[Sammelthread] ASUS ROG Maximus XI Apex & Gene - Das Mini APEX! (Z390)
[Sammelthread] ASUS ROG Maximus XI Gene (90MB10E0-M0EAY0)
--- Produktseite | PDF-Handbuch | Support-Downloads | Preisvergleich | HWBOT ---
The Gene is back with the Maximus XI family, this time with a twist. Multi-GPU configurations are becoming rarer as NVIDIA and AMD focus on single-card performance, and GPU coolers are growing beyond two slots to improve performance and reduce noise. The old Gene’s dual-GPU focus doesn’t reflect the kinds of systems gamers and enthusiasts are building, so the new model refocuses to aggressively pursue higher performance and support additional storage. It has already made its mark on the hardware leaderboards by claiming 11 global first place scores and eight world records, including the fastest CPU frequency at 7613.19MHz and the highest memory clock at 5566MHz.
Spezifikationen
attachment.php
attachment.php
attachment.php
CPUBuild in Intel® 9th / 8th Gen Intel® Core™, Pentium® Gold and Celeron® Processors
Supports Intel® Turbo Boost Technology 2.0
* Refer to ASUS Deutschland
for CPU support list
ChipsetBuild in Intel® Z390
MemorySocket 1151 for 9th / 8th Gen Intel® Core™, Pentium® Gold and Celeron® processors
2 x DIMM, Max. 64GB, DDR4 4700(O.C)/4600(O.C)/4500(O.C)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3333(O.C.)/3300(O.C.)/3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400(O.C.)/2133(O.C.) MHz Non-ECC, Un-buffered Memory *
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
for the Memory QVL (Qualified Vendors Lists).
* Double Capcity DRAM support depends oh the DRAM models
GraphicIntegrated Graphics Processor- Intel® UHD Graphics support
- Supports HDMI 1.4b with max. resolution 4096 x 2160 @ 30 Hz
Expansion SlotsSocket 1151 for 9th / 8th Gen Intel® Core™, Pentium® Gold and Celeron® processors
1 x PCIe 3.0 x16
Intel® Z390 Chipset
1 x PCIe 3.0 x4
StorageSocket 1151 for 9th / 8th Gen Intel® Core™, Pentium® Gold and Celeron® processors :
2 x ROG DIMM.2 Module support(CPU_DIMM.2), with M key, type 2242/2260/2280/22110 storage devices support (PCIE 3.0 x 4 mode)
Intel® Z390 Chipset :
2 x M.2 Socket 3, with M Key, type 2242/2260/2280 storage devices support (x4 PCIE mode)
4 x SATA 6Gb/s port(s),
Support Raid 0, 1, 5, 10
Intel® Optane™ Memory Ready
LANIntel® I219V, 1 x Gigabit LAN Controller(s)
Anti-surge LANGuard
ROG GameFirst Technology
Wireless Data NetworkIntel® Wireless-AC 9560
Wi-Fi 802.11 a/b/g/n/ac
Supports dual band frequency 2.4/5 GHz
Supports MU-MIMO
Supports channel bandwidth: HT20/HT40/HT80/HT160. Up to 1.73Gbps transfer speed
BluetoothBluetooth® 5.0
AudioROG SupremeFX 8-Channel High Definition Audio CODEC S1220A
- Impedance sense for front and rear headphone outputs
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output 113 dB SNR recording input
Audio Feature :
- SupremeFX Shielding™ Technology
- Gold-plated jacks
- Optical S/PDIF out port(s) at back panel
- Sonic Radar III
- Sonic Studio III + Sonic Studio Link
USB PortsIntel® Z390 Chipset :
1 x USB 3.1 Gen 2 front panel connector port(s)
4 x USB 3.1 Gen 2 port(s) (3 x Type-A+1 x Type-C)
8 x USB 3.1 Gen 1 port(s) (2 at mid-board)
6 x USB 2.0 port(s)
ROG Exclusive FeaturesROG CPU-Z
ROG CloneDrive
Pre-mounted I/O Shield
Slow Mode
CMOS button
Overwolf
ReTry Button
Safe Boot Button
Start Button
Reset Button
LN2 Mode
ROG Aura
- Aura Lighting Control
- Aura RGB Strip Headers
Extreme Engine Digi+ :
- MicroFine Alloy Chokes
- 10K Black Metallic Capacitors
Mem TweakIt
Double Power :
- Dual 8 -pin CPU
USB BIOS Flashback
ROG Exclusive Software
- RAMCache III
- GameFirst V
- Sonic Radar III
Special FeaturesAI Overclocking
ASUS 5X Protection III :
- ASUS SafeSlot Core: Fortified PCIe Slot prevents damage
- ASUS LANGuard: Protects against LAN surges, lightning strikes and static-electricity discharges!
Gamer's Guardian:
- SafeSlot
ASUS Optimem II:
- Optimem (Improved DDR4 stability)
- Improved DDR4 Stability
ASUS Exclusive Features :
- MemOK! II
- Pre-mounted I/O Shield
- ASUS NODE : hardware control interface
- BIOS Flashback Button
- Clear CMOS Button
- Reset Button
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 4
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-LED (CPU, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
AURA: RGB Lighting Control
Armoury Crate
Operating System SupportWindows® 10 64-bit
Back I/O Ports1 x PS/2 keyboard/mouse combo port(s)
1 x HDMI
1 x LAN (RJ45) port(s)
3 x USB 3.1 Gen 2 (red)Type-A,
1 x USB 3.1 Gen 2 (red)Type-C
6 x USB 3.1 Gen 1 (blue)
2 x USB 2.0
1 x Clear CMOS button(s)
1 x Wi-Fi antenna port(s)
BIOS1 x 128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0, ACPI 6.0, Multi-language BIOS, ASUS EZ Flash 3, CrashFree BIOS 3, F11 EZ Tuning Wizard, F6 Qfan Control, F3 My Favorites, Last Modified log, F12 PrintScreen, F3 Shortcut functions and ASUS DRAM SPD (Serial Presence Detect) memory information.
ManageabilityWfM2.0, DMI3.0, WOL by PME, PXE
Support DiscOverwolf
1-year Anti-Virus software
Daemon Tools Software
WinRAR
Form FactormATX Form Factor
9.6 inch x 8.9 inch ( 24.4 cm x 22.6 cm )
Backpanel:
attachment.php
Special Features
1) Double-capacity DIMM support (DC DIMM)
Maximus XI Gene features a unique memory-trace design that supports up to 32GB per slot for a total memory capacity of 64GB. With double-capacity UDIMM modules, Maximus XI Gene delivers four-DIMM memory capacity in a compact, dual-DIMM design.
--> [Sammelthread] Double Capacity DIMM DDR4 (DC DIMM)
2) Overclocker's toolkit
1) MEMOK! II - DRAM Auto Training Switch
2) QLED - 4 LEDs to show current boot status.
3) LN2 Mode - Jumper to enable special options and functions for liquid-nitrogen (LN2) overclocking.
4) Pause Switch - Activate to pause the system and fine-tune OC parameters mid-benchmark.
5) Slow Mode Switch - Instantly reduces the CPU ratio to 8X to bypass finicky benchmark passages.
6) ReTry Button - One press instantly initiates a hard reset.
7) Safe Boot Button - Instantly reset the PC and boot directly in to a safe mode.
8) ProbeIt - Check the voltage via integrated measurement points.
BIOS
Reguläre Releases (Support Downloads - BIOS Shortcut)
  • 1502 (2020/04/29, Improved system stability)
  • 1401 (2019/12/11, Improve Memory-OC rules & Intel Optane H10 compatibility, fixed Tjmax for i9-9900KS)
  • 1302 (2019/09/11, Improve system stability)
  • 1105 (2019/06/20, Improved DRAM compatibility & system performance & storage device comp, Updated ME to v12.0.39 & microcode for Security)
  • 1005 (2019/04/25, Enhanced security. Improved SSD & DRAM compatibility, Updated RAID driver)
  • 0905 (2019/04/11, Enhanced Security)
  • 0903 (2019/03/22, Microcode Update)
  • 0805 (2019/01/02, Supported JEDEC Standard DDR4 32GB memory, Updated RST driver & ME FW, Improve system performance & DRAM stability)
  • 0702 (2018/12/18, Improved system stability and performance, updated RST Driver)
  • 0602 (2018/10/31, Updated Microcode, improved DRAM stability, fixed USB issue)
  • 0506 (2018/09/29, First Release BIOS)
Bilder ( ASUS Maximus XI Gene BIOS walkthrough. - YouTube )
Inoffizielle BIOS Versionen u.a. für Extrem-OC (Achtung: Nutzung auf eigene Gefahr!)
  • 0021 (OC BIOS, New Sammy A2 Profiles, need to be logged in @ HWBOT Forums to download)
  • 0050 (OC BIOS, allows BCLK change with OC PANEL)
  • 0093 (OC BIOS, allow higher voltages without LN2 mode, need to be logged in @ HWBOT Forums to download)
  • 0057 (3rd OC BIOS, improves a2 dimms overclocking)
  • 0044 (2nd OC BIOS, some memory related fixes vs 0084)
  • 0084 (1st OC BIOS for short-traced DIMMs such as G.Skill RGB or Galax based A2-pcb)
News & Reviews
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
  • Hersteller Modell @ Preisvergleich | Quelle | kompatibel | Einschränkungen / Anmerkungen
  • Hersteller Modell @ Preisvergleich | Quelle | inkompatibel | Grund/Foto(s)
  • --> Bitte helft mit sammeln!
2) RAM
ASUS Memory QVL (PDF).
attachment.php
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.​
Nützliche Links & Tipps (im Forum & im WWW)
1) Hardwareluxx
2) WWW (international)
3) Tips & Tricks
  • RAM OC MemOK per SChalter auf dem Board deaktiiveren beim RAM OC
  • ASMedia USB 3(.1) Treiber in das Windows 7 Image integrieren oder P/S2 Tastatur verwenden und die Treiber von einer angeschlossenen Festplatte installieren. Alternativ einen PCIe USB Controller verwenden, der nativ unterstützt wird.
4) FAQ - Frequently Asked Questions
  • Q: Wie exakt wird die Vcore per Software ausgelesen?
  • A: Elmor hat dies so erklärt:
    Elmor schrieb:
    A note on voltage reporting on the Maximus XI-series, and voltage measurements in general. Like on Crosshair VII Hero, we've improved the SIO voltage readings for better accuracy. The CPU Core Voltage is now reading very close to the voltage the CPU is getting. Applied voltages and load-line levels are comparable to before, but not the software voltage readings.
    When measuring voltages on a motherboard and large currents are involved, it's important to use accurate measurement points due to resistance/impedance present on the board. The power plane for example can be modeled as a resistor connected in series between the VRM output and the target device, together with Ohm's law, U = R*I. The larger the current, the larger the voltage drop. If you measure the voltage at the VRM output, for example at the inductor, you'll see a large difference compared to the voltage measured at the CPU socket MLCC. What we're interested in is what voltage the CPU die is actually getting after passing through the output filter, power plane, socket and package.
    The Super I/O controller is used by BIOS/AiSuite/CPU-Z/HWInfo/AIDA64 for reading most voltages, temperatures and fan speeds. Its single-ended ADC inputs measure the input voltage referenced to the local SIO ground. With increased VRM output currents, this reading will be more and more inaccurate. We've added a circuit for measuring the differential CPU-die sense and converting it to a single-ended signal to the SIO. The CPU-die sense is accessible through two dedicated pins on the CPU, and are routed to the supply and ground on the CPU die itself. It's typically used by the CPU VRM controller for output voltage control.
    Something to look out for is when you're seeing a voltage reported during load which is much higher than what you've set. It would require a negative load-line which is just not supported on any controller as far as I know. At 0 mOhm load-line, you get exactly what you set (Level 8 on M11).
    The resulting difference can be seen in the graph below.
    Prime95 26.6 12K FFTs
    Manual Mode Voltage = Voltage set in BIOS
    CPU-die Sense = DMM measurement of the CPU die-sense pins, "true" CPU Core Voltage
    Socket MLCC = DMM measurement of the capacitors at the back of the socket
    SIO (traditional) = Software reading with standard SIO voltage sense circuit
    SIO (Maximus XI Hero) = Software reading with the improved SIO voltage sense circuit
  • Q: Das Bluetooth funktionert mit den ASUS Treibern nicht. Gibt es dafür eine Lösung?
  • A: Mit den original Intel Treibern v20.70.0.4 gibt es laut Low keine Probleme (Download).
  • Q: Meine Tastatur wird beim Systemstart nicht rechtzeitig initialisiert. Wie komme ich ins UEFI?
  • A: Die einfachste Möglichkeit ist es, wie im Handbuch beschrieben die Reset Taste dafür zu verwenden. Wer keine Taste mehr dafür an seinem Gehäuse hat, kann auch den Onboard Button verwenden. Für wen weder das Eine noch das Andere in Frage kommt, der kann alternativ auch einen Start ins UEFI mit dem Power Button erzwingen (siehe Handbuch Seite 3-2 "Entering BIOS Setup after POST").
  • Q: Wie sind die einzelnen M.2 Steckplätze genau angebunden?
  • A: Die beiden auf dem DIMM.2 Modul, teilen sich PCIe Lanes von der CPU mit dem PEG. Wenn das DIMM.2 verwendet wird, reduziert sich dessen Anbindung auf x8. Die beiden Steckpätze auf dem MAinboard selbst sind mit PCIe Lanes vom Chipsatz angebunden. Man hat also die frei Wahl, was einem wichtiger ist (Storage/GPU-Performance).
  • Q: Was ist der Unterschied zwischen XMP-1 und XMP2? Mein Kit sollte eigentlich gar kein zweites XMP besitzen.
  • A: ASUS hat den Z390 Modellen eine Funktion spendiert, die statt dem originalen XMP des RAM-Hertellers (XMP-2), von ASUS optmierte Einstellungen verwendet (XMP-1). In der Regel ist XMP-1 zu bevorzugen und etwas performanter, im Fall von Performance- oder Stabilitätsproblemen, empfiehlt es sich aber auf XMP-2 auszuweichen.
    Silent Scone@ASUS schrieb:
    On Z390, there is now the option to use the DIMM profile which is XMP II. These settings are not validated, so mileage will vary depending on the kit and CPU.
    XMP I - Board optimised timings
    XMP II - Default XMP timings
    Often, XMP II timings will be slightly looser depending on the memory kit. If you check within the UEFI or memtweakit, you'll see a difference in memory subsets.
  • Q: Wie stelle ich die RTL/IOL richtig ein?
  • A: Dazu hat swdtechnik eine Anleitung im Coffee Lake RAM OC Thread gepostet:
    Nun wegen RTL`s und IO-L`s und wie man steuern bzw. beeinflussen kann:
    wir gehen ins Bios und setzen MRC Fast Boot auf [Disabled]
    (wenn Modulen B-Die A2 sind dann zusätzlich noch Trace Centering auf [Enabled])
    dann MCH Full Check auf [Enabled]
    dazu noch Round Trip Latency auf [Enabled]
    noch müssen wir folgende Settings unbedingt auf diese Werte setzen :
    DRAM RTL INIT value [x Wert]
    DRAM RTL (CHA DIMM0 Rank0) [Auto]
    DRAM RTL (CHA DIMM0 Rank1) [Auto]
    DRAM RTL (CHA DIMM1 Rank0) [Auto]
    DRAM RTL (CHA DIMM1 Rank1) [Auto]
    DRAM RTL (CHB DIMM0 Rank0) [Auto]
    DRAM RTL (CHB DIMM0 Rank1) [Auto]
    DRAM RTL (CHB DIMM1 Rank0) [Auto]
    DRAM RTL (CHB DIMM1 Rank1) [Auto]
    DRAM IOL (CHA DIMM0 Rank0) [Auto]
    DRAM IOL (CHA DIMM0 Rank1) [Auto]
    DRAM IOL (CHA DIMM1 Rank0) [Auto]
    DRAM IOL (CHA DIMM1 Rank1) [Auto]
    DRAM IOL (CHB DIMM0 Rank0) [Auto]
    DRAM IOL (CHB DIMM0 Rank1) [Auto]
    DRAM IOL (CHB DIMM1 Rank0) [Auto]
    DRAM IOL (CHB DIMM1 Rank1) [Auto]
    CHA IO_Latency_offset [21]
    CHB IO_Latency_offset [21]
    CHA RFR delay [14]
    CHB RFR delay [14]
    den DRAM RTL INIT value [x Wert] rechnen wir mit : (euer tCAS x 2) + IO-L bzw. 4 + IOL Offset bzw. 21 + 10
    Jetzt wo alles eingestellt, speichern und Neustarten!
    Wenn bootet wieder ins Bios und NUR DRAM RTL INIT value auf eine Zahl runter setzen, speichern und Neustarten!
    Und nun so weiter wiederholen mit DRAM RTL INIT value Senkung bis nicht mehr bootet.
    Nun haben wir irgendwann Punkt erreicht wo es nicht mehr bootet, dann Power Knopf 5 Sek. lang halten
    Rechner geht dann aus.
    Wieder Start Knopf drücken, mit F1 ins Bios landen und DRAM RTL INIT value auf den letzten funktionierenden Wert setzen, speichern und Neustarten und ins Windows booten lassen.
    So, sind wir im Windows,
    Starten nun und ASRock Timing Configurator Programm und schauen auf unsere IO-L´s an!
    Die werden im Idealfall gleich sein 7-7 oder 6-6 also, wenn nicht (was am meisten der Fall ist) zbsp. 7-6 oder 6-7 oder 7-13 oder 11-7 oder was auch immer,
    dann alles was wir nun brauchen ist nur auf unser Channel A or Channel B, schauen bei dem IOL Wert falsch ist.
    Beispiel:
    euer letzte ermittelte bootfähige DRAM RTL INIT value Wert ist 68 <---- nur für Beispiel genommene Zahl <---
    dabei hat es folgende RTL/IO-L Kombo bei euer DRAM RTL INIT value 68 trainiert
    62-63-6-7
    aber wir wollen natürlich unsere Werte auf 62-63-6-6 haben
    dann alles was wir nun brauchen ist:
    ins Bios gehen und unser CHB IO_Latency_offset auf von 21 auf [22] setzen weil genau da unser IO-L nicht stimmt! , speichern und Neustarten.
    Nun wird es 62-63-6-6 sein.
    Wollen wir mal unser RTL/IO-L Werte beispielweise auf 62-63-5-5 haben
    dann gehen wir ins Bios und erhöhen unser DRAM RTL INIT value Wert um eins höher UND NOCH beide CHA IO_Latency_offset / CHB IO_Latency_offset auch um eins höher., nun speichern und Neustarten.
    Schon wird es dann 62-63-5-5 sein!
    Falls jemand noch Fragen hat, einfach melden ;)
    P.S. - Was aber komisch oder ein Bug von ASRock Timing Configurator Tool ist - manch mal werden die Änderungen von CH IO_Latency_offset im ASRock Timing Configurator Tool nicht angezeigt (oder es ist nur bei mir so das ASRock Tool spinnt), das Asus MemTweakIt dagegen zeigt die Änderungen immer korrekt an (im Reiter "Timings 4" zusehen).
  • --> Deine Frage hier!
5) ASUS ROG Wallpaper
6) Wasserkühler (Mainboard)
[Sammelthread] ASUS ROG Maximus XI Apex (90MB0XV0-M0EAY0)
Reviews
  • 0021 (OC BIOS, New Sammy A2 Profiles)
  • 0093 (OC BIOS, allows higher voltages without LN2 switch)
  • 0033 (early OC BIOS)
Dancops ApeXI Guide (Samsung 8Gbit B-Die SR/A2): ROG Maximus XI APEX - NEW BIOS PROFILES small guide @ HWBOT Community Forums
M11G_01.jpg M11G_02.jpg M11G_03.jpg M11G_3D.jpg M11G_2D.jpg M11G_BP.jpg M11G_BP2.jpg M11G_3D500.jpg M11G_2D2.jpg M11G_2D500.jpg M11G_3D2.jpg ASUS ROG Maximus XI Gene QVL.png
Wenn im BIOS alles aktiviert ist, musst du in Windows die Standardeinstellungen für den Energiezustand wiederherstellen.
Ja, das habe ich schon alles versucht. Ich vermute, da ich die Standards nicht wiederherstellen kann (die Buttons sind ausgegraut), dass bei meiner etwas älteren Windows Installation irgendwas beim letzten Update oder aber durch den Umstieg von Mainboard und CPU etwas "durcheinander" gekommen ist.
Vermutlich behebt eine Neuinstallation von Windows das Problem. Weiter debuggen will ich jetzt gar nicht, da der Zeitaufwand einer Neuinstallation deutlich geringer sein dürfte ;)
Kurzes Update zu meinem Problem - die Neuinstallation hat es behoben.... da dürfte was gespießt haben nach dem Plattformwechsel. Jetzt taktet die CPU brav runter im IDLE...
Aus Neugierde Bluetooth mit Handy verbunden - zu was auch immer :d
Nur um zu schauen ob es funktioniert, eventuell für den One Controller ?
Auf jeden Fall mit dem im Startpost erwähnten Intel Treiber läufts.
Jungs neue Bios ist da! :banana:
Version 1005
2019/04/25
ROG MAXIMUS XI GENE BIOS 1005
"Firmware Change ROG MAXIMUS XI Gene R1.00 release BIOS 1005
damit bootet sich mein Ram endlich mit 4600 ohne die RTL`s manuell fixieren müssen
Das Changelog ist aktualisiert:
Enhanced security.
Improved SSD device compatibility.
Updated RAID driver.
Wäre schön wenn die endlich mal die Lüftersteuerung fixen würden...
Lüfter Step up und down, aber ich glaube das wird niemals gefixed werden. Taugt die Steuerung nur nichts vom Board
Mit welchen Lüftern hast du denn Probleme? Ich hatte weder beim IX Apex noch jetzt mit dem XI Gene irgendwelchen Stress mit der Lüftersteuerung.
Hab den D15 dran und Noctua Gehäuse Lüfter. Problem ist, dass alle Lüfter, da sie ja nach CPU Temp regeln, immer auf und wieder runterdrehen. Die CPU Temp geht ja hoch und runter, da aber dieser "Verzögerungsmodus" seit gefühlt 6 Generationen von Asus Baords nicht läuft immer der gleiche Kack. Etwa man stellts "Leise" ein, also alle Temps so hoch, aber dann wirds auch heiß oder man stellts normal und die Lüfter drehen auf und ab.
Siehe Q-fan step up time
Ich stell für meine Lüfter immer Custom Kurven ein und konfiguriere sie so, dass nur unter Last überhaupt erst hochgeregelt wird. Im Normalbetrieb mit nur kleinen Temperaturschwankungen laufen sie dann mit einer konstanten Geschwindigkeit und wenn die Post abgeht, drehen sie relativ schnell auf.
Ja das ist ja auch logisch, nur stell ich ein bis
40° Low Temp 30%
50° Middle Temp 70%
65° Volle Pulle
Nur springt die CPU Temp, dann gerne mal auf 52° für 2s und die Platine gibt instand Vollgas binnen von 0,1s weil ja die Temp über 40°
Stelle ich die ganze Geschichte Höher, so wie jetzt
52° Low Temp 30%
58° Middle Temp 70%
65° Volle Pulle
Gibts zwar kaum noch Lüfter auf und Abdrehen, nur drehen die dann eben in Games auch kaum noch auf, weil die CPU Temp unter 50° (Sockel Temp oder wo immer der Sensor sitzt). Prime alles Hübsch, aber Games nicht, Heizt sich der RAM etc unnötig auf
Ich verwende generell einen geringeren % Schritt zwischen Low u Mid, aber einen sehr großen Sprung zwischen Mid u Full. Damit fahre ich seit jeher sehr gut, auch bei meinen anderen Systemen (Gigabyte/MSI) und auch früher bei meinen abit Boards mit µGuru. Eventuell experimentiere noch mal ein wenig damit...
An sowas hab ich auch schon gedacht, probiere ich mal.
Ich wollte gerne das 1005 per Flashback drauf hauen. Das Flashback geht einfach nicht, es blinkt drei mal, dann leuchtet die Bios Taste wieder durchgängig. Jemand ne Idee?
So hatte das 1005 drauf, damit bootet mein RAM Setting gar nicht mehr. Wirft nur 23 Errors. Würde also das Bios für 16GB Riegel Besitzer nicht empfehlen. 8GB Riegel könnte da besser gehen.
Bzgl Lüfter, das Aufdrehen wird sich wohl nicht komplett verhindern lassen.
Hab nun:
40° Low Temp 38%
50° Middle Temp 50%
60° Volle Pulle
Hat hier jemand zufälligerweise zwei NVMe SSDs mit jeweils x4 Anbindung auf einem XI Apex am laufen? Laut Handbuch sollte es ja funktionieren.
Bei meinem alten Maximus X Hero ging das aber nie so recht obwohl es im Handbuch angepriesen wurde und spätestens, wenn man beide SSDs in x4 geschaltet hatte, wollte das System prompt nicht mehr starten. Bei M.2 NVMe + M.2 Sata das selbe Spiel. Leider habe ich keines der M.2 SSD mehr in der Nähe um dies zu testen.
sry, nur x4 + x2 drin.
Hast du nur eine zweite x2 SSD drin oder kann man mit deinem Gene nur x4 & x2 betreiben? Das Board hat doch im Gegensatz zum Apex sowieso Probleme, was den Dimm2 Slot angeht oder habe ich das im Thread falsch verstanden?!
@webwilli
Danke für die Info. Mir würde es ja eigentlich schon reichen, wenn ich zu 100% sicher sein könnte, dass die zweite SSD im DIMM.2, egal ob NVMe oder SATA, funktioniert. Du scheinst ja auch auch zwei M.2 SSDs zu besitzen. Läuft das so?
Ich kann nur für NVME sprechen und das funktioniert, hab zwei 970er im m2 Modul und beide laufen mit x4 anbindung.
Danke an euch. Beide Varianten hören sich sehr gut an. Dann werde ich wohl die Angebote checken und irgendwo zwischen 860 Evo und 970 Evo Plus landen. :)
Samsung PM981 ist meistens P/L Sieger.
Im M.2 1&2 hast du jeweils x4 und im DIMM.2 hast du auch jeweils x4, aber dann schaltet die Grafikkarte auf x8.
Bios 1005 läuft. Jetzt muss ich nur noch die 4400er wieder einbauen und schauen wie sie laufen.
@Low
Hierzulande (Schweiz) kostet die alte 970 Evo meistens gleich oder weniger als die OEM Ableger.
Deine zweite Aussage bezieht sich vermutlich auf das Gene oder? Auf dem Apex gibt es gar keine anderen M.2 Slots ausser im DIMM.2. Und das Manual ist ja angeblich nur kopiert und somit nicht korrekt im Bezug auf die Laneverteilung der Grafikkarte, so zumindest steht es hier im Thread. Wenn die Karte auf x8 abfällt würde ich es natürlich sein lassen und nur eine M.2 Sata einbauen.
Ja, das war auf das Gene bezogen. Das unterstützt auch generell keine SATA M.2 in den vier Steckplätzen (ich hab das auch noch mal kontrolliert).
Habe mir inzwischen eine WD Blue 3D Nand mit nur 1TB geholt, weil sie vergünstigt angeboten wurde. Die 2TB Variante war unverständlicherweise trotz Aktion mehr als doppelt so teuer.
Anfänglich hatte ich Schwierigkeiten, da der M2_2 nicht für Sata SSD ausgelegt ist, obwohl es so im Manual so angepriesen wird. Oder wird es das?
Immerhin bleibt das Board nicht einfach aus oder hängt im Boot fest und dank dem praktischen DIMM.2 muss ich nicht das halbe System auseinander nehmen. :bigok:
Anhand der Beschreibung wüßte ich nicht welcher der beiden Slots der Richtige ist.
Weiß jemand wie man die roten LEDs auf dem DIMM.2 Modul deaktiviert? Bei anderen Modellen gibt es Jumper, hier nicht :(
edit:
Hat sich erledigt, hab sie abgeklebt..
Für die nächsten Wochen wurde ein neues Bios mit dem neuen Microcode + ME angekündigt.
Ähnliche Themen
