[Sammelthread] Gigabyte GA-Z170X-Gaming 7 (Intel Z170) Sockel 1151
Specifications
Intel® Thunderbolt™ 3 Certified Motherboard
•Supports 6th Generation Intel® Core™ Processor
•Dual Channel DDR4, 4 DIMMs
•Intel® USB 3.1 with USB Type-C™ - The World's Next Universal Connector
•3-Way Graphics Support with Exclusive Ultra Durable Metal Shielding over the PCIe Slots
•Dual PCIe Gen3 x4 M.2 Connectors with up to 32Gb/s Data Transfer (PCIe NVMe & SATA SSD support)
•3 SATA Express Connectors for up to 16Gb/s Data Transfer
•Integrated HDMI 2.0 support
•Creative SoundCore™ 3D Gaming Audio
•Killer™ E2400 and Intel® Gaming Networks
•LED Trace Path with Multi-Color Choice
•APP Center Including EasyTune™ and Cloud Station™ Utilities
•GIGABYTE UEFI DualBIOS™ Technology
CPU
1.Support for Intel® Core™ i7 processors/Intel® Core™ i5 processors/ Intel® Core™ i3 processors/Intel® Pentium® processors/ Intel® Celeron® processors in the LGA1151 package
2.L3 cache varies with CPU
Chipset
1.Intel® Z170 Express Chipset
Memory
1.4 x DDR4 DIMM sockets supporting up to 64 GB of system memory
* Due to a Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than the size of the physical memory installed.
2.Dual channel memory architecture
3.Support for DDR4 3866(O.C)/3733(O.C)/3666(O.C) /3600(O.C.) /3466(O.C.) /3400(O.C.) /3333(O.C.) /3300(O.C.) /3200(O.C.) /3000(O.C.) /2800(O.C.) /2666(O.C.) /2400(O.C.) /2133 MHz memory modules
4.Support for ECC UDIMM 1Rx8/2Rx8 memory modules (operate in non-ECC mode)
5.Support for non-ECC UDIMM 1Rx8/2Rx8/1Rx16 memory modules
6.Support for Extreme Memory Profile (XMP) memory modules
Onboard Graphics
Integrated Graphics Processor-Intel® HD Graphics support: 1.1 x DisplayPort, supporting a maximum resolution of 4096x2304@60 Hz
* Support for DisplayPort 1.2 version.
ŠŠ Integrated Graphics Processor+MegaChips MCDP2800 chip: 1.1 x HDMI 2.0 port
Requires the latest Intel® Graphic Driver from GIGABYTE website.
Maximum shared memory of 512 MB
Audio
1.Creative® Sound Core 3D chip
2.Support for Sound Blaster Recon3Di
3.TI Burr Brown® OPA2134 operational amplifier
4.High Definition Audio
5.2/5.1-channel
6.Support for S/PDIF Out
LAN
1.1 x Intel® GbE LAN chip (10/100/1000 Mbit)(LAN1)
2.1 x Killer E2400 chip (10/100/1000 Mbit) (LAN2)
* Teaming is not supported.
Expansion Slots
1.1 x PCI Express x16 slot, running at x16 (PCIEX16)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
2.1 x PCI Express x16 slot, running at x8 (PCIEX8)
* The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
3.1 x PCI Express x16 slot, running at x4 (PCIEX4)
* The PCIEX4 slot shares bandwidth with the M2H_32G connector. The PCIEX4 slot will become unavailable when an SSD is installed in the M2H_32G connector.
4.3 x PCI Express x1 slots
(All of the PCI Express slots conform to PCI Express 3.0 standard.)
Mlti-Graphics Technology
1.Support for 3-Way/2-Way AMD CrossFire™ and 2-Way NVIDIA® SLI™ Technology
Storage Interface
Chipset: 1.2 x M.2 Socket 3 connectors (Socket 3, M key, type 2242/2260/2280 SATA & PCIe x4/x2/x1 SSD support)
2.3 x SATA Express connectors
3.6 x SATA 6Gb/s connectors (SATA3 0~5)
4.Support for RAID 0, RAID 1, RAID 5, and RAID 10
* Refer to "1-10 Internal Connectors," for the supported configurations with the M.2, SATA Express, and SATA connectors.
ASMedia® ASM1061 chip: 1.2 x SATA 6Gb/s connectors (SATA3 6~7), supporting AHCI mode only
USB
Chipset: 1.5 x USB 3.0/2.0 ports on the back panel
2.4 x USB 2.0/1.1 ports (available through the internal USB headers)
Chipset+Renesas® USB 3.0 Hub: 1.4 x USB 3.0/2.0 ports (available through the internal USB headers)
Chipset+Intel® Thunderbolt™ 3 Controller: 1.1 x USB Type-C™ port on the back panel, with USB 3.1 support
2.1 x USB 3.1 Type-A port (red) on the back panel
Internal I/O Connectors
1.1 x 24-pin ATX main power connector
2.1 x 8-pin ATX 12V power connector
3.2 x M.2 Socket 3 connectors
4.3 x SATA Express connectors
5.8 x SATA 6Gb/s connectors
6.1 x I/O shield audio LED power connector
7.1 x CPU fan header
8.1 x water cooling fan header (CPU_OPT)
9.3 x system fan headers
10.1 x front panel header
11.1 x front panel audio header
12.2 x USB 3.0/2.0 headers
13.2 x USB 2.0/1.1 headers
14.1 x Trusted Platform Module (TPM) header
15.1 x serial port header
16.1 x Clear CMOS jumper
17.1 x power button
18.1 x reset button
19.1 x Clear CMOS button
20.1 x ECO button
21.1 x OC button
22.1 x audio gain control switch
23.Voltage Measurement Points
24.1 x BIOS switch
Back Panel Connectors
1.1 x PS/2 keyboard/mouse port
2.1 x DisplayPort
3.1 x HDMI port
4.1 x USB Type-C™ port, with USB 3.1 support
5.1 x USB 3.1 Type-A port (red)
6.5 x USB 3.0/2.0 ports
7.2 x RJ-45 ports
8.1 x optical S/PDIF Out connector
9.5 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Line In/Mic In, Line Out, Headphone)
I/O Controller
1.iTE® I/O Controller Chip
H/W Monitoring
1.System voltage detection
2.CPU/System/Chipset temperature detection
3.CPU/CPU OPT/System fan speed detection
4.CPU/System/Chipset overheating warning
5.CPU/CPU OPT/System fan fail warning
6.CPU/CPU OPT/System fan speed control
* Whether the fan speed control function is supported will depend on the cooler you install.
Bios
1.2 x 128 Mbit flash
2.Use of licensed AMI UEFI BIOS
3.Support for DualBIOS™
4.PnP 1.0a, DMI 2.7, WfM 2.0, SM BIOS 2.7, ACPI 5.0
Unique Features
1.Support for APP Center
* Available applications in APP Center may vary by motherboard model. Supported functions of each application may also vary depending on motherboard specifications.
3D OSD
@BIOS
Ambient LED
AutoGreen
Cloud Station
EasyTune
Easy RAID
Fast Boot
Smart TimeLock
Smart Keyboard
Smart Backup
System Information Viewer
USB Blocker
2.Support for Q-Flash
3.Support for Smart Switch
4.Support for Xpress Install
Bundle Software
1.Norton® Internet Security (OEM version)
2.Intel® Smart Response Technology
Operating System
1.Support for Windows 10/8.1/7*
* Please download “Windows® USB Installation Tool” to install Windows® 7.
Form Factor
1.ATX Form Factor; 30.5cm x 24.4cm
Box Contents
1.GA-Z170X-Gaming 7 motherboard
2.Motherboard driver disk
3.User's Manual
4.Quick Installation Guide
5.Four SATA cables
6.I/O Shield
7.One 2-Way SLI bridge connector
8.One G Connector
9.One pack of back I/O dust covers
Remark
1.Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website.
2.Most hardware/software vendors may no longer offer drivers to support Win9X/ME/2000/XP. If drivers are available from the vendors, we will update them on the GIGABYTE website
Reviews
GIGABYTE Z170X Gaming 7 Motherboard Review
Gigabyte Z170X-Gaming 7 | TrustedReviews
GIGABYTE GA-Z170X-Gaming 7 - Bjorn3D.com
Gigabyte GA-Z170X-Gaming-7
Gigabyte GA-Z170X-Gaming 7 Motherboard Review
OVP/Zubehör/Layout/Features
Geizhals Link
https://geizhals.de/gigabyte-ga-z170x-gaming-7-a1306472.html
Treiber&Tools
GIGABYTE - Motherboard - Socket 1151 - GA-Z170X-Gaming 7 (rev. 1.0)
Bios Downloadlink
Bios History
F5
1.Update CPU Microcode
F5p
1.Beta BIOS
2.Improve DDR XMP compatibility
F4
1.Fix Intel processor issue which may cause some video games to exhibit launch issues with video game error code 8016.
F3
F2
1.First Release
Beta Bios
Aktuelle Beta Biose findet ihr wie immer bei JZ auf seiner Homepage im Drop Down Menü
Das Flashen geschieht wie immer auf eigene Gefahr.
http://www.jzelectronic.de/jz2/index.php
CPU Support Liste
GIGABYTE TECHNOLOGY Socket 1151 - Intel Z170 - GA-Z170X-Gaming 7 (rev. 1.0)
Hallo
Hat hier schon Jemand das Gaming 7 mit HDMI 2.0 UHD Auflösung 60 Hz am laufen bekommen . Wenn ja , mit welches HDMI Kabel.
gibt es denn auf dem board auch einen pumpen anschluss wie bei den ASUS ROG boarads oder ist nur ein CPU FAN header vorhanden?
Doch, CPU_FAN1 (weiß) und den CPU_FAN2 (black) Anschluß.
- - - Updated - - -
Hallo
Es muss ein Kabel speziell für HDMI 2.0 sein :-)
Hallo zusammen,
Mein System
Mainboard: Gigabyte Z170 Gaming 7
CPU: i7 6700K
Graka: Asus Asus 980 Ti Strix 3DOC
DDR4: G.Skill DIMM 16GB DDR4-3000 Kit CL15 15-15-35
Ich habe meine CPU auf 4,7 GHz übertaktet und läuft auch Stabil.
Meine Grafikkarte ist auf 1450 GHz übertaktet und läuft Stabil.
Das Problem was ich habe ist das wenn ich das Profil von meinem DDR4 aktiviere das dieser sich nicht auf die 3000 MHz einstellt sondern bei 2133 bleibt.
Gehe ich hin und setze den auf die 3000 MHz schmiert das System ab oder Bootet gar nicht erst hoch.
Leider verstehe ich jetzt hier nicht so wirklich was ich falsch mache bzw was muss ich machen damit auch der DDR4 dann auf die 3000 MHz läuft ?
Wenn ich alles auf Standard setzte und das Profil lade läuft der DDR auf seine 3000 MHz...
Würde mich echt super freuen wenn ihr mich auf klärt bzw mir helfen könnt mein Problem zu lösen. =)
Minus Offset sollte jetzt damit gehen, eben nur dass die Loadline nicht richtig funktioniert und bei Last Vcore drauf packt anstatt diese zu senken :-(
Hmm ... das ist blöde ... aber kann man sich ja drauf einstellen ... auch wenns net unbedingt im Sinne von Intel ist. ;)
f7d non-K OC ist verbuggt ? habe einen i7 6700 drauf.
Ich kann zwar höhere Multi einstellen er nimmt aber maxmimal Core Ratio 34x anstatt der eingestellten 40x 36x usw.
Oder ist sich das normal ? ;)
... das ist zwar schade, aber kein Bug - die entsprechenden BIOSe sollen das OC per BCLK ja gerade ermoeglichen, um den fehlenden offenen Multiplikator zu kompensieren. Ich kenne auch kein BIOS eines anderen Herstellers, das einen hoeheren Multiplikator auf Non-K´s erlauben wuerde. 150*30 und die Sonne scheint ...
"Bescheiden" ist gut bie 4.76 GHz ... Wieviel VCore braucht die CPU dafuer? Was fuer Einstellungen hast Du sonst noch geaendert?
LLC habe ich auf High ... im UEFI ist VC 1.320 eingestellt ... gibt dann unter Prime95 Last 1.308.
VCCIO auf 1.020 VCCSA auf 1.050 ... mit dem Speicher habe ich noch nicht wirklich rumgespielt.
Und momentan auch nur ein Modul verbaut. :fresse:
Die VID der CPU ist 1.176 @ 4.0 GHz ... also ich denke das ist schon ein sehr gutes Exemplar.
Wenn Du ihn haben magst PN me ... für mich ist das nur eine kurze Spielerei.
Bei Non-K OC sollte man nicht mit AVX testen ;)
Nein, AVX ist mit dem Non-K BIOS nicht im grünen Bereich.. siehe hier: http://forum.hwbot.org/showthread.php?t=150771
Prime läuft quasi im Easy Mode, da AVX Instruktionen nur im Schneckentempo abgearbeitet werden. Kannst ja mal gegentesten, wird ohne AVX bestimmt eine Schippe VCore mehr brauchen.
Vielen Foren-User ist sehr wahrscheinlich nicht bewusst, dass so ein Screen Humbug ist ;)
Versenken an den Ort, an dem dein MSI Review lagert? :lol:
Zurück zum Thema, AVX braucht also 30mV weniger als non AVX?
Hallo Zusammen,
ich habe ein paar Probleme mit dem Board, kann mir jemand etwas unter die Arme greifen ??
1. Wenn ich die SSD auf dem ersten M2 Steckplatz ( M2D_32G ) verbaue, werden keine SATA Laufwerke mehr angezeigt .... am zweiten M2 Steckplatz ist alles in Ordnung
-> 2 HDD´s an Port 0 und 1
-> 2 Laufwerke an Port 2 und 3
a.) Was mache ich falsch ?
b.) Ist es egal wo die M2 SSD angeschlossen wird ?
2. Welcher Speicher wäre für das Board prinzipiell besser geeignet .... Corsair Vengeance LPX DDR4-3000 1.35V oder der Corsair Vengeance LPX DDR4-2800 1.20V?
3. Ist das normal das der Vcore nach Aktivierung des XMP Profils so massiv ansteigt oder liegt das am Corsair Vengeance LPX DDR4-3000 1.35V?
4. Ich würde gerne den CPU auf 4500MhZ übertakten und wenn möglich die Spannung so klein wie möglich halten inkl. Stromsparmodus
-> Ich habe Testweise mal den Multi auf 45 eingestellt und den Turbo deaktiviert, die restliche Einstellungen sind unverändert bzw. auf Standard Einstellung
a.) Wieso wird nur 4300MhZ unter Last angezeigt ( Prime95 ) obwohl der Multi auf 45 eingestellt ist ?
b.) Welche Einstellungen bzw. Werte sollten vorgenommen werden ?
5. Wo ist der Unterschied unter CPU Vcore Loadline Calibration bei Standard oder High ?
6. Was ist den die VAXG Loadline Calibration ?
Ich habe mal ein paar Bilder angehängt:
Bild: PC Health Status - CPU auf Standard und Speicher ohne XMP
Bild: CPU-Z unter Last ( Prime95 ) - CPU auf Standard und Speicher ohne XMP
Bild: HWInfo unter Last ( Prime95 ) - CPU auf Standard und Speicher ohne XMP
Bild: PC Health Status - CPU auf 4500MhZ und Speicher mit XMP
Bild: CPU-Z unter Last ( Prime95 ) - CPU auf 4500MhZ und Speicher mit XMP
Bild: HWInfo unter Last ( Prime95 ) - CPU auf 4500MhZ und Speicher mit XMP
Zu 3.
Liegt wohl eher am schlecht programmierten BIOS/UEFI
Zu 4.
Bei Asus und AsrockBoards muss der Turbo all Core aktiviert sein, da Du im OC die höchste
Booststufe ansprichst.
a. Evtl. Powerlimits zu gering. würde mich bei der hohen Vcore nicht wundern oder Energieeinstellung im Windows nicht auf Höchstleistung.
b. Powerlimits im BIOS erhöhen. Energieoption im Windows ändern.
Zu 5. LLC kriegen die bei Gigabyte auch nicht gebacken.
Normal sollte bei Standard die Vcore unter Last gesenkt werden, auf High wird sie angehoben.
Wird bei Gigabyte wohl immer erhöht, was ebenfalls Deine hohe Vcore erklärt.
@Bin2good
zu 3.) Bios F6 bis F7d getestet und keins davon bringt eine Verbesserung, habe mal den Corsair Vengeance LPX DDR4-2800 1.20V bestellt ... vielleicht bringt das was
zu 4.) wenn ich das richtig interpretiere muss bei Gigabyte der Turbo ausgeschaltet sein
a.) Windows Einstellung werde ich mal testen / bei der hohen Vcore habe ich wohl bei der CPU voll daneben gegriffen?
Ich bin jetzt einen Schritt weiter und der CPU läuft bei 4500MhZ unter Prime stabil .... allerdings verstehe ich nicht warum der unter Last ( Prime95 ) bei HWBot / CPU-Z nur 4300MhZ anzeigt ?!?
Kann sich einer mal die Einstellungen anschauen und wo noch Optimierungsbedarf besteht und warum der nur auf 4300MhZ unter Last läuft ?
Die CPU Enhanced Halt (C1E) und CPU Eist Function habe ich erstmal für den Test deaktiviert.
Hallo zusammen,
habe am WE meinen neuen Gaming-PC zusammen gebaut, wo ich auch das Gigybate Z170X Gaming 7 verbaut habe. Bin bisher sehr zufrieden. Habe mir zwar einen i5-6600k geholt, aber OC ist für mich aktuell erstmal noch kein Thema, da alles was ich bisher getestet hatte für mich zufriedenstellend lief. Habe mir das MB hauptsächlich wegen dem Thunderbolt 3 geholt, da ich hoffe damit eine gute Schnittstelle für die Zukunft zu haben.
Da ich was Gaming und Windows-PC allgemein eine paar Jahre Auszeit hatte, habe ich da mal eine Frage zum der Option Fast Boot. Ich habe in Win10 in der der Gigabyte Software das Fast Boot aktiviert und den Rechner neu gestartet, aber anstatt schneller zu booten hat es sogar ein paar Sekunden länger gedauert. Ich verwende eine SSD als Systemplatte.
Jemand eine Idee?
@Calimero1609
Gigabyte baut ja schicke Boards, allerdings haben die seit Z87 Probleme ein ordentliches BIOS zu programmieren.
Gigabyte Bretter geben gern ordentlich Spannung, Probleme mit LLC .....
Ich kaufe deshalb seit X59 keine Gigabyteboards mehr.
Dein Screen zeigt 4300 MHz bei fast 1,3 V unter Last.
Evtl. gibt das Board da bei 4,5 GHz noch ordentlich was drauf, so dass das im BIOS eingestellte Powerlimit von 95 W
überschritten wird und die CPU deshalb runter geht.
@ Zer2Cool
Win 10 im UEFI Modus installiert ?
Fast Boot sollte so schnell beschleunigen, dass Du nicht mehr ins BIOS kommst während des Bootens.
