12 Angry Men SPIDER WEB CASE ( 900 D ) FINAL
arg-ist
Hi
I'm here again after a long illness vacation.
My SAK SAK 800D CASE was completed.
http://www.hardwareluxx.de/communit...-watercooled-copper-acrylic-pipe-1028332.html
Final Photos of MAC G5 CASE are comng soon.
http://www.hardwareluxx.de/community/f143/mac-g5-mod-arg-ist-1050219.html
And it is time to begin with a new Mod.
12 Angry Men SPIDER WEB Case
Again a 900D case… A nice case but with some with some shortcomings and errors. I do not know how many 900D case it was.
With the theme SPIDER WEB CASE.
A1-
A2-
A3-
A4-
A5-
A6-
A7-
A8-
materials used at this case
CASE : Corsair 900D
D2
MB : Asus Rampage 5 extreme
D 10
CPU: İNTEL 5820 K
D14
RAM: CORSAIR DOMİNATOR PLATİNUM 4X8GB 3000
D13
VIDEO CARD :Evga 980 Classified
D8
D9
WATERCOOLING PARTS
RADIATORS: Alphacool UT60 480
Alphacool Monsta 480
D1
WB: EK
FITTINGS:
Mat black Enchace 90 Dual Multilink Adapter
F10 A
Mat black Enhance Multi-link for Acrylic OD 12mm
F10 B
Mat black Enhance Rotary 90 Multilink Adapter
F10 C
RESERVOIR : Bitspower Z Multi 250
F8A
POMP : Swiftech MCP 655
D6
MOD KIT: Bitspower D5
D12
INLINE TEMP. SENSOR:Aqua computer
D11
FANS: 4x Corsair SP 120 Perf. Edition
4x Corsair SP 120 LED-kırmızı
3x Corsair AF 120
PSU: Corsair AX 1200İ
D3
SSD: OCZ VERTEX 4 Sata III 512 GB
D4
SOUND CARD: ASUS Sound Blaster SBX
D7
FAN CONTROLLER : Lamptron CW 611
D5
Don t be angry , Mod photos are coming soon. arg-ist
Again a 900D, and again still known watercool installation problems at 900D...
I say always… 900D is a lizard with severed tail . This time, I'll cut it.
it is very diffucult to put a 480 rad in the subdivision.
And do not even think of putting a 480 Monsta at the sub.
Only a HAMSTER can walk in narrow corridors.
E1
If you use a 480 Monsta ,the distance between RAD and PSU is only 15 mm ,and a ¾ OD tube is 19mm... Not enough place for fittings and for tubing.
And do not even think of putting a 480 Monsta as push pull at the sub.
I f you use 60 mm thick rad too , it is very diffucult to mount fittings and tubing expecially ¾ tubes
E2
We must turn the radiator 180 degree , to use fittings at the front side panel…to escape from the pressure of PSU.
and you have a mini problem…
There are 3 fans mounted at the front panel.
B1
Becouse they are mounted at the inside of the front panel ,there is no place for the radiator tanks..
B2
you must remove the fan, or you mount it to the outside.
I removed the fan
B3
I said; the designers have thought a solutione to mount the fans at the outside…
something that… has not even come to mind of the designers.
I made a simple adapter to this place , ı mounted the fan to the outside
B5-B6-B7
You can use the fan filter , and you can close the front door.
I have 25mm more place to mount the rad, place fort he tanks…
B10-
B11
Front filter and front door can be used as seamless .
A1
I began slowly to dismantle the case.
C1-
C2-
C3-
C4-
C5
We decided to disassemble 5:25 cages too.
C6
Case with removed front panel .
C7-
C8
firstly you need to remove parts of the case and later dress the case. And make
A backside panel to place A.
A mini cage to place B
and a midplate to place C.
F1
First 5.25 cages
Instead of 200m deep 5.25 cages, ı make an 65 mm deep cage.
C9
Back side of the the new cage is closed.
Number 1 at the photo.
C10
And mounted temporarily.
C11
Front panel with the new cage.
C12
to cover the backside of the case, to keep out this image from the eyes…
C7
I made a backplate Number 2 at photo C10
C13
The most problematic place of 900D , if you don t want to see this
C14
I decided to make an acrylic midplte with waterway. I made a tray from alu, for acrylic midplate.
C15
Tray leveled
C16
And mounted
C17
The center of the plate was poured
C19
-C20
All parts have been grinded
C21
Al parts painted.
F5
Another problem at 900D is, the design error, at the rad fans…
If you mount the rad with original mounting brackets , 1/5 of the fans are masked from the brackets and from the door.
R1
If you use led fans , it looks very bad out.
To fix it , ı made a new rad bracket . to compare the old ones(black) the new ones.
R6
I lowered down the rad 15 mm.
R2
You can see full size of the fans.
R4
R5
Brackets sent to powder coating.
After assembling the parts into place started in the quest for the reservoir and the pump.
F6
F7
After a little effort, I decided to put 250mm reservoir as a column in the center,without using clamps.
F8
I decided to use the same way , to mount the pomp without using mounting bracket,
F35
, on 3 acrylic tubes like a spider as apart from various and customary manner.
F26A-B-
F26
F27
After determining the location of the pump and reservoir ,it is time to make connections to the rad with acrylic tubing.
These schema emerged with a little work
F9
and the last station for tubing plans.
F10
respecting the owner's request , ı used 90 angel fittings at corners .
Connections to the rad
F11
F12
F13
Connections to the CPU and MB
F14
F15
F16
And mounting reservoir and pomp without clamps and brackets..
F19
F17
Connections to Video card and self made Spider Web in the corner.
F20
After connectons with acrylic tubing , pipe joints were detected on the acrylic midd plate .
F22
Water chanels added.
F23
After a little work
F24
Drawn at corel for laser cutting
F25
acrylic plates came , from laser cutting
10mm thick midplate, with waterchanels , was cut 16mm smaler than the others,
to make a chanel for led strip.
the bottom plate is White , it can be lit from below in addition
F29
Akrilik plates
F28
I said I would mount reservoir and pump on acrylic tubes like spider legs.
I put them on midplate plate for trial .
F30
F31
F32
F33
F34
And as well came, bonding acrylic plates.
We have 4 sheet Plexi for bonding.
F28
The 10 mm thick clear middle layer with water channels, was bonded with 5 mm clear topsheet.
Y2
tapping and preparing for fittings
Y1
The10 mmthick midplate is 16 mm smaller then 5mm acrylics.
Y3
First leak test with green fluid.
Y5
There is no leak problem. We cann bond third layer.
Second leak test with blue fluid.and no leak problem
Y6
To see the results slightly, curiously.
Y7
Round ,8mmX10mm chanel for led strip.
F29
This channel was wrapped round with RGB led strip.
Y11
And at last… pressure test
Y10
PASSED.
Although 900 D is a big case , but subdivision too cramped.
U1
One small problem of the case is mounting of the PSU and and work on them.
U2
Only the bottompart of the Rad mounting plate (at back side)is portable. upper part is fixed.can not be romoved.
U4
To be a little more comfortable in the PSU mounting and mounting of PSU connectors ,
I made a mounting plate to install PSU. As I was accustomed from SilverStone TJ 07. Cosmos II
U7
U13- U14
I cut the mounting location of PSU.
U6
Made a mounting plate from 2mm thick alu.
U8
So that, I can mount PSU without tilting and wriggling…
U15
U9
And ı cann take out the PSU without disassembling back rad.
PSU with mounting plate
U10
Pushing the PSU in the case ,backplate with PSU , mounted to the case with four self-tapping screws.
U11
I'm pulling out the PSU and can mount easily PSU connectors.
With adding a frame from 10x15 mm box profile to the backplate , can I mount , an additional 360mm rad to the bottom part of the case ,if it is necessary.
Mounting plate sent to powder coating.
I am also curious as you are for the result. I want to see midplate with color.
I could not wait .
I photographed , before filling colored liquid , with clear liquid and RGB led light.
1 red led
2 green led
3 blue led
4 yellow led
5 white led
6 light blue led
7 orange led
And then with selected fluid MAYHEM X1 Blood red .
.8mayhemX1
a short break
2 Weeks late summer holiday at Fethiye /TURKEY , to watercool my self
Holiday is over, continue to work
Worklog of this week.( It's hard work after the holiday…)
Step by step final assembly.
Empty case
R1
First montage of the pipe from pomp to 480 rad.
R2
From MB block to monsta 480
R3
Montage of EVGA 980 Classified Hydrocopper
İn and out pipes of Evga 980
R4
Montage of reservoir without montage bracket like a tower.
R5
Montage of pomp on 3 feet, without montage bracket.
R6
R7
R8
R8a
And at last self made SPIDER WEB GRIL
With 5K Potansiometer as dimmer.
R9
R10
R11
Spider web grill backlighted with led strip and with a dimmer.
R12
Case illuminated with led without fluid, to see th effect and to predict the result.
R13
R14
Because I have changed my house , ı could not add final photos.Sorry.
Some final photos
Although I think the pump to work properly upsidedown.
but I changed pumps position not to risk the pump
Thanks for warning to TheL4mka Multimodder and cheepskate..
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
19
20
21
22
23
24
25
26
LOL, my old house renters name was Ali Riza, so you turkish xD Not bad work, but it is not my taste. I dont like ESEK projects, i joke xD:p
I'm curious.
Aren't there 2 dead ends in the lightplate? Where's the water flowing into? :o
Only thing which made sense were bottom radiator but I couldn't see a passthrough in your pictures.
Does the flow of the water through the lightplate affect the overall flow of the water in the system? If so - is it marginally?
I'm curious.
it seems 4 dead end at the plate 2 of them are at the buttom of the plate to rad2 and from rad 2.
and 2 output lines from rez for the pomp . ı have used 2 inlines of the pomp . ı hope you can see at drawing.
There is no problem with flowrate. a D5 pomp is enogh for flowrate..This is my 5 th built with midplate and ı have no problems.
