[Sammelthread] Project CARS
die 5 Autos sind teurer geworden, kann das sein? Kosten jetzt auf steam 3,49€
Der Patch 1.4 wurde soeben ausgerollt. Hier nochmal für alle die Changelog :
Project CARS –Patch 1.4 – Release Notes
General
* Pagani Monza Clubday invitational event - No longer causes the game to crash when using a specific livery on the Pagani Huayra.
* PC - Fixed an issue that would cause the game to crash while watching saved replays, when shared memory is enabled.
* PS4 - Anisotropic filtering has been increased to help reduce blurry textures.
* PS4 - Temporal anti-aliasing has been further optimized. This reduces the ghosting effect and additionaly gives the player full control via a slider to tweak the resulting image according to personal preference.
Performance improvements
* Xbox One - Various performance optimizations, adding up to an average of 5-6% performance improvement. This results in an overall smoother experience.
* PS4 - All shaders have been rebuilt using new shader compiler, giving a significant performance boost in some areas.
* PS4 - CPU performance gains due to new more aggressive code optimisations.
Physics & AI
* The AI loss of grip that results from tyre degradation as a result of wear is now more noticeable.
* The AI will now show much more realistic grip loss when running on slick tyres in the rain.
* First pass improvements on various tracks to enhance the AI performance and ability (Azure Circuit, Donington GP, Watkins Glen, Bathurst, Nordschliefe)
Pitting, tuning, setups
* Fixed an issue where certain street cars would pit for tyre change during rain when they already had the correct tyres fitted.
* Fixed an issue where custom vehicle setups were lost when progressing through sessions.
* Improved the system used to select the most appropriate tyres based on current and predicted weather conditions.
* Ensure that the AI always pit when they need to change tyres based on the weather conditions.
* The Default strategy will now correctly show the tyres that will be fitted on the player vehicle during a pit stop.
* The pit stop routine will no longer start during online races until the player closes the pit stop menu. This ensures that the player has enough time to select or configure an appropriate set of actions before the pit crew start working on the car.
* Tyre pressures will now be correctly set when the player changes to a new set of tyres.
* The currently-active Pit strategy will now remain in action when advancing through race sessions.
Online
* Fixed an issue where the player was sometimes given a large time penalty when exiting the pit lane.
* Fixed an issue where the remaining session time displayed an incorrect value in the Tuning screen.
* Fixed an issue that at times would prevent a player from entering a race, after joining a second online lobby.
* Fixed and issue where the Track Location popup would at times appear on some screens.
* PS4 – The lobby browser now displays random lobbies instead of always the oldest lobbies.
* PS4 – Fixed an issue where network features could not be used after resuming from rest mode.
* PC - The lobby browser now automatically extends the search distance for lobbies when not enough of them are found using the default filter. Lobbies that are hosted further away (and therefore have potentially worse latency to all peers) appear at the bottom of the browser, and are colour coded with yellow or orange icons do indicate the quality of the connection.
* PC - The session host now regularly sets the current timestamp into a session attribute, so that sessions with too old timestamps are not displayed in the browser. This prevents stale sessions with no active host from appearing in the session browser.
* PC - When joining a session, the client now attempts to request the member details multiple times before giving up. This helps to improve the success rate of joining online sessions.
* Xbox One – Fixed an issue where matchmaking was not filtering the race length correctly.
Controls – All platforms
* Fixed pedals and triggers that vibrates during replays.
* Fixed an issue that causes the wheel centring spring to be active during driving.
* Improved force feedback strength and tweaked the default force feedback parameters for all supported wheels based on community feedback.
* Further enhancements to the steering feeling – Improved blending between the tyre force spring and the steering lock spring.
* Improved behaviour of the wheel force springs while navigating the menu system.
Controls – PS4
* Fixed an issue where the player got stuck on the career screen when entering driver name using a wheel controller.
* Improved the support implementation of several older Fanatec wheels, such as the GT2, GT3, and CSR.
* Fixed the Fanatec CSS so that it works correctly in sequential mode.
* Fixed the Fanatec CSP pedals to save the calibration correctly if player calibrated only pedals.
* Fixed the Fanatec CSP ABS rumble.
* Fixed the Fanatec CSW handbrake.
* Game Pad - Tilt Control support implemented to allow controller tilt to be used to control the vehicles.
Vehicles
* Adjusted handbrake strength on vehicles which are equipped with handbrakes.
Fixed an issue where the rain wipers’ state did not reset correctly when restarting a session.
Fixed an issue where light glows from a vehicle behind the player would sometimes appear in front of the player.
* Fixed fuel pressure gauge calibration in several cars.
* Fixed an issue where a white border would at times appear around the brake light glow of certain cars.
* Ford Mk.IV – Improved the collision model to prevent vehicles wedging in under other vehicles.
* Formula Gulf, Gumper Apollo, Formula Rookie - Fixed and issue with the livery sets that caused the livery selection to display wrong liveries.
* Lykan Hypersport -Statistics updated to latest manufacturer specification.
* Lotus 72D - Improved handing characteristics, exposed bump stops to be adjustable in the vehicle setup, reduced cold sensitivities of the slick tyres, adjusted the AI speed, wear and rain tires to match the player’s experience.
* Karts - Reworked the Karts optimization to help address performance drops with a lot of Karts on track.
* McLaren 12C GT3 - Adjusted the vehicle pose to more closely match the real car.
* BMW M3 GT4 – Improved the accuracy of the levels at which the oil and water temperature warning lights will activate.
* Ford Escort RS1600 - Improved the collision and wheel contact model to prevent climbing over other cars in collisions.
* 250cc Superkart – Improved the default setup to address controller issues on higher speed tracks, and improved the AI handling.
* Lotus 49 – Improved the AI handling of the vehicle in corners and in close racing.
* Pagani Huayra - Reduced fuel consumption to around 3mpg in hard track use, and improved cooling to prevent engine overheating.
Tracks
* Bathurst – Removed cones in the pit lane that was causing cars to get stuck.
* Watkins Glen – Fixed a number of accuracy issues around the track.
* Lemans 24h – Improved the race line at a few corners to keep the LMP cars off the curbs as this was causing the cars to lean over on two wheels.
* Silverstone National – Vehicle grid placement reworked to more closely align with the painted start boxes.
* Hockenheim (various layouts) – Reworked the wet weather reflection mapping to address incorrect object reflections.
* Willow Springs – Fixed an issue where the vehicle could drive through the barriers when exiting the pits.
GUI
* Driver Network Profile - Visual tidy up to improve usability.
* Fixed an issue where very thin lines would not always appear.
* Added support for better info display on the Community Events page.
* Fixed the issue where HUD customization was not saved on exiting a session.
* Fixed an issue where the Potential Lap time display on the Lap Info board would be inconsistent with the sector times being displayed.
* Monitor/Spectate mode - Fixed an issue where the vehicle being viewed would automatically reset to the player’s vehicle on leaving the monitor screen.
ich hab seit den beiden dlcs das problem das er ziemlich lange braucht um von einem event rauszukommen und wieder auf den hauptschirm zu wechseln... teilweise sogar mit schwarzen schirm zwischen durch.
aber wirklich nur wenn ich von einem event wieder ins hauptmenü will.
any idea?
Moin moin,
hast du das Update schon gezogen und getestet ob er immernoch die Hänger hat?
Edit:Ich würde ja gerne die 24Stunden von Le Mans fahren. Wenn ich in die Box fahre,kann ich ja n Fahrerwechsel betätigen. Ergo fährt dann die KI weiter für mich.Wie mache ich es denn,wenn ich weiterfahren möchte?Weiss das evtl. einer?
In den Settings nen Button für "Pit Request" belegen und den benutzen, dann kommt der KI Fahrer rein und du kannst wieder das Steuer übernehmen.
Selbst noch nicht gemacht, soll so aber funktionieren.
Ist auch für Karriere Rennen sinnvoll, den Button zu nutzen, denn manchmal kanns sein dass grad der Teamkollege in der Box ist wenn man einfach nur reinfährt ohne das vorher anzukündigen, dann ist die Box belegt und man fährt durch und muss uU ne Runde später nochmal rein. Mit dem Button sollte das dann Rückmeldung geben ob die Box "ready" ist.
keine Ahnung, muss ich mal prüfen ob 1.4 den fehler bei mir behebt.
Moin moin,
also das Monza Rennen konnt ich jetzt fahren. Weiß aber nicht, ob es an der Willkür des Spiels lag.. :d
Was mir aber auch aufgefallen ist, bei Regen schießt die Gpuauslastung nimmer so hoch, wie vor Patch 1.4
Mal sehen, vielleicht kann ich ja jetzt endlich die Rennen gescheit fahren.
Okay. Gut zu wissen. Dann darf ich mal ca. 600Mb über Stick ziehen xD
@kalgani:Vielen Dank. Hab da gar nicht drauf geachtet^^
sei froh, dass es nur so wenig sind ;) Ganz ungewohnt, dass Updates heutzutage noch im MB Bereich angegeben werden :fresse:
Mit Sändy online ging ja eben auch ganz gut. Aber ich will nix beschreien ;)
War ich eigentlich am laggen oder so?
Nö. Hab aber bisher nur 2 Online-Partien gespielt und in der einen davon is mir einer dank lag (bei ihm) tierisch in die Kiste gekracht.
ich nehm alles zurück. :fresse2:
grad eben mein GT4 Rennen auf Hockenheim national fahren wollen. Quali gestartet, 2 Runden gefahren, problemlos. Lass mich in die Box zurücksetzen und hab dann wohl den Fehler gemacht, der Ki beim fahren zuschauen zu wollen, ging ne halbe Runde gut, dann kam der freeze :banana: Wobei sich aber der Streckenposten noch in die Richtungen gedreht hat.
Wiederholungen kann man noch immer nicht anschauen.
Widerholungen funktionieren bei mir. Armet m@tti :(
ja, wirklich arm :fresse:
hab eben mal testweise den Takt auf 1280Mhz runtergeschraubt, konnt das Rennen dann fahren. Kann doch nicht sein, das ein Spiel wegen bissl Takt so rumzickt :motz:
Will aber nicht beschreien, dass es daran liegt. Das Monza Rennen bin ich ja auch mit vollem Werkstakt gefahren.
Und eben noch mal fix getestet, auch mit dem niedrigeren Takt freezen die Replays bei mir.
lass ich schon, keine Angst. War ja nur ein kleiner Test :wink:
Das Hauptrennen geh ich mutigerweise wieder mit vollem Takt an :d
Hört sich ja top an xD
Ich darf 22 Stunden 515mb saugen xD
Wenns bei dir nicht klappt,dann bei mir erst recht nicht^^
Bei mir gehen die replays nun auch nicht mehr, vorher kein Problem. Werde es mal mit neu aufgenommenen replays versuchen. Scheinen jedoch wieder mal nur einige betroffen zu sein.
Sind wohl "alte" Replays die mit 1.3 oder früher gespeichert wurden und nicht mehr kompatibel sind? Passiert das bei neu aufgenommenen auch?
was soll dieses Spiel eigentlich sein?
sorry, aber einige Dinge gehen gar nicht..
online GT3 Rennen.. NUR GT3 - wieso kommt dann einer rein und fährt einen LMP1?
KI fährt im Regen ohne Wechsel wie eine Eisenbahn, egal ob nass oder trocken^^
ne... das ist ne Frechheit eigentlich
und wieso muss online jeder Nebel, Regen 5 Stunden Practice und irgendeine Hinterweltstrecke auswählen?
weil da keiner kommt wenn man 8 -10 Mins Quali, Rennen 3-5 Runden, GT3, Wetter Sonne einstellt
Wenn da keiner kommt bist du mit deinen Vorlieben so ziemlich allein , kann ich mir aber nicht vorstellen , nimm das Qually am besten noch ganz raus und du hast wenigstens die crash Kiddys bei dir , dafür wäre ich dir sehr Dankbar .
So ist es. Scheinen wohl nur die alten replays betroffen zu sein. Neu aufgenommene replays bereiten keine Probleme.
und du bist nochmal wer?
das Spiel treibt mich in den Wahnsinn. Eben das Hauptrennen gefahren. 26 Runden ohne Probleme und ratet mal, was in der 27 Runde passiert ist... :wall: Renndauer 28 Runden.
Ihr könnt mir sagen, was ihr wollt, das liegt definitiv an diesem Spiel!
Schön 27 Runden umsonst gefahren. :motz:
