[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
Woooot??? 12 Fans an dem CPU Header des Boards? Und das läuft ohne Problem?
Ich mein....irgendwann ist ja mal Schluss mit Spannung, da kommt doch hinten nichts mehr an am letzten 🤔.
Respekt! Kurz gesagt es lag an einer fixen Spannung im Bios? Sollte aber nicht durch einen CMOS Reset alles an Spannungen auf default zurückgesetzt sein? Sprich Auto
Danke :P Und nein, anscheinend nicht. oder wie es xYeti beschrieben hat: es hat die Spannungen halt wieder verändert.
Das mit den 1,24v ist normal bei dem Board.
Das passiert nach nen BIOS Update und wird erst geändert wenn man Einstellungen vor nimmt. (seit dem Update welches für die neuen ryzen raus kam)
Und wo her hast du denn das keine 128gb gehen?
Also das mit den 128 GB habe ich mir aus dem QVL durchgelesen, dass die Speichersteuerung des Ryzen 5950x den 128 GB Trident Z - 4er - Kit mit 3200 MHZ nicht mehr nehmen will. Zumindest ist das die Behauptung, aber derzeit laufen halt auch wieder 64 GB. Ist also alles irgendo wirsch >.<
Nur weil es dort nicht aufgelistet ist, heißt das aber nichts. Es soll doch noch ein Update kommen zwecks uv usw .... Würde da mal noch warten.
Die Steuerung der Lüfter über das Board ist gruselig und ich hab es aufgegeben.
Hab mir dann das Ding geholt und bin zufrieden.
Vielen Dank für diesen Einwand, wäre auch eine alternative. Aber so ein 4-pin Molex kommt mir nicht mehr ins Gehäuse :ROFLMAO:.
Ich denke ich werde mal die Corsair Commander Pro testen, preislich ist da kein großer Unterschied zu der von aquacomputer.
Ja das Corsair Ding hatte ich auch auf dem Schirm, bis ich die Bewertungen auf Amazon gelesen hatte.
Da gibt es eine häufigkeit von Leuten, die melden das ganze Ports einer nach dem anderen ausfallen.
Der Molex ist nicht schön, kann und darf aber deutlich mehr saft liefern.
Ich habe vor, demnächst das Unify zu holen. Nun ist mir aufgefallen, dass der von mir anvisierte RAM auf der MSI-Seite nicht in der Kompatibilitätsliste auftaucht..
Wie hoch ist die Wahrscheinlichkeit, dass es zu Problemen kommen kann?
Oder lieber andere Riegel nehmen?
Das muss nicht zwingend bedeuten, dass der RAM nicht mit dem Board funktioniert. Ich würde es zunächst einmal ausprobieren.
sollte doch bekannt sein, das de ganzen hersteller gar nicht die zeit haben all die riegel auf dem markt zu testen.
Egal was ich versuche, bei 3600 RAM Takt ist Schluß. Die sollen endlich machen.
Ist bekannt welche Boards diese Probleme nicht haben?
Dienstag kommt meine 6800xt, hätte gerne ein ordentliches BIOS dazu..
Welches BIOS fährst du aktuell?
Davon ab habe ich das Problem mit der Lüftersteuerung wohl gelöst bekommen. Es lag wohl an der LED-Firmware, die nicht aktuell war...
CPU NB/SoC Voltage angehoben?
Schon versucht, über 3600 kein Post, immer Fehlercode 92 am Display.
Hab noch ein zweites Unify mit einem 3900x drauf. Da gehen 1900/3800 ohne irgendwas zu erhöhen. Asynchron läuft der RAM auch mit über 4133, daran liegt es nicht.
Dann müssen wir einfach ein paar BIOS-Updates abwarten.
Ja, ich meinte die RGB-LED-Firmware. Ich hatte derbe Probleme mit der Lüftersteuerung und habe dann über die MSI-Dragon-Center-Software die LED-Firmware aktualisiert. Installiert war Version A4 und neu geflasht wurde Version A7. Nun läuft bisher alles reibungslos und die Lüftersteuerung arbeitet korrekt.
@Cr@zed^ @Maxxx @Mastereye
Hab nun ein 64 GB - Kit getestet, die RAM-Slots 1 und 2 von Rechts sind immer noch direkt am piepen. Ich vermute, dass es tatsächlich an dem BIOS liegt. Das mein Mainboard ein Problem bei den beiden RAM-Slots hat glaube ich nicht, da nach dem A82 - Update und der Anpassung der Spannung ein Slot wieder funktionierte.
Das Ergebnis ist aber eher ernüchternd als erschreckend, damit kann ich derzeit leben. Hilft wohl nix außer abzuwarten :)
Da mein Unify seit Anfang September hin und her geschickt wird, kann ich momentan nichts dazu sagen.
Ich hoffe dass das Board irgendwann einmal wieder funktionierend hier eintrifft.
Kein Thema. War mehr oder minder ein Status zu der ganzen Thematik und ich hab nun mittlerweile auch ein bis zwei andere Fälle gefunden, die exakt das gleiche Problem haben. Es muss wohl am Board und am BIOS liegen, daher kann ich nicht wirklich viel machen als abwarten :/
Wo macht man im Dragon Center nochmal das Firmwareupdate für die LEDs? Ich kann mich erinnern, dass ich beim letzten Mal schon ewig gesucht habe und jetzt kann ich mich wieder nicht daran erinnern und nichts finden.
Edit:
Ich scheine einfach nur schon die aktuellste Verison zu haben. LED Firmware: A7, Flash BIOS Button: 6.
Kann das Unify Ryzen 5000 out of the box oder muss man USB Bios flashen?
Ist im Grunde egal, da Du ein Biosupdate bloß mit dem Board, nen Netzteil und einem USB Stick durchführen kannst.
Nein! Musst ein Update machen mit Flashback für Ryzen 5000
Es sei denn er bekommt ein super duppa frisches aus dem Werk, das eventuell schon die benötigte BIOS Version drauf hat. Die Chance ist aber sehr gering :d.
Ansonsten wurde alles schon von BiG OnE erläutert, BIOS Flashback Funktion nutzen, kinderleicht und im Handbuch gut erklärt.
Version
7C35vA82(Beta version)
Erscheinungsdatum
2020-11-16
Beschreibung
- Support AMD SAM(SMART ACCESS MEMORY) function
Weiß hier Jemand ob die A81 Version auch ausreicht um SAM zu betreiben? Die Funktionen sind im BIOS ja vorhanden (Above 4G Decoding & Re-Size Bar Support)
Unklar ist ob im A81 noch etwas anderes SAM nicht unterstützt. Da ansonsten alles gerade gut läuft will ich das BIOS ungern flashen!
Zum Thema Sleep kann ich sagen, dass es bei mir funktioniert. Bisher keine Probleme.
um einen 420 Radiator ob ins Gehäuse zu setzen überlege ich, die wuchtige Aluabdeckung über dem Kühler beim Unify abzumachen. Hat diese Abdeckung erhebliche Auswirkungen auf die Abdeckung oder kann ich diese demontieren zumal die Abdeckung nicht direkt auf den Spannungswandlern liegen sondern in der Luft darüber?
Hat jemand von euch schon Erfahrungen sammeln können mit 2 m.2 SSD im Raid 0? Lief das problemlos? Die Anleitung ist ja relativ detailliert und auf den ersten Blick scheint man nicht viel falsch machen zu können.
Ähnliche Themen
