[Sammelthread] Battlefield 4
Battlelog ist wieder online. Die Server füllen sich langsam.
BATTLEFIELD 4 WILL RECEIVE A NEW GAME UPDATE SEP 30. MULTIPLAYER WILL BE UNAVAILABLE STARTING 10 AM CEST / 1AM PDT, FOR APPROXIMATELY AN HOUR IN PREPARATIONS FOR THIS.
Na super. Beim Loginversuch:
Fehler
Deine Verbindung zu EA Online wurde unterbrochen. (1)
Geht ja schon wieder gut los. Komme nicht auf die Server. Jedesmal die Fehlermeldung. PB ist aktuell.
Hier mal was geändert wurde:
ANIMATION BUG FIXES AND IMPROVEMENTS
• All pistols: Removed randomization of iron sights fire animation on most pistols per CTE feedback.
• All automatic pistols: Shortened duration of slide animation during firing animations to prevent slide appearing to not cycle when firing quickly.
• Automatic rifles: Fixed missing trigger pull animations.
• Unica 6: Fixed hammer getting stuck on iron sights fire animation. Shortened reload threshold so magazine registers as full, faster.
• CS5: Fixed magazine going invisible if reload is interrupted. Fixed problem where bolt action animation wouldn’t play when firing near the end of the tactical reload animation.
• G36C: Fixed charging handle position during full/tactical reload.
• CZ-805: Fixed charging handle position during full/tactical reload.
• AWS: Enabled semi-automatic fire.
• XM25: Fixed fire animation; including reciprocating charging handle.
• Bulldog: Fixed problem with tiered reload.
• M60E4: Adjusted reload interrupt branches to match other LMGs; ammo box now stays mounted on interrupt.
• L96A1: Added missing interruptible reload branches.
• JNG90: Adjusted reload threshold to prevent bypassing re-chamber animation at the end of empty reload.
• SR338: Fixed bug where fire animation could be skipped by firing at a certain cadence. Raised reload threshold.
• L85A2: Adjusted foregrip position so Angled Grip attachment doesn’t clip through the trigger guard; fixed reload animation bug that could cause accessories to shift on the weapon during animation.
• RPK-74M: Reduced both reload times by .3 seconds to better match animation.
• HK45C: Removed hammer position mismatch between idle and ADS.
• ACW-R: Reduced time to register reload.
• QBU-88: Fixed clipping issue in deploy animation.
• SR2: Added reciprocating bolt fire animation.
• SR2: Fixed missing bolt on empty reload animation, fixed sprint pose clipping issue in water.
• 870: Fixed blending issue after zoom fire/pump action animation.
• M16A4: Fixed mismatched bipod pose, broken dust cover on model.
• RFB: Removed extra shell that moved when firing with a bipod and iron sights.
• MK 11 MOD 0: Opened dust cover to prevent jamming. Removed incorrect rotation during bipod fire animation.
• All DMRs, M82A3 Battle Pickups: Fixed bipod fire issue that skipped fire animation at higher rates of fire.
• M412 Rex, .44 Magnum: Adjusted fire animations for new trigger delay values, corrected trigger discipline while running.
• All belt-fed LMGs: Added “last few rounds” ammo visibility system to ADS fire animations.
• AWS: Fixed foregrip position to be on-rail in 1st person.
GRENADES
First grenade balance pass.
Highlights:
• Reduced initial capacity of RGO and v40 Minis by one.
• Reduced blast radius of RGO and v40 Minis requiring more accuracy for full damage.
• Increased the time it takes to refill explosives from ammo sources.
• These changes are an indirect buff to the Offensive and Grenadier specialization.
Detailed list:
• Reduced RGO capacity 2->1
• Reduced RGO inner blast radius 1.65->1
• Reduced v40 capacity 3->2
• Reduced v40 blast radius 7->6
• Reduced v40 inner blast radius 2.5->1
• Increased ammo bag pickup time for grenades:
Flashbang 5s->9s
RGO 7s->25s
v40 8s->13s
Handflare 1s->6s
M18 5s->9s
M34 8s->25s
M67 5s->25s
XM25 DART 1s->3.5s (5->4 rounds)
XM25 3.5s->6s (2->1 rounds)
40mm 3GL 8s->18s
40mm Smoke 2.5s->5s (matching flashbang now)
40mm LVG/HE 8s->9s
UI TRIAGE (HUD TWEAKS AND FIXES)
• Added advanced options for adjusting HUD icons.
• HUD icons transparency support.
• Aim down the sight (ADS) now causes auto transparency for HUD icons.
• Added a new option for whether tapping spot button should give attack/defense orders.
• Game mode bar on top of the mini map now also display objective squad order status.
• Fixed issue with having space between the mini map and the Team Deathmatch game mode info bar.
• Fixed the minimap world directions not showing in the Chinese version of the game.
• Added advanced gameplay options sliders to control the transparency of the HUD elements.
• Adjusted the red dot reticles for medium and long range sights for the Engineer Class primary weapons.
• Added an advanced gameplay option to change the size of the minimap
• Added an advanced gameplay option to make the minimap icons auto size along with the minimap scale
• Added an advanced gameplay option to set the default minimap scale
REVIVE IMPROVEMENTS
• Revive timer has been added. It will show timers on teammates so that the player can choose who to revive.
• Added a sound when defibrillators are 100% charged (giving the revived player 100% health back).
• Fix for an issue that could cause the HUD to disappear when the player brought up the game menu while in a revive state.
• Added initial implementation of revive timers for soldiers in man down state. It will now show timers on a teammate so that the player can choose who to revive.
• Fix for a bug when you were able to revive teammates by only rubbing the defibrillators.
• Fix for issue that would sometimes occur when two players on a team equipped defibrillators at the same time next to each other and are about to revive another team player, the player who is reviving gets no score and the other player gets score instead.
RUSH IMPROVEMENTS
DICE <3 RUSH is an ongoing Battlefield 4 Community Test Initiative with the intent to improve Rush on base-game maps. This initial release includes new layouts and rule sets implemented on:
• Flood Zone
• Golmud Railway
• Hainan Resort
• Lancang Dam
• Operation Locker
• Paracel Storm
• Rogue Transmission
• Siege of Shanghai
• Zavod 311
Improvements to Dawnbreaker and further tweaks to the above maps will be looked at.
• Disabled Commander on the Rush game mode for all maps
OBLITERATION COMPETITIVE IMPROVEMENTS
• Reduced radar sweep on home bases to 40 meters.
• Bomb does not have to be planted in a sequence anymore.
• Reduced the time it takes to plant a bomb from 10 to 8 seconds.
• Raised Obliteration Bomb icon over the bomb carrier's head.
• Reduced the combat area on Operation Locker based on player feedback.
• Reduced the combat area on Golmund Railway and tweaked the spawn points.
• Fixed bomb out of bounds on Golmund Railway.
• Blocked pipe access to rooftops on Zavod 311.
• Reduced the combat area on Zavod 311.
PLATFORM SPECIFIC FIXES
PC
• Fix for a game crash.
• Added FOV slider (option) for the chase cameras of all vehicles.
• Fix for an issue where Users where unable to rebind gadgets to slot 1.
• Fixed an issue where the chat log settings wouldn’t properly function after a player exited the game.
• Tweaked latency indicator.
• Better post-processing for medium graphics settings.
• Fix for when the text input form clears when switching between EOR camera and scoreboard. The text now remains in place regardless of the game actions.
• Added an option to turn off the jets auto throttle feature.
PS3
• Fix for a crash that could occur during the end of round screen.
SERVER FIXES
• Fixed an issue where taking damage indicators (the red wedge) where pointing in the wrong direction.
• Lowered frame history time on all platforms to improve on ‘out of region’ player issues.
Detailed list:
Flashbang 5s->9s
RGO 7s->25s
v40 8s->13s
Handflare 1s->6s
M18 5s->9s
M34 8s->25s
M67 5s->25s
40mm 3GL 8s->18s
40mm LVG/HE 8s->9s
:vrizz:
Liq...
30 Versuche mittlerweile auch nur auf irgend einen Server zu kommen. Null Chance.
Fehler
damit ist die RGO tot
weniger Radius, langer Reload
dann eben die normale Frag
da bin ich mal richtig auf die erste Runde Metro gespannt, was die Noobs dann da so treiben werden nach den massiven BummBumm-Nerfs....
Sollte nicht die Trägheit gefixt werden? Habe davon jetzt nichts gelesen.
spiele gerade ein paar runden rush. muss sagen gefällt. viele bomben liegen wo anders. zb zavod nicht mehr im tower.
mehr deckung usw.
gerade flutgebiet komplett anders. mal gespannt was man noch so findet :)
hab durch ein vid vom sheriff mitbekommen das es einen septemper pätsch gibt der heute online ist.
ist das richtig so das cte implementiert wird ?
will nur ne antwort und keinen kommentar das ich die letzten 100 seiten lesen soll ;)
Muhahah, ich hatte also doch recht RV (Patchgröße) ^^ 🙂
Gebe mich geschlagen :bigok:
FOV habe ich bei der CTE 72 gehabt. Entspricht glaub dann 95.
Movement wurde ja auch von der CTE übernommen, oder? Weil in den Patchnotes find ich dazu nix.
Also kurzes Resumé:
Hat sich schon einiges getan. Spielt sich alles etwas Fixer. Allerdings brauchen die Gegner manchmal zu lange zum Sterben. Hatte im Gegenzug dazu kaum Oneshots. Betonung liegt auf kaum.
Die eigenen Mitspieler sind natürlich immernoch stark behindert. Keine Ahnung in BF 3 war das doch auch nicht so schlimm .........
Ansonsten ich denke es wurde durch diesen Patch spielbarer.
Error
You were disconnected from EA Online (1)
Keine Chance, nicht mal auf einem leeren Server. Keine Ahnung was da los ist. Habe bestimmt über 60 Joinversuche. PB aktuell, Spiel repariert versucht, ist aber nichts zu reparieren. Rechnerneustart. Nada.
Da mehrer Leute schon danach gefragt haben:
Bin mir nicht ganz sicher ob diese Änderung nun morgen auch kommt, aber hier die Umrechnung für den horizontalen und vertikalen FOV
For most people, 90 hfov is 59 vfov (16:9)
Für alle anderen:
Battlefield: Bad Company 2 FOV Calculator
Liq...
P.S Hier der Vergleich zwischen CTE und B4 vanilla 90 FOV: 90 FOV CET vs 90 FOV BF4 - Imgur
Liq...
P.S Gibt es überhaupt die Einstellung zum hFOV und vFOV? ^^ Muss bis 23 Uhr Arbeiten, füttert mich mit Informationen :coffee:
Error
vielleicht liegs auch einfach nur an deinem internet.
Das war in der Tat so. Damit hatte man erreicht, dass alle zukünftigen Patches nur noch einige MB groß waren statt wie zuvor einige GB. Wurde wohl nicht in die Vanilla eingebaut.
Sorry, wenn ich nochmal so "doof" nachfrage: Die Änderungen sind also in der aktuellen CTE berücksichtigt worden aber "live" nicht an die Spieler ausserhalb der CTE gedrungen?
Hab ich das richtig verstanden?
Falls ja ... war die CTE denn wirklich besser, was Netcode anbetrifft? Gibt es noch Hoffnung?
Das ist richtig. Heute kommt der Patch von dem ich in dem Video sprach.
Wenn du damit das Gefühl meinst, das man sich vorkommt die ganze zeit durch Gallert zu waden, nein das ist immer so. Der FPS fix ist auch lustig, zwar mehr avg fps dafür absolut reudige frametimes. Je mehr Zeit ich wieder mit Bf3 verbringe, desto wneiger versteh ich was ich an der 4 so toll fand.
Ähnliche Themen
