[Sammelthread] MSI MEG X570(S) Unify (X MAX) / ACE (MAX) (AM4)
product_10_20191002132606_5d9434ee62129.pngproduct_9_20190723092258_5d3661724d540.pngproduct_1629079667f4b88b2d70e858818adcfd4767cd52a2.pngproduct_1629094385a72f0a5d4a37c30deff6b3dcba91659c.png
Sammelthread für das MSI MEG x570 Unify/ACE
Herstellerseite:
MEG X570 UNIFY
Herstellerseite: MEG X570 ACE
Herstellerseite: MEG X570S ACE MAX
Herstellerseite: MEG X570S UNIFY-X MAX
Reviews:
MSI MEG X570 UNIFY Review - Introduction
MSI MEG X570 Unify motherboard (updated)
MSI MEG X570 Unify: An All-Black Motherboard
MSI MEG X570 Unify kommt ohne RGB aus
MSI MEG X570 Unify | Tom's Hardware
MSI MEG X570 ACE Infinity | Hardwareluxx
MSI MEG X570 Ace Motherboard Review
MSI MEG X570 Ace - Review 2019 - PCMag UK
MSI MEG X570 ACE - Hardware Journal
MSI MEG X570 ACE - Review
MSI MEG X570S ACE MAX - digideutsche
MSI MEG X570S ACE MAX - wccftech
MSI MEG X570S ACE MAX - IT Info
MSI MEG X570S UNIFY-X MAX - geeknetic
Besonderheiten:
  • Supports 2nd and 3rd Gen AMD Ryzen™ / Ryzen™ with Radeon™ Vega Graphics and 2nd Gen AMD Ryzen™ with Radeon™ Graphics Desktop Processors for AM4 socket
  • Supports DDR4 Memory, up to 5000+(OC) MHz
  • Aluminum Cover with Extended Heatsink: All-metal extended heatsink cover enlarge the surface of heat dissipation, ensures even high-end processors to run in full speed.
  • Lightning Fast Game Experience: PCIe 4.0, Triple Lightning Gen4 x4 M.2 with M.2 Shield Frozr, StoreMI, AMD Turbo USB 3.2 Gen2.
  • 2.5G Gaming LAN with Latest Wi-Fi 6 Solution: Onboard 2.5G LAN with gaming LAN manager, combining latest Wi-Fi 6 solution which supports MU-MIMO and BSS color technology, delivering the best online gaming experience.
  • Frozr Heatsink Design: Designed with the patented fan and double ball bearings to provide the best performance for enthusiast gamers and prosumers.
  • Audio Boost HD: Isolated audio with dedicated processor combining ESS audio DAC with amplifier, deliver the breathtaking, game-changing sound to create the most exciting gameplay.
  • Pre-installed I/O Shielding: Better EMI protection and more convenience for installation
  • ACE: Mystic Light Infinity, Dual LAN, Extended Heat-pipe Design
Spezifikationen Unify/ACE/ACE MAX/Unify X:
SOCKET:
AM4
CPU (MAX SUPPORT): Ryzen 9
CHIPSET:
AMD® X570 Chipset
DDR4 MEMORY: 1866/ 2133/ 2400/ 2667/ 2800/2933 /3000 /3066 /3200 /3466 /3600 /3733 /3866 /4000 /4133 /4266 /4400 /4533 /4600 /4733 /4800 /5000+ Mhz by JEDEC and A-XMP OC MODE
MEMORY CHANNEL: Dual
DIMM SLOTS: 2/4
MAX MEMORY (GB): 128GB
PCI-E X16: 3
PCI-E X1: 2
SATAIII: 4
M.2 SLOT: 3/4/6
RAID: 0/1/10
TPM (HEADER): 1
LAN UNIFY/UNIFY X: 1x Realtek® RTL8125 2.5 Gbps
LAN ACE/ACE MAX: 1x Intel® WGI211AT Gigabit / Intel® Wi-Fi 6E AX210, 1x Realtek® RTL8125 2.5 Gbps
USB 3.2 PORTS (FRONT): 1(Gen2, Type C), 4(Gen1, Type A)
USB 3.2 PORTS (REAR): 1(Gen2, Type C), 3(Gen2, Type A), 2(Gen1, Type A)
USB 2.0 PORTS (FRONT): 4
USB 2.0 PORTS (REAR): 2
AUDIO PORTS (REAR): 5+ Optical S/PDIF (Realtek® ALC1220 Codec)
DIRECTX: 12
FORM FACTOR: ATX
SLI: Y
CROSSFIRE: Y
OPERATING SYSTEM: Support for Windows® 10 64-bit
MSI Support bei hwluxx.
Hier ein paar Bilder zu denn Boards:
@Murazor speziell mit dem Ram den ich habe oder generell OC auf 4000Mhz Sweetspot meinste?
Sowohl als auch. ;)
4000 ist nicht der neue Sweetspot. Wer immer so behauptet liegt falsch.
Ob ja oder nein sind beides nur Vermutungen.
Vermutungen haben aber hier nichts verloren. Fakten zählen. Und AMD hat nie was gepostet in diese Richtung von daher bleiben 3200 bzw 3600 das Mass was auch AMD selbst sagt.
Dieser Post von dir ist aber auch nur eine Vermutung. ;) Und Hardwareluxx hat doch auch schon darüber berichtet. Es ist ein Gerücht, nichts desto trotz.
Nein ist fakt. Ansonsten zeig mir einen einzigen Post von AMD wo die rede von 4000 ist und das der neue Standard sein soll.
Und zwischen 3600 und 4000 merkt niemand im real life. Nur für Benchmarks relevant und wem das wichtig ist hat eh andere Probleme 😂.
Also bei Games wie Anno1800 merkst du das schon wenn du mit manuellem RamOC 20-30% mehr FPS hast. 🤷‍♂️
Leute die @Stock fahren möchten brauchen aber auch kein Board wie das Unify, das macht dann so völlig gar keinen Sinn :unsure:.
Wenn es Fakt ist, dann müsste es eine offizielle Stellungsnahme oder Folie dazu geben. Gibt es aber nicht.
Außerdem wurde doch schon durch die Blume bestätigt, dass es aus einer offiziellen AMD Präsentation stammt.
Don schrieb:
Auch wenn ich das nicht bestätigen kann oder darf, die Kollegen schreiben nicht ohne Grund: „Seite aus einer offiziellen AMD-Präsentation“
Ich vermute auch das sich die neuen Ram chanel der Ryzen5000 serie sich 10-20% höher tacken lassen.
Irgend wo habe ich das auch gelesen finde ich gerade nicht.
Kann gut sein das 4000er ram doch sinn machen würden.
Selten so einen Blödsinn gelesen. Leute kaufen kein Unify nur wegen OC.
Nicht nur sondern auch, das Unify ist nicht nur bei Intel eines der besten Board´s besonders P/L.
Es hat nur nur ein starkes VRM, sondern auch einiges an Ram Gimmicks, auf der Z490 Plattform kann es fast mit dem doppelt so teuren Apex standhalten.
Wenn du nicht übertaktest gibt es auch billigere Board´s die ne gute Ausstattung haben.
Für dich mag das stimmen ,da es dich nicht interessiert und du dich damit nicht auskennst.
Leute mit Expertise greifen vielleicht genau deswegen zum Unify. 😉
Z490 Plattform. Lol so viel zu deiner Expertise. Dann gehörst du auf jedem Fall nicht zu denen.
Wenn du das meinst :unsure: 😉
Ich hab zumindestens schonmal passenden Speicher, 32GB laut XMP sogar 4400, das kann man ja runtertakten für 1:1 🤷‍♂️
Hier geht es um das Unify x570 und nicht z490. Das wird hier niemand interessieren was mit z490 geht.
@Taani wenn du es rausgefunden hast, wäre es super, wenn du deine Erfahrung teilen könntest. Ich habe auch 4000 MHz RAM im Auge, wenn das wirklich der neue sweetspot für Vermeer ist.
Also ich hatte meine G.Skill Trident Z (F4-4000C19D-32GTZ) schon mit 4200MHz (IF 1900) bei 1.38V und XMP_Timings testweise laufen - null Probleme gehabt
Wobei man nicht vergessen darf das der IMC das entscheidende ist. das MB ist bis 4600MHz angegeben... also reichlich Luft was die Leiterbahnen auf dem Bord angeht.
Nicht ganz richtig..... AMD sagt 4000MHz bei ZEN 3 ist wie 3800MHz bei Zen 2 - also ist 4000 das neue 3800 was den IF angeht....
Findest Du auch hier im Forum.... 3800 soll Sweetspot sein.
Gruß RON
@Oldironsides220 Wollte keinen Krieg hier ausbrechen lassen :P Mir macht es einfach Spaß zu gucken was geht, mich einzulesen und rumzuknüseln... Mein momentanes Asus X470 Prime Pro gibt leider nur 3600Mhz offiziell her, drum freue ich mich beim Unify die Grenzen diesmal ausloten zu können, kommt morgen an. Installieren werde ich es aber erst, wenn ich zeitnah an einen 5900x komme, das ist sonst zuviel Gefummel mit einem Dark Rock 4 Pro im Gehäuse.... Mal sehen, was die Verfügbarkeit (Donnerstag ab wieviel Uhr und wo?) hergibt...
Mein X570 UNIFY wartet auch schon auf den 5900X. Mal sehen, ob ich am Donnerstag gleich einen bekomme. Andernfalls läuft das Board zum Glück nicht weg. :d Mein neues 64-GB-RAM-Kit will nativ mit 3.600 MHz arbeiten.
BTW: Es gibt für das Board ein neues Beta-BIOS: https://forum-en.msi.com/index.php?threads/msi-x570-b550-beta-bios-update.348919/
Statt AGESA 1.1.0.0 Patch B ist dort der Patch C integriert.
Gibt übrigens ein neues Test Bios mit Agesa v2 1.1.0.0 Patch C. Falls es jemand testen will.
@FM4E
Was für ein 64GB Kit ist es denn genau?
@Reous Wo ich es gerade in deiner Sig lese... eine Möglichkeit beim X470 Prime Pro den Speichertakt über 3600 zu boosten gibt es nicht, ohne das Bios zu modden oder?
Hab heute mein Unify erhalten. Nach der Anleitung vorgegangen, um das aktuellste BIOS zu flashen, damit der 5000er läuft. USB eingesteckt, BIOS-Flashback-Knopf gedrückt, Board geht an, Quirl läuft auf höchsttouren, Flashbackbutton-LED fängt an zu blinken, schneller dann langsamer und dann geht sie nach ein paar Minuten aus. Da hört das Handbuch dann auch auf.
Was mich jetzt ein bisschen wundert: Nachdem die LED ausgeht, bleibt das Board an, kein restart oder so und der Quirl läuft weiter und weiter. PostCode LED 00. Nur ein langer druck auf den Powerknopf schaltet das Board aus. Hab ich das BIOS nun erfolgreich geflasht?
Ich glaube schon. War bei mir auch so!
kurzes update:
mit dem 7C35vA75(Beta version) vom 3.11. hat es vermutlich nicht geklappt, denn ich habe es dann mit A73 vom 29.9 geflasht und da ist das Board nach dem flashen kurz ausgegangen und ist neu gestartet.
Jetzt fass ich erst mal nichts mehr an und hoffe, dass es mit nem 5000er dann bootet
habe nun das unify und crosshair hero VIII hier.
zu beginn wollte ich nur das unify, aber nach bissl review lesen/gucken, hat mich das bios etwas abgeschreckt. das asus bios kenne ich ja schon.
zudem hat das hero mehr und hoeher spezifizierte usbs lots hinten
mal gucken welches ich nun letztendlich einbaue wenn ich ne cpu uebermorgen kriege.
Ich bin auch noch immer hin- und her gerissen welches Board es werden soll. Das Asus habe ich auch in der engeren Auswahl aufgrund der USB Anschlüsse und weil ich mein i7 8700k ebenfalls auf einem Asus Hero X betreibe. Wie ist das mit dem Lüfter auf dem Asus geregelt? Beim MSI ist dieser ja still und läuft beinahe nie an.
kurzes update:
Dann muss ich auch nochmal nachschauen. Warte noch bis zum Wochenende vielleicht kommt da ja nochmal ein neues Bios.
Edit: Seit heute auf der MSI-Seite: 7C35vA75(Beta version) Release Date 2020-11-03.
Ist glaube ich das Bios wo uns gestern schon Reous drauf hingewiesen hat.
bei dem BIOS hat das Board keinen restart nach dem flashen gemacht.
Der MSI Support hat gesagt, anderen Stick und anderes Bios probieren. Das war dann mit dem vom 29.9 (welches nicht mehr auf der Homepage ist, ich aber noch hatte) wahrscheinlich erfolgreich (restart).
Ähnliche Themen
