[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Das musst du selbst Wissen ob du das Update brauchst. Wenn alles läuft las es, wenn nicht mach das Update. Ansonsten ist die Frage eher sinnfrei.
Update einspielen wenn man nicht von den USB Problemen betroffen ist?
Ich stand vor derselben Entscheidung und habe das 1.2.0.3b-Update einfach aufgespielt, in der Hoffnung, dass dann größtenteils alle groben Fehler behoben sind. Aber es bleibt natürlich deine Entscheidung.
Ich habe jetzt schon längere Die BIOS-Version AGESA 1.2.0.3b für das msi x570 unify und hatte alle bei dem BIOS ist mir aufgefallen bei meinem 5950x das er aggressiver arbeitet mithören Spitzen auch im Office Bereich Das war bei den anderen BIOS Version nicht so.
Kannst du das bitte nochmal verständlicher formulieren?
Das Gefühl habe ich auch mit der AGESA 1.2.0.3b! Die Cpu taktet aggressiver hoch und wird ca. 5 Grad wärmer als mit dem AGESA 1.2.0.2.
Genauso ist es bei mir auch 👌 Habe ein arctic liquid freezer ii 420 im Push - Pull musste meine Lüfterkurve auch anpassen Bin aber noch In allem unter 70°.
Im Idealbereich bei 31° Bei Office Internet YouTube 35-45 grad schieß auch manchmal hoch bis 65° Beim zocken kommt es auf das Spiel an zwischen 60-68° Alles ohne PBO Mit PBO 5° höher
Habe einen 5900x und X570 Unify verbaut. Der NH-D15 drehte die ganze Zeit voll auf und die Temps gingen bis 80° hoch (Cinebench R23). Nach langen Suchen fand ich eine Lösung, clear CMOS gemacht, XMP gesetzt und seitdem geht er nicht höher als 75° und die Lüfter sind auch leise. Vielleicht hatte jemand schon ein ähnliches Problem und es kann ihn weiterhelfen. LG
Gibt ein neues Bios !!
MEG X570 UNIFY​
7C35vAB1(Beta version)
Update to AMD ComboAM4PIV2 1.2.0.3c
kann sich ja einer mal melden ob sich was verändert hat Leistung Lüfter Arbeitsspeicher…?
Lg
Entscheidend war wohl der CMOS-Reset da irgendwas verstellt war. XMP sorgt nicht für höhere CPU-Temperaturen. Aber klar, Hauptsache das Ergebnis stimmt auch wenn 75 oder 80 Grad in der Praxis vollkommen egal sind.
Das neue Beta Bios ist primär ein Update für die Cezanne APUs. Allerdings gibt es auch ein Downgrade der SMU für die 5000er Vermeer CPUs. Siehe Screenshot Vergleich für MEG Unify.
Liebe Community,
heute habe ich meinen neuen externen BD-Brenner Pioneer BDR-XS07TUHD erhalten.
Diesen bei USB anzuschließen stellte kein Problem dar.
Nun wollte ich eine UHD-BD mit PowerDVD 21.0.1519.62 (64Bit) wiedergeben, bekomme ich folgende Meldung:
Nach dem Klick auf Installieren kommt:
Habe nun aus dem Microsoft Store das installiert:
Das Meckert mich nun an:
Nun die Frage: Was muss ich wo im BIOS/UEFI einstellen?
Gem. diesem Artikel -> https://www.intel.de/content/www/de...0058952/software/intel-security-products.html
soll man etwas im BIOS einstellen. Geht das überhaupt?
Danke für Eure Informationen!
du musst den UEFI Modus im Bios aktivieren, falls du aktuell den CSM (auch Legacy Mode genannt) aktiviert hast.
Mein PC läuft im UEFI-Modus. Habe gerade noch nachgesehen.
Das aktuelle BIOS welches ich drauf habe ist das A.90
Helfen kann ich bei dem leider nicht aber wenn es nicht unbedingt powerdvd sein muss: ich nutze für BluRay Wiedergabe makemkv + VLC. Das benötigt keine weitere Software und du könntest die BluRay damit auch Rippen.
Nach kurzer Recherche stellt sich heraus, dass es gar nicht möglich ist 4K BluRay direkt wiederzugeben. Die Voraussetzungen sind eine Intel CPU, ein Intel Board mit SGX und eine Intel GPU mit HDCP 2.2 Unterstützung auf dem HDMI/DP Port.
Lustig ist, dass nicht mal alle Intel CPUs SGX unterstützen. Bei AMD gibt es wiederum gar keine Möglichkeit.
Was für eine DRM Politik hinter BluRay steckt ist der Wahnsinn und war mir bis jetzt auch nicht bewusst.
Naja, lange Rede kurzer Sinn: Abspielen kannst du sie nicht. Du kannst nur den Umweg über einen Converter gehen, indem du z.B. die Disc in eine mkv konvertierst.
Das hat ja mit PowerDVD nichts zu tun. Das liegt an den Kopierschutzmaßnahmen bzw. an der DRM Politik, die von der BluRay Association kommt. Dahinter steckt einfach Lobbyarbeit.
Nutzt jemand eine Corsair-Tastatur am Unify die funktioniert? Meine K55 wird kurz erkannt und leuchtet dann nur fröhlich weiter, ohne Eingaben zu akzeptieren. Egal an welchem Port.
Zwei Billigtastaturen (einmal mit, einmal ohne Kabel) funktionieren ohne Probleme.
Habe die K70 RGB MK2 und die Nightsword, beide per iCUE gemanaged.
Keine Probleme, selbst nach mehrmaligen BIOS Updates usw.
Hab zwar das Ace aber der Unterschied ist sehr gering.
Hmm... mystisch. Aber gut zu wissen, danke.
Eine Idee woran das liegen könnte? Am anderen PC mit Z170-Board lief und läufts tadellos :confused:
Hast du andere Ports Mal probiert. Ich habe eine MX keys und hatte immer wieder Mal das Problem, dass bei manchen Ports die Tastatur sporadisch einfach nicht mehr getan hat. Ging immer 3 bis 4 Sekunden, dann war es wieder OK. Aktuell steckt bei mir die Tastatur glaube ich dem Port, der für das BIOS Flashback gedacht ist.
Das kommende MEG X570S ACE MAX ist schon sehr nice. Ein Upgrade alleine wegen dem schnelleren USB3.2 wäre für mich schon super. Hoffe, es wird nicht zu teuer werden, was ich aber befürchte. Ich habe die erste Seite etwas angepasst mit neueren Informationen und Bildern.
Kleiner Hinweis: "CHIPSET: AMD® X570/X570S Chipset" Es gibt keinen X570S-Chipsatz. ;)
Natürlich gibt es denn x570S oder wurde der wieder umbenannt? S heißt ohne Lüfter unter anderem und alle Hersteller schreiben auch X570S. Habe es dennoch mal rausgenommen, aber wenn es denn nicht gibt, warum schreiben dann alle X570S?
Hmm ok. Beitrag oben nochmals angepasst.
Ist eben eine reine Bezeichnung, der PCH ist unverändert.
Um ehrlich zu sein, nahm ich auch an, dass der PCH verändert wurde. Anderfalls verstehe ich nicht, warum der gleiche Chipsatz nun plötzlich keine aktive Kühlung brauch. Naja, dann sorry @FM4E ;)
Ähnliche Themen
