[Sammelthread] ASUS ROG Maximus IX Apex - The New Hardcore (Z270)
--- Produktseite | PDF-Handbuch | Preisvergleich ---
388055d1484583484-intel-union-point-mainboards-ft-200-series-chipset-news-reviews-specs-bilder-1561949-1.jpg
Spezifikationen
CPUIntel® for 7th/6th Generation Core i7 / i5 / i3 / Pentium / Celeron Processors
Supports Intel 14 nm CPU
* The Intel Turbo Boost Technology 2.0 support depends on the CPU types.
ChipsetIntel Z270
Memory2x DDR4, Non-ECC, Un-buffered DIMM, max. 32GB**
DDR4 4266/4133/4000/3866/3800/3733/3600/3500/3466/3400/3333/3300/3200/3000/2800/2666/2400(O.C.)/2133 MHz
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
** Anm. d. Verf.: bzw 64GB, sobald 16Gbit DDR4 ICs verfügbar sind
GraphicIntegrated Graphics Processor HD Graphics support
Multi-Monitor support : HDMI/DisplayPort ports
- HDMI 1.4b (up to 4096 x 2160 @ 24 Hz)
- DisplayPort 1.2 (up to 4096 x 2304 @ 60 Hz)
Maximum shared memory of 1024 MB
Multi-GPU Support (2-Way SLI, Quad-GPU SLI, 2-Way & 4-Way CrossfireX)
Expansion Slots2 x PCIe 3.0/2.0 x16 (x16 or dual x8)
1 x PCIe 3.0/2.0 x16 (max at x4 mode)
2 x PCIe 3.0/2.0 x1
StorageIntel® Z270 Chipset :
Supports Intel Smart Response, Rapid Start , Smart Connect
Support Raid 0, 1, 5, 10
Intel Optane Memory Ready
LANIntel® I219V, 1 x Gigabit LAN Controller(s)
ASUS LAN Guard
Dual interconnect between the integrated Media Access Controller (MAC) and physical layer (PHY)
AudioROG SupremeFX 8-Channel High Definition Audio CODEC S1220A
- Impedance sense for front and rear headphone outputs
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
- ESS ES9023P
- SupremeFX Shielding Technology
- Optical S/PDIF out port(s) at back panel
USB PortsIntel Z270 Chipset :
8 x USB 3.0 port(s)
6 x USB 2.0 port(s)
ASMedia USB 3.1 controller :
2 x USB 3.1 port(s) (2 at back panel, Type-A + Type-C)
ROG Exclusive FeaturesROG RAMCache II
ROG CPU-Z
ROG CloneDrive
MemOK! Button
Slow Mode
CMOS button
Overwolf
ReTry Button
Safe Boot Button
Start Button
Reset Button
LN2 Mode
ROG Aura
- Aura Lighting Control
- Aura RGB Strip Headers
Extreme Engine Digi+ :
- MicroFine Alloy Chokes
- NexFET Power Block MOSFET
- 10K Black Metallic Capacitors
Mem TweakIt
UEFI BIOS features :
Special Features
5-Way Optimization by Dual Intelligent Processors 5
SafeDIMM slot
AURA :
- Aura Lighting Effects Synchronization with compatible ASUS ROG devices
ASUS Exclusive Features- MemOK!
- AI Suite 3
- Anti-Surge
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
- ASUS USB BIOS Flashback
- ASUS UEFI BIOS EZ Mode
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-Connector
Gaming Aesthetics :
- 3D printing friendly
- AURA-RGB Lighting
Performance Optimization :
- Fan Xpert 4 featuring Fan Auto Tuning function and multiple thermistors selection for optimized system cooling control
Back I/O Ports1 x PS/2 keyboard (purple)
1x PS/2 mouse (green)
1x DisplayPort
1x HDMI
1x LAN (RJ45) port(s)
2x USB 3.1 (Type-A + Type-C)
6x USB 3.0
1x Optical S/PDIF out
1x Clear CMOS button(s)
1x USB BIOS Flashback Button(s)
5x Gold-plated audio jacks
Internal I/O Ports1x AAFP
2x RGB Header(s)
1x USB 3.0
3x USB 2.0
4x SATA 6Gb/s
1x CPU Fan
1x CPU OPT Fan
3x Chassis Fan
1x W_PUMP+
1x AIO_PUMP
1x W_Pump+ Header
1x AIO PUMP Header
1x W_IN header
1x W_OUT header
1x W_FLOW header
2x Thermal sensor connector
1x 24-pin EATX Power
2x 8-pin ATX 12V Power
1x EZ Plug connector(s) (4-pin Molex)
1x LN2 Mode switch(es)
1x LN2 Mode jumper(s)
1x Slow Mode switch(es)
1x Slow Mode jumper(s)
1x Reset button(s)
1x BIOS Switch button(s)
1x Safe Boot button
1x ReTry button
1x Start button
1x 14-1 pin TPM
1x 3D Mount screw port(s)
AccessoriesUser's manual
I/O Shield
2 x SATA 6Gb/s cable(s)
1 x SLI HB BRIDGE(2-WAY-L)
1 x Q-Connector
1 x DIMM.2 extension card with 2 x M key (2242/2260/2280/22110, SATA & PCIE 3.0 x 4 mode)
1 x ROG coasters
Operating SystemWindows 10 64-bit
Windows 8.1 64-bit
Windows 7 32-bit
Windows 7 64-bit
Form FactorExtended ATX Form Factor
12 inch x 10.7 inch ( 30.5 cm x 27.2 cm )
Special Features
ASUS Dimm.2 - Dual M.2 Mount Add-On Card
The DIMM.2 module has an exclusive design that accepts two M.2 drives vertically-mounted on a DDR4 interface. This allows a DRAM fan cooler to direct air towards the M.2 drives to prevent throttling.
BIOS
Bilder
Inoffizielle BIOS Versionen u.a. für Extrem-OC (Achtung: Nutzung auf eigene Gefahr!)
  • 0009 (for IGPU benching, higher voltage limits without LN2 Mode)
  • 0023 (0801 with USB over-current detection disabled)
  • 0026 (very early release)
  • 0088 (might fix CBB issues with CPU RSVD switch, BIOS behaves differently during POST with B-die + high voltage)
  • 0091 (0088 + updated Microcode for Core i3-7350K)
  • 0701 (recommended for general use)
News & Reviews
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
2) RAM
ASUS Memory QVL (PDF).​
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.​
Nützliche Links & Tipps (im Forum & im WWW)
1) Hardwareluxx
2) WWW (international)
3) Tips & Tricks
4) FAQ - Frequently Asked Questions
  • --> Deine Frage hier!
  • Q: Wie sind die Lüfter und Pumpenanschlüsse konfiguriert? Was ist die maximale Belastbarkeit pro Anschluss?
  • A: Die regulären Lüfteranschlüsse lassen manuell als PWM oder per Spannung geregelt konfigurieren. Die Belastbarkeiten im Überblick:
  • Q: Wie sind die PCI Express Slots angebunden?
  • A:
  • Q: Wo finde ich auf dem Board XYZ?
  • A: (zum vergrößern auf die Grafik klicken)
  • Q: Aus welchen Komponenten besteht und wie leistungsfähig ist das VRM des Apex?
  • A: Es handelt sich um eine 8+2 [2*4(CPU) + 2(iGFX)] & [+ 1(SA) + 1(IO)] Implementierung, mit einem digitalen IR IR35201/3 PWM Controller und zehn TI NexFET PowerBlocks vom Typ 87350D mit einem Rating von bis zu 40A pro Phase für CPU und iGFX.
    (Mosfets für SA/IO sind OnSemi NTMFS4C06B)
  • Q: Wie kann ich den Startvorgang des System beschleunigen?
  • A: Ich habe den Startvorgang bis zum Desktop mit dem M8G mit folgenden Einstellungen auf unter 10s reduzieren können. Diese scheinen analog auch für das Apex wirksam zu sein.
    Code:
    MRC Fast Boost [Enabled] [color=red]Vorher unbedingt die Speichereinstellungen auf Stabilität testen, da das Speicherretraining damit deaktiviert wird![/Color]
    MCH Full Check [Disabled]
    PCH Storage configuration Smart self test [Disabled]
    CSM [Disabled] [color=red]Nur wenn ihr euer OS im UEFI Modus installiert habt.[/Color]
    Option ROM Messages [Disabled]
    Fast Boot [Enabled]
    POST delay time [0]
    Boot Logo [AUTO] oder [Full Screen]
  • Q: Kann man auf dem Maximus IX Apex Coffee Lake Prozessoren verwenden?
  • A: Offiziell ist dies von Intel nicht vorgesehen, es gibt aber einen relativ simplen Hardware+BIOS Mod, der dies ermöglicht. Dies wurde so auch schon von einigen Seiten wie hier Intel Core I9-9900K & Z270! @ overclockers.ru getestet. The_patchelor hat dazu eine Anleitung erstellt:
    APEX IX Coffeelake Mod
    Ohne zusätzliche Modifikationen an der CPU (weder SKT_OCC noch 2 Punkte isolieren) ;) nur Mainboard Mod notwendig.
    So hab ich es gemacht, Bilder sind von mir:
    die 2 Mods
    1x CPU Paqd Mod (SKT_OCC brücken)
    1x Bios brücken (löten, Silberleitlack, Bleistift oder einfach nur kurzschließen) damit wohl das "fremde" Bios drauf kann
    hier der Link zur Quelle
    jAlex@ro hat ein IX Bios aufgebohrt (XP geht damit)
    0084v2 (wohl ohne HT)
    jjxaker hat das Board quasi in ein X verwandelt (XP geht nicht)
    1602 mit HT
    Bios UPDATE
    Base: Asus Maximus X Apex for Maximus IX Apex@BIOS MOD 1602
    Support CPU: Skylake/Kaby Lake/Coffee Lake
    Latest Bios Microcode:
    Intel CPU SKL 0xC6, KBL 0x8E, CFL 8 Core 0x96 / 6 Core 0x96 / 4 Core 0x8E.
    Intel EFI RST 16.5.0.3492
    Intel VBIOS 1059/GOP 9.0.1080
    Intel Lan UNDI 0.0.19/Lan OROM 0.1.13/Lan GBE 0.5
    Intel ME Firmware 11.7.0.1129
    All Region DESC/ME/BIOS Unlock.
    All components of the board are working. including RGB Light, on-board graphics card, HT, PCI-e.
    To MOD flash through the ISP programmer or HW MOD USB Bios Flashback.
    Habe das 1602 einfach per USB Bios Flashback drauf gepackt. Beim ersten Start dreht das Bios 2 Runden und aktualisiert sich, dann habe ich noch den nicht vorhandenen 5G LAN Anschluss deaktiviert. Um das gemoddete 1602 downloaden zu können, müsst ihr im HWBOT Forum eingelogged sein.
    Hinweis zum Bios Flashback: Das Bios überschreibt euch die MAC, UUID und MB Serial.
    Lösung:
    -mit altem Bios zuvor oder mit Bios2 booten (SL oder KL CPU erforderlich...)
    -Universal Bios Backup Toolkit 2.0 suchen und downloaden (als Admin ausführen, Viruswarnung ignorieren... am besten mit einem temp. Windows arbeiten..)
    -Bios auslesen und abspeichern
    -FD44Editor verwenden um die MAC, UUID und Motherboard S/N auszulesen (vom backupBios)
    -1602 creative.rom auch mit FD44Editor öffnen und die Werte eintragen und abspeichern
    hier werden die Werte aus dem alten ins neue eingetragen...
    wieder als creative.rom speichern und auf einen USB Stick packen. BIOS wieder auf 1 umstellen und das korrigierte "persönliche" BIOS per USB Flashback laden
5) ASUS ROG Wallpaper
6) Wasserkühler (Mainboard)
WORK IN PROGRESS :angel:
Ich habe ebenfalls das Apex Board und zwei 512gb Samsung 960 Pro. Macht es mehr sind ein RAID 0 zu erstellen und System und Games auf eine Partition zu packen oder lieber zwei getrennte Platten? Was ist von der Performance besser?
Und bei RAID 0 welche Strip Size ist zu empfehlen?
Habs mir mal gezogen und werde kurz antesten, ob sich beim Speichertraining @ 4133+ was getan hat.
Downloadhinweise
BETA BIOS
- Update ME version to 11.8.50.3399
- Improve system stability
*please back your Bitlocker recovery key and suspend Bitlocker encryption in the operating system befor updathe your BIOS or ME Firmware
Konntest du es schon kurz antesten? Habs mir grad mal geladen und werds jetz mal aufs 2. Bios flashen.
Wird bei mir erst später, bin noch am arbeiten.
Hatte paar kleine Probs damit. Weiß aber noch nicht woran es gelegen hat. Die m2 hat sich nach 2-3 Neustarts (in Win10) verabschiedet, konnte nicht mehr von gebootet werden.
1010 alles lüppt, 1101 m2 weg, wechsel auf 1010 alles lüppt, wechsel auf 1101 naja usw. Beides auch mit Default gegen getestet^^
Vlt war es auch nur irgendeine Einstellungssache, aber das werde ich dann am Sonntag mal in Ruhe angehen. Muss morgen noch mal ran. & dann steht NFL Wildcard Weekend auf dem Programm und nebenher muss ich noch Memtest laufen lassen denn 16-16-36-1T 4000scheint erstmal stable Zusein. 4133 17-18-38-1t sah auch nicht schlecht aus aber dann muss ich gut SA drauf geben^^
Das m.2 Problem hatte ich nicht, in der Kiste stecken aber auch nur meine alten m.2 SATA SSDs und eine klassische HDD.
Hoffentlich ist am Wochenende nicht so viel los, will mir die Wildcard Round auch ansehen :d
Wildcard Games geschafft? Samstag sind wa zu 4. auf der Couch weggesackt^^
Also da beim Stammtisch irgendwie kein "echter Nerd" antwort geben konnte, versuch ich mal hier mein Glück erneut.
Mein Ram Setting lief jetzt 6x 2047MB + 1x 1200% 1Error. Sollte das reichen oder besteht da noch Handlungsbedarf ?
Habe den Ram ja mit Stock CPU ausgelotet. Wenn ich jetzt versuche langsam das CPU OC draufzugeben, bekomme ich egal bei welchen Spannungen nach 1-2 Minuten einen Worker Ausstieg.
Schafft meine CPU den hohen Ramtakt nicht auch wenn ich endlich durch 1000% Memtest gekommen bin ?
Bei 4000MHz musste ich bei 5GHz, 2 VCore-Stufen draufgeben um durch Prime95 29.2 zukommen.
Auch CPU Stock + 4133MHz Ram, Worker Ausstieg nach 2-3 Minuten im Custom Run.
Sollte dann wohl eher gucken, was der Ram @4000MHz kann, ai ?
E: übrigens alles noch mit Bios 1010
E2: so, 4000MHz, CPU@Stock - Prime 29.2 läuft dann schon mal min. 20min.
Werde dann wohl mal gucken was ich an den Timings noch drehen kann für 4000MHz. Damit kommt meine CPU scheinbar noch klar^^
Das erste habe ich halb verpasst, die beiden späteren waren aber doch recht unterhaltsam :)
Hebst du dabei den Cachetakt mit an?
Meist steht und fällt die Stabilität dann mit den passenden Nebenspannungen.
Ist warscheinlich sinnvoll für 24/7, vor allem wenn du damit deutlich bei den Nebenspannungen sparen kannst. Das schont die CPU und 4000 16-16-16 1T sieht ja auch nicht so übel aus.
attachment.php
Grundsätzlich sollten 4133 mit dem Apex aber auch möglich sein (mit einem guten Sample auch bei 1T).
Nope. Hebe erst den CPU Takt an und wenn das Setup am Ende Stabil ist,
heb ich den Cachtakt an und lasse dann Prime/Memtest noch mal final laufen.
Ja, Memtest schafft auch 2000% ohne Error. Nur Prime wirft sofort Worker raus.
4000 C17-18-38 1T (4133 Setup) läuft stabil.
Dann werde ich mal zunächst SA/IO erneut anpassen und dann mal gucken ob ich mit den Timings noch
was runter kann. Denn C16 war eig schon mein Ziel. Aber selbst für 24/7 ist das schon ganz ok. Such gleich mal n Aida Screen raus.
Werde dann mal am Weekend gucken ob nicht vlt mit dem 12er Bios die 4133 in Prime laufen.
Ich habe mehrere Probleme mit meinem Apex und wollte mal hören ob es an Einstellungen liegt oder am ggf. ein defektes Board ist.
1. Problem
Bei ca. jedem zweiten Start und dem versuch direkt das Bios zu laden friert der PC ein und ich muss den Retry Button benutzen.
Bzw. wenn ich aus Windows einen Neustart mache und ins Bios will friert er immer ein. Code 04
2. Problem
Wenn ich alle Einstellungen auf Default habe und das XMP lade bekomme ich immer einen Code 55
16GB (G.Skill Trident Z RGB DDR4-4266 DIMM CL19-19-19-39
CPU Intel Core i7 7700K
3. Problem
Der Jumper der die M.2 LED deaktivieren soll, tut dies nicht.
Hallo liebe Apex-Besitzer,
ich habe mir dieses Board zum Benchen gegönnt und wüsste gerne, ob es noch möglich ist, Windows XP darauf zu installieren. Das würde mir bei alten Grafikkarten wahrscheinlich sehr helfen.
1. Problem
2. Problem
3. Problem
Wenn Default und CMOS keine Abhilfe schaffen würde ich noch ne andere Bios Version Testen ansonsten hat das Board wohl einen weg.
4266 hatten hier glaube einige Probleme das gescheit ans laufen zu bekommen, meine bei 4133 war ende.
Ich denke nicht, gibt zwar nen Video vom letzten Jahr wo Dancop da was am laufen hat aber eher schlecht als recht, da keine Treiber....
so ziemlich am ende des Videos
DREAMHACK Live vom ASUS Stand mit Debitor und Frank Sirius / Gaming PC Live Build i7 7700k Kabbylake - YouTube
Vielen Dank!
Das Problem sind ja die USB Treiber, das kann ich zumindest umgehen, weil das Apex zum Glück noch zwei PS2-Anschlüsse hat. Als ich die gesehen habe, hab ich mich echt gefreut - das findest du heute doch auf keinem Board mehr, aber fürs Extreme-OC ist das ungemein praktisch.
Also mal gucken wie einfach die Installation von WinXP wird, angeblich gibt es keinen SATA-IDE Mode Support mehr (und ich weiß nicht ob man WinXP als AHCI installieren kann, sicherlich nicht einfach so). Aber vielleicht kann ich ein XP auf einem älteren System installieren und dann einfach die Platte umklemmen.
Notfalls wird eine PCI-Express-USB 2.0 Karte nötig, aber ich werd erstmal schauen obs nicht ohne geht. In meinem HWBot Team habe ich da zum Glück in der Zwischenzeit schon einige Tipps bekommen. Dass es überhaupt möglich ist, ist für mich schon mal eine große Erleichterung.
Im verlinkten Guide ist eigentlich alles erklärt. Die benötigte Software ist auf der letzten Seite des Guides verlinkt.
MemTest für DDR4-4000 16-16-16-36 1T mit den Torque ist durch:
Nach 100% abgebrochen, weil ich vergessen hatte den CPU-Lüfter vor dem Test wieder hochzuregeln :fresse:
Allerdings sehen DDR4-4133 17-17-17-37 1T auch schon recht vielversprechend aus:
Ich finde das absolut erstaunlich, wie gut derselbe Ram auf dem Apex läuft, mit dem ich auf der Ryzen Plattform solche Probleme habe. Meine G.Skill B-Die Chips laufen auf dem ROG 6 Hero so in etwa 3200MHz CL14 stabil, während ich auf dem Apex einfach 3866MHz einstellen kann, Timings komplett auf Auto!! und das läuft mit CL15 komplett stabil. Dachte meine Sticks wären Mist :d
Übrigens läuft mein caseking pretested 7600 mittlerweile in XP wunderbar, easy 5,6GHz@1,475V 4C/4T für Benches wie wPrime, 3D Mark 01, 03 usw.
Intels DDR4 First Gen hatte ähnliche Limitierungen beim Speichertakt. Die meisten erinnern sich nur nicht mehr daran, dass bei LGA2011-3 mit Haswell-E in den meisten Fällen auch bei DDR4-3200/3333 Schluss war.
Also bisschen was konnten die 2011-3 Chips schon :fresse:
Du nun wieder :fresse:
Möglich ja, aber nicht jede CPU und nicht auf jedem Board und nicht mit jedem Speicher usw. Es gibt inzwischen auch Screens für DDR4-3733+ auf Ryzen, nur ist das eben eher die Ausnahme. Daher hinkt der Vergleich gar nicht so sehr, imo.
He Leute,
- kann man die LEDs auch per Bios ausschalten/umschalten?
- die 3-pin e-loops lassen sich nur bis 800 U/min herunterregeln. Auf meinen anderen Boards liefen die allerdings auch mit 400-500 U/min.
Das Apex Bios lässt mich nicht tiefer als ~60% gehen. Kann man irgendwo zwischen % und Volt wechseln, oder zumindest das untere Limit verschieben?
Punkt 2 hat sich erledigt. Es musste zunächst die Fan Kalibrierung durchgeführt werden, um die Minimumdrehzahl durch das Board ermittlen zu lassen.
Jetzt bleibt nur noch die Sache mit den LEDs ;)
Ich habe ebenfalls das Apex Board und zwei 512gb Samsung 960 Pro. Macht es mehr Sinn ein RAID 0 zu erstellen und System und Games auf eine Partition zu packen oder lieber zwei getrennte Platten? Was ist von der Performance besser?
Hat hierzu evtl. Jemand eine Meinung oder Empfehlung?
Welches BIOS benutzt ihr eigentlich derzeit? Ich überlege, ob ich wieder ein downgrade von 1203 auf 1010 mache. (Ohne Spectre/Meltdown microcode)
Oder war bereits bei 1010 der MC schon drin?
Ist eben eine reine Benchmark/Gaming Kiste
Raid0 bei 960er macht keinen Sinn, da du bereits mit einer am Limit der Schnittstelle bist.
