[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
- bei mir läuft aktuell noch mein Setting, das seit über einem Jahr stabil auf mehreren Boards läuft: 3733 MHz, CL16-17-17-32 und optimierten Subs mit 1,42V. Das Corsair Kit ist nicht das beste, daher dürfte nach oben nicht mehr viel gehen...
- kein Spulenfiepen zu hören, auch wenn ich mein Ohr auf den PC oben lege.
@Ralle86 bin gespannt auf deine Erfahrungen, insbesondere natürlich bzgl. RAM OC.
Kannst ja mal testen, ob sich mit dem Board bzgl. IF-Takt (ohne WHEAs) was ändert oder ob da alles beim Alten bleibt...
So gestern alles eingebaut bin auch sehr zufrieden mit meinem neuen X570s Unify-X Max Speicher wird besser erkannt Spannung so wie es sein soll gegenüber meinem alten Bord CPU Spannung ist auch noch mal besser geworden Ein Leistungsschub habe ich auch noch mal bekommen mein CPU taktet jetzt besser meine Grafikkarte Taktet jetzt auch höher rein rechnerisch gegenüber meinen alten Bord Sind es 10 % Zuwachs an Leistung und das schönste alles ist jetzt ruhig schön silent also für mich hat sich das gelohnt und es ist ein sehr schönes Bord Ach ja das einzigste was noch dazu gekommen ist Das hatte ich vorher nicht im bios cpu core Temperatur liegt bei 44 - 51 und CPU socket bei 34 ich weiß jetzt nicht wo der unterschied da ist aber sonst sind meine Temperaturen perfekt im Betriebsprogramm ideal 28 unter leichter Last 40
Aber sehr schnell fallend beim Spielen 57 durchschnittlich bei jedem Spiel ohne PBO
Ps ich habe keinerlei USB Probleme oder sonstiges.
Lg
10% mehr Leistung bei ansonsten gleichen Einstellungen? Von welchem Board bist du gewechselt?
Der Chipsatzlüfter auf meinem Unify X570 ist noch nie angesprungen mit der "silent" Einstellung im Bios und im gut belüfteten Gehäuse. Spannend auch, dass deine GPU höher taktet.
Es gibt eine eigene Einstellung für CPU Temperatur auf der POST-code anzeige im BIOS. Muss man zusätzlich deaktivieren mit der der Einstellung im Hauptmenü ("normale Ansicht", F7.. genaue Namen vergessen)
Denke, dass das X570s Max mehr Spielraum bietet für maximale Frequenzen im RAM OC, eventuell auch für IF > 1900. Für normale daily-settings irrelevant.
X570 Unify
Moin, neben dem RAM Sockel gibt es Status LEDs da leuchte bei mir eine rot. Kann mir jmd sagen was die besagen? Es sind nicht die 4 die CPU / RAM / GPU betreffen. Es ist eine rote LED etwas tiefer an den RAM Slots.
In der Anleitung gibt es nix dazu.
Die sagt aus, dass XMP aktiv ist.
Um deine Frage mal zu beantworten ja ich hatte das Unify X570 also den Vorgänger da ich aber massive Probleme hatte mit dem Bord wie eingefrorenes BIOS wollte nicht Booten unter sporadisch und ich sowieso geliebäugelt habe
Konnte ich nicht widerstehen ging das Bord zurück Woher der Performance Schub aussagekräftig sein könnte vielleicht Windows 11 Beta habe mein System ja neu gemacht zu den Komponenten kam noch eine mp600 pro xt 4tb und für Windows ein MP600 pro xt 1tb Vorher hat ich mp510 für das Betriebsprogramm meine Spannung beim CPU im Bios haben sich auch geändert hatte vorher 1,48 v jetzt 1,4 und der RAM hate vorher 1,545 v und jetzt 1,5 v bei der Grafikkarte kann es daran liegen dass die Tiefer Liegt jedenfalls Takte die jetzt Höhe ist auch kühler Einstellungen sind die gleichen wie beim alten Bord auch Lüfterkurve ich gehe von aus Das Bord wurde besser optimiert für die neun 5000 CPU ich habe einen 5950 X und es läuft alles viel geschmeidiger und flotter mein Lüfter ist immer angesprungen meine Karte ist auch vertikal verbaut
Ps Ach ja und alles ist schön silent sogar unterlasst.
Lg
Hast du das schon am Laufen? Hatte mit B-Die und Ace ivm. 5950X massive Probleme.
Noch nicht. Habe noch auf einen Gutschein von Alternate gewartet und wollte heute bestellen...also jetzt 8-)
Was waren denn deine Probleme?
War zwar wohl ein einzelfall, aber kannst dir ja mal durchlesen.
Ich glaube ich bin auch vom USB Bug betroffen. Habe ne Firecuda 520 2TB hier ausm MP, per USB C zu NVME Adapter an den PC angebunden. Versuche seit 2 Std. alle Daten von der 500er (3. M.2 Slot, ca 400GB) auf die 2TB zu bekommen, der Copy bricht dauern ab oder hängt sich auf.
Dann die Firecuda eingebaut, 500er an den Adapter, selbes Spiel. Nicht möglich, die Daten rüber zu bekommen.
Habe dann mal nen Testcopy von der internen 970 evo Plus (2. Slot) auf die Firecuda intern gemacht, das läuft durch wie Butter. 800 GB einwandfrei kopiert.
Was mich wundert, bekomme immer ne Meldung vom Explorer, das mein Papierkorb auf der Firecuda defekt ist, habe die SSD schon mehrmals formatiert usw. Neuster Chipsatztreiber ist drauf. Habt ihr ne Idee? Anhang anzeigen 684081
Edit:
Außerdem fällt mir gerade auf, dass der Copy von der Evo Plus zur Firecuda nicht am Limit läuft. ist eine große Datei (50GB VMDK) Sollte doch eigentlich in der nähe des max. Read der Evo Plus liegen oder nicht? (ca.3,2 GB/s) Temps sind ja alle im Rahmen. 1GB/s unter max finde ich schon schwach.
Anhang anzeigen 684088 Anhang anzeigen 684089
Zusätzlich hierzu:
Frage:
Jemand auf dem ACE das aktuellste Beta Bios (aus September LOL) 7C35v1G4(Beta version) installiert?
Ich hab so einige Stellen an denen mein Rechner nicht zufriedenstellend läuft.
Gibts bei dem BIOS bekannte Probleme und weiß man, wann die latest stable rauskommt?
Ja hab ich. Aber bei mir läuft alles rund.
@reinhardrudi
Auf wie viel lässt Du deinen 5800x allcore laufen?
Hab nur PBO on, CO -15 , Watt 130w, 95 und 130 AMP.
RAM auf 3800 1,4v und IF 1900.
Läuft super. Allcor geht er teilweise auf 4800- 4850 , kurzfristig aber eher sehr selten unter 4750 allcore.
Boost auf 4950mhz.
Wie, auf allen Kernen einfach nur -15?
Sieht aber nicht getestet aus... 🤪
Bei CurveOptimizer sind Stresstests zwingend für die Stabilität, sonst gibt's mal im ungünstigsten Moment einen Fehler.
Nachdem man die Cores wirklich auf Fehler testet, kriegt man dann eine ganz bunte Mischung an wirklich stabilen Werten (wie bspw. -5, -15, - 8, -25 usw.)
Jo mit dem BoostTester jeden einzelnen Kern optimiert dadurch hab ich jetzt 3 Kerne mit 5,050GHz die restlichen 12 sind von 4.900-4,975 und es ist stabil.Ist aufwendig das zu ermitteln und zu testen aber lohnt sich.
lass mal den Corecycler über Nacht durchlaufen. Der wirft wahrscheinlich noch Fehler
Einfach mit Cinebench und HWInfo testen. HWInfo sagt dann beim Boost welche Spannung anliegt und dann einfach gucken welcher Takt bei welcher Spannung läuft. Aber als Anhaltspunkt hat man immerhin schon mal einen Paar aus Spannung und Boost zur Orientierung.
Dann noch ein paar Mal Cinebench oder was anderes laufen und schon weißt Du ob das ansatzweise stabil läuft.
...so hab ich das gemacht mit den 4.200Mhz allcore und 1.225 V beim 3900x...läuft prima
Alles andere ist wahrscheinlich nur für Leute mit zu viel Zeit 8-)
Und Grund war nicht die Performance, sondern dass die Lüfter (bei Luft) nicht immer dem komischen Boost nachjagen....kühler läuft es zudem seitdem auch noch
nöö- hab ich auch nicht. zu aufwendig. ich kann alles mit meinem PC was ich machen will-und das stundenlang wenns sein muss das reicht mir. ich würde das system als stabil bezeichnen. alles problemlos und performant.
Wäre für mich in etwa das gleiche wie Auto fahren mit fehlender Tankanzeige.
Hallo zusammen,
habe gestern auf das neuste Bios geupdatet. Nach dem ersten Neustart ging der Rechner an, aber ich hatte kein Bild. Rechner lief bisher einwandfrei, nur der CPU Takt lag im Idle im bei 3600 Mhz, deswegen das Bios Update.
Habe dann einen CMOS Reset gemacht, doch das Problem war dasselbe. Da ich zwei Monitore am Rechner hängen habe, kam mir die Idee, nur den hängen zu lassen der über HDMI angeschlossen ist und tada ein Bild.
Jetzt komm ich zwar ins UEFI Bios kann aber mein Laufwerk auf welchem Windows installiert ist nicht auswählen, obwohl es in der Übersicht dargestellt wird. Kann nur die ganzen UEFI Geschichten auswählen (UEFI USB, UEFI HDD, usw.).
Jemand ´ne Ahnung, wie ich in Windows komme?
5900x
Crucial Ballistix Elite 16 GB
2 x Samsung SSD (840 Pro, 850 Evo)
1 x Samsung 980 Pro 1 TB
Gainward Gtx 1080
Sicherlich nutzt du den CSM-Mode, der nach dem Zurücksetzen des BIOS inaktiv ist. Davon abgesehen ist es normal, dass der Idle-Takt mit dem Standard-Energieschema von Windows bei 3.600 MHz liegt. Es gibt aber Mittel und Wege, den weiter herabzusetzen, was gleichzeitig auch die Idle-VCore betrifft.
Okay, was ist der CSM Mode? Bei AMD gab es doch immer Cool and Quiet? Hatte jetzt ewig lange ´ne Intel CPU. Mein letzte AMD CPU war der 3800+
Kannst du mir vielleicht sagen, wie ich wieder in Windows komme? Bitte!
Ersten Post etwas angepasst, mit Reviews für die neuen Boards und Produktlinks hinzugefügt.
Auf der MSI-Seite gibt es den Chipsatztreiber 3.10.22.706 vom 02.11.2021 und bei AMD 3.10.08.506 vom 21.10.2021.
Kann es wirklich sein, das der Chipsatztreiber bei MSI aktueller ist oder hat MSI eine eigene Version?
EDIT:
Ich habe jetzt weitere Infos zu meiner Frage gefunden:
Der Chipsatztreiber ist ein Paket mit mehreren Treibern. Ich habe den aktuellen von AMD installiert (Win10).
MSI hat eine andere Version vom AMD Processor Power Management Support Treiber dabei, die anderen Pakete haben die gleiche Versionsnummer.
Mehr Infos habe ich nicht :)
...oder hier: https://www.reddit.com/r/Amd/comments/qma864/windows_11_new_power_plan_7044_7035_was_the_cppc/
So kann man die eigene Version checken:
1. Hold down the Windows logo key and press "X" to open a menu at the
lower-left area of the screen.
2. Press "N" key to open Settings
3. Click "Account".
4. Click "Access work or school"
5. Click "Add or move aprovisioning package" left area of the screen
6. Click "AMD.Power.Processor.Setting"
7. Click "Detail"
Ich hab meine Versuche eingestellt und bin zurück auf stock 3600 16-18-18-38.
Alles mit 3800 auf dem Speicher wird irgendwann instabil -ich habe damit aber auch zu wenig Erfahrung.
Die Werte vom DRAM-Calculator kann ich auch nicht als groben Richtwert nehmen.
Prizipjell machen Board und CPU das mit -gehört daher wohl eher in einen OC-Speicherthread.
Jungs, ich warte seit Wochen auf eure Fabric/RAM OC Ergebnisse :geek:
soweit ich weiß, hat es noch keine AGESA geschafft, die WHEA Probleme bei IF >1900 in iregend einer Form zu verbessern. Aber vielleicht wirds ja mit 1.2.0.5 was
Ähnliche Themen
