wer von euch hat nen i5 12600k,i7 12700k oder i9 12900k?
Latiose
Experte
Hi an alle ,wer von euch hat so eine CPU und kann was für mich testen.Sofern ihr so nett seid. Und dann wird auch geklärt wie ich es euch senden kann.Es handelt sich um VIdeoumwandeln.Es mag zwar sein das es tests gibt aber meine sind halt als Settings sehr speziell.Und keine sorge es wird nicht zu lange dauern.Und bin gespannt was für ein Pc man mit Intel für 600 € Gesammt so kriegt.Danke schon mal für eure Antwort dafür.
What software or program does it need? I have a 12900k ddr4 4133c15 2x16 i might be able to test for you. I am in the US so it needs to be English ;)
ok writing by pm,that is all for your testing.
This Video is 188+199 in simultaneously and one simultaneously in than time
I. thought you said it wouldnt take too long? We have a different idea of time ;)
Sorry, this Comication is not as easy in English as I thought. Now all tests are done. And yes, the results were really interesting. And clearly showed how good the CPU really is. And yeah, this CPU is really not that bad. And you shouldn't forget that Intel hasn't really started optimizing yet. So there will be even more with newer models in the future. And now I can also estimate how fast the lower models will be. You could now do more tests, but it wouldn't help because the behavior will not behave differently from what you saw. That is why it will go down linearly. This also helps me a lot with my decision and now it's time to weigh up what is better and more economical. Nobody can make the decision for me because I have to decide for myself. I say again many thanks for the great effort that you have given yourself. You really have it and that despite the fact that I also used google translater like you did.
Teilst du diese Testergebnisse auch mit uns? :) Hilft ja ggf. auch anderen mit ähnlichen Anwendungsfeldern
@BastiM
Ich weiß nicht was so lustig dran ist was ich da gepostet hatte. Und ich weiß ist alles nur per google translater gewesen wie er auch. Und ich finde es ist schon ne meister Leistung wenn man nicht gut englisch kann es dennoch zu schaffen weil google ja dafür bekannt ist nicht immer optimal zu übersetzen.
Und joa ich weiß das es euch interessiert. Habe auch ne liste mit allen CPUs. Und endlich mal ne neue Intel CPU. Die 9980xe ist nicht mehr aktuell. Ich frage mich was ihr sehen wollt. Ich könnte die Liste aktualiesieren die ich habe oder Bilder hochladen was ist euch lieber. Und joa so ein test sieht man echt nicht überall das ich da so gefahren lassen hatte. Die Ergebnisse sind beeindruckend. Aber auch der Stromverbrauch ist es aber da gibt es auch was mit nur 125 Watt als test. Schreibt mir ob ihr die ergebnisse als Bild oder als zahlen sehen wollt oder gar beides.
Also ich könnte mir vorstellen allen Bildern ne Nummer zu geben und dann da drunter die Zahlen. Da steht dann wie das Ergebnis erreicht wurde. Also so könnte ich das durchaus handhaben.
It was actually interesting for me to do and compare Windows 10 and Windows 11. That is what took a lot of time is booting to 2 differen OS back and forth to test. Plus I have never used that software so it was a learning curve.
Hope the resulls help you.
Es wäre natürlich nett wenn @Latiose uns noch über die Ergebnisse informieren könnte. :)
I have no idea good or bad. I might have misunderstood his "good" may have meant I ran the test correctly not good results:)
huh, that was something positive, nothing negative. Yes, it means that I am satisfied with it. I just went to the matter before without thinking too much. The last results are then in the direction of smaller CPUs what there is to buy. So you can tell the differences.
Ja ich werde alles hier dann posten,weis nur leider nicht ob ich heute noch dazu komme.Im schlimmsten Fall wird es halt dann erst am Wochende so weit sein.Dann wird es alle Bilder samt info geben und die Liste mit allen CPUs zum Vergleich hier eingefügt. Dort wird man dann auch sehen wo sie sich befinden und wie gut sie sich schlagen werden.Da wird es dann auch die CPUS 5900x und 5950x und auch die 3000 serie drin vorkommen. Sogar die Threadripper CPUS tauchen dort auf.Und wenn man sich dann das so anschauen wird,wird man feststellen wie Blass sich die Threadripper beim VIdeoumwandeln sich so anfühlt.Soviel kann ich schon mal sagen. Und als Misch CPU eignet sich ne 12900k sehr gut. Also wer so wie ich VIdeoumwandeln und zockt,für den ist die CPU Ideal.Das kann man alles dann als Ergebnis gewiss jeder für sich selbst herauslesen.Damit ist es dann die Richtige Anlaufstelle für sowas.
Es sind aber nicht alle Modelle mit dabei,also es deckt nicht alle ab.Sollte was vermissen,so kann ich die Quelldateien auch posten und diese kann dann auch jeder nachreichen.So fehlen 4 und 6 Kerner in der Liste.Aber ist klar bei 2 gleichzeitig würden die ohne hin nicht gut abschneiden gegenüber die wo mehr Kerne hat.Man erwartet ja nicht das ein 6 Kerner mit 2 Anwendung gleichzeitig gegenüber nen 10 oder mehr Kerner eine Chance haben könnte. Damit ich schon mal was gepostet habe hier ein Vorgeschmack darauf(ist noch nicht alles aktualisiert)
CPU Ergebnisse
Ryzen 7 5800H@3,2 ghz @45 Watt 7:04 & 1:35
Intel core i7 12700k @ 125 Watt 8P Kerne 4,3 ghz ohne E Kerne Windows 11 4:00 & 4:00
Intel core i9 12900k @ 74 Watt 6P 4 ghz ohne E Kerne @ Windows 11 3:57 & 2:13
Intel core i7 12700k @ 125 Watt 8P Kerne 3,8 ghz & 4E Kerne 3,6 Ghz Windows 11 3:51 & 3:51
Intel core i7 12700k @ 125 Watt 6P Kerne 4,6 ghz ohne E Kerne Windows 11 4:42 & 4:42
Intel core i7 12700k @ 125 Watt 6P Kerne 4,8 ghz & 4E Kerne 3,6 Ghz Windows 11 3:45 & 3:45
AMD treadripper 1950x ohne Übertaktung 3:30 & 3:30
Intel xenon e5 2699v4 mit ht 2,8 ghz 3:15 & 3:16
Ryzen 7 3700x @87 Watt @ 4,15 ghz 3:02 & 3:02
Intel i7 6950x auf 4 ghz 3:00 & 3:00
Ryzen 7 5700G @ 4,0 ghz bei 76 Watt 3:00 & 3:00
Intel Core i7 12700k @4,7 ghz 6P Kerne ohne E Cores = 12 Threads 3:00 & 3:00
Ryzen 7 5700G @ 4,2 ghz bei 88 Watt 2:56 & 2:37
Ryzen 7 5800x @ 76 Watt @ 3,4 ghz 2:48 & 2:41
Intel core i9 12900k @114 Watt 6P 4,5 ghz+4E 3,6 ghz @ Windows 11 2:41 & 1:37
Intel xenon e5 2699v4 ohne ht, bei 22 kernen nur 2:40 & 2:40
AMD ryzen 2920x @ 4,1 ghz 2:34 & 2:34
Intel core i9 7920x im durschnitt 4,4 ghz also aus alles Kernen gezogen 2:30 & 2:30
AMD threadripper 2970 mit ht Standard takt 2:30 & 2:25
Intel Core i7 12700k@ 4,7 ghz 8 Kerne ohne E Cores =16 Threads 2:25 & 2:25
Intel Core i9 12900K@4,0 GHz =I5 12600k 6P+4E Cores = 16 Threads 2:23&2:20
Intel Core i7 12700K@4,7 ghz 6P +4E Cores = 16 Threads 2:22&2:22
Intel core i9 12900k @125 Watt 8P 4,4 ghz+4E 3,4 ghz @ Windows 11 2:20 & 1:34
AMD 2950x @ 4 ghz 2:20 & 2:21
AMD 3900x @ 3,8 ghz 2:07 & 2:02
Intel Core i7 12700K@ 4,7 ghz 8+4 Cores =20 Threads 2:05 & 2:05
Intel Core i9 12900k @ 4,1 ghz bei 125 Watt maximal & 20 Threads begrenzt(6 Große Kerne+8HT + 6 kleine Kerne) 2:02 & 1:59
Intel core i9 12900k @4,2 ghz(4,1-4,3) 125 Watt @ Windows 11 2:02 & 1:37
Intel core i9 7960x @ 4,6 ghz 2:00 & 1:58
Core i7 14600k 1:59 & 1:19
AMD threadripper 2970wx ohne smt & ohne oc 1:58 & 1:57
AMD treadripper 2990wx @ 3,9 ghz mit smt 1:57 & 1:52
Intel core i9 9980xe mit standard 3,8 ghz 1:55 & 1:57
Ryzen 9 5900x @ 4,1 ghz 1:53 & 1:50
Intel core i9 9980xe @ 4,1 GHz 1:49 & 1:50
Intel Core i9 12900k @ 4,1 ghz bei 125 Watt maximal 1:44 & 124
Intel Core i9 9980xe @ 4,5 ghz 1:42 & 1:43
Amd 3950x mit 4,1 GHz 1:42 & 1:42
Intel Core i9 12900k @ 4,7 ghz 1:36 & 1:21
AMD Threadripper 3960x @ 4,1 ghz mit SMT 1:35 & 1:33
AMD Threadripper 3960x @ 4,1 ghz ohne SMT 22 Kerne beschränkt 134 & 1:27
AMD Threadripper 3960x @ 4,1 ghz ohne SMT 1:34 & 1:23
Intel Core i9 12900K@4,7 ghz und 6 kerne(8HT cores) & 6 kleine cores 1:33& 1:25
AMD treadripper 2990wx @ 3,9 GHz ohne smt 1:28 & 1:28
Amd Ryzen 9 5950x @ 4 bzw 4,1 ghz 1:28 & 1:27
AMD Ryzen 9 9700x @ 5,5 ghz 1:26 & 1:27
Ryzen 9 7900x 180 Watt 1:28 & 1:24
Threadripper 3970x @ 3,7 ghz - 4 GHz schwankend mit ht 1:26 & 1:26
Threadripper 3970x @ 3,7 GHz - 4 GHz schwankend ohne smt 1:25 & 1:23
Threadripper 3960x @ 4,1 ghz ohne SMT 22 Kerne beschränkt(gepinnt 11 kerne auf jeder Software jeweils) 121 & 1:22
Ryzen 9 9950x Takt durschnitt 5 GHz bis maximal 240 Watt ungebremst ,constante Bitrate crf 18 +avx 1&2 aus so wie Vorgaben 1:21 & 1:15
Core i9 14900k 200W 1:16 & 1:16
Core i9 14900ks 4,73 ghz 1:17 & 1:09
Core ultra 9 285k 248watt avx 1&2 an ,Mixed Referenz &constante quantisierung 20 p Kerne 5,1 GHz & e Kerne 4,6 GHz 1:17&0:56 Minuten
9950x3d chiplet 0 4,8 GHz & chiplet 1 4,9 GHz ,Mixed Referenz & constante quantisierung 20 1:16 & 1:08 Minute
Ryzen 9 9950x Takt durschnitt 5 GHz bis maximal 240 Watt ungebremst ,constante Bitrate crf 18 +avx 1&2 an so wie Vorgaben siehe packet 1:10 & 1:17
Core i7 14700K mit AVX 1 & AVX2 1:10 & 1:13
Threadripper 5965WX mit AVX 1 & 2 1:11 & 1:10
Ryzen 9 7950x mit 200 Watt 1:13 & 1:09
Core Ultra 285k 200 Watt dafür standard 5,4 Ghz P Kerne & 4,6 ghz e Kerne + 48 GiB DDR5-7200 Cl36 1,17 & 56
Core ultra 265k nach allen Treiber installieren Mixed Referenz + constante quantisierung 20; 1:14 & 1:01
Core Ultra 265k alles in Standard (4800 MHZ) Mixed Referenz + Constante Quantisierung 20 1:14 & 1:01 bestes Ergebnis von der CPU von mir
Core Ultra 265k alles in Standard Mixed (Referenz + Constante Quantisierung )(6400 mhz) 114 & 58 (bestes Ergebnis leider)
Ryzen 9 9950x Takt durschnitt 5 GHz bis maximal 240 Watt ungebremst ,Mixed Referenz 20+avx1&2 aus 1:11 & 1:14
Core Ultra 265k alles auf Standard und mit Vorgaben der sowie bei den ohne das es was steht 1:11 & 58
Core i7 14700k ohne avx 1:09 & 59
Core i9 13900k 320 Watt 1:07&1:07
Ryzen 9 9950x Takt durschnitt 5 GHz bis maximal 240 Watt ungebremst ,Mixed Referenz 20+avx 1&2 an 1:06 & 1:11/1:12
Core i9 14900ks avx 1 & 2 ein(alle Beschleuniger ,mit mixed Referenz & konstante quantisierung 20 5,3 GHz P Kerne 1:06 & 50
Ryzen 9 9950x3d 5,2 ghtz allcore Takt mit avx 1 und 2 ,Mixed Referenz ,constante quantisierung 20 ; 59 & 1:04
Threadripper 7960 @ 4,8 ghz & avx 1&2 ,Mixed Referenz und constante quantisierung 20 1:01 & 1:06
Threadripper 7960 @ 5 ghz & avx 1&2 ,Mixed Referenz und constante quantisierung 20 59 & 1:03
Das ist alles was dabei herausgekommen ist.Bilder samt settings kommen noch. Verwendet wurde die Software Xmedia Recode Version 3.4.3.0 bei allen Mit Windows 10.Auch etwas von mir mit dabei das mit Windows 7 betrieben wurde. Ram Takt ist das was die Plattform so hergibt. Es wird die Liste noch auf Ryzen 7 5800H akualisiert. Und mal sehen ich dachte ich hätte bei wem auch nen Ryzen 7 5700 G testet gehabt. Die fehlen noch und werden auch hier noch mit akualsiert. Ich weis es sind nicht alle Enthalten,aber ist ja nicht so einfach die restlichen CPUS als Tester zu finden.Ich hoffe ihr könnt damit was anfangen.
Warum ich da zwei zeiten angegeben habe,es wurde 2x die Software Xmedia Recode gestartet und Paralell Umgewandelt. Wie man sieht der neue Intel COre i9 schlägt sich gut insgesammt.Wo keine Wattangabe ist,ist 250 Watt verbrauch anzugeben.Also Intel könnte das noch angehen.Die Leistung ist als gut zu werten. Achja das ist alles nur H264 und kein H265 oder sonst was.Das sollte man wissen.Ergebnisse bei anderen Formaten könnten ähnliche Ergebnisse liefern,kann dazu aber nix sagen.
Es fehlt nur noch der 12600k.Denke mal es ist ersichtlich,Windows 11 scheint mit dem Programm Probleme zu haben.Es ist wohl spziell und kommt mit 2 gleichzeitig wohl in arge Probleme.Das erkennt man sehr gut das es zwei unterschiedliche Ergebnisse daher kommen.Unter Windows 10 scheint es solche Probleme nicht zu geben.Die Letzte CPU wird das Ergebnis wirklich spannend werden.Noch habe ich keinen dazu gefunden.Denke mal die Ergebisse werden nicht mehr wirklich besser werden.
Mag zwar besser geworden,aber ist leider immer noch so.Die Aktuellen CPUS gleichen jedoch die Probleme gut aus,Programm hat jedoch noch immer Probleme.Stört bei der Leistung jedoch nicht. Bin dennoch lieber mit Windows 10 unterwegs.Sobald ich mal selbst ne bessere CPU habe,kann ich gerne auch meine Ergebnisse hinzufügen.
PS der 9950x durfte ich dank eines netten Menschen Persönlich testen ,es fühlte sich an wie wenn ein Sturm in das Zimmer wehen würde. Es handelt sich um eine custom Wasserkühlung. Die CPU wurde 82 Grad warm. Das ist echt heftig. Und ich wollte einst diese CPU kaufen . War eine bessere Entscheidung gewesen es nicht zu nehmen. Soweit ich weiß kommt noch ein 7950x als real Test. Ob es daraus was wird ,sehe ich da schon noch. Erwarte mir da allerdings keine Wunder davon.
Hier mal ein Update aller neuen CPUS. Intel war nicht ganz einfach gewesen,aber es liegt an Windows 11 und ich weiß nicht wie es sich wohl das mit niedrigen Priorität aus sieht,aber minimal schneller ist es schon aber ändert nichts an dem hohen Stromverbrauch.
Nun wenn der hohe Stromverbrauch vom 13900k nicht wäre,wäre es nun endlich ein gleichwertiges ausgeglichenes Duell.Also so gleichmäßg beide sind,war es ja noch nie gewesen.Also wenn man den Stromverbrauch ausblendet,dann wäre das neue Intel wirklich besser.
so ich hole es wieder hervor.Fehlt nur noch der 14900k.Wird bestimmt angesicht dessen nicht viel bewegen,aber interessant wäre es dennoch wie der im Vergleich zu den anderen CPUS sich so Verhalten würde.Kleinere CPUS wie der 245k sind hier auch willkommen.Denn spannender als die Monster CPUS sind die ganz bestimmt mehr.Wo liegt die Schmerzgrenze und wie werden die sich so schlagen.
PS: der i7 14700k hat einzeln 47 Sekunden an Zeit gebraucht. Für die wo einzeln umwandeln ist also so eine CPU auch vollkommen ausreichend. Mit zwei erreicht man also mehr effizients.
Wenn ich Mal die beiden oben genannten wen gefunden habe ,ist somit es komplett. Ich werde keine neueren threadripper mehr suchen zum testen. Es bringt nix mehr. Das ist die logische schluss Folgerung. Mit den beiden ergebnissen endet es dann. Sollte wer das ganze nach stellen wollen ,kann mir gerne eine Pm schreiben,dann sende ich es zu. Oder ich poste es hier sofern das gewünscht ist. Es scheint ja doch einige hier zu interessieren. Von daher kann ich die Neugier schon verstehen. Sobald es sich was tut ,wird weiter aktualisiert. Also könnt gerne immer mal wieder vorbei schauen.
Mach es doch einfach öffentlich. Ich würde mir den Spaß ziehen und schauen wo ich lande.
i5-12500
Core i5 225
Core i7 265K
Core i9 285K
Dann wäre da noch ein i9-10980XE.
Ui OK also der 10980xe fehlt ,Core i5 225 und der 12500 ebenso . Bin gespannt welche Ergebnisse diese so liefern werden.
achja und der 265k am besten mit der Version die das enthält auch noch, denn es ist ja blöd wenn unterschiedliche version da getestet werden. sollte ja die selbe version sein. Genauso wie instabile cpus mit unrealistischen takt. Darum auch den 285k ebenso noch. Damit die Speerspitze richtig getestet worden ist.
Hi und wie läuft es bei dir denn so ? Weil ne PM kann ich dir ja nicht schreiben.
Ich bin aktuell nicht zu Hause. Wenn dann komme ich erst nächste Woche Montag oder Dienstag dazu.
ah ok,dann weis ich bescheid.Ist kein Problem für mich.
Achja eines habe ich vergessen. Es fehlt Mixed Referenz. Das am besten nen hacken dran. Ist Bild 8 . Das soll einen ordentlichen boost geben weil dann die CPU flexible arbeiten kann. Ich Frage mich warum ich das nicht erneuert habe das Bild.
Achja das mit dem 14900Ks habe ich als Video gefunden gehabt.Der Takt schwankte echt ganz schön und mit 87 Grad wohl schon am Limit gewesen.Kein Wunder das diese Person nur 4,73 ghz Takt hat amm laufen gehabt. Das Monster hat einfach zu hohen Stromverbrauch mit 321 Watt gehabt.Scheint wohl üblich damals gewesen zu sein.
PS einen weiteren gefunden. Dieses Mal stabil . Der 14900ks war mit 5,3 GHz und Temperatur von 90 Grad stabil gewesen. Mehr geht wirklich nicht aus dieser CPU.
Schade das sich schrotti nicht mehr meldet ,der Core i5 225 wäre noch interessant gewesen ,wie der sich so unter den harten Bedingungen so geschlagen hätte . Denn einordnet kann ich den schlecht. Es ist eindeutig das AMD wohl doch schneller ist als Intel ,wenn auch nur ein bisschen aber dafür ist AMD etwas teuer bei der Anschaffung. Ist eben eine Abwägung was einem wichtig ist. Hätte ich das gewusst wäre wohl auch der 14700k eine Option gewesen. Aber das weiß man ja erst hinter. Der 13900k hat eben die in dem Paket enthalten Einstellung. Mit den aktuellen würde der wohl auch noch etwas besser sein. In Anbetracht des Alters ,Respekt wie ich finde. Hätte ich echt nicht gedacht. Aber gut das ist wohl der aktuelle Stand halt eben. Ist dennoch interessant wie nah die an einander kleben .
Ich hab aktuell keine Zeit dafür und RAM fehlt auch.
Richtig cool wäre es ja wenn du die Ergebnisse (und Einstellungen / Parameter) in eine Excel fasst und diese auf einen Google Drive legst.
So könnte man sich die Ergebnisse übersichtlich filtern und die Prozessoren untereinander besser vergleichen. So sind die Daten zwar da aber recht unübersichtlich.
Und wenn du mal eine generelles Konklusio zu deiner Testreihe hin schreiben möchtest wäre das natürlich auch eine coole Sache.
Naja mache ich wenn ich Mal mehr Zeit habe gerne. Zur Zeit habe ich andere Probleme. Und wie mah sieht sind die beiden letzten Ergebnisse am Schlusslichtit Vorsicht zu genießen. Das der 265k um einiges schneller sein sollte hätte mich auch gewundert. Das er also in Wahrheit langsamer als der 14700k ist ist nun realistisch zu sehen. Soll ich die beiden fraglichen Ergebnisse die wo nicht stabil und so sind löschen . Denn das ist nicht so gut.
Achso dachte du hättest alle PCs komplett ,das habe ich wohl missverstanden gehabt weil es so aussah als ob du alles komplett haben würdest.
Nun gut ,war eine gute Entscheidung gewesen nicht auf dem 9950x zu gehen. Auch wenn er minimal schneller ist ,die Temperaturen sind noch schlimmer als gedacht,ohne drosseln des taktes geht da wohl nix unter Luft Kühlung. Dann ist er langsamer als ein 265k weil Takt ist hier der Gewinner.
Das der wichtiger als die Kerne sind sieht man deutlich das 200 MHz Takt unterschied hier gleich 7 Sekunden an Zeit gekostet hatte. Darum ist ja der 9950x3d auch der schnellste weil er auf 5,2 GHz Taktet. Wurde dieser auch auf 5 GHz gehen ,würde er sich nicht vom 9950x abesetzen .
Ähnliche Themen
