[Sammelthread] ASUS ROG Maximus IX Apex - The New Hardcore (Z270)
--- Produktseite | PDF-Handbuch | Preisvergleich ---
388055d1484583484-intel-union-point-mainboards-ft-200-series-chipset-news-reviews-specs-bilder-1561949-1.jpg
Spezifikationen
CPUIntel® for 7th/6th Generation Core i7 / i5 / i3 / Pentium / Celeron Processors
Supports Intel 14 nm CPU
* The Intel Turbo Boost Technology 2.0 support depends on the CPU types.
ChipsetIntel Z270
Memory2x DDR4, Non-ECC, Un-buffered DIMM, max. 32GB**
DDR4 4266/4133/4000/3866/3800/3733/3600/3500/3466/3400/3333/3300/3200/3000/2800/2666/2400(O.C.)/2133 MHz
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
** Anm. d. Verf.: bzw 64GB, sobald 16Gbit DDR4 ICs verfügbar sind
GraphicIntegrated Graphics Processor HD Graphics support
Multi-Monitor support : HDMI/DisplayPort ports
- HDMI 1.4b (up to 4096 x 2160 @ 24 Hz)
- DisplayPort 1.2 (up to 4096 x 2304 @ 60 Hz)
Maximum shared memory of 1024 MB
Multi-GPU Support (2-Way SLI, Quad-GPU SLI, 2-Way & 4-Way CrossfireX)
Expansion Slots2 x PCIe 3.0/2.0 x16 (x16 or dual x8)
1 x PCIe 3.0/2.0 x16 (max at x4 mode)
2 x PCIe 3.0/2.0 x1
StorageIntel® Z270 Chipset :
Supports Intel Smart Response, Rapid Start , Smart Connect
Support Raid 0, 1, 5, 10
Intel Optane Memory Ready
LANIntel® I219V, 1 x Gigabit LAN Controller(s)
ASUS LAN Guard
Dual interconnect between the integrated Media Access Controller (MAC) and physical layer (PHY)
AudioROG SupremeFX 8-Channel High Definition Audio CODEC S1220A
- Impedance sense for front and rear headphone outputs
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
- ESS ES9023P
- SupremeFX Shielding Technology
- Optical S/PDIF out port(s) at back panel
USB PortsIntel Z270 Chipset :
8 x USB 3.0 port(s)
6 x USB 2.0 port(s)
ASMedia USB 3.1 controller :
2 x USB 3.1 port(s) (2 at back panel, Type-A + Type-C)
ROG Exclusive FeaturesROG RAMCache II
ROG CPU-Z
ROG CloneDrive
MemOK! Button
Slow Mode
CMOS button
Overwolf
ReTry Button
Safe Boot Button
Start Button
Reset Button
LN2 Mode
ROG Aura
- Aura Lighting Control
- Aura RGB Strip Headers
Extreme Engine Digi+ :
- MicroFine Alloy Chokes
- NexFET Power Block MOSFET
- 10K Black Metallic Capacitors
Mem TweakIt
UEFI BIOS features :
Special Features
5-Way Optimization by Dual Intelligent Processors 5
SafeDIMM slot
AURA :
- Aura Lighting Effects Synchronization with compatible ASUS ROG devices
ASUS Exclusive Features- MemOK!
- AI Suite 3
- Anti-Surge
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
- ASUS USB BIOS Flashback
- ASUS UEFI BIOS EZ Mode
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-Connector
Gaming Aesthetics :
- 3D printing friendly
- AURA-RGB Lighting
Performance Optimization :
- Fan Xpert 4 featuring Fan Auto Tuning function and multiple thermistors selection for optimized system cooling control
Back I/O Ports1 x PS/2 keyboard (purple)
1x PS/2 mouse (green)
1x DisplayPort
1x HDMI
1x LAN (RJ45) port(s)
2x USB 3.1 (Type-A + Type-C)
6x USB 3.0
1x Optical S/PDIF out
1x Clear CMOS button(s)
1x USB BIOS Flashback Button(s)
5x Gold-plated audio jacks
Internal I/O Ports1x AAFP
2x RGB Header(s)
1x USB 3.0
3x USB 2.0
4x SATA 6Gb/s
1x CPU Fan
1x CPU OPT Fan
3x Chassis Fan
1x W_PUMP+
1x AIO_PUMP
1x W_Pump+ Header
1x AIO PUMP Header
1x W_IN header
1x W_OUT header
1x W_FLOW header
2x Thermal sensor connector
1x 24-pin EATX Power
2x 8-pin ATX 12V Power
1x EZ Plug connector(s) (4-pin Molex)
1x LN2 Mode switch(es)
1x LN2 Mode jumper(s)
1x Slow Mode switch(es)
1x Slow Mode jumper(s)
1x Reset button(s)
1x BIOS Switch button(s)
1x Safe Boot button
1x ReTry button
1x Start button
1x 14-1 pin TPM
1x 3D Mount screw port(s)
AccessoriesUser's manual
I/O Shield
2 x SATA 6Gb/s cable(s)
1 x SLI HB BRIDGE(2-WAY-L)
1 x Q-Connector
1 x DIMM.2 extension card with 2 x M key (2242/2260/2280/22110, SATA & PCIE 3.0 x 4 mode)
1 x ROG coasters
Operating SystemWindows 10 64-bit
Windows 8.1 64-bit
Windows 7 32-bit
Windows 7 64-bit
Form FactorExtended ATX Form Factor
12 inch x 10.7 inch ( 30.5 cm x 27.2 cm )
Special Features
ASUS Dimm.2 - Dual M.2 Mount Add-On Card
The DIMM.2 module has an exclusive design that accepts two M.2 drives vertically-mounted on a DDR4 interface. This allows a DRAM fan cooler to direct air towards the M.2 drives to prevent throttling.
BIOS
Bilder
Inoffizielle BIOS Versionen u.a. für Extrem-OC (Achtung: Nutzung auf eigene Gefahr!)
  • 0009 (for IGPU benching, higher voltage limits without LN2 Mode)
  • 0023 (0801 with USB over-current detection disabled)
  • 0026 (very early release)
  • 0088 (might fix CBB issues with CPU RSVD switch, BIOS behaves differently during POST with B-die + high voltage)
  • 0091 (0088 + updated Microcode for Core i3-7350K)
  • 0701 (recommended for general use)
News & Reviews
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
2) RAM
ASUS Memory QVL (PDF).​
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.​
Nützliche Links & Tipps (im Forum & im WWW)
1) Hardwareluxx
2) WWW (international)
3) Tips & Tricks
4) FAQ - Frequently Asked Questions
  • --> Deine Frage hier!
  • Q: Wie sind die Lüfter und Pumpenanschlüsse konfiguriert? Was ist die maximale Belastbarkeit pro Anschluss?
  • A: Die regulären Lüfteranschlüsse lassen manuell als PWM oder per Spannung geregelt konfigurieren. Die Belastbarkeiten im Überblick:
  • Q: Wie sind die PCI Express Slots angebunden?
  • A:
  • Q: Wo finde ich auf dem Board XYZ?
  • A: (zum vergrößern auf die Grafik klicken)
  • Q: Aus welchen Komponenten besteht und wie leistungsfähig ist das VRM des Apex?
  • A: Es handelt sich um eine 8+2 [2*4(CPU) + 2(iGFX)] & [+ 1(SA) + 1(IO)] Implementierung, mit einem digitalen IR IR35201/3 PWM Controller und zehn TI NexFET PowerBlocks vom Typ 87350D mit einem Rating von bis zu 40A pro Phase für CPU und iGFX.
    (Mosfets für SA/IO sind OnSemi NTMFS4C06B)
  • Q: Wie kann ich den Startvorgang des System beschleunigen?
  • A: Ich habe den Startvorgang bis zum Desktop mit dem M8G mit folgenden Einstellungen auf unter 10s reduzieren können. Diese scheinen analog auch für das Apex wirksam zu sein.
    Code:
    MRC Fast Boost [Enabled] [color=red]Vorher unbedingt die Speichereinstellungen auf Stabilität testen, da das Speicherretraining damit deaktiviert wird![/Color]
    MCH Full Check [Disabled]
    PCH Storage configuration Smart self test [Disabled]
    CSM [Disabled] [color=red]Nur wenn ihr euer OS im UEFI Modus installiert habt.[/Color]
    Option ROM Messages [Disabled]
    Fast Boot [Enabled]
    POST delay time [0]
    Boot Logo [AUTO] oder [Full Screen]
  • Q: Kann man auf dem Maximus IX Apex Coffee Lake Prozessoren verwenden?
  • A: Offiziell ist dies von Intel nicht vorgesehen, es gibt aber einen relativ simplen Hardware+BIOS Mod, der dies ermöglicht. Dies wurde so auch schon von einigen Seiten wie hier Intel Core I9-9900K & Z270! @ overclockers.ru getestet. The_patchelor hat dazu eine Anleitung erstellt:
    APEX IX Coffeelake Mod
    Ohne zusätzliche Modifikationen an der CPU (weder SKT_OCC noch 2 Punkte isolieren) ;) nur Mainboard Mod notwendig.
    So hab ich es gemacht, Bilder sind von mir:
    die 2 Mods
    1x CPU Paqd Mod (SKT_OCC brücken)
    1x Bios brücken (löten, Silberleitlack, Bleistift oder einfach nur kurzschließen) damit wohl das "fremde" Bios drauf kann
    hier der Link zur Quelle
    jAlex@ro hat ein IX Bios aufgebohrt (XP geht damit)
    0084v2 (wohl ohne HT)
    jjxaker hat das Board quasi in ein X verwandelt (XP geht nicht)
    1602 mit HT
    Bios UPDATE
    Base: Asus Maximus X Apex for Maximus IX Apex@BIOS MOD 1602
    Support CPU: Skylake/Kaby Lake/Coffee Lake
    Latest Bios Microcode:
    Intel CPU SKL 0xC6, KBL 0x8E, CFL 8 Core 0x96 / 6 Core 0x96 / 4 Core 0x8E.
    Intel EFI RST 16.5.0.3492
    Intel VBIOS 1059/GOP 9.0.1080
    Intel Lan UNDI 0.0.19/Lan OROM 0.1.13/Lan GBE 0.5
    Intel ME Firmware 11.7.0.1129
    All Region DESC/ME/BIOS Unlock.
    All components of the board are working. including RGB Light, on-board graphics card, HT, PCI-e.
    To MOD flash through the ISP programmer or HW MOD USB Bios Flashback.
    Habe das 1602 einfach per USB Bios Flashback drauf gepackt. Beim ersten Start dreht das Bios 2 Runden und aktualisiert sich, dann habe ich noch den nicht vorhandenen 5G LAN Anschluss deaktiviert. Um das gemoddete 1602 downloaden zu können, müsst ihr im HWBOT Forum eingelogged sein.
    Hinweis zum Bios Flashback: Das Bios überschreibt euch die MAC, UUID und MB Serial.
    Lösung:
    -mit altem Bios zuvor oder mit Bios2 booten (SL oder KL CPU erforderlich...)
    -Universal Bios Backup Toolkit 2.0 suchen und downloaden (als Admin ausführen, Viruswarnung ignorieren... am besten mit einem temp. Windows arbeiten..)
    -Bios auslesen und abspeichern
    -FD44Editor verwenden um die MAC, UUID und Motherboard S/N auszulesen (vom backupBios)
    -1602 creative.rom auch mit FD44Editor öffnen und die Werte eintragen und abspeichern
    hier werden die Werte aus dem alten ins neue eingetragen...
    wieder als creative.rom speichern und auf einen USB Stick packen. BIOS wieder auf 1 umstellen und das korrigierte "persönliche" BIOS per USB Flashback laden
5) ASUS ROG Wallpaper
6) Wasserkühler (Mainboard)
WORK IN PROGRESS :angel:
Danke loopy, mit deinen Aussagen zum Impact hast du mir einiges an Bastelarbeit erspart am Wochenende!
@aerotracks:
Alle hwbotler benchen auf 0013 aber behalten es schön für sich :d Das ist mehr was für die Insider scheint mir.
Apex, check :p
Edit: Mit dem 0013er BIOS 5.0@1.296V nach 7 Minuten ausgestiegen, das lief auf dem OCF mit P7.40 1344k und Listenrun-stable.
Muss man sich bisschen durchprobieren mit den verschieden Versionen, sieht aber grundsätzlich ganz gut aus.
Na toll, mein Apex scheint Out of the Box tot zu sein. Bekomme nur Postcode 00 und sonst tut sich nix. Prozzi wieder aufs OCFM und alles läuft.....
Gesendet von meinem LG G5 mit Tapatalk
Hast du einen Link dazu? Auf die Schnelle hab ich es nicht gefunden.
Wenn man das 0013 weitergeben darf und es mir jemand schickt, lade ich es für alle auf den Luxx FTP.
Der EK Supremacy EVO Full-Nickel passt aufs Brett. Der Abstand der Halterung zum ersten RAM-Slot beträgt 2,3 mm.
Hier mal ein Foto: https://abload.de/img/cpu-khlerupssx.jpg
Trage ich gleich ein.
Vielleicht auch noch interessant im Startpost - das kurze OC-Tutorial von Roman:
OC-Tutorial by der8auer - Part 1
OC-Tutorial by der8auer - Part 2
Waren von Anfang drin ;)
Naja, so ziemlich alles was mir bleibt... Anderes NT, anderer Speicher, aufm Tisch, im Gehäuse etc... Nur keine andere CPU, weil ich hab nur den einen hier...
Apex müsste out of the box Kaby tauglich sein, oder? :fresse:
Wie gesagt, Postcode 00 und Prozzi bleibt auch kalt (ohne Kühler)
Bin jetzt auf der Suche nach entsprechendem RAM.
Hatte mir diesen RAM rausgesucht, welcher ja auch kompatibel ist.
Bekommt man den auch auf 4000 MHz oder ist bei 3600 schluss?
Ja das Apex unterstützt Kaby von Haus aus. Mit dem Auslieferungsbios ist das kein Problem.
Zeigen die LEDs (nicht QCode) oben rechts in der Ecke was an? Also leuchten sie?
Sind alle Jumper und Switches auf default?
0026 Bios .....Similar to 0701 but slightly older, seems to work well for a lot of people.
Die Versionen aus dem Thread im BOT sind alle schon drin (26, 88, 91, 701).
Hatte mir F4-3600C16D-16GTZ rausgesucht, welcher ja auch kompatibel ist. Bekommt man den auch auf 4000 MHz oder ist bei 3600 schluss?
Habe meine selbst auf dem M8G problemlos auf 4000 bekommen, allerdings nur bis 1.5V getestet also kein CL12.
Ist nun auch verlinkt :)
Schau mal ob alle Switches aus sind! Danach mal Bios reflash blind mit USB Stick... Wenn das auch nicht hilft, einschicken...
Gesendet von meinem HUAWEI NXT-L29 mit Tapatalk
Der 2*8GB 4000MHz CL18 von G Skill läuft auch mit XMP 1a.
Jau danke, eben nochmal kontrolliert und auch nen reflash durchgeführt. Aber keine Besserung
@ webwilli
die LEDs oben in der Ecke bleiben aus, da passiert nix.
Naja, morgen kommt noch nen APEX von PC King (haben ja verschickt trotz stornierung). Dann bekommt Vibo seins zurück sofern das von King dann läuft :fresse:
2093MHz 12-12-12 50/51 straight Winboot, meine :fresse:
2066 12-11-11 50/51/6/6 super tight auch straight boot und 32M Waza... Dennoch ist das Board mit dem RAM zickiger als gedacht.
Die ewig langen Boot Zeiten nerven auch...
12-11 ist nochmal ein Kapitel für sich, egal welches Kit, zickt nur rum. 12-12 bootet stressfrei.
Die Fummelei mit Z270 Treibern in XP integrieren tue ich mir heute Abend nicht an.
Schau gleichmal was in Geekbench max Mem takt geht.
Eines von den alten Kits oder die RGB?
@All: Bitte postet für Einträge in die Komp-Listen wenigstens einen Preisvergleichslink, den Rest ergänze ich dann notfalls.
Mit den Platinum SE? Edit -nvm-
Bei den Maximus VIII Modellen konnte man die POST Dauer mit ein paar Einstellungen deutlich drücken. Sub-10s ins Windows mit HDD waren dann kein Problem mehr.
Code:
CSM [Disabled]
Fast Boot [Enabled]
POST delay time [0]
Ihr wisst ja sicherlich selbst, was ihr zum Speicher testen nicht anfassen dürft ;)
Nee, die SE habe ich noch nicht im LN2 Modus getestet. Ohne ist bei 2V VDIMM Ende.
Bei 2V laufen die Corsairs 2020MHz C12, also 2066+ eher nicht.
Emi: die bootdauer sind nicht irgendwelche sinnlosen Peripherie Sachen oder sowas. Das sind RAM abhängige Post Codes... 4F/78/22... Das dauert nur bei krassen B-DIE Settings so lange :)
4F lässt er sich bisschen Zeit, 78 hängt auch bisschen wenn die weiße Lampe an ist und eigentlich gebootet ist.
22 mit dem jetzigen Kit und tRCD/tRP 12 gar nicht.
Geekbench fertig:
12-11 kann ich derzeit nur bei 4000 MHz bieten:
2066 mag nicht booten. Vielleicht noch etwas Spannung auf den RAM
Warum haben diese "High end" boards nur 10 Phasen insgesammt? nicht bisl wenig für hohes OC ?
