Intel Sockel 1700 - Alder Lake-S Verfügbarkeit/Laberthread + Z690 Boards + DDR5 RAM
Kann mir jemand helfen woran das liegen könnte? Bios 0811, Z690 Apex, 12900KF, DDR5 6000MHz CL36
wie Ihr oben sehen könnt - Number of Events 3517 - ich bekomme die Fehlermeldung fast sekündlich :poop:
Was steht denn bei Details?
Log Name: Microsoft-Windows-Kernel-WHEA/Errors
Source: Microsoft-Windows-Kernel-WHEA
Date: 24/12/2021 13:49:22
Event ID: 20
Task Category: None
Level: Information
Keywords: WHEA Error Events
User: SYSTEM
Computer: ggOS
Description:
WHEA Event
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-WHEA" Guid="{7b563579-53c8-44e7-8236-0f87b9fe6594}" />
<EventID>20</EventID>
<Version>0</Version>
<Level>4</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x4000000000000800</Keywords>
<TimeCreated SystemTime="2021-12-24T12:49:22.4557710Z" />
<EventRecordID>3970</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="32" />
<Channel>Microsoft-Windows-Kernel-WHEA/Errors</Channel>
<Computer>ggOS</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="Length">672</Data>
<Data Name="RawData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ata>
</EventData>
</Event>
Schlimm genug bei so einem Board und natürlich kann man nur hoffen, dass es auch "nur" beim Hero vorkommt....und als Ergänzung es auch bitte NUR Einzelfälle sind
Wenn es bei mehreren auftritt will ich natürlich nicht ausschließen, dass es hier einen Defekt geben mag, der natürlich ärgerlich ist. Allerdings wenn ich mir so manche Bilder ansehe, stelle ich fest, dass bei einigen Leuten das Geld sehr locker zu sitzen scheint. Mit welcher Sorgfalt man da arbeitet bei der Installation eines Boards, was 600€+ kostet, ist schon erstaunlich:
Sieht fast so aus, als ob man da auf Abstandshalter verzichtet hat. Dazu keine Schraube im mittleren Loch und die rechte sieht auch fast aus wie eine Holzschraube oder zumindest kaum eine, die zur Befestigung des Boards geeignet wäre. Da wundert mich ehrlich gesagt nicht, dass da was weggebrutzelt ist. Mein Hero rennt ohne Probleme, falls doch noch ein weihnachtlicher Räuchergeruch auftreten sollte, werde ich berichten 🎄
Ja, sieht echt so aus. :oOhne Abstandshalter braucht man sich da nicht zu wundern. Wobei gleich ein kleines Feuerchen.....au weia.:eek:
Ist ne blöde Suche, könntest mal anfangen deine aktuellen Einstellungen im BIOS zu speichern und mal schauen, obs mit Default Einstellungen ebenfalls auftritt...
Man sieht ja, dass die Verfärbung zumindest in diesem Fall ganz klar bis zur Schraube reicht bzw. wahrscheinlich von dort ausgeht, weil dort möglicherweise der Kurzschluss entstanden ist ^^ Wenn es wirklich eine Holzschraube ist, die sich dazu noch schön ins PCB schneidet kann da durchaus auch mal was fackeln. Mal schauen, was ASUS dazu sagen wird und wie sich das weiter entwickelt :)
Anderen RAM zum testen hast du keinen?
Wenn nein, mach mal einen Riegel raus. Wenn das nichts hilft, zweiten Riegel einzeln testen.
Tritt es erst mit dem aktuellen Version 0811 auf oder schon vorher?
Evtl mal Version 0702 probieren?
Verbogene Sockel durch starken Druck Problem. Wie ichs damals hatte
Kurzfassung des Videos:
Mainboard ins Gehäuse einbauen, Schrauben anziehen wenn alles passt. Alle Schrauben nehmen. Dann (neue) S1700 Backplate montieren. Anziehen. Dann erst CPU einsetzen und arretieren. Dann WLP + Kühler montieren. Dann sollte es passen.
wurde erwähnt ob das bei allen Z690 Boards der Fall ist oder bei einer bestimmten Marke?
Alle Bretter haben ab Werk eine Krümmung. Je billiger desto größer. Und der Sockel hat einen höheren Anpressdruck auf die CPU. Also es sind zwei Faktoren per Norm und nicht per Hersteller.
Ich habe den S1200 Kühler drauf, also brauche ich eine dicke S1200 Backplate und die Aquacomputer Backplate (Extra Stark) geht nur auf S1700. :(
besteht der Fehler auch bei ner Standard Windows Installation? ansonsten installier mal alle Chipset Treiber usw
WHEA in der Folge kenne ich nur vom Uncore, wenn der zu hoch eingestellt ist.
Wegen den WHEAs aufm Apex und den DDR5 Problemen ist mein Main bisher auch noch der 5950x geblieben.
Hm, komisch ich hab überhaupt keine WHEAs
die wheas sind einfach nur da, die sorgen nicht fuer system instabilitaet. und wie oben von @tIRREG erwaehnt,
wie kriegt man die LEDS hier an? das teil ist bei mir dunkel.
Die sind eigentlich immer an sobald das Board Strom hat und solange man die nicht im Bios ausschaltet.
Wenn die von Anfang an aus sind dann sind die Defekt oder der Stecker der Leds steckt nicht im Board.
Ich habe gerade mehrere CPUs (12900K und KF) getestet und kann euch sagen, dass der RAM nicht sauber läuft liegt beim aktuellen BIOS Stand auch an der CPU bzw. deren Unterschieden. Wärend auf der einen CPU der Teamgroup 6400 lief mit XMP lief er auf 4 andern CPUs nicht. Die CPUs waren SP94 SP86 SP86 SP84 und SP81
Gelaufen ist er auf einer der beiden SP86 CPU.
Auffällig war auch das ich die Spannungen für SA deutlich (auf dieser SP86 CPU) absenken konnte. Die Samsung Sticks liefen auf den meisten CPUs mit dem 0811 Bios mit XMP bis auf einer.
Bin mal gespannt ob Asus das in den Griff bekommt. Getestet habe ich auf nem Apex nicht auf dem Extreme.
Bin aktuell noch am rumspielen, aber ich wollte euch diese Erkenntnisse zwecks XMP nicht vorenthalten.
Ich hoffe wirklich, sollten sich deine Tests für die breite Masse bewahrheiten, dass Intel auch wirklich an einer Lösung arbeitet. Es kann ja nicht sein, dass ein überwiegender Teil der Alder Lake Besitzer nur DDR5 RAM bis 5200Mhz nutzen können, da danach die Lotterie zuschlägt, ob RAM mit niedrigeren Timings und höherem Takt überhaupt laufen. Ich war am Anfang von Alder Lake sehr überrascht, wie unproblematisch alles lief, bis ich die G.SKill Module eingebaut habe. Nach vielen Stunden rumtesten, hatte ich es dann aufgegeben. Dann der Lichtblick mit den Team Group, welche wirklich gut laufen (warum auch immer). Denke, dass es im Moment keinen Sinn macht, RAM über 5200Mhz zu kaufen, wenn man nur gamen möchte. Alles andere ist zu viel Testerei und kostet viel Nerven. Wenn man sich auskennt oder Spaß daran hat, nach 20 BSODs noch Einstellungen anzupassen, dann macht das Sinn. Allen anderen kann man nur raten, die schnelleren Module erstmal liegen zu lassen oder sein Glück zu versuchen, wenn einem 500-800€ nicht weh tun, wenn diese einige Monate ungenutzt auf dem Schreibtisch liegen.
