spielen schneller sein.
Wieviel mhz liegen denn bei dir an bei 1.025v? Meine rennt da nur mit 2420mhz ca.
Den run gerade einfach noch mal gemacht, nun sind es 51 fps. Also hast schon Schwankungen drin.
Nächste noch mal leicht besser.
Also exkat wie deiner ^^
720p
DLSS OFF
RTX ON
Simply1337 | 10850K @ 5,0 GHz | HT=ON | RTX 3080 UV @ 1850 MHz | 2x8 GB DDR4-4000 CL18 | 101.7 FPS
kmwteam | 5950X @4640Mhz | SMT=ON | 6900XT@2710Mhz | Ram DDR4 3800 CL14 | 53.1 FPS
1710mhz? Vertippt und 2710 gemeint oder?
Konnte auch nochmal leicht zu legen durch noch etwas mehr GPU Takt:
Holzmann | 12900KS 5.4/5.6 | SMT=ON | RTX 3090 2.25GHZ/RAM 1440mhz | Ram DDR5 6800 CL34 | 133.9
@Termi
Was bringt deine 3090ti hier? :)
720p
DLSS OFF
RTX ON
Coole Karte hast du (als LC-Version)!
Komme bei 1125 mV auf 2550 MHz. Sorry hatte mich vertan mit der Spannung. o_ODanke für den Vergleich :wink:
Hab noch einen F1-Stream nebenher laufen gehabt.
aber zur groben Einordnung:
PogoPunk | 5800X @ PBO 130W| SMT=ON | RTX 3070 TI @ 0.875/1920MHz | Ram DDR4 3600 CL14 | 84.7
Keine Ahung was meine in dem Benchmark bei der Spannung macht, das ist einfach mein daily gewesen. Mehr takt macht da halt gelegentlich Probleme. Gut mögich das in dem Bench da noch weitaus mehr Takt drin ist.
Ist aber sinnlos da lange zu testen, wenn dann knall ich alles hoch und geh an die 3000mhz ran. Entweder max bench oder einfach daily.
Ich muss jetzt erstmal schauen das ich den Überblick wiederbekomme 😅
An und für sich ist das immer interessant, ob du was am Scheduling für die CPU gemacht hast oder nicht.
Ich hatte mal als es Assetto Corsa Competizione einige Tage umsonst habe da auch mal n bisschen herumgebencht gehabt, der Cracky von Rawiioli hatte da ja so ne Szene als Replay zum herunterladen, damit man da auch etwas vergleichbares hatte.
dürfte man auf dem Discord da noch finden wenn man möchte, ansonsten könnte ich mal gucken, aber so an sich, war da halt dann auch mit dem Afterburner gemessen, CPU0 deaktivieren und SMT brachte bessere min.-Werte oder so und da war dort dann im Discord auch der ein oder anderen sehr interessiert gewesen wie ich das angestellt hatte.
Obwohl das halt auch eher Grafikkarten zum Frühstück vernascht als das die CPU in einem Limit wäre.
Man sieht es ja auch bei CS:GO, da haut das average ja sogar einfach mal 30 Frames rein 😁
Gruss Dennis
So mal grob drübergeschaut und aktualisiert, grundsätztlich ist @ Stock ja, HT/SMT an würd ich mal sagen, wenn man was gemacht hat, wie ich mit nem Tool threads deaktiviert oder den ersten Kerne oder beides oder Bios etc. kann man es ja dazu notieren.
Gruss Dennis
Find ich interessant, ohne DLSS und RTX on, wir sollten aber auch DLSS OFF und RTX OFF testen, wenn das überhaupt geht :d
Dann könnte es für AMD Karten vs Nvidia im Vergleich auch ganz ganz ander aussehen
Gruss Dennis
Hab meine DLSS off und 720 schonmal eingetragen
Gruss Dennis
Witziger weise ist im Menü die Leistungsaufnahme höher.
Waren während des Benchmarks 291-316w
PS. Nix ausgestellt,geschlossen oder sonst was ,so wie er 24/7 im Betrieb ist ;)
Macht Sinn, guck mal was er während des Screenshots raushaut, Grafikkarte absolute Vollast und entsprechend auch mehr Last auf der CPU
Gruss Dennis
Das wäre bei einem aktuellen Game dann so wo man sagen müsste, da hat man in der Entwicklung halt gepfuscht, es gibt genügend positive Beispiele die haben nen Cap aufm Menü
Wenn ich jetzt nichts übersehen habe aktualisiert und die 720p DLSS aus Settings mal gesondert in eine Liste
