D5 next zero l/h
pau1er
Profi
Have a nice day!
Is it possible to be overhead setup for D5 NEXT in way of 3m zmt and too many 90 degree adapters? Twisted it many times, no air jam i guess but not completely sure. Propyleneglicole as a coolant, 1100 ml approx. My first waku. Thanks!
The awesome pump could easily handle 30 or more of those little buggers :)
You still got lots of air in your loop mate. Shake the whole case gentlly from left to the right like a baby and wait patiently. All will be good :)
You still got lots of air in your loop mate. Shake the whole case gentlly from left to right like a baby and wait patiently. All will be good:)
Thanks for your positive answer mate!
There was no air jam in the system. I made sure of that when i got disassembled some tubes and rad ports. Problem was appeared around highly viscous coolant - industrial grade propylenglycole for heating systems that i found to be useful for additives it contains. Once i flushed existing coolant and mixed it with hydrogen oxide in 1:1 proportion, it goes fine. D5 next's virtual sensor was never activated after that, but i found tip in calibration section saying that flow must be above 80 l/h at least. Hope, further mix with Destilliertes Wasser will be useful and enough :-)
After a short first test, the temperatures are amazing.
